[GRASS-SVN] r64934 - grass-addons/grass7/gui/wxpython/wx.mwprecip
svn_grass at osgeo.org
Mon Mar 30 08:20:18 PDT 2015
Author: krejcmat
Date: 2015-03-30 08:20:18 -0700 (Mon, 30 Mar 2015)
New Revision: 64934
grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
open file Win fix
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-03-30 15:02:42 UTC (rev 64933)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-03-30 15:20:18 UTC (rev 64934)
@@ -2,14 +2,13 @@
import os
import sys
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'g.gui.mwprecip'))
from mw_util import *
from mw3 import *
+sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'g.gui.mwprecip'))
from core.gcmd import GMessage, GError
from gui_core import gselect
class DBconn(wx.Panel):
def __init__(self, parent, settings={}):
wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-03-30 15:02:42 UTC (rev 64933)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-03-30 15:20:18 UTC (rev 64934)
@@ -218,7 +218,7 @@
def grass_vinASCII(self, asciiStr, outMapName):
currDir = os.path.dirname(os.path.realpath(__file__))
tmpFile = os.path.join(currDir, 'tmp')
- f = open(tmpFile, 'w')
+ f = open(tmpFile, 'w+')
f.write(asciiStr)
f.close()
grass.run_command('v.in.ascii',
@@ -507,7 +507,7 @@
else:
TMPname = 'g_timewindow'
try:
- io2 = open(os.path.join(self.path, TMPname), "wr")
+ io2 = open(os.path.join(self.path, TMPname), 'w+')
io2.writelines(nameList)
io2.close()
except IOError as (errno, strerror):
@@ -518,7 +518,7 @@
self.timestamp_max).replace(' ', '_')
try:
self.temporalRegPath = os.path.join(self.path, filename)
- io4 = open(self.temporalRegPath, "wr")
+ io4 = open(self.temporalRegPath, 'w+')
io4.writelines(tgrass_vector)
io4.close()
@@ -587,11 +587,11 @@
sql = "DROP TABLE %s.tempround" % database.schema
database.connection.executeSql(sql, False, True)
- io0 = open(os.path.join(database.pathworkSchemaDir, "baseline"), "wr")
+ io0 = open(os.path.join(database.pathworkSchemaDir, "baseline"), 'w+')
io0.writelines(tmp)
io0.close()
- # io1 = open(os.path.join(database.pathworkSchemaDir, "compute_precip_info"), "wr")
+ # io1 = open(os.path.join(database.pathworkSchemaDir, "compute_precip_info"), 'w+')
# io1.write('mode|' + str(baseline.aw))
# io1.close
@@ -776,7 +776,7 @@
#write values to flat file
- io = open(os.path.join(database.pathworkSchemaDir, "mode_tmp"), "wr")
+ io = open(os.path.join(database.pathworkSchemaDir, "mode_tmp"), 'w+')
c = 0
for it in tmp:
for i in it:
@@ -807,7 +807,7 @@
#write unique mark to file
- io1 = open(os.path.join(database.pathworkSchemaDir, "compute_precip_info"), "wr")
+ io1 = open(os.path.join(database.pathworkSchemaDir, "compute_precip_info"), 'w+')
st = st + '|' + str(baseline.aw)
io1.write(st)
io1.close
@@ -835,11 +835,11 @@
resu = resu[0][0]
tmp.append(str(linkid) + ',' + str(resu) + '\n')
io0.writelines(tmp)
io0.close()
io1.write('quantile' + str(baseline.quantile) + '|' + str(baseline.aw))
io1.close
@@ -1003,7 +1003,7 @@
# write values to flat file
# print temp
pathExp = os.path.join(self.database.pathworkSchemaDir, "precip")
- io = open(pathExp, "wr")
+ io = open(pathExp, 'w+')
io.writelines(temp)
io.close()
#if getData:
@@ -1275,7 +1275,7 @@
timeOfLay += timedelta(seconds=self.timeWinConf.intervalStr)
regTMP += mapsName + '|' + str(timeOfLay) + '\n'
- io1 = open(regFilePath, "wr")
+ io1 = open(regFilePath, 'w+')
io1.writelines(regTMP), io1.close
io1.close()
print 'datasetName', self.datasetName
