[GRASS-SVN] r65196 - grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic
svn_grass at osgeo.org
Fri May 8 02:44:57 PDT 2015
Author: osfraid
Date: 2015-05-08 02:44:57 -0700 (Fri, 08 May 2015)
New Revision: 65196
grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic/r.green.biomassfor.economic.py
new version of economic
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic/r.green.biomassfor.economic.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic/r.green.biomassfor.economic.py 2015-05-05 10:36:01 UTC (rev 65195)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic/r.green.biomassfor.economic.py 2015-05-08 09:44:57 UTC (rev 65196)
@@ -21,22 +21,33 @@
#% description: Estimates bioenergy that can be collected to supply heating plants or biomass logistic centres and that is associated with a positive net revenue for the entire production process
#% keyword: raster
#% keyword: biomass
+#% overwrite: yes
#%End
+#%option G_OPT_V_INPUT
+#% key: forest
+#% type: string
+#% description: Name of vector parcel map
+#% label: Name of vector parcel map
+#% required : yes
+#%end
+#% key: boundaries
+#% type: string
+#% description: Name of vector boundaries map (boolean map)
+#% label: Name of vector boundaries map (boolean map)
+#% required : yes
+#%end
#%option
-#% key: field_prefix
+#% key: forest_column_price
#% type: string
-#% description: Prefix for forest type yield fields (prefix_voltypx)
-#% key_desc : name
+#% description: Vector field of wood typologies
#% required : yes
-#% guisection: Base
#%end
-#%option
-#% key: prices
-#% type: double
-#% multiple: yes
-#% description: Market price for a-th assortment €/m³
-#% required : no
-#% guisection: Prices
+#%option
+#% key: conditions
+#% type: string
+#% description: List of wood assorments:price
+#% required : yes
#%end
#%option
#% key: output_basename
@@ -45,121 +56,106 @@
#% gisprompt: new
#% key_desc : name
#% required : yes
#%end
#% key: dhp
#% type: string
#% description: Name of vector district heating points
#% label: Name of vector district heating points
-#% required : no
+#% required : yes
#%end
-#%option G_OPT_R_INPUT
-#% key: yield1
+#%option
+#% key: forest_column_yield
#% type: string
-#% description: Map of forest yield (cubic meters)
+#% description: Vector field of yield
#% required : yes
#%end
-#% key: yield_surface
+#%option
+#% key: forest_column_yield_surface
#% type: string
-#% description: Map of stand surface (ha)
+#% description: Vector field of stand surface (ha)
#% required : yes
#%end
-#% key: management
+#%option
+#% key: forest_column_management
#% type: string
-#% description: Map of forest management (1: high forest, 2:coppice)
+#% description: Vector field of forest management (1: high forest, 2:coppice)
#% required : yes
#%end
-#% key: treatment
+#%option
+#% key: forest_column_treatment
#% type: string
-#% description: Map of forest treatment (1: final felling, 2:thinning)
+#% description: Vector field of forest treatment (1: final felling, 2:thinning)
#% required : yes
#%end
#% key: forest_roads
#% type: string
-#% description: Raster map of forest roads (0, 1)
+#% description: Vector map of forest roads
+#% label: Vector map of forest roads
#% required : yes
#%end
#% key: main_roads
#% type: string
-#% description: Raster map of main roads (0, 1)
+#% description: Vector map of main roads
+#% label: Vector map of main roads
#% required : yes
#%end
#% key: dtm2
#% type: string
#% description: Name of Digital terrain model map
#% required : yes
#%end
#% key: soilp2_map
#% type: string
#% description: Soil production map
-#% required : no
#% guisection: Opt files
+#% required : no
#%end
#% key: tree_diam
#% type: string
#% description: Average tree diameter map
-#% required : no
+#% required : no
#%end
#% key: tree_vol
#% type: string
#% description: Average tree volume map
-#% required : no
+#% required : no
#%end
#% key: rivers
#% type: string
-#% description: Raster map of rivers (0, 1)
-#% required : no
+#% description: Vector map of rivers
+#% label: Vector map of rivers
+#% required : no
#%end
#% key: lakes
#% type: string
-#% description: Raster map of lakes (0, 1)
-#% required : no
+#% description: Vector map of lakes
+#% label: Vector map of lakes
+#% required : no
#%end
-#% key: roughness
+#%option
+#% key: forest_column_roughness
#% type: string
-#% description: Name of roughness map
-#% required : no
+#% description: Vector field of roughness
#%end
-#%option G_OPT_V_INPUT
-#% key: forest
-#% type: string
-#% description: Name of vector parcel map
-#% label: Name of vector parcel map
-#% required : yes
-#%end
#%option
#% key: slp_min_cc
#% type: double
#% description: Percent slope lower limit with Cable Crane
#% answer: 30.
