[GRASS-SVN] r65489 - in grass/trunk: include/defs lib/raster raster/r.null raster/r.support
svn_grass at osgeo.org
Tue Jun 16 16:09:08 PDT 2015
Author: glynn
Date: 2015-06-16 16:09:08 -0700 (Tue, 16 Jun 2015)
New Revision: 65489
grass/trunk/include/defs/raster.h
grass/trunk/lib/raster/put_row.c
grass/trunk/raster/r.null/main.c
grass/trunk/raster/r.support/main.c
Clean up compressed null support
Fix r.null, r.support to handle compressed nulls
Modified: grass/trunk/include/defs/raster.h
--- grass/trunk/include/defs/raster.h 2015-06-16 21:13:31 UTC (rev 65488)
+++ grass/trunk/include/defs/raster.h 2015-06-16 23:09:08 UTC (rev 65489)
@@ -465,7 +465,7 @@
void Rast_put_c_row(int, const CELL *);
void Rast_put_f_row(int, const FCELL *);
void Rast_put_d_row(int, const DCELL *);
-void Rast__write_null_bits(int, const unsigned char *, int, int, int);
+void Rast__write_null_bits(int, const unsigned char *);
/* put_title.c */
int Rast_put_cell_title(const char *, const char *);
Modified: grass/trunk/lib/raster/put_row.c
--- grass/trunk/lib/raster/put_row.c 2015-06-16 21:13:31 UTC (rev 65488)
+++ grass/trunk/lib/raster/put_row.c 2015-06-16 23:09:08 UTC (rev 65489)
@@ -481,52 +481,42 @@
put_fp_data(fd, null_buf, rast, row, n, map_type);
-static void put_null_data(int fd, const char *flags, int row)
+static void put_null_value_row(int fd, const char *flags)
struct fileinfo *fcb = &R__.fileinfo[fd];
+ if (fcb->gdal)
+ G_fatal_error(_("GDAL output doesn't support writing null rows separately"));
if (fcb->null_fd < 0)
G_fatal_error(_("No null file for <%s>"), fcb->name);
Rast__convert_01_flags(flags, fcb->null_bits,
fcb->cellhd.cols);
- Rast__write_null_bits(fcb->null_fd, fcb->null_bits, row,
- fcb->cellhd.cols, fd);
+ Rast__write_null_bits(fd, fcb->null_bits);
-static void put_null_value_row(int fd, const char *buf)
+static void write_null_bits_compressed(const unsigned char *flags,
+ int row, size_t size, int fd)
- if (fcb->gdal)
- G_fatal_error(_("GDAL output doesn't support writing null rows separately"));
- put_null_data(fd, buf, fcb->null_cur_row);
- fcb->null_cur_row++;
-static void write_null_bits_compressed(int null_fd, const unsigned char *flags,
- int row, size_t size, int fd)
- struct fileinfo *fcb = &R__.fileinfo[fd];
unsigned char *compressed_buf;
ssize_t nwrite;
- fcb->null_row_ptr[row] = lseek(null_fd, 0L, SEEK_CUR);
+ fcb->null_row_ptr[row] = lseek(fcb->null_fd, 0L, SEEK_CUR);
compressed_buf = G_alloca(size + 1);
nwrite = G_zlib_compress(flags, size, compressed_buf, size);
if (nwrite < size) {
- if (write(null_fd, compressed_buf, nwrite) != nwrite)
+ if (write(fcb->null_fd, compressed_buf, nwrite) != nwrite)
G_fatal_error(_("Error writing compressed null data for row %d of <%s>"),
row, fcb->name);
else {
- if (write(null_fd, flags, size) != size)
+ if (write(fcb->null_fd, flags, size) != size)
row, fcb->name);
@@ -537,7 +527,6 @@
\brief Write null data
- \param null_fd file descriptor of null file where data is to be written
\param flags ?
