[GRASS-SVN] r65412 - grass/trunk/vector/v.voronoi
Mon Jun 8 00:20:07 PDT 2015
Author: neteler
Date: 2015-06-08 00:20:07 -0700 (Mon, 08 Jun 2015)
New Revision: 65412
   grass/trunk/vector/v.voronoi/main.c
   grass/trunk/vector/v.voronoi/v.voronoi.html
v.voronoi manual: fix examples
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c	2015-06-07 21:32:30 UTC (rev 65411)
+++ grass/trunk/vector/v.voronoi/main.c	2015-06-08 07:20:07 UTC (rev 65412)
@@ -123,6 +123,7 @@
     G_add_keyword(_("vector"));
     G_add_keyword(_("geometry"));
     G_add_keyword(_("triangulation"));
+    G_add_keyword(_("skeleton"));
     module->description = _("Creates a Voronoi diagram in current region from "
 			    "an input vector map containing points or centroids.");
Modified: grass/trunk/vector/v.voronoi/v.voronoi.html
--- grass/trunk/vector/v.voronoi/v.voronoi.html	2015-06-07 21:32:30 UTC (rev 65411)
+++ grass/trunk/vector/v.voronoi/v.voronoi.html	2015-06-08 07:20:07 UTC (rev 65412)
@@ -32,11 +32,11 @@
 <h2>EXAMPLE</h2>
-<h4>Voronoi diagram for points</h4>
+<h3>Voronoi diagram for points</h3>
 This example uses the hospitals in the North Carolina dataset.
 <div class="code"><pre>
-  g.region -p raster=elev_state_500m
-  v.voronoi in=hospitals out=hospitals_voronoi
+g.region -p raster=elev_state_500m
+v.voronoi input=hospitals output=hospitals_voronoi
 </pre></div>
 Result:
@@ -45,11 +45,11 @@
 <i>Voronoi diagram for hospitals in North Carolina</i>
 </center>
-<h4>Voronoi diagram for areas</h4>
+<h3>Voronoi diagram for areas</h3>
 This example uses urban areas in the North Carolina dataset.
-  g.region -p n=162500 s=80000 w=727000 e=846000 res=500
-  v.voronoi in=urbanarea out=urbanarea_voronoi -a
+g.region -p n=162500 s=80000 w=727000 e=846000 res=500
+v.voronoi input=urbanarea output=urbanarea_voronoi -a
 </pre></div>
 Result:
@@ -58,12 +58,12 @@
 <i>Voronoi diagram for urban areas in North Carolina</i>
 </center>
-<h4>Skeletons and center lines of areas</h4>
+<h3>Skeletons and center lines of areas</h3>
-  g.region -p n=161000 s=135500 w=768500 e=805500 res=500
-  v.voronoi in=urbanarea out=urbanarea_centerline -s
-  v.voronoi in=urbanarea out=urbanarea_skeleton -s thin=2000
+g.region -p n=161000 s=135500 w=768500 e=805500 res=500
+v.voronoi input=urbanarea output=urbanarea_centerline -s
+v.voronoi input=urbanarea output=urbanarea_skeleton -s thin=2000
 </pre></div>
 Result:
@@ -74,7 +74,8 @@
 <h2>REFERENCES</h2>
 <em>Steve J. Fortune,  (1987).  A Sweepline Algorithm for
-    Voronoi Diagrams, Algorithmica 2, 153-174.</em>
+    Voronoi Diagrams, Algorithmica 2, 153-174
+    (<a href="http://dx.doi.org/10.1007/BF01840357">DOI</a>).</em>
 <h2>SEE ALSO</h2>
