[GRASS-SVN] r65561 - in grass-addons/grass7/raster: . r.subdayprecip.design
svn_grass at osgeo.org
Fri Jul 10 05:14:57 PDT 2015
Author: martinl
Date: 2015-07-10 05:14:57 -0700 (Fri, 10 Jul 2015)
New Revision: 65561
Added:
grass-addons/grass7/raster/r.subdayprecip.design/
grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html
grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
Removed:
grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.series.html
grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.series.py
grass-addons/grass7/raster/r.subdayprecip.series/
grass-addons/grass7/raster/r.subdayprecip.design/Makefile
r.subdayprecip.series rename to r.subdayprecip.design
Modified: grass-addons/grass7/raster/r.subdayprecip.design/Makefile
--- grass-addons/grass7/raster/r.subdayprecip.series/Makefile 2015-07-10 10:30:08 UTC (rev 65560)
+++ grass-addons/grass7/raster/r.subdayprecip.design/Makefile 2015-07-10 12:14:57 UTC (rev 65561)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = r.subdayprecip.series
+PGM = r.subdayprecip.design
include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html (from rev 65560, grass-addons/grass7/raster/r.subdayprecip.series/r.subdayprecip.series.html)
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html (rev 0)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html 2015-07-10 12:14:57 UTC (rev 65561)
@@ -0,0 +1,28 @@
+<h2>DESCRIPTION</h2>
+<em>r.in.proj</em> computes subday design precipitation series.
+TODO
+<h2>EXAMPLE</h2>
+TODO
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.rast.stats.html">v.rast.stats</a>
+</em>
+<h2>REFERENCES</h2>
+<ul>
+ <li><a href="http://geo.fsv.cvut.cz/proj/bp/2013/martin-tomasu-bp-2013.pdf">http://geo.fsv.cvut.cz/proj/bp/2013/martin-tomasu-bp-2013.pdf</a> (in Czech)</li>
+</ul>
+<h2>AUTHORS</h2>
+Martin Landa, OSGeoREL, Czech Technical University in Prague<br>
+<p>
+<i>Last changed: $Date $</i>
Copied: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py (from rev 65560, grass-addons/grass7/raster/r.subdayprecip.series/r.subdayprecip.series.py)
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py (rev 0)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py 2015-07-10 12:14:57 UTC (rev 65561)
@@ -0,0 +1,159 @@
+#!/usr/bin/env python
+# MODULE: r.subdayprecip.series
+# AUTHOR(S): Martin Landa
+# PURPOSE: Computes subday design precipitation series.
+# COPYRIGHT: (C) 2015 Martin Landa and GRASS development team
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
+#%module
+#% description: Computes subday design precipitation series.
+#%end
+#%option G_OPT_V_MAP
+#% description: Name of basin vector map
+#%end
+#%option G_OPT_R_INPUTS
+#% key: raster
+#% description: Name of input raster map(s) (H_002,H_005,H_010,H_020,H_050,H_100)
+#%end
+#%option
+#% key: rainlength
+#% description: Rain length value in minutes
+#% type: integer
+#% options: 0-1439
+#% required: yes
+#%end
+import os
+import sys
+import grass.script as grass
+from grass.pygrass.modules import Module
+from grass.exceptions import CalledModuleError
+def main():
+ # get list of existing columns
+ try:
+ columns = grass.vector_columns(opt['map']).keys()
+ except CalledModuleError as e:
+ return 1
+ allowed_rasters = ('H_002', 'H_005', 'H_010', 'H_020', 'H_050', 'H_100')
+ # extract multi values to points
+ for rast in opt['raster'].split(','):
