[GRASS-SVN] r64933 - grass-addons/grass7/gui/wxpython/wx.mwprecip
svn_grass at osgeo.org
Mon Mar 30 08:02:42 PDT 2015
Author: krejcmat
Date: 2015-03-30 08:02:42 -0700 (Mon, 30 Mar 2015)
New Revision: 64933
grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py
open file Win
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-03-30 13:27:39 UTC (rev 64932)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-03-30 15:02:42 UTC (rev 64933)
@@ -42,22 +42,30 @@
self.SetSizerAndFit(panelSizer)
+ def getSettVal(self,key):
+ if self.settings[key] is not None:
+ return self.settings[key]
+ if self.settings[key] is not 'None':
+ if self.settings[key] is not'':
def loadSettings(self, sett=None):
if sett:
self.settings = sett
if 'database' in self.settings:
- self.database.SetValue(self.settings['database'])
+ self.database.SetValue(self.getSettVal('database'))
if 'schema' in self.settings:
- self.schema.SetValue(self.settings['schema'])
+ self.schema.SetValue(self.getSettVal('schema'))
if 'host' in self.settings:
- self.host.SetValue(self.settings['host'])
+ self.host.SetValue(self.getSettVal('host'))
if 'user' in self.settings:
- self.user.SetValue(self.settings['user'])
+ self.user.SetValue(self.getSettVal('user'))
if 'port' in self.settings:
- self.port.SetValue(self.settings['port'])
+ self.port.SetValue(self.getSettVal('port'))
if 'passwd' in self.settings:
- self.passwd.SetValue(self.settings['passwd'])
+ self.passwd.SetValue(self.getSettVal('passwd'))
def saveSettings(self, settings=None):
if settings is not None:
@@ -84,7 +92,6 @@
self.val = BaseInput(self, label='Value')
panelSizer = wx.BoxSizer(wx.VERTICAL)
panelSizer.Add(self.interpolState, flag=wx.EXPAND)
panelSizer.Add(self.rb1, flag=wx.EXPAND)
panelSizer.Add(self.rb2, flag=wx.EXPAND)
@@ -132,7 +139,6 @@
self.aw = BaseInput(self, 'Antena wetting value')
self.dryInterval = TextInput(self, 'Set interval of dry period')
self.fromFileVal = TextInput(self, 'Set baseline values in csv format')
- # self.SLpanel = SaveLoad(self)
self.okBtt = wx.Button(self, wx.ID_OK, label='ok and close')
self.onChangeMethod(None)
self.fromFile.Bind(wx.EVT_RADIOBUTTON, self.onChangeMethod)
@@ -292,6 +298,7 @@
self.mapLabel.Hide()
self.map.Hide()
self.Fit()
+ self.Parent.Fit()
def saveSettings(self, evt=None, sett=None):
if sett:
@@ -326,7 +333,6 @@
if 'inpRainGauge' in self.settings:
self.inpRainGauge.SetPath(self.settings['inpRainGauge'])
def _layout(self):
@@ -341,7 +347,7 @@
stBoxSizerTWIN.Add(linksSizer, flag=wx.EXPAND, proportion=1)
stBoxSizerTWIN.Add(self.links, flag=wx.EXPAND, proportion=1)
stBoxSizerTWIN.Add(self.mapLabel, flag=wx.EXPAND)
- stBoxSizerTWIN.Add(self.map, flag=wx.EXPAND)
+ stBoxSizerTWIN.Add(self.map, flag=wx.EXPAND,proportion=1)
stBoxSizerTWIN.AddSpacer(5, 5, 1, wx.EXPAND)
stBoxSizerTWIN.Add(self.start, flag=wx.EXPAND, proportion=1)
@@ -362,8 +368,6 @@
panelSizer.Add(stBoxSizerTWIN, flag=wx.EXPAND)
panelSizer.Add(stBoxSizerRGAUGE, flag=wx.EXPAND)
- # panelSizer.Add(self.exportDataBtt, flag=wx.EXPAND)
- # panelSizer.Add(self.computeBtt, flag=wx.EXPAND)
self.refreshLinkSet()
@@ -465,12 +469,14 @@
class MyFrame(wx.Frame):
def __init__(self, parent, id, title):
- wx.Frame.__init__(self, parent, id, title, size=(480, 640))
