[GRASS-SVN] r65758 - grass/trunk/gui/wxpython/tplot
svn_grass at osgeo.org
Tue Jul 21 09:32:08 PDT 2015
Author: lucadelu
Date: 2015-07-21 09:32:08 -0700 (Tue, 21 Jul 2015)
New Revision: 65758
grass/trunk/gui/wxpython/tplot/frame.py
grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
g.gui.tplot: implemented categories for vector temporal datasets
Modified: grass/trunk/gui/wxpython/tplot/frame.py
--- grass/trunk/gui/wxpython/tplot/frame.py 2015-07-21 15:57:14 UTC (rev 65757)
+++ grass/trunk/gui/wxpython/tplot/frame.py 2015-07-21 16:32:08 UTC (rev 65758)
@@ -24,10 +24,6 @@
import wx
from grass.pygrass.modules import Module
-import re
-import wx.lib.flatnotebook as FN
-from mapdisp.main import DMonGrassInterface
-from core.giface import StandaloneGrassInterface
import grass.script as grass
from core.utils import _
@@ -50,24 +46,19 @@
import grass.temporal as tgis
from core.gcmd import GMessage, GError, GException, RunCommand
-from gui_core.widgets import CoordinatesValidator
+from gui_core.widgets import CoordinatesValidator
from gui_core import gselect
from core import globalvar
from grass.pygrass.vector.geometry import Point
from grass.pygrass.raster import RasterRow
from collections import OrderedDict
from subprocess import PIPE
-import os
-import multiprocessing as multi
try:
import wx.lib.agw.flatnotebook as FN
except ImportError:
-from core import globalvar
from gui_core.widgets import GNotebook
-import ipdb
ALPHA = 0.5
COLORS = ['b', 'g', 'r', 'c', 'm', 'y', 'k']
@@ -226,10 +217,12 @@
self.attribute = gselect.ColumnSelect(parent=self.controlPanelVector)
self.attributeLabel = wx.StaticText(parent=self.controlPanelVector,
id=wx.ID_ANY,
- label=_('Select attribute '))
- # TODO fix the select
+ label=_('Select attribute column'))
+ # TODO fix the category selection as done for coordinates
#self.cats = gselect.VectorCategorySelect(parent=self.controlPanelVector,
# giface=self._giface)
+ self.cats = wx.TextCtrl(parent=self.controlPanelVector, id=wx.ID_ANY,
+ size=globalvar.DIALOG_TEXTCTRL_SIZE)
self.catsLabel = wx.StaticText(parent=self.controlPanelVector,
id=wx.ID_ANY,
label=_('Select category of vector(s)'))
@@ -246,8 +239,7 @@
self.controlPanelSizerVector.Add(self.attribute, flag=wx.EXPAND)
self.controlPanelSizerVector.Add(self.catsLabel, flag=wx.EXPAND)
- #self.controlPanelSizerVector.Add(self.cats, flag=wx.EXPAND)
+ self.controlPanelSizerVector.Add(self.cats, flag=wx.EXPAND)
self.controlPanelVector.SetSizer(self.controlPanelSizerVector)
self.controlPanelSizerVector.Fit(self)
@@ -273,6 +265,7 @@
self.vbox.Add(self.ntb, flag=wx.EXPAND)
self.vbox.Add(self.vButtPanel, flag=wx.EXPAND)
self.vbox.Fit(self)
+ self.mainPanel.Fit()
def _getSTRDdata(self, timeseries):
"""Load data and read properties
@@ -287,8 +280,8 @@
etype = series[2]
sp = tgis.dataset_factory(etype, fullname)
if not sp.is_in_db(dbif=self.dbif):
- GError(self, message=_("Dataset <%s> not found in temporal "
- "database") % (fullname))
+ GError(message=_("Dataset <%s> not found in temporal "
+ "database") % (fullname), parent=self)
return
sp.select(dbif=self.dbif)
@@ -319,8 +312,9 @@
if unit is None:
unit = self.timeDataR[name]['unit']
elif self.timeDataR[name]['unit'] != unit:
- GError(self, _("Datasets have different time unit which "
- "is not allowed."))