\param row row number
\param col col number
@@ -545,26 +534,26 @@
\return void
-void Rast__write_null_bits(int null_fd, const unsigned char *flags, int row,
- int cols, int fd)
+void Rast__write_null_bits(int fd, const unsigned char *flags)
+ int row = fcb->null_cur_row++;
off_t offset;
size_t size;
- size = Rast__null_bitstream_size(cols);
+ size = Rast__null_bitstream_size(fcb->cellhd.cols);
if (fcb->null_row_ptr) {
- write_null_bits_compressed(null_fd, flags, row, size, fd);
+ write_null_bits_compressed(flags, row, size, fd);
return;
- offset = (off_t) size *row;
+ offset = (off_t) size * row;
- if (lseek(null_fd, offset, SEEK_SET) < 0)
+ if (lseek(fcb->null_fd, offset, SEEK_SET) < 0)
G_fatal_error(_("Error writing null row %d of <%s>"), row, fcb->name);
Modified: grass/trunk/raster/r.null/main.c
--- grass/trunk/raster/r.null/main.c 2015-06-16 21:13:31 UTC (rev 65488)
+++ grass/trunk/raster/r.null/main.c 2015-06-16 23:09:08 UTC (rev 65489)
@@ -31,7 +31,7 @@
const char *name, *mapset;
char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
char path[GPATH_MAX];
- int row, col, null_fd;
+ int row, col, fd;
unsigned char *null_bits;
RASTER_MAP_TYPE map_type;
int change_null = 0, create, remove, only_int, only_fp, only_null;
@@ -170,17 +170,17 @@
for (col = 0; col < Rast__null_bitstream_size(cellhd.cols); col++)
null_bits[col] = 0;
- null_fd = G_open_new_misc("cell_misc", "null", name);
+ fd = Rast__open_null_write(name);
G_verbose_message(_("Writing new null file for raster map <%s>..."),
name);
for (row = 0; row < cellhd.rows; row++) {
G_percent(row, cellhd.rows, 1);
- Rast__write_null_bits(null_fd, null_bits, row, cellhd.cols, 0);
+ Rast__write_null_bits(fd, null_bits);
- close(null_fd);
+ Rast__close_null(fd);
G_done_msg(_("Raster map <%s> modified."), name);
@@ -191,9 +191,10 @@
/* write a file of no-nulls */
G_verbose_message(_("Removing null file for raster map <%s>..."),
name);
G_file_name_misc(path, "cell_misc", "null", name, mapset);
unlink(path);
+ G_file_name_misc(path, "cell_misc", "null2", name, mapset);
+ unlink(path);
Modified: grass/trunk/raster/r.support/main.c
--- grass/trunk/raster/r.support/main.c 2015-06-16 21:13:31 UTC (rev 65488)
+++ grass/trunk/raster/r.support/main.c 2015-06-16 23:09:08 UTC (rev 65489)
@@ -271,7 +271,7 @@
if (null_flag->answer) {
int row, col;
- int null_fd;
+ int fd;
if (is_reclass)
G_fatal_error(_("[%s] is a reclass of another map. Exiting."),
@@ -283,22 +283,21 @@
null_bits[col] = 0;
/* Open null file for writing */
- null_fd = G_open_new_misc("cell_misc", "null", raster->answer);
+ fd = Rast__open_null_write(raster->answer);
G_message(_("Writing new null file for [%s]... "), raster->answer);
/* Cleanup */
- close(null_fd);
G_free(null_bits);
if (del_flag->answer) {
- int null_fd;
if (is_reclass)
@@ -308,10 +307,10 @@
/* Write a file of no-nulls */
G_message(_("Removing null file for [%s]...\n"), raster->answer);
G_file_name_misc(path, "cell_misc", "null", raster->answer, G_mapset());
unlink(path);
- close(null_fd);
+ G_file_name_misc(path, "cell_misc", "null2", raster->answer, G_mapset());
+ unlink(path);
G_done_msg(_("Done."));