+ wx.Frame.__init__(self, parent, id, title, size=(480, 640),style=wx.DEFAULT_FRAME_STYLE ^ wx.RESIZE_BORDER)
self.workPath = os.path.dirname(os.path.realpath(__file__))
self.initWorkingFoldrs()
self.settings = {}
self.settingsLst = []
self.mainSizer = wx.BoxSizer(wx.VERTICAL)
+ self.panelSizer = wx.BoxSizer(wx.VERTICAL)
+ self.mainPanel = wx.Panel(self,id=wx.ID_ANY)
menubar = wx.MenuBar()
settMenu = wx.Menu()
@@ -481,11 +487,6 @@
quitItem = settMenu.Append(wx.ID_EXIT, 'Quit', 'Quit application')
menubar.Append(settMenu, '&Options')
- # geoMenu = wx.Menu()
- #menubar.Append(geoMenu, '&Settings')
self.SetMenuBar(menubar)
self.Bind(wx.EVT_MENU, self.onQuit, quitItem)
self.Bind(wx.EVT_MENU, self.onSetDatabase, databaseItem)
@@ -494,7 +495,7 @@
#def initNotebook(self):
- self.ntb = wx.Notebook(self, id=wx.ID_ANY)
+ self.ntb = wx.Notebook(self.mainPanel, id=wx.ID_ANY)
self.dataMgrMW = DataMgrMW(self.ntb)
self.dataMgrMW.getEndBtt.Bind(wx.EVT_BUTTON, self.getMaxTime)
self.dataMgrMW.getStartBtt.Bind(wx.EVT_BUTTON, self.getMinTime)
@@ -509,18 +510,18 @@
self.ntb.AddPage(page=self.grassLayers, text='Layers')
#def initProfileSett(self):
- self.loadScheme = wx.StaticText(self, label='Load settings', id=wx.ID_ANY)
- self.profilSelection = wx.ComboBox(self)
- self.schema = BaseInput(self, 'Name of new working profile')
+ self.loadScheme = wx.StaticText(self.mainPanel, label='Load settings', id=wx.ID_ANY)
+ self.profilSelection = wx.ComboBox(self.mainPanel)
+ self.schema = BaseInput(self.mainPanel, 'Name of new working profile')
self.schema.text.Bind(wx.EVT_TEXT, self.OnSchemeTxtChange)
- self.newScheme = wx.Button(self, label='Save new profile')
+ self.newScheme = wx.Button(self.mainPanel, label='Save new profile')
self.newScheme.Bind(wx.EVT_BUTTON, self.OnSaveSettings)
self.newScheme.Disable()
self.profilSelection.Bind(wx.EVT_COMBOBOX, self.OnLoadSettings)
#def initRunBtt(self):
- self.computeBtt = wx.Button(self, label='Compute')
- self.exportDataBtt = wx.Button(self, label='Export data')
+ self.computeBtt = wx.Button(self.mainPanel, label='Compute')
+ self.exportDataBtt = wx.Button(self.mainPanel, label='Export data')
self.computeBtt.Bind(wx.EVT_BUTTON, self.runCompute)
self.exportDataBtt.Bind(wx.EVT_BUTTON, self.exportData)
@@ -732,7 +733,6 @@
interface.initVectorGrass(type=type, name=name)
def exportData(self, evt):
self.exportDialog = wx.Dialog(self, id=wx.ID_ANY,
title='Database connection settings',
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
@@ -802,7 +802,7 @@
lines += str(r)[1:][:-1].replace('datetime.datetime', '').replace("'", "") + '\n'
print conn.pathworkSchemaDir
#path=os.path.join(conn.pathworkSchemaDir, "export")
- io0 = open(path, "wr")
+ io0 = open(path, "w+")
io0.writelines(lines)
io0.close()
GMessage('Data exported<%s>' % path)
@@ -832,7 +832,7 @@
lines += str(r)[1:][:-1] + '\n'
io0.close()
@@ -862,21 +862,24 @@
interface.doCompute()
def layout(self):
- self.mainSizer.Add(self.loadScheme, flag=wx.EXPAND)
- self.mainSizer.Add(self.profilSelection, flag=wx.EXPAND)
- self.mainSizer.Add(self.schema, flag=wx.EXPAND)
- self.mainSizer.Add(self.newScheme, flag=wx.EXPAND)
- self.mainSizer.AddSpacer(10, 0, wx.EXPAND)
- self.mainSizer.Add(self.ntb, flag=wx.EXPAND)
+ self.panelSizer.Add(self.loadScheme, flag=wx.EXPAND)
