[GRASS-SVN] r65195 - grass/trunk/lib/gis
Tue May 5 03:36:02 PDT 2015
Author: martinl
Date: 2015-05-05 03:36:01 -0700 (Tue, 05 May 2015)
New Revision: 65195
Removed:
   grass/trunk/lib/gis/local_proto.h
   grass/trunk/lib/gis/error.c
   grass/trunk/lib/gis/get_window.c
   grass/trunk/lib/gis/gis_local_proto.h
   grass/trunk/lib/gis/gisinit.c
   grass/trunk/lib/gis/home.c
   grass/trunk/lib/gis/mapset_nme.c
   grass/trunk/lib/gis/open.c
   grass/trunk/lib/gis/open_misc.c
   grass/trunk/lib/gis/put_window.c
   grass/trunk/lib/gis/rd_cellhd.c
   grass/trunk/lib/gis/set_window.c
   grass/trunk/lib/gis/tempfile.c
libgis: merge local_proto.h with gis_local_proto.h
Modified: grass/trunk/lib/gis/error.c
--- grass/trunk/lib/gis/error.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/error.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -22,7 +22,7 @@
 #include <grass/glocale.h>
 #include <grass/gis.h>
-#include "local_proto.h"
+#include "gis_local_proto.h"
  * \def MSG
Modified: grass/trunk/lib/gis/get_window.c
--- grass/trunk/lib/gis/get_window.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/get_window.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -17,7 +17,7 @@
 #include "G.h"
 static struct state {
     int initialized;
Modified: grass/trunk/lib/gis/gis_local_proto.h
--- grass/trunk/lib/gis/gis_local_proto.h	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/gis_local_proto.h	2015-05-05 10:36:01 UTC (rev 65195)
@@ -2,13 +2,34 @@
 #define __GIS_LOCAL_PROTO_H__
 /* subroutines used only by GIS Library */
-/* TODO: move other G__*() subroutines here */
+/* env.c */
+void G__read_env(void);
+void G__write_env(void);
+/* gisinit.c */
+void G__check_gisinit(void);
+/* handler.c */
+void G__call_error_handlers(void);
+/* home.c */
+const char *G__home(void);
 /* location.c */
 char *G__location_path(void);
+/* mach_name.c */
+const char *G__machine_name(void);
 /* mapset.c */
 const char *G__mapset(void);
 char *G__mapset_path(void);
+/* mapset_nme.c */
+void G__get_list_of_mapsets(void);
+/* timestamp.c */
+int G__read_timestamp(FILE *, struct TimeStamp *);
 #endif
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/gisinit.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -24,7 +24,7 @@
 #include "G.h"
 struct G__ G__;
Modified: grass/trunk/lib/gis/home.c
--- grass/trunk/lib/gis/home.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/home.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -16,7 +16,7 @@
  * \brief Get user's home directory
Deleted: grass/trunk/lib/gis/local_proto.h
--- grass/trunk/lib/gis/local_proto.h	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/local_proto.h	2015-05-05 10:36:01 UTC (rev 65195)
@@ -1,26 +0,0 @@
-#ifndef __LOCAL_PROTO_H__
-#define __LOCAL_PROTO_H__
-/* env.c */
-void G__read_env(void);
-void G__write_env(void);
-/* gisinit.c */
-void G__check_gisinit(void);
-/* handler.c */
-void G__call_error_handlers(void);
-/* home.c */
-const char *G__home(void);
-/* mach_name.c */
-const char *G__machine_name(void);
-/* mapset_nme.c */
-void G__get_list_of_mapsets(void);
-/* timestamp.c */
-int G__read_timestamp(FILE *, struct TimeStamp *);
-#endif /* LOCAL_PROTO_H__ */
Modified: grass/trunk/lib/gis/mapset_nme.c
--- grass/trunk/lib/gis/mapset_nme.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/mapset_nme.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -17,7 +17,7 @@
 #include <unistd.h>
     struct list {
Modified: grass/trunk/lib/gis/open.c
--- grass/trunk/lib/gis/open.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/open.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -22,7 +22,7 @@
   \brief Lowest level open routine.
Modified: grass/trunk/lib/gis/open_misc.c
--- grass/trunk/lib/gis/open_misc.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/open_misc.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -29,7 +29,7 @@
 static int G__open_misc(const char *dir,
 			const char *element,
Modified: grass/trunk/lib/gis/put_window.c
--- grass/trunk/lib/gis/put_window.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/put_window.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -14,7 +14,7 @@
 #include <stdlib.h>
  * \brief Writes the region (window)
Modified: grass/trunk/lib/gis/rd_cellhd.c
--- grass/trunk/lib/gis/rd_cellhd.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/rd_cellhd.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -16,7 +16,7 @@
 static int scan_item(const char *, char *, char *);
 static int scan_int(const char *, int *);
Modified: grass/trunk/lib/gis/set_window.c
--- grass/trunk/lib/gis/set_window.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/set_window.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -16,7 +16,7 @@
 #include "G.h"
   \brief Get the current working window (region)
Modified: grass/trunk/lib/gis/tempfile.c
--- grass/trunk/lib/gis/tempfile.c	2015-05-05 08:30:59 UTC (rev 65194)
+++ grass/trunk/lib/gis/tempfile.c	2015-05-05 10:36:01 UTC (rev 65195)
@@ -16,7 +16,7 @@
 #include <sys/stat.h>
 static struct Counter unique;
 static int initialized;
