[GRASS-SVN] r65757 - in grass/trunk/scripts/g.extension: . testsuite testsuite/data testsuite/data/sample_modules testsuite/data/sample_modules/r.plus.example
svn_grass at osgeo.org
Tue Jul 21 08:57:14 PDT 2015
Author: wenzeslaus
Date: 2015-07-21 08:57:14 -0700 (Tue, 21 Jul 2015)
New Revision: 65757
Added:
grass/trunk/scripts/g.extension/testsuite/data/sample_modules/
grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example.tar.gz
grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example.zip
grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/
grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/Makefile
grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/r.plus.example.html
grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/r.plus.example.py
grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example_sep.tar.gz
grass/trunk/scripts/g.extension/g.extension.py
grass/trunk/scripts/g.extension/testsuite/test_addons_modules.py
grass/trunk/scripts/g.extension/testsuite/test_addons_toolboxes.py
g.extension: support tar without root directory, fix install prefix for relative paths, add tests
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2015-07-21 14:00:53 UTC (rev 65756)
+++ grass/trunk/scripts/g.extension/g.extension.py 2015-07-21 15:57:14 UTC (rev 65757)
@@ -919,13 +919,14 @@
if len(files) == 1:
shutil.copytree(os.path.join(extract_dir, files[0]), target_dir)
else:
+ os.mkdir(target_dir)
for file_name in files:
actual_file = os.path.join(extract_dir, file_name)
if os.path.isdir(actual_file):
shutil.copytree(actual_file,
os.path.join(target_dir, file_name))
else:
- shutil.copy(actual_file, target_dir)
+ shutil.copy(actual_file, os.path.join(target_dir, file_name))
# Original copyright and license of the original version of the CRLF function
@@ -1022,6 +1023,7 @@
grass.fatal(_("Unknown extension (addon) source type '{}'."
" Please report this to the grass-user mailing list.")
.format(source))
+ assert os.path.isdir(directory)
def install_extension_std_platforms(name, source, url):
@@ -1372,7 +1374,7 @@
# together with file names
if not path.endswith(os.path.sep):
path = path + os.path.sep
- return path
+ return os.path.abspath(path) # make likes absolute paths
def resolve_xmlurl_prefix(url):
@@ -1447,7 +1449,7 @@
_("Not using {service} as known hosting service"
" because the URL ends with '{suffix}'")
.format(service=key, suffix=suffix))
- return None
+ return None, None
if match:
if not actual_start:
actual_start = match['url_start']
@@ -1460,7 +1462,7 @@
.format(url))
return 'remote_zip', url
else:
- return None
+ return None, None
def resolve_source_code(url):
@@ -1529,14 +1531,14 @@
return 'dir', os.path.abspath(url)
elif os.path.exists(url):
if url.endswith('.zip'):
- return 'zip', os.path.abspath(url)
+ return 'zip', os.path.abspath(url)
for suffix in extract_tar.supported_formats:
if url.endswith('.' + suffix):
return suffix, os.path.abspath(url)
else:
- result = resolve_known_host_service(url)
- if result:
- return result
+ source, url = resolve_known_host_service(url)
+ if source:
+ return source, url
# we allow URL to end with =zip or ?zip and not only .zip
# unfortunately format=zip&version=89612 would require something else
# special option to force the source type would solve it
Added: grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/Makefile
--- grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/Makefile (rev 0)
+++ grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/Makefile 2015-07-21 15:57:14 UTC (rev 65757)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.plus.example
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/r.plus.example.html
--- grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/r.plus.example.html (rev 0)
+++ grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/r.plus.example.html 2015-07-21 15:57:14 UTC (rev 65757)
@@ -0,0 +1,25 @@
+<h2>DESCRIPTION</h2>
+<em>r.plus.example</em>
+<h2>NOTES</h2>
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+r.plus.example
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>
+</em>
+<h2>AUTHORS</h2>
+Vaclav Petras, NCSU OSGeoREL<br>
+<p>
+<i>Last changed: $Date: 2015-06-07 07:21:31 -0400 (Sun, 07 Jun 2015) $</i>
Added: grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/r.plus.example.py
--- grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/r.plus.example.py (rev 0)
+++ grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example/r.plus.example.py 2015-07-21 15:57:14 UTC (rev 65757)
@@ -0,0 +1,36 @@
+#!/usr/bin/env python
+#%module
+#% description: Adds the values of two rasters (A + B)
+#% keyword: raster
+#% keyword: algebra
+#% keyword: sum
+#%end
+#%option G_OPT_R_INPUT
+#% key: araster
+#% description: Name of input raster A in an expression A + B
+#%end
+#% key: braster
+#% description: Name of input raster B in an expression A + B
+#%end
+#%option G_OPT_R_OUTPUT
+#%end
+import grass.script as gscript
+def main():
+ options, flags = gscript.parser()
+ araster = options['araster']
+ braster = options['braster']
+ output = options['output']
+ gscript.mapcalc('{r} = {a} + {b}'.format(r=output, a=araster, b=braster))
+ return 0
+if __name__ == "__main__":
+ main()
Added: grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example.tar.gz
(Binary files differ)
Property changes on: grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example.tar.gz
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example.zip
Property changes on: grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example.zip
Added: grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example_sep.tar.gz
Property changes on: grass/trunk/scripts/g.extension/testsuite/data/sample_modules/r.plus.example_sep.tar.gz
Modified: grass/trunk/scripts/g.extension/testsuite/test_addons_modules.py
--- grass/trunk/scripts/g.extension/testsuite/test_addons_modules.py 2015-07-21 14:00:53 UTC (rev 65756)
+++ grass/trunk/scripts/g.extension/testsuite/test_addons_modules.py 2015-07-21 15:57:14 UTC (rev 65757)
@@ -15,6 +15,7 @@
from grass.gunittest.case import TestCase
from grass.gunittest.main import test
from grass.gunittest.gmodules import SimpleModule
+from grass.gunittest.utils import silent_rmtree
import os
@@ -49,7 +50,7 @@
url = 'file://' + os.path.abspath('data')
- def test_limits(self):
+ def test_listing(self):
"""Test if results is in expected limits"""
module = SimpleModule('g.extension', flags='l', svnurl=self.url)
self.assertModule(module)
@@ -57,5 +58,68 @@
self.assertMultiLineEqual(stdout, MODULES_OUTPUT)
+class TestModulesFromDifferentSources(TestCase):
+ url = 'file://' + os.path.abspath('data/sample_modules')
+ path = os.path.join('data', 'sample_modules')
+ install_prefix = 'gextension_test_install_path'
+ # TODO: this is wrong for MS Win
+ files = [
+ os.path.join(install_prefix, 'scripts', 'r.plus.example'),
+ os.path.join(install_prefix, 'docs', 'html', 'r.plus.example.html'),
+ # to create archives from the source, the following was used:
+ # zip r.plus.example.zip r.plus.example/*
+ # tar czvf r.plus.example.tar.gz r.plus.example
+ # cd r.plus.example/
+ # tar czvf ../r.plus.example_sep.tar.gz *
+ def setUp(self):
+ """Make sure we are not dealing with some old files"""
+ if os.path.exists(self.install_prefix):
+ files = os.listdir(self.install_prefix)
+ if files:
+ RuntimeError("Install prefix path '{}' contains files {}"
+ .format(self.install_prefix, files))
+ def tearDown(self):
+ """Remove created files"""
+ silent_rmtree(self.install_prefix)
+ def test_directory_install(self):
+ """Test if results is in expected limits"""
+ self.assertModule('g.extension', extension='r.plus.example',
+ svnurl=os.path.join(self.path, 'r.plus.example'),
+ prefix=self.install_prefix)
+ for file in self.files:
+ self.assertFileExists(file)
+ def test_targz_install(self):
+ 'r.plus.example.tar.gz'),
+ def test_remote_targz_without_dir_install(self):
+ svnurl=self.url + '/' + 'r.plus.example_sep.tar.gz',
+ prefix=self.install_prefix, verbose=True)
+ def test_remote_zip_install(self):
+ svnurl=self.url + '/' + 'r.plus.example.zip',
+ self.assertFileExists(os.path.join(file))
if __name__ == '__main__':
test()
Modified: grass/trunk/scripts/g.extension/testsuite/test_addons_toolboxes.py
--- grass/trunk/scripts/g.extension/testsuite/test_addons_toolboxes.py 2015-07-21 14:00:53 UTC (rev 65756)
+++ grass/trunk/scripts/g.extension/testsuite/test_addons_toolboxes.py 2015-07-21 15:57:14 UTC (rev 65757)
@@ -40,7 +40,7 @@
module = SimpleModule('g.extension', flags='lt', svnurl=self.url)
