[GRASS-SVN] r65442 - grass/trunk/lib/python/temporal
Thu Jun 11 12:59:17 PDT 2015
Author: huhabla
Date: 2015-06-11 12:59:17 -0700 (Thu, 11 Jun 2015)
New Revision: 65442
   grass/trunk/lib/python/temporal/core.py
Show a warning if a temporal database connection is defined, but the database file is not present
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py	2015-06-11 16:02:43 UTC (rev 65441)
+++ grass/trunk/lib/python/temporal/core.py	2015-06-11 19:59:17 UTC (rev 65442)
@@ -437,6 +437,7 @@
                   database) are the values
     global c_library_interface
+    global message_interface
     mapsets = c_library_interface.available_mapsets()
@@ -447,8 +448,18 @@
         database = c_library_interface.get_database_name(mapset)
         if driver and database:
-            tgis_mapsets[mapset] = (driver,  database)
+            # Check if the temporal sqlite database exists
+            # We need to set non-existing databases in case the mapset is the current mapset
+            # to create it
+            if (driver == "sqlite" and os.path.exists(database)) or mapset == get_current_mapset() :
+                tgis_mapsets[mapset] = (driver,  database)
+            # We need to warn if the connection is defined but the database does not
+            # exists
+            if driver == "sqlite" and not os.path.exists(database):
+                message_interface.warning("Temporal database connection defined as:\n" + \
+                                          database + "\nBut database file does not exists.")
     return tgis_mapsets
@@ -769,7 +780,7 @@
                                         "postgresql_indexes.sql"), 'r').read()
     # Connect now to the database
-    if not dbif.connected:
+    if dbif.connected is not True:
         dbif.connect()
     # Execute the SQL statements for sqlite
@@ -879,7 +890,7 @@
             driver,  dbstring = self.tgis_mapsets[mapset]
             conn = self.connections[mapset]
             if conn.is_connected() is False:
-                conn .connect(dbstring)
+                conn.connect(dbstring)
         self.connected = True
