[GRASS-SVN] r65503 - grass-addons/grass7/vector/v.kriging
svn_grass at osgeo.org
Sat Jun 20 04:26:07 PDT 2015
Author: evas
Date: 2015-06-20 04:26:07 -0700 (Sat, 20 Jun 2015)
New Revision: 65503
Added:
grass-addons/grass7/vector/v.kriging/spatial_index.c
v.kriging: Functions using spatial index (R-tree (GRASS GIS))
Added: grass-addons/grass7/vector/v.kriging/spatial_index.c
--- grass-addons/grass7/vector/v.kriging/spatial_index.c (rev 0)
+++ grass-addons/grass7/vector/v.kriging/spatial_index.c 2015-06-20 11:26:07 UTC (rev 65503)
@@ -0,0 +1,101 @@
+#include "local_proto.h"
+void insert_rectangle(int dim, int i, struct points *pnts)
+ struct RTree_Rect *rect; // rectangle
+ double *r; // pointer to the input coordinates
+ r = &pnts->r[3 * i];
+ switch (dim) {
+ case 3: // 3D:
+ rect = RTreeAllocRect(pnts->R_tree); // allocate the rectangle
+ RTreeSetRect3D(rect, pnts->R_tree,
+ *r, *r,
+ *(r+1), *(r+1),
+ *(r+2), *(r+2)); // set 3D coordinates
+ RTreeInsertRect(rect, i + 1, pnts->R_tree); // insert rectangle to the spatial index
+ break;
+ case 2: // 2D:
+ rect = RTreeAllocRect(pnts->Rtree_hz); // allocate the rectangle
+ RTreeSetRect2D(rect, pnts->Rtree_hz,
+ *r, *r,
+ *(r+1), *(r+1)); // set 2D coordinates
+ RTreeInsertRect(rect, i + 1, pnts->Rtree_hz); // insert rectangle to the spatial index
+ break;
+ case 1: // 1D
+ rect = RTreeAllocRect(pnts->Rtree_vert); // allocate the rectangle
+ RTreeSetRect1D(rect, pnts->Rtree_vert,
+ *(r+2), *(r+2)); // set 1D coordinates
+ RTreeInsertRect(rect, i + 1, pnts->Rtree_vert); // insert rectangle to the spatial index
+ break;
+ RTreeFreeRect(rect); // free rectangle memory
+/* find neighbors in cubic (square) surroundings */
+struct ilist *find_NNs_within(int dim, int i, struct points *pnts, double max_dist, double max_dist_vert)
+ // local variables
+ double *r; // pointer to vector of the coordinates
+ struct RTree_Rect *search; // search rectangle
+ struct ilist *list;
+ list = G_new_ilist();
+ switch (dim) {
+ case 3: // 3D:
+ search = RTreeAllocRect(pnts->R_tree); // allocate new rectangle
+ RTreeSetRect3D(search, pnts->R_tree,
+ *r - max_dist, *r + max_dist,
+ *(r+1) - max_dist, *(r+1) + max_dist,
+ *(r+2) - max_dist_vert, *(r+2) + max_dist_vert); // set up searching rectangle
+ RTreeSearch2(pnts->R_tree, search, list); // search the nearest rectangle
+ break;
+ case 2: // 2D:
+ search = RTreeAllocRect(pnts->Rtree_hz); // allocate new rectangle
+ RTreeSetRect2D(search, pnts->Rtree_hz,
+ *(r+1) - max_dist, *(r+1) + max_dist); // set up searching rectangle
+ RTreeSearch2(pnts->Rtree_hz, search, list); // search the nearest rectangle
+ break;
+ case 1: // 1D:
+ //G_debug(0, "%d %f %f", pnts->Rtree_vert->n_nodes, *(r+2), max_dist_vert);
+ search = RTreeAllocRect(pnts->Rtree_vert); // allocate new rectangle
+ RTreeSetRect1D(search, pnts->Rtree_vert,
+ RTreeSearch2(pnts->Rtree_vert, search, list); // search the nearest rectangle
+ break;
+ RTreeFreeRect(search);
+ return list;
+/* find neighbors in spherical (circular) surroundings */
+struct ilist *find_n_NNs(int dim, int i, struct points *pnts, int n)
+ double max_dist0 = pnts->max_dist; // initial maximum distance
+ struct ilist *list; // list of selected rectangles (points)
+ int n_vals = 0; // # of the nearest neighbours (NN)
+ int iter = 1; // iteration number (searching NN)
+ double max_dist = max_dist0; // iterated search radius
+ while (n_vals < n) { // until some NN is found (2 points: identical and NN)
+ list = find_NNs_within(dim, i, pnts, max_dist, -1);
+ n_vals = list->n_values; // set up control variable
+ if (n_vals < n) {
+ iter += 1; // go to the next iteration
+ max_dist = iter * max_dist0; // enlarge search radius
+ // check spherical (circular) surrounding
+ list = find_NNs_within(dim, i, pnts, sqrt(2.) * max_dist, -1);
+ return list;