+ GError(parent=self, message=_("Datasets have different "
+ "time unit which is not "
+ "allowed."))
return
rows = sp.get_registered_maps(columns=columns, where=None,
@@ -358,16 +352,24 @@
:param list timeseries: a list of timeseries
- # TODO parse categories to where condition
- # cats = self.cats.GetValue()
- cats = [str(i) for i in range(1,137)]
- cats = ','.join(cats)
# idKye = 'linkid' #TODO
mode = None
unit = None
+ cats = None
attribute = self.attribute.GetValue()
+ if self.cats.GetValue() != '':
+ cats = self.cats.GetValue().split(',')
+ if cats and self.poi:
+ GMessage(message=_("Both coordinates and categories are set, "
+ "coordinates will be used. The use categories"
+ "remove text from coordinate form"))
+ if not attribute or attribute == '':
+ GError(parent=self, showTraceback=False,
+ message=_("With Vector temporal dataset you have to select"
+ " an attribute column"))
+ return
columns = ','.join(['name', 'start_time', 'end_time', 'id', 'layer'])
for series in timeseries:
name = series[0]
@@ -375,14 +377,14 @@
etype = series[2]
- GError(self, message=_("Dataset <%s> not found in "
- "temporal database") % (fullname))
+ "database") % (fullname), parent=self,
+ showTraceback=False)
return
rows = sp.get_registered_maps(dbif=self.dbif, order="start_time",
columns=columns, where=None)
- self.plotNameListV.append(name)
self.timeDataV[name] = OrderedDict()
self.timeDataV[name]['temporalDataType'] = etype
@@ -392,9 +394,9 @@
if mode is None:
mode = self.timeDataV[name]['temporalType']
elif self.timeDataV[name]['temporalType'] != mode:
- GError(parent=self, message=_("Datasets have different "
- "temporal type (absolute x "
- "relative), which is not allowed."))
+ message=_("Datasets have different temporal type ("
+ "absolute x relative), which is not allowed."))
return
self.timeDataV[name]['unit'] = None # only with relative
if self.timeDataV[name]['temporalType'] == 'relative':
@@ -402,20 +404,22 @@
if unit is None:
unit = self.timeDataV[name]['unit']
elif self.timeDataV[name]['unit'] != unit:
- GError(self, _("Datasets have different time unit"
- " which is not allowed."))
+ GError(message=_("Datasets have different time unit which"
+ " is not allowed."), parent=self,
return
- ipdb.set_trace()
if self.poi:
+ self.plotNameListV.append(name)
# TODO set an appropriate distance, right now a big one is set
# to return the closer point to the selected one
out = grass.vector_what(map='pois_srvds',
coord=self.poi.coords(),
distance=10000000000000000)
if len(out) != len(rows):
- GError(parent=self, message=_("Difference number of vector"
- " layers and maps in the "
- "vector temporal dataset"))
+ message=_("Difference number of vector layers and "
+ "maps in the vector temporal dataset"))
+ return
for i in range(len(rows)):
row = rows[i]
values = out[i]
@@ -427,63 +431,34 @@
self.timeDataV[name][lay]['end_datetime'] = row['start_time']
self.timeDataV[name][lay]['value'] = values['Attributes'][attribute]
else:
- print "NotImplementeYet"
- return
- for attr in attributes.split(','):
- for x, cat in enumerate(cats.split(',')):
- # TODO chck
- idKye = self.parseVDbConn(rows[x]['name'],
- rows[x]['layer'])
- conditionWhere = idKye + '=' + cat
- self.listWhereConditions.append(conditionWhere)
- name = str(series) + str(conditionWhere)
- # check topology
- maps = sp.get_registered_maps_as_objects(dbif=self.dbif)
- self.timeDataV[name]['validTopology'] = sp.check_temporal_topology(maps=maps, dbif=self.dbif)
- workers = multi.cpu_count()
- # Check if workers are already being used
- # run all bands in parallel
- if "WORKERS" in os.environ:
- workers = int(os.environ["WORKERS"])
- else:
- workers = len(rows)
- # Initialize process dictionary
- proc = {}
- pout = {}
- for j, row in enumerate(rows):
- self.timeDataV[name][row[3]] = {}
- self.timeDataV[name][row[3]]['start_datetime'] = row[1]
- self.timeDataV[name][row[3]]['end_datetime'] = row[2]
- if self.timeDataV[name][row[3]]['end_datetime'] is None:
- self.timeDataV[name][row[3]]['end_datetime'] = row[1]
- proc[j] = grass.pipe_command('v.db.select',
- map=row['name'],
- layer=row['layer'],
- where=conditionWhere,
- columns=attr,
- flags='c')
- if j % workers is 0:
- # wait for the ones launched so far to finish
- for jj in range(j):
- if not proc[jj].stdout.closed:
- pout[jj] = proc[jj].communicate()[0]
- proc[jj].wait()
- for row in range(len(proc)):
- if not proc[row].stdout.closed:
- pout[row] = proc[row].communicate()[0]
- proc[row].wait()
- for i, row in enumerate(rows):
- self.timeDataV[name][row[3]]['value'] = pout[i]
+ wherequery = ''
+ totcat = len(cats)
+ ncat = 1
+ for cat in cats:
+ if ncat == 1:
+ wherequery += 'cat={c} or'.format(c=cat)
+ elif ncat == totcat:
+ wherequery += ' cat={c}'.format(c=cat)
+ else:
+ wherequery += ' cat={c} or'.format(c=cat)
+ catn = "cat{num}".format(num=cat)
+ self.plotNameListV.append("{na}+{cat}".format(na=name,
+ cat=catn))
+ self.timeDataV[name][catn] = OrderedDict()
+ ncat += 1
+ for row in rows:
+ lay = int(row['layer'])
+ vals = grass.vector_db_select(map=row['name'], layer=lay,
+ where=wherequery,
+ columns=attribute)
+ layn = "lay{num}".format(num=lay)
+ for cat in cats:
+ if layn not in self.timeDataV[name][catn].keys():
+ self.timeDataV[name][catn][layn] = {}
+ self.timeDataV[name][catn][layn]['start_datetime'] = row['start_time']
+ self.timeDataV[name][catn][layn]['end_datetime'] = row['end_time']
+ self.timeDataV[name][catn][layn]['value'] = vals['values'][int(cat)]
self.unit = unit
self.temporalType = mode
return
@@ -515,7 +490,10 @@
if self.datasetsR:
self.drawR()
if self.datasetsV:
- self.drawV()
+ if self.poi:
+ self.drawV()
+ elif self.cats:
+ self.drawVCats()
self.canvas.draw()
DataCursor(self.plots, self.lookUp, InfoFormat, self.convert)
@@ -523,7 +501,7 @@
def drawR(self):
for i, name in enumerate(self.datasetsR):
name = name[0]
- # just name; with mapset it would be long
+ # just name; with mapset it would be long
self.yticksNames.append(name)
self.yticksPos.append(1) # TODO
xdata = []
@@ -552,9 +530,44 @@
handles, labels = self.axes2d.get_legend_handles_labels()
self.axes2d.legend(loc=0)
+ def drawVCats(self):
+ for i, name in enumerate(self.plotNameListV):
+ labelname = name.replace('+', ' ')
+ self.yticksNames.append(labelname)
+ name_cat = name.split('+')
+ name = name_cat[0]
+ self.yticksPos.append(1) # TODO
+ xdata = []
+ ydata = []
+ for keys, values in self.timeDataV[name_cat[0]][name_cat[1]].iteritems():
