[GRASS-SVN] r65490 - in grass/trunk/raster: r.null r.support
svn_grass at osgeo.org
Tue Jun 16 16:22:34 PDT 2015
Author: glynn
Date: 2015-06-16 16:22:34 -0700 (Tue, 16 Jun 2015)
New Revision: 65490
grass/trunk/raster/r.null/main.c
grass/trunk/raster/r.support/main.c
Set window before writing null file
Add option to re-create null file to r.null
Modified: grass/trunk/raster/r.null/main.c
--- grass/trunk/raster/r.null/main.c 2015-06-16 23:09:08 UTC (rev 65489)
+++ grass/trunk/raster/r.null/main.c 2015-06-16 23:22:34 UTC (rev 65490)
@@ -34,7 +34,7 @@
int row, col, fd;
unsigned char *null_bits;
RASTER_MAP_TYPE map_type;
- int change_null = 0, create, remove, only_int, only_fp, only_null;
+ int change_null = 0, create, remove, only_int, only_fp, only_null, recreate;
int is_reclass;
struct GModule *module;
@@ -51,6 +51,7 @@
struct Flag *i;
struct Flag *c;
struct Flag *r;
+ struct Flag *z;
} flags;
G_gisinit(argv[0]);
@@ -106,6 +107,11 @@
flags.r->description = _("Remove NULL-value bitmap file");
flags.r->guisection = _("Remove");
+ flags.z = G_define_flag();
+ flags.z->key = 'z';
+ flags.z->description =
+ _("Re-create NULL-value bitmap file (to compress or uncompress)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -114,6 +120,7 @@
only_null = flags.n->answer;
create = flags.c->answer;
remove = flags.r->answer;
+ recreate = flags.z->answer;
name = parms.map->answer;
mapset = G_find_raster2(name, "");
@@ -165,11 +172,12 @@
if (create) {
/* write a file of no-nulls */
- null_bits = (unsigned char *)Rast__allocate_null_bits(cellhd.cols);
+ null_bits = Rast__allocate_null_bits(cellhd.cols);
/* init all cells to 0's */
for (col = 0; col < Rast__null_bitstream_size(cellhd.cols); col++)
null_bits[col] = 0;
+ Rast_set_window(&cellhd);
fd = Rast__open_null_write(name);
G_verbose_message(_("Writing new null file for raster map <%s>..."),
@@ -187,6 +195,32 @@
exit(EXIT_SUCCESS);
+ if (recreate) {
+ int in_fd;
+ /* write a file of no-nulls */
+ in_fd = Rast_open_old(name, mapset);
+ fd = Rast__open_null_write(name);
+ G_verbose_message(_("Writing new null file for raster map <%s>..."),
+ name);
+ for (row = 0; row < cellhd.rows; row++) {
+ G_percent(row, cellhd.rows, 1);
+ Rast_get_null_value_row(in_fd, (char*) null_bits, row);
+ Rast__write_null_bits(fd, null_bits);
+ Rast__close_null(fd);
+ Rast_close(in_fd);
+ G_done_msg(_("Raster map <%s> modified."), name);
+ exit(EXIT_SUCCESS);
if (remove) {
G_verbose_message(_("Removing null file for raster map <%s>..."),
Modified: grass/trunk/raster/r.support/main.c
--- grass/trunk/raster/r.support/main.c 2015-06-16 23:09:08 UTC (rev 65489)
+++ grass/trunk/raster/r.support/main.c 2015-06-16 23:22:34 UTC (rev 65490)
@@ -283,6 +283,7 @@
null_bits[col] = 0;
/* Open null file for writing */
fd = Rast__open_null_write(raster->answer);
G_message(_("Writing new null file for [%s]... "), raster->answer);