+ self.panelSizer.Add(self.profilSelection, flag=wx.EXPAND)
+ self.panelSizer.Add(self.schema, flag=wx.EXPAND)
+ self.panelSizer.Add(self.newScheme, flag=wx.EXPAND)
- self.mainSizer.Add(self.computeBtt, flag=wx.EXPAND)
- self.mainSizer.Add(self.exportDataBtt, flag=wx.EXPAND)
+ self.panelSizer.AddSpacer(10, 0, wx.EXPAND)
+ self.panelSizer.Add(self.ntb, flag=wx.EXPAND)
- self.SetSizer(self.mainSizer)
- # self.Fit()
+ self.panelSizer.Add(self.computeBtt, flag=wx.EXPAND)
+ self.panelSizer.Add(self.exportDataBtt, flag=wx.EXPAND)
+ self.mainSizer.Add(self.mainPanel,flag=wx.EXPAND)
+ self.mainPanel.SetSizerAndFit(self.panelSizer)
+ self.SetSizerAndFit(self.mainSizer)
+ self.Fit()
def onQuit(self, e):
self.Close()
@@ -1028,6 +1031,7 @@
GMessage(msg)
#self.initgrassManagement()
def initGrassLayerMgr(self):
grassLayerMgr = {}
if 'colorRules' in self.settings:
@@ -1039,7 +1043,6 @@
grassLayerMgr['database'] = self.dbConn
GrassLayerMgr(**grassLayerMgr)
def initTemporalMgr(self):
GrassTemporalMgr(self.dbConn, self.twin)
GMessage('Finish')
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-03-30 13:27:39 UTC (rev 64932)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-03-30 15:02:42 UTC (rev 64933)
@@ -275,7 +275,7 @@
# write list of string to database
try:
- with open(os.path.join(self.schemaPath, gaugeTMPfile), 'wr') as io:
+ with open(os.path.join(self.schemaPath, gaugeTMPfile), 'w+') as io:
io.writelines(tmp)
io.close()
except IOError as (errno, strerror):
@@ -599,8 +599,11 @@
def chckTimeValidity(tIn):
# print tIn
tIn = str(tIn).replace("\n", "")
- tIn = datetime.strptime(tIn, "%Y-%m-%d %H:%M:%S")
+ try:
+ tIn = datetime.strptime(tIn, "%Y-%m-%d %H:%M:%S")
+ except ValueError:
+ grass.message('Wrong datetime format')
+ return False
if tIn > tMax or tIn < tMin:
return False
return True
@@ -661,8 +664,11 @@
if not isTimeValid(time):
grass.warning("Input data are not valid. Parameter 'baselitime'")
return False
- time = datetime.strptime(time, "%Y-%m-%d %H:%M:%S")
+ try:
+ time = datetime.strptime(time, "%Y-%m-%d %H:%M:%S")
+ return False
st += str(time).replace("\n", "")
fromt = time + timedelta(seconds=-60)
if not chckTimeValidity(fromt):
@@ -706,7 +712,7 @@
break
#write values to baseline file
- writer = csv.writer(open(os.path.join(database.pathworkSchemaDir, 'baseline'), 'wr'))
+ writer = csv.writer(open(os.path.join(database.pathworkSchemaDir, 'baseline'), 'w+'))
for key, value in mydict1.items():
writer.writerow([key, value])
@@ -745,7 +751,11 @@
return False
+ try:
+ return False
@@ -1315,9 +1325,9 @@
else:
self.grassConnection()
self.grassTemporalConnection('postgres')
- self.firstPreparation()
- self.prepareDB()
- self.prepareDir()
+ #self.firstPreparation()
+ #self.prepareDB()
+ #self.prepareDir()
def minTimestamp(self):
sql = "SELECT min(time) FROM %s.%s" % (self.dataSchema, self.recordTableName)
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py 2015-03-30 13:27:39 UTC (rev 64932)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py 2015-03-30 15:02:42 UTC (rev 64933)
@@ -481,7 +481,7 @@
data_list = open(old_file, 'r').readlines()
temp_list = data_list[0:start]
temp_list[len(temp_list):] = data_list[end:len(data_list)]
- open(new_file, 'wr').writelines(temp_list)
+ open(new_file, 'w+').writelines(temp_list)
def OnSaveAs(parent):
