[GRASS-SVN] r65434 - grass/trunk/vector/v.in.ascii/testsuite
svn_grass at osgeo.org
Wed Jun 10 10:00:38 PDT 2015
Author: wenzeslaus
Date: 2015-06-10 10:00:38 -0700 (Wed, 10 Jun 2015)
New Revision: 65434
grass/trunk/vector/v.in.ascii/testsuite/test_csv.py
v.in.ascii: extend test case with more characters
Modified: grass/trunk/vector/v.in.ascii/testsuite/test_csv.py
--- grass/trunk/vector/v.in.ascii/testsuite/test_csv.py 2015-06-10 13:13:36 UTC (rev 65433)
+++ grass/trunk/vector/v.in.ascii/testsuite/test_csv.py 2015-06-10 17:00:38 UTC (rev 65434)
@@ -25,6 +25,22 @@
107,450833.019732,4048207.02664,"High Erosion","Low Erosion"
+INPUT_TSV = """Id\tPOINT_X\tPOINT_Y\tCategory\t"ED field estimate"
+100\t437343.6704\t4061363.41525\t"High Erosion"\t"Low Deposition"
+101\t453643.127906\t4050070.29852\t"High Erosion"\t"Low Erosion"
+102\t454903.605427\t4049480.80568\t"High Erosion"\t"High Erosion"
+105\t437734.838807\t4060493.98315\t"High Erosion"\t"Low Erosion"
+107\t450833.019732\t4048207.02664\t"High Erosion"\t"Low Erosion"
+INPUT_UNCOMMON = """Id at POINT_X@POINT_Y at Category@^ED field estimate^
+100 at 437343.6704@4061363.41525@^High Erosion^@^Low Deposition^
+101 at 453643.127906@4050070.29852@^High Erosion^@^Low Erosion^
+102 at 454903.605427@4049480.80568@^High Erosion^@^High Erosion^
+105 at 437734.838807@4060493.98315@^High Erosion^@^Low Erosion^
+107 at 450833.019732@4048207.02664@^High Erosion^@^Low Erosion^
TABLE_1 = """cat|x|y|ed_cat|field_estimate
100|437343.6704|4061363.41525|High Erosion|Low Deposition
101|453643.127906|4050070.29852|High Erosion|Low Erosion
@@ -56,7 +72,7 @@
separator='pipe')
self.assertEqual(first=TABLE_1.replace('\n', os.linesep),
second=category,
- msg="Labels do not match")
+ msg="Attribute table has wrong entries")
def test_text_delimeter(self):
"""Test loading CSV with delimiter
@@ -65,7 +81,8 @@
self.assertModule(
'v.in.ascii', input='-', output=self.xyvector,
- separator='comma', skip=1, x=2, y=3, cat=1,
+ separator='comma', text='doublequote',
+ skip=1, x=2, y=3, cat=1,
columns="cat int, x double, y double,"
" ed_cat varchar(20), field_estimate varchar(20)",
stdin_=INPUT_DOUBLEQUOTES)
@@ -79,6 +96,41 @@
# TODO: standardize string strip? perhaps discourage, it messes up the diff
# TODO: use replace solution for newlines in lib (compare to current one)
+ def test_tsv(self):
+ """Test loading TSV (CSV with tab as delim)
+ Using double quote character for quote.
+ self.assertModule(
+ 'v.in.ascii', input='-', output=self.xyvector,
+ separator='tab', text='"',
+ columns="cat int, x double, y double,"
+ " ed_cat varchar(20), field_estimate varchar(20)",
+ stdin_=INPUT_TSV)
+ category = read_command('v.db.select', map=self.xyvector,
+ separator='pipe')
+ self.assertEqual(first=TABLE_1.replace('\n', os.linesep),
+ second=category,
+ def test_uncommon_delims(self):
+ """Test loading CSV with uncommon delimiters"""
+ separator='@', text='^',
+ stdin_=INPUT_UNCOMMON)
+ separator='pipe')
+ second=category,
if __name__ == '__main__':
test()
