[GRASS-SVN] r65410 - grass/branches/releasebranch_7_0/raster/r.in.gdal
svn_grass at osgeo.org
Sun Jun 7 13:33:39 PDT 2015
Author: neteler
Date: 2015-06-07 13:33:39 -0700 (Sun, 07 Jun 2015)
New Revision: 65410
grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
r.in.gdal: flag to print Print number of bands; error handler (trunk, r64371)
Modified: grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
--- grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2015-06-07 20:04:49 UTC (rev 65409)
+++ grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2015-06-07 20:33:39 UTC (rev 65410)
@@ -9,7 +9,7 @@
* PURPOSE: Imports many GIS/image formats into GRASS utilizing the GDAL
* library.
- * COPYRIGHT: (C) 2001-2011 by Frank Warmerdam, and the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2015 by Frank Warmerdam, and the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -42,6 +42,7 @@
static void SetupReprojector(const char *pszSrcWKT, const char *pszDstLoc,
struct pj_info *iproj, struct pj_info *oproj);
static int dump_rat(GDALRasterBandH hBand, char *outrat, int nBand);
+static void error_handler_ds(void *p);
static int l1bdriver;
@@ -74,7 +75,7 @@
struct Option *input, *output, *target, *title, *outloc, *band,
*memory, *offset, *rat;
} parm;
- struct Flag *flag_o, *flag_e, *flag_k, *flag_f, *flag_l, *flag_c;
+ struct Flag *flag_o, *flag_e, *flag_k, *flag_f, *flag_l, *flag_c, *flag_p;
/* Initialize. */
@@ -184,6 +185,13 @@
_("Create the location specified by the \"location\" parameter and exit."
" Do not import the raster file.");
+ flag_p = G_define_flag();
+ flag_p->key = 'p';
+ flag_p->description = _("Print number of bands and exit");
+ flag_p->suppress_required = YES;
+ G_option_requires(flag_p, parm.input, NULL);
/* The parser checks if the map already exists in current mapset, this is
* wrong if location options is used, so we switch out the check and do it
* in the module after the parser */
@@ -261,22 +269,14 @@
exit(EXIT_SUCCESS);
- if (!parm.outloc->answer) { /* Check if the map exists */
- if (G_find_raster2(output, G_mapset())) {
- if (overwrite)
- G_warning(_("Raster map <%s> already exists and will be overwritten"),
- output);
- else
- G_fatal_error(_("Raster map <%s> already exists"), output);
/* Open the file. */
hDS = GDALOpen(input, GA_ReadOnly);
if (hDS == NULL)
- exit(EXIT_FAILURE);
+ G_fatal_error(_("Unable to open datasource <%s>"), input);
+ G_add_error_handler(error_handler_ds, hDS);
hDriver = GDALGetDatasetDriver(hDS); /* needed for AVHRR data */
/* L1B - NOAA/AVHRR data must be treated differently */
/* for hDriver names see gdal/frmts/gdalallregister.cpp */
@@ -290,6 +290,24 @@
"(%s or %s)."), "i.rectify -t", "gdalwarp -tps");
+ if (flag_p->answer) {
+ /* print number of bands */
+ fprintf(stdout, "%d\n", GDALGetRasterCount(hDS));
+ GDALClose(hDS);
+ exit(EXIT_SUCCESS);
+ if (!parm.outloc->answer &&
+ GDALGetRasterCount(hDS) == 1) { /* Check if the map exists */
+ if (G_find_raster2(output, G_mapset())) {
+ if (overwrite)
+ G_warning(_("Raster map <%s> already exists and will be overwritten"),
+ output);
+ else
+ G_fatal_error(_("Raster map <%s> already exists"), output);
/* zero cell header */
G_zero(&cellhd, sizeof(struct Cell_head));
@@ -498,7 +516,8 @@
- G_verbose_message(_("Proceeding with import..."));
+ G_message(_("Proceeding with import of %d raster bands..."),
+ GDALGetRasterCount(hDS));
/* Set the active window to match the available data. */
@@ -595,6 +614,16 @@
else
sprintf(szBandName, "%s.%d", output, nBand + offset);
+ if (!parm.outloc->answer) { /* Check if the map exists */
+ if (G_find_raster2(szBandName, G_mapset())) {
+ if (overwrite)
+ szBandName);
+ else
+ G_fatal_error(_("Raster map <%s> already exists"), szBandName);
ImportBand(hBand, szBandName, &ref);
if (title)
@@ -873,6 +902,8 @@
int have_colors = 0;
GDALRasterAttributeTableH gdal_rat;
+ G_message(_("Importing raster map <%s>..."), output);
/* Select a cell type for the new cell. */
@@ -1468,8 +1499,6 @@
- G_message(_("Raster map <%s> created."), output);
return;
@@ -1577,3 +1606,9 @@
return 1;
+void error_handler_ds(void *p)
+ GDALDatasetH hDS = (GDALDatasetH) p;
+ GDALClose(hDS);