-#% required : no
#% guisection: Technical data
#%end
#%option
@@ -167,7 +163,6 @@
#% type: double
#% description: Percent slope higher limit with Cable Crane
#% answer: 100.
-#% required : no
#%end
#%option
@@ -175,7 +170,6 @@
#% type: double
#% description: Maximum distance with Cable Crane
#% answer: 800.
-#% required : no
#%end
#%option
@@ -183,7 +177,6 @@
#% type: double
#% description: Percent slope higher limit with Forwarder
#% answer: 30.
-#% required : no
#%end
#%option
@@ -191,7 +184,6 @@
#% type: double
#% description: Maximum distance with Forwarder
#% answer: 600.
-#% required : no
#%end
#%option
@@ -199,7 +191,6 @@
#% type: double
#% description: Percent slope higher limit with other techniques for Coppices
#% answer: 30.
-#% required : no
#%end
#%option
@@ -207,7 +198,6 @@
#% type: double
#% description: Maximum distance with other techniques for Coppices
#% answer: 600.
-#% required : no
#%end
#%option
@@ -215,7 +205,6 @@
#% type: double
#% description: Price for energy from woodchips €/MWh
#% answer: 19.50
-#% required : no
#%end
#%option
@@ -223,7 +212,6 @@
#% type: double
#% description: Felling and/or felling-processing cost with chainsaw €/h
#% answer: 13.17
-#% required : no
#% guisection: Costs
#%end
#%option
@@ -231,7 +219,6 @@
#% type: double
#% description: Processing cost with processor €/h
#% answer: 87.42
-#% required : no
#%end
#%option
@@ -239,7 +226,6 @@
#% type: double
#% description: Felling and processing cost with harvester €/h
#% answer: 96.33
-#% required : no
#%end
#%option
@@ -247,7 +233,6 @@
#% type: double
#% description: Extraction cost with high power cable crane €/h
#% answer: 111.44
-#% required : no
#%end
#%option
@@ -255,7 +240,6 @@
#% type: double
#% description: Extraction cost with medium power cable crane €/h
#% answer: 104.31
-#% required : no
#%end
#%option
@@ -263,7 +247,6 @@
#% type: double
#% description: Extraction cost with forwarder €/h
#% answer: 70.70
-#% required : no
#%end
#%option
@@ -271,7 +254,6 @@
#% type: double
#% description: Extraction cost with skidder €/h
#% answer: 64.36
-#% required : no
#%end
#%option
@@ -279,7 +261,6 @@
#% type: double
#% description: Chipping cost €/h
#% answer: 150.87
-#% required : no
#%end
#%option
@@ -287,7 +268,6 @@
#% type: double
#% description: Transport with truck €/h
#% answer: 64.90
-#% required : no
#%end
#%option
@@ -295,7 +275,6 @@
#% type: double
#% description: Energy for tops and branches in high forest in MWh/m³
#% answer: 0.49
-#% required : no
#% guisection: Energy
#%end
#%option
@@ -303,7 +282,6 @@
#% type: double
#% description: Energy for the whole tree in high forest (tops, branches and stem) in MWh/m³
#% answer: 1.97
-#% required : no
#%end
#%option
@@ -311,48 +289,30 @@
#% type: double
#% description: Energy for tops and branches for Coppices in MWh/m³
#% answer: 0.55
-#% required : no
#%end
#%flag
#% key: r
#% description: Remove all operational maps
#%end
-#%flag
-#% key: x
-#% description: Raster wood typologies ready to import (prefix_voltypx)
-#%end
import grass.script as grass
from grass.script.core import run_command, parser,overwrite
from grass.pygrass.raster import RasterRow
import numpy as np
-import pdb
+import ipdb
import string
ow = overwrite()
-def import_map(opts, flgs,forest):
- prf_yield = opts['field_prefix']
- forest_split=str.split(forest,'@')
- campi=str.split(read_command('db.columns', table=forest_split[0]),"\n")
- prefix1=prf_yield+"_voltyp"
- vol_matching = [s for s in campi if prefix1 in s]
- for x in vol_matching:
