[GRASS-SVN] r64875 - in grass-addons/grass7/raster: . r.divergence
svn_grass at osgeo.org
Mon Mar 16 08:30:32 PDT 2015
Author: annakrat
Date: 2015-03-16 08:30:32 -0700 (Mon, 16 Mar 2015)
New Revision: 64875
Added:
grass-addons/grass7/raster/r.divergence/
grass-addons/grass7/raster/r.divergence/Makefile
grass-addons/grass7/raster/r.divergence/r.divergence.html
grass-addons/grass7/raster/r.divergence/r.divergence.py
grass-addons/grass7/raster/Makefile
added r.divergence addon to simplify USPED computation
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile 2015-03-16 14:31:25 UTC (rev 64874)
+++ grass-addons/grass7/raster/Makefile 2015-03-16 15:30:32 UTC (rev 64875)
@@ -22,6 +22,7 @@
r.convergence \
r.crater \
r.damflood \
+ r.divergence \
r.diversity \
r.droka \
r.edm.eval \
Added: grass-addons/grass7/raster/r.divergence/Makefile
--- grass-addons/grass7/raster/r.divergence/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.divergence/Makefile 2015-03-16 15:30:32 UTC (rev 64875)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.divergence
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.divergence/r.divergence.html
--- grass-addons/grass7/raster/r.divergence/r.divergence.html (rev 0)
+++ grass-addons/grass7/raster/r.divergence/r.divergence.html 2015-03-16 15:30:32 UTC (rev 64875)
@@ -0,0 +1,20 @@
+<h2>DESCRIPTION</h2>
+Module <em>r.divergence</em> computes the divergence of a vector field
+given by <b>magnitude</b> and <b>direction</b> raster maps.
+Direction is in degrees counterclockwise from the east
+and can be computed using <em><a href="r.slope.aspect.html">r.slope.aspect</a></em>.
+<h2>EXAMPLES</h2>
+TBD
+<h2>SEE ALSO</h2>
+<em><a href="r.slope.aspect.html">r.slope.aspect</a></em>
+<h2>AUTHOR</h2>
+Anna Petrasova, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU OSGeoREL</a><br>
+Helena Mitasova, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU OSGeoREL</a>
+<p><i>Last changed: $Date: 2015-02-12 14:32:45 -0500 (Thu, 12 Feb 2015) $</i>
Added: grass-addons/grass7/raster/r.divergence/r.divergence.py
--- grass-addons/grass7/raster/r.divergence/r.divergence.py (rev 0)
+++ grass-addons/grass7/raster/r.divergence/r.divergence.py 2015-03-16 15:30:32 UTC (rev 64875)
@@ -0,0 +1,103 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: r.divergence
+# AUTHOR(S): Anna Petrasova (kratochanna gmail.com)
+# PURPOSE: Implementation of divergence of field
+# COPYRIGHT: (C) 2015 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Computes divergence of a vector field defined by magnitude and direction
+#% keyword: raster
+#% keyword: divergence
+#%end
+#%option G_OPT_R_INPUT
+#% key: magnitude
+#% description: Name of input raster map representing magnitude
+#%end
+#% label: Name of input raster map representing direction
+#% description: Direction is in degrees ccw from the east
+#% key: direction
+#%end
+#%option G_OPT_R_OUTPUT
+#% description: Name of output divergence raster
+#%end
+import sys
+import os
+import atexit
+from grass.exceptions import CalledModuleError
+import grass.script.core as gcore
+import grass.script.raster as grast
+TMP = []
+CLEANUP = True
+def cleanup():
+ if CLEANUP:
+ gcore.run_command('g.remove', flags='f', type='raster', name=TMP)
+def main():
+ magnitude = options['magnitude']
+ direction = options['direction']
+ divergence = options['output']
+ global TMP, CLEANUP
+ tmp_name = 'tmp_divergence_' + str(os.getpid())
+ qsx = tmp_name + "qsx"
+ qsy = tmp_name + "qsy"
+ qsx_dx = tmp_name + "qsx_dx"
+ qsy_dy = tmp_name + "qsy_dy"
+ TMP.extend([qsx, qsy, qsx_dx, qsy_dy])
+ # checks if there are already some maps
+ old_maps = temp_maps_exist()
+ if old_maps:
+ if not gcore.overwrite():
+ CLEANUP = False
+ gcore.fatal(_("You have to first check overwrite flag or remove"
+ " the following maps:\n"
+ "names}").format(names=','.join(old_maps)))
+ else:
+ gcore.warning(_("The following maps will be overwritten: {names}"
+ ).format(names=','.join(old_maps)))
+ try:
+ grast.mapcalc(exp="{qsx}={mag} * cos({direct})".format(qsx=qsx, mag=magnitude, direct=direction))
+ grast.mapcalc(exp="{qsy}={mag} * sin({direct})".format(qsy=qsy, mag=magnitude, direct=direction))
+ gcore.run_command('r.slope.aspect', elevation=qsx, dx=qsx_dx)
+ gcore.run_command('r.slope.aspect', elevation=qsy, dy=qsy_dy)
+ grast.mapcalc(exp="{div}={qsx_dx} + {qsy_dy}".format(div=divergence, qsx_dx=qsx_dx, qsy_dy=qsy_dy))
+ except CalledModuleError:
+ gcore.fatal(_("r.divergence failed, check errors above. Please report this problem to developers."))
+ return 1
+ grast.raster_history(divergence)
+ return 0
+def temp_maps_exist():
+ maps = gcore.list_grouped('raster')[gcore.gisenv()['MAPSET']]
+ return [x for x in TMP if x in maps]
+if __name__ == "__main__":
+ options, flags = gcore.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