+ if keys in ['temporalType', 'granularity', 'validTopology',
+ 'unit', 'temporalDataType']:
+ continue
+ xdata.append(self.convert(values['start_datetime']))
+ ydata.append(values['value'])
+ self.lookUp.AddDataset(yranges=ydata, xranges=xdata,
+ datasetName=name)
+ color = self.colors.next()
+ self.plots.append(self.axes2d.plot(xdata, ydata, marker='o',
+ color=color, label=labelname)[0])
+ if self.temporalType == 'absolute':
+ self.axes2d.set_xlabel(_("Temporal resolution: %s" % self.timeDataV[name]['granularity']))
+ else:
+ self.axes2d.set_xlabel(_("Time [%s]") % self.unit)
+ self.axes2d.set_ylabel(', '.join(self.yticksNames))
+ # legend
+ handles, labels = self.axes2d.get_legend_handles_labels()
+ self.axes2d.legend(loc=0)
+ self.listWhereConditions = []
def drawV(self):
self.yticksNames.append(self.attribute.GetValue())
self.yticksPos.append(0) # TODO
xdata = []
@@ -569,8 +582,6 @@
datasetName=name)
- #print xdata
- #print ydata
color=color, label=name)[0])
@@ -594,32 +605,43 @@
if not datasetsR and not datasetsV:
return
try:
- coordx, coordy = self.coorval.coordsField.GetValue().split(',')
- coordx, coordy = float(coordx), float(coordy)
- except (ValueError, AttributeError):
+ getcoors = self.coorval.coordsField.GetValue()
+ except:
try:
- coordx, coordy = self.coorval.GetValue().split(',')
+ getcoors = self.coorval.GetValue()
+ except:
+ getcoors = None
+ if getcoors and getcoors != '':
+ try:
+ coordx, coordy = getcoors.split(',')
- GMessage(_("Incorrect format of coordinates, should be: x,y"))
- coors = [coordx, coordy]
- if coors:
- try:
- self.poi = Point(float(coors[0]), float(coors[1]))
- except GException:
- GError(parent=self, message=_("Invalid input coordinates"))
- return
+ try:
+ coordx, coordy = self.coorval.GetValue().split(',')
+ coordx, coordy = float(coordx), float(coordy)
+ except (ValueError, AttributeError):
+ GMessage(message=_("Incorrect coordinates format, should "
+ "be: x,y"), parent=self)
+ coors = [coordx, coordy]
+ if coors:
+ try:
+ self.poi = Point(float(coors[0]), float(coors[1]))
+ except GException:
+ GError(parent=self, message=_("Invalid input coordinates"),
+ return
# check raster dataset
if datasetsR:
datasetsR = datasetsR.split(',')
try:
- datasetsR = self._checkDatasets(datasetsR)
+ datasetsR = self._checkDatasets(datasetsR, 'strds')
if not datasetsR:
return
except GException:
- GError(parent=self, message=_("Invalid input raster dataset"))
+ GError(parent=self, message=_("Invalid input raster dataset"),
return
self.datasetsR = datasetsR
@@ -628,14 +650,14 @@
if datasetsV:
datasetsV = datasetsV.split(',')
try:
- datasetsV = self._checkDatasets(datasetsV)
+ datasetsV = self._checkDatasets(datasetsV, 'stvds')
if not datasetsV:
return
except GException:
- GError(parent=self, message=_("Invalid input vector dataset"))
+ GError(parent=self, message=_("Invalid input vector dataset"),
return
self.datasetsV = datasetsV
self._redraw()
def _redraw(self):
@@ -648,14 +670,13 @@
if self.datasetsV:
self._getSTVDData(self.datasetsV)
- ipdb.set_trace()
# axes3d are physically removed
if not self.axes2d:
self.axes2d = self.fig.add_subplot(1, 1, 1)
self._drawFigure()
- def _checkDatasets(self, datasets):
+ def _checkDatasets(self, datasets, typ):
"""Checks and validates datasets.