- run_command("v.to.rast", overwrite=ow, input=forest,
- output=x, use="attr", attrcolumn=x)
def remove_map(opts, flgs):
@@ -453,10 +413,14 @@
if rivers!='':
+ run_command("v.to.rast", input=rivers,output="rivers", use="val", overwrite=True)
+ rivers="rivers"
run_command("r.null", map=rivers, null=0)
exprmap+='+ if('+rivers+'>=1, 99999)'
if lakes!='':
+ run_command("v.to.rast", input=lakes,output="lakes", use="val", overwrite=True)
+ lakes="lakes"
run_command("r.null", map=lakes, null=0)
exprmap+='+ if('+lakes+'>=1, 99999)'
@@ -527,60 +491,53 @@
print ("Tech bioenergy stimated (Mwh): %.2f" % np.nansum(T))
-def revenues(opts, flgs,yield_surface,management,treatment):
+def revenues(opts, flgs,yield_surface,management,treatment,forest,yield_):
# Calculate revenues
+ fieldprice=opts['forest_column_price']
+ fieldcond=opts['conditions']
- pricelist=string.split(opts['prices'],',') #convert the string in list of string
+ # pricelist=string.split(opts['prices'],',') #convert the string in list of string
- for x in range(1,len(pricelist)+1):
- price_field=prf_yield+"_voltyp"+str(x)
- run_command("r.mapcalc", overwrite=ow,expression=prf_yield+'_vol_typ'+str(x)+'pix = ('+price_field+'/'+yield_surface+')*(ewres()*nsres()/10000)')
- run_command("r.null", map=prf_yield+'_vol_typ'+str(x)+'pix', null=0)
+ # for x in range(1,len(pricelist)+1):
+ # price_field=prf_yield+"_voltyp"+str(x)
+ # run_command("r.mapcalc", overwrite=ow,expression=prf_yield+'_vol_typ'+str(x)+'pix = ('+price_field+'/'+yield_surface+')*(ewres()*nsres()/10000)')
+ # run_command("r.null", map=prf_yield+'_vol_typ'+str(x)+'pix', null=0)
+ listwoods=fieldcond.split(',')
+ prices=''
+ for wood in listwoods:
+ #ipdb.set_trace()
+ woodprice=wood.split('=')
+ where_cond=fieldprice+" like "+"'"+woodprice[0]+"'"
+ run_command("v.to.rast",input=forest,output='forest_'+woodprice[0],use="attr", attrcolumn=yield_, where=where_cond)
+ exprpix='forest_'+woodprice[0]+'_pix=(forest_'+woodprice[0]+"/"+yield_surface+')*(ewres()*nsres()/10000)'
+ run_command("r.mapcalc", overwrite=ow, expression=exprpix)
+ nullmap='forest_'+woodprice[0]+'_pix'
+ run_command("r.null", map=nullmap,null=0)
+ prices+=nullmap+'*'+woodprice[1]+"+"
+ prices=prices[:-1]
#prices = '+'.join(["vol_typ%dpix*%f" % (i+1, price) for i, price in enumerate(opts['prices'])])
- prices = '+'.join([prf_yield+"_vol_typ%dpix*%f" % (i+1, float(price)) for i, price in enumerate(pricelist)])
+ #prices = '+'.join([prf_yield+"_vol_typ%dpix*%f" % (i+1, float(price)) for i, price in enumerate(pricelist)])
- #pdb.set_trace()
+ #ipdb.set_trace()
price_energy_woodchips=float(opts['price_energy_woodchips'])
TR1='total_revenues1 = technical_surface*(if('+management+' == 1 && '+treatment+'==1 || '+management+' == 1 && '+treatment+'==99999 || '+management+' == 2,('+prices+'+(technical_bioenergy*'+str(price_energy_woodchips)+')), if('+management+' == 1 && '+treatment+'==2, technical_bioenergy*'+str(price_energy_woodchips)+')))'
- #IMPORTANT: in order to calculate the total revenue it's required to process both round wood price
- # (destnated to the wood production) and the residuals (for the energy production)
- # so inside the total revenues formula there is vol_typXpix*price + bioenergy*energy_price
run_command("r.mapcalc", overwrite=ow, expression=TR1)
- #if there is a value of vol_typxx there must be also the corresponding map
- #divide the yield only in the yarding surface e not in all the parcel surface
- # for x in range(1,len(pricelist)+1):
- # price_field=prf_yield+"_voltyp"+str(x)
- # #pdb.set_trace()