+ # check valid rasters
+ name = grass.find_file(rast, element='raster')['name']
+ if not name:
+ grass.warning('Raster map <{}> not found. '
+ 'Skipped.'.format(rast))
+ continue
+ if name not in allowed_rasters:
+ grass.warning('Raster map <{}> skipped. '
+ 'Allowed: {}'.format(rast, allowed_rasters))
+ continue
+ grass.message('Processing <{}>...'.format(rast))
+ table = '{}_table'.format(name)
+ # TODO: handle null values
+ Module('v.rast.stats', flags='c', map=opt['map'], raster=rast,
+ column_prefix=name, method='average', quiet=True)
+ rl = float(opt['rainlength'])
+ field_name='{}_{}'.format(name, opt['rainlength'])
+ if field_name not in columns:
+ Module('v.db.addcolumn', map=opt['map'],
+ columns='{} double precision'.format(field_name))
+ a = c = None
+ if name == 'H_002':
+ if rl < 40:
+ a = 0.166
+ c = 0.701
+ elif rl < 120:
+ a = 0.237
+ c = 0.803
+ elif rl < 1440:
+ a = 0.235
+ c = 0.801
+ elif name == 'H_005':
+ if rl < 40:
+ a = 0.171
+ c = 0.688
+ elif rl <120:
+ a = 0.265
+ c = 0.803
+ elif rl < 1440:
+ a = 0.324
+ c = 0.845
+ elif name == 'H_010':
+ if rl < 40:
+ a = 0.163
+ c = 0.656
+ elif rl <120:
+ a = 0.280
+ c = 0.803
+ elif rl < 1440:
+ a = 0.380
+ c = 0.867
+ elif name == 'H_020':
+ if rl < 40:
+ a = 0.169
+ c = 0.648
+ elif rl > 40 and rl < 120:
+ a = 0.300
+ c = 0.803
+ elif rl < 1440:
+ a = 0.463
+ c = 0.894
+ elif name == 'H_050':
+ if rl < 40:
+ a = 0.174
+ c = 0.638
+ elif rl < 120:
+ a = 0.323
+ c = 0.803
+ elif rl < 1440:
+ a = 0.580
+ c = 0.925
+ elif name == 'H_100':
+ if rl < 40:
+ a = 0.173
+ c = 0.625
+ elif rl < 120:
+ a = 0.335
+ c = 0.803
+ elif rl < 1440:
+ a = 0.642
+ c = 0.939
+ if a is None or c is None:
+ grass.fatal("Unable to calculate coefficients")
+ coef = a * rl ** (1 - c)
+ expression = '{}_average * {}'.format(name, coef)
+ Module('v.db.update', map=opt['map'],
+ column=field_name, query_column=expression)
+ # remove not used column
+ Module('v.db.dropcolumn', map=opt['map'],
+ columns='{}_average'.format(name))
+ return 0
+if __name__ == "__main__":
+ opt, flg = grass.parser()
+ sys.exit(main())
Deleted: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.series.html
--- grass-addons/grass7/raster/r.subdayprecip.series/r.subdayprecip.series.html 2015-07-10 10:30:08 UTC (rev 65560)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.series.html 2015-07-10 12:14:57 UTC (rev 65561)
@@ -1,28 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.in.proj</em> computes subday design precipitation series.
-TODO
-<h2>EXAMPLE</h2>
-TODO
-<h2>SEE ALSO</h2>
-<em>
-<a href="v.rast.stats.html">v.rast.stats</a>
-</em>
-<h2>REFERENCES</h2>
-<ul>
- <li><a href="http://geo.fsv.cvut.cz/proj/bp/2013/martin-tomasu-bp-2013.pdf">http://geo.fsv.cvut.cz/proj/bp/2013/martin-tomasu-bp-2013.pdf</a> (in Czech)</li>
-</ul>
-<h2>AUTHORS</h2>
-Martin Landa, OSGeoREL, Czech Technical University in Prague<br>
-<p>
-<i>Last changed: $Date $</i>
Deleted: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.series.py
--- grass-addons/grass7/raster/r.subdayprecip.series/r.subdayprecip.series.py 2015-07-10 10:30:08 UTC (rev 65560)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.series.py 2015-07-10 12:14:57 UTC (rev 65561)
@@ -1,159 +0,0 @@
-#!/usr/bin/env python
-# MODULE: r.subdayprecip.series
-# AUTHOR(S): Martin Landa
-# PURPOSE: Computes subday design precipitation series.
