[GRASS-SVN] r65433 - grass/branches/releasebranch_7_0/scripts/g.extension
Wed Jun 10 06:13:36 PDT 2015
Author: martinl
Date: 2015-06-10 06:13:36 -0700 (Wed, 10 Jun 2015)
New Revision: 65433
   grass/branches/releasebranch_7_0/scripts/g.extension/g.extension.py
g.extension: check permission only when GRASS_ADDON_BASE exists
             (merge r65432 from trunk)
Modified: grass/branches/releasebranch_7_0/scripts/g.extension/g.extension.py
--- grass/branches/releasebranch_7_0/scripts/g.extension/g.extension.py	2015-06-10 13:09:13 UTC (rev 65432)
+++ grass/branches/releasebranch_7_0/scripts/g.extension/g.extension.py	2015-06-10 13:13:36 UTC (rev 65433)
@@ -198,7 +198,7 @@
         if force:
             write_xml_modules(fXML)
         else:
-            grass.warning(_("No addons metadata file available"))
+            grass.debug(1, "No addons metadata file available")
         return []
     # read XML file
@@ -702,8 +702,11 @@
         # create addons dir if not exists
         if not os.path.exists(options['prefix']):
-            os.mkdir(options['prefix'])
+            try:
+                os.mkdir(options['prefix'])
+            except OSError as e:
+                grass.fatal(_("Unable to create <{}>. {}").format(options['prefix'], e))
         # download data
         fo = tempfile.TemporaryFile()
         fo.write(f.read())
@@ -1043,9 +1046,10 @@
         else:
             options['prefix'] = os.environ['GRASS_ADDON_BASE']
-    if not os.access(options['prefix'], os.W_OK):
+    if os.path.exists(options['prefix']) and \
+       not os.access(options['prefix'], os.W_OK):
         grass.fatal(_("You don't have permission to install extension to <{}>. "
-                      "Try to run {} with administrator rights"
+                      "Try to run {} with administrator rights "
                       "(su or sudo).").format(options['prefix'], 'g.extension'))
     if 'svn.osgeo.org/grass/grass-addons/grass7' in options['svnurl']:
