[GRASS-SVN] r65441 - grass/trunk/lib/raster
Thu Jun 11 09:02:43 PDT 2015
Author: glynn
Date: 2015-06-11 09:02:43 -0700 (Thu, 11 Jun 2015)
New Revision: 65441
   grass/trunk/lib/raster/close.c
Partial revert of r65348
Modified: grass/trunk/lib/raster/close.c
--- grass/trunk/lib/raster/close.c	2015-06-11 15:03:46 UTC (rev 65440)
+++ grass/trunk/lib/raster/close.c	2015-06-11 16:02:43 UTC (rev 65441)
@@ -375,15 +375,15 @@
 	if (fcb->null_cur_row > 0) {
 	    /* if temporary NULL file exists, write it into cell_misc/name/null */
-	    if (0 != G_rename_file(fcb->null_temp_name, path)) {
-		G_warning(_("Unable to rename file <%s> to <%s>: %s"),
+	    if (rename(fcb->null_temp_name, path)) {
+		G_warning(_("Unable to rename null file '%s' to '%s': %s"),
 			  fcb->null_temp_name, path, strerror(errno));
 		stat = -1;
-            /* if rename() was successful what is left to remove() ? */
+	    /* if rename() was successful what is left to remove() ? */
 	    else {
 		remove(fcb->null_temp_name);
 	else {
@@ -450,9 +450,8 @@
     if (ok && (fcb->temp_name != NULL)) {
 	G_file_name(path, CELL_DIR, fcb->name, fcb->mapset);
 	remove(path);
-	if (G_rename_file(fcb->temp_name, path)) {
+	if (rename(fcb->temp_name, path)) {
+	    G_warning(_("Unable to rename cell file '%s' to '%s': %s"),
 		      fcb->temp_name, path, strerror(errno));
 	    stat = -1;