-# COPYRIGHT: (C) 2015 Martin Landa and GRASS development team
-# This program is free software under the GNU General
-# Public License (>=v2). Read the file COPYING that
-# comes with GRASS for details.
-#%module
-#% description: Computes subday design precipitation series.
-#%end
-#%option G_OPT_V_MAP
-#% description: Name of basin vector map
-#%end
-#%option G_OPT_R_INPUTS
-#% key: raster
-#% description: Name of input raster map(s) (H_002,H_005,H_010,H_020,H_050,H_100)
-#%end
-#%option
-#% key: rainlength
-#% description: Rain length value in minutes
-#% type: integer
-#% options: 0-1439
-#% required: yes
-#%end
-import os
-import sys
-import grass.script as grass
-from grass.pygrass.modules import Module
-from grass.exceptions import CalledModuleError
-def main():
- # get list of existing columns
- try:
- columns = grass.vector_columns(opt['map']).keys()
- except CalledModuleError as e:
- return 1
- allowed_rasters = ('H_002', 'H_005', 'H_010', 'H_020', 'H_050', 'H_100')
- # extract multi values to points
- for rast in opt['raster'].split(','):
- # check valid rasters
- name = grass.find_file(rast, element='raster')['name']
- if not name:
- grass.warning('Raster map <{}> not found. '
- 'Skipped.'.format(rast))
- continue
- if name not in allowed_rasters:
- grass.warning('Raster map <{}> skipped. '
- 'Allowed: {}'.format(rast, allowed_rasters))
- continue
- grass.message('Processing <{}>...'.format(rast))
- table = '{}_table'.format(name)
- # TODO: handle null values
- Module('v.rast.stats', flags='c', map=opt['map'], raster=rast,
- column_prefix=name, method='average', quiet=True)
- rl = float(opt['rainlength'])
- field_name='{}_{}'.format(name, opt['rainlength'])
- if field_name not in columns:
- Module('v.db.addcolumn', map=opt['map'],
- columns='{} double precision'.format(field_name))
- a = c = None
- if name == 'H_002':
- if rl < 40:
- a = 0.166
- c = 0.701
- elif rl < 120:
- a = 0.237
- c = 0.803
- elif rl < 1440:
- a = 0.235
- c = 0.801
- elif name == 'H_005':
- if rl < 40:
- a = 0.171
- c = 0.688
- elif rl <120:
- a = 0.265
- c = 0.803
- elif rl < 1440:
- a = 0.324
- c = 0.845
- elif name == 'H_010':
- if rl < 40:
- a = 0.163
- c = 0.656
- elif rl <120:
- a = 0.280
- c = 0.803
- elif rl < 1440:
- a = 0.380
- c = 0.867
- elif name == 'H_020':
- if rl < 40:
- a = 0.169
- c = 0.648
- elif rl > 40 and rl < 120:
- a = 0.300
- c = 0.803
- elif rl < 1440:
- a = 0.463
- c = 0.894
- elif name == 'H_050':
- if rl < 40:
- a = 0.174
- c = 0.638
- elif rl < 120:
- a = 0.323
- c = 0.803
- elif rl < 1440:
- a = 0.580
- c = 0.925
- elif name == 'H_100':
- if rl < 40:
- a = 0.173
- c = 0.625
- elif rl < 120:
- a = 0.335
- c = 0.803
- elif rl < 1440:
- a = 0.642
- c = 0.939
- if a is None or c is None:
- grass.fatal("Unable to calculate coefficients")
- coef = a * rl ** (1 - c)
- expression = '{}_average * {}'.format(name, coef)
- Module('v.db.update', map=opt['map'],
- column=field_name, query_column=expression)
- # remove not used column
- Module('v.db.dropcolumn', map=opt['map'],
- columns='{}_average'.format(name))
- return 0
-if __name__ == "__main__":
- opt, flg = grass.parser()
- sys.exit(main())
