[GRASS-SVN] r65754 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Tue Jul 21 04:41:07 PDT 2015
Author: wenzeslaus
Date: 2015-07-21 04:41:07 -0700 (Tue, 21 Jul 2015)
New Revision: 65754
grass/trunk/scripts/g.extension/g.extension.py
g.extension: support incomplete URLs for download from (well) known hosting services
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2015-07-21 11:14:50 UTC (rev 65753)
+++ grass/trunk/scripts/g.extension/g.extension.py 2015-07-21 11:41:07 UTC (rev 65754)
@@ -141,6 +141,7 @@
except ImportError:
import elementtree.ElementTree as etree # Python <= 2.4
+import grass.script as gscript
from grass.script.utils import try_rmdir
from grass.script import core as grass
@@ -916,7 +917,6 @@
if len(files) == 1:
shutil.copytree(os.path.join(extract_dir, files[0]), target_dir)
- print("copytree:", os.path.join(extract_dir, files[0]), target_dir)
else:
for file_name in files:
actual_file = os.path.join(extract_dir, file_name)
@@ -1384,6 +1384,72 @@
return url
+KNOWN_HOST_SERVICES_INFO = {
+ 'OSGeo Trac': {
+ 'domain': 'trac.osgeo.org',
+ 'ignored_suffixes': ['format=zip'],
+ 'possible_starts': ['', 'https://', 'http://'],
+ 'url_start': 'https://',
+ 'url_end': '?format=zip',
+ 'GitHub': {
+ 'domain': 'github.com',
+ 'ignored_suffixes': ['.zip', '.tar.gz'],
+ 'url_end': '/archive/master.zip',
+ 'GitLab': {
+ 'domain': 'gitlab.com',
+ 'ignored_suffixes': ['.zip', '.tar.gz', '.tar.bz2', '.tar'],
+ 'url_end': '/repository/archive.zip',
+ 'Bitbucket': {
+ 'domain': 'bitbucket.org',
+ 'ignored_suffixes': ['.zip', '.tar.gz', '.gz', '.bz2'],
+ 'url_end': '/get/default.zip',
+# TODO: support ZIP URLs which don't end with zip
+# https://gitlab.com/user/reponame/repository/archive.zip?ref=b%C3%A9po
+def resolve_known_host_service(url):
+ match = None
+ actual_start = None
+ for key, value in KNOWN_HOST_SERVICES_INFO.iteritems():
+ for start in value['possible_starts']:
+ if url.startswith(start + value['domain']):
+ match = value
+ actual_start = start
+ gscript.verbose(_("Indentified {} as known hosting service")
+ .format(key))
+ for suffix in value['ignored_suffixes']:
+ if url.endswith(suffix):
+ gscript.verbose(
+ _("Not using {service} as known hosting service"
+ " because the URL ends with '{suffix}'")
+ .format(service=key, suffix=suffix))
+ return None
+ if match:
+ if not actual_start:
+ actual_start = match['url_start']
+ else:
+ actual_start = ''
+ url = '{prefix}{base}{suffix}'.format(prefix=actual_start,
+ base=url.rstrip('/'),
+ suffix=match['url_end'])
+ gscript.verbose(_("Will use the following URL for download: {}")
+ .format(url))
+ return 'remote_zip', url
+ else:
+ return None
def resolve_source_code(url):
"""Return type and URL or path of the source code
@@ -1397,18 +1463,54 @@
:returns: tuple with type of source and full URL or path
+ Subversion:
>>> resolve_source_code('http://svn.osgeo.org/grass/grass-addons/grass7')
('svn', 'http://svn.osgeo.org/grass/grass-addons/grass7')
+ ZIP files online:
>>> resolve_source_code('https://trac.osgeo.org/.../r.modis?format=zip')
('remote_zip', 'https://trac.osgeo.org/.../r.modis?format=zip')
+ Local directories and ZIP files:
>>> resolve_source_code(os.path.expanduser("~")) # doctest: +ELLIPSIS
('dir', '...')
>>> resolve_source_code('/local/directory/downloaded.zip') # doctest: +SKIP
('zip', '/local/directory/downloaded.zip')
+ OSGeo Trac:
+ >>> resolve_source_code('trac.osgeo.org/.../r.agent.aco')
+ ('remote_zip', 'https://trac.osgeo.org/.../r.agent.aco?format=zip')
+ >>> resolve_source_code('https://trac.osgeo.org/.../r.agent.aco')
+ GitHub:
>>> resolve_source_code('github.com/user/g.example')
('remote_zip', 'https://github.com/user/g.example/archive/master.zip')
>>> resolve_source_code('github.com/user/g.example/')
+ >>> resolve_source_code('https://github.com/user/g.example')
+ ('remote_zip', 'https://github.com/user/g.example/archive/master.zip')
+ >>> resolve_source_code('https://github.com/user/g.example/')
+ GitLab:
+ >>> resolve_source_code('gitlab.com/JoeUser/GrassModule')
+ ('remote_zip', 'https://gitlab.com/JoeUser/GrassModule/repository/archive.zip')
+ >>> resolve_source_code('https://gitlab.com/JoeUser/GrassModule')
+ Bitbucket:
+ >>> resolve_source_code('bitbucket.org/joe-user/grass-module')
+ ('remote_zip', 'https://bitbucket.org/joe-user/grass-module/get/default.zip')
+ >>> resolve_source_code('https://bitbucket.org/joe-user/grass-module')
if os.path.isdir(url):
return 'dir', os.path.abspath(url)
@@ -1416,11 +1518,10 @@
for suffix in ['.zip', '.tar.gz']:
return suffix.lstrip('.'), os.path.abspath(url)
- elif url.startswith('github.com') and \
- not (url.endswith('.zip') or url.endswith('.tar.gz')):
- url = 'https://{}/archive/master.zip'.format(url.rstrip('/'))
- return 'remote_zip', url
else:
+ result = resolve_known_host_service(url)
+ if result:
+ return result
# we allow URL to end with =zip or ?zip and not only .zip
# unfortunately format=zip&version=89612 would require something else
# special option to force the source type would solve it
@@ -1478,6 +1579,7 @@
if __name__ == "__main__":
if len(sys.argv) == 2 and sys.argv[1] == '--doctest':
import doctest
+ _ = str # doctest gettext workaround
sys.exit(doctest.testmod().failed)
options, flags = grass.parser()
global TMPDIR