Reports also type of dataset (e.g. 'strds').
@@ -664,7 +685,7 @@
:return: (mapName, mapset, type)
validated = []
- tDict = tgis.tlist_grouped('stds', group_type=True, dbif=self.dbif)
+ tDict = tgis.tlist_grouped(type=typ, group_type=True, dbif=self.dbif)
# nested list with '(map, mapset, etype)' items
allDatasets = [[[(map, mapset, etype) for map in maps]
for etype, maps in etypesDict.iteritems()]
@@ -713,7 +734,7 @@
def OnHelp(self, event):
"""Function to show help"""
- RunCommand('g.manual', quiet=True, entry='g.gui.tplot')
+ RunCommand(prog='g.manual', quiet=True, entry='g.gui.tplot')
def SetDatasets(self, rasters, vectors, coors, cats, attr):
"""Set the data
@@ -724,34 +745,40 @@
:param list cats: a list with incld. categories of vector
:param str attr: name of atribute of vectror data
- if not (rasters or vectors) or not coors:
+ if not (rasters or vectors) or not (coors or cats):
return
try:
if rasters:
- self.datasetsR = self._checkDatasets(rasters)
+ self.datasetsR = self._checkDatasets(rasters, 'strds')
if vectors:
- self.datasetsV = self._checkDatasets(vectors)
+ self.datasetsV = self._checkDatasets(vectors, 'stvds')
if not (self.datasetsR or self.datasetsV):
return
except GException:
- GError(parent=self, message=_("Invalid input temporal dataset"))
+ GError(parent=self, message=_("Invalid input temporal dataset"),
return
- try:
- return
+ if coors:
+ try:
+ return
+ try:
+ self.coorval.coordsField.SetValue(','.join(coors))
+ except:
+ self.coorval.SetValue(','.join(coors))
if self.datasetsV:
- self.datasetSelectV.SetValue(','.join(map(lambda x: x[0] + '@' + x[1],
- self.datasetsV)))
- self.attribute.SetValue(attr)
+ vdatas = ','.join(map(lambda x: x[0] + '@' + x[1], self.datasetsV))
+ self.datasetSelectV.SetValue(vdatas)
+ if attr:
+ self.attribute.SetValue(attr)
+ if cats:
+ self.cats.SetValue(cats)
if self.datasetsR:
self.datasetSelectR.SetValue(','.join(map(lambda x: x[0] + '@' + x[1],
self.datasetsR)))
- try:
- self.coorval.coordsField.SetValue(','.join(coors))
- except:
- self.coorval.SetValue(','.join(coors))
self._redraw()
def OnVectorSelected(self, event):
@@ -774,8 +801,9 @@
def AddDataset(self, yranges, xranges, datasetName):
if len(yranges) != len(xranges):
- GError(parent=self, message=_("Datasets have different number of"
- "values"))
+ message=_("Datasets have different number of values"))
+ return
self.data[datasetName] = {}
for i in range(len(xranges)):
self.data[datasetName][xranges[i]] = yranges[i]
Modified: grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
--- grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2015-07-21 15:57:14 UTC (rev 65757)
+++ grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2015-07-21 16:32:08 UTC (rev 65758)
@@ -99,7 +99,7 @@
if options['stvds']:
vectors = options['stvds'].strip().split(',')
if not options['attr']:
- gscript.fatal(_("With stvds you have to use also 'attr' option"))
+ gscript.fatal(_("With stvds you have to set 'attr' option"))
else:
attr = options['attr']
if coords and cats:
@@ -108,7 +108,6 @@
elif not coords and not cats:
gscript.warning(_("With stvds you have to use 'coordinates' or "
"'cats' option"))
app = wx.App()
frame = TplotFrame(parent=None, giface=StandaloneGrassInterface())
frame.SetDatasets(rasters, vectors, coords, cats, attr)