- # run_command("r.mapcalc", overwrite=ow,expression=prf_yield+'_vol_typ'+str(x)+'pix2 = '+price_field+'/(technical_surface*@techn_pix_comp)')
- # run_command("r.null", map=prf_yield+'_vol_typ'+str(x)+'pix2', null=0)
- # # price_energy_woodchips=float(opts['price_energy_woodchips'])
- # expression='total_revenues2 = technical_surface*(if(management == 1 && treatment==1 || management == 1 && treatment==99999 || management == 2,(%s+(technical_bioenergy*%f)), if(management == 1 && treatment==2, technical_bioenergy*20)))' % (prices, price_energy_woodchips))
- # expression='total_revenues = total_revenues1*%d + total_revenues2*%d' % (1 if flgs['u'] else 0, 0 if flgs['u'] else 1))
run_command("r.mapcalc",overwrite=ow,expression='total_revenues=total_revenues1')
- #total_revenues1: take into account only the yarding surface inside the parcel
- #total_revenues2: take into account the entire parcel sufrace
def productivity(opts, flgs,management,treatment,soilp2_map,tree_diam,tree_vol,forest_roads,main_roads):
@@ -760,7 +717,7 @@
- output = opts['output_prefix']
+ output = opts['output_basename']
econ_bioenergyHF=output+'_econ_bioenergyHF'
econ_bioenergyC=output+'_econ_bioenergyC'
@@ -800,35 +757,75 @@
def main(opts, flgs):
- yield_=opts['yield1']
- management=opts['management']
- treatment=opts['treatment']
- yield_surface=opts['yield_surface']
- roughness=opts['roughness']
+ forest=opts['forest']
+ boundaries=opts['boundaries']
+ yield_=opts['forest_column_yield']
+ management=opts['forest_column_management']
+ treatment=opts['forest_column_treatment']
+ yield_surface=opts['forest_column_yield_surface']
+ roughness=opts['forest_column_roughness']
forest_roads=opts['forest_roads']
main_roads=opts['main_roads']
rivers=opts['rivers']
lakes=opts['lakes']
tree_diam=opts['tree_diam']
tree_vol=opts['tree_vol']
soilp2_map=opts['soilp2_map']
- vector_forest = opts['forest']
econ_bioenergy=output+'_econ_bioenergy'
+ ######## start import and convert ########
+ run_command("g.region",vect=boundaries)
+ run_command("v.to.rast", input=forest,output="yield", use="attr", attrcolumn=yield_,overwrite=True)
+ run_command("v.to.rast", input=forest,output="yield_surface", use="attr", attrcolumn=yield_surface,overwrite=True)
+ run_command("v.to.rast", input=forest,output="treatment", use="attr", attrcolumn=treatment,overwrite=True)
+ run_command("v.to.rast", input=forest,output="management", use="attr", attrcolumn=management,overwrite=True)
+ run_command("v.to.rast", input=forest_roads,output="forest_roads", use="val", overwrite=True)
+ run_command("v.to.rast", input=main_roads,output="main_roads", use="val", overwrite=True)
+ run_command("r.null", map='yield',null=0)
+ run_command("r.null", map='yield_surface',null=0)
+ run_command("r.null", map='treatment',null=0)
+ run_command("r.null", map='management',null=0)
+ ######## end import and convert ########
+ ######## temp patch to link map and fields ######
+ management="management"
+ treatment="treatment"
+ yield_surface="yield_surface"
+ yield_="yield"
+ forest_roads="forest_roads"
+ main_roads="main_roads"
+ ######## end temp patch to link map and fields ######
if roughness=='':
run_command("r.mapcalc",overwrite=ow,expression='roughness=0')
roughness='roughness'
+ else:
+ run_command("v.to.rast", input=forest,output="roughness", use="attr", attrcolumn=roughness,overwrite=True)
+ run_command("r.null", map='roughness',null=0)
+ roughness='roughness'
if tree_diam=='':
run_command("r.mapcalc",overwrite=ow,expression='tree_diam=99999')
@@ -842,13 +839,11 @@
run_command("r.mapcalc",overwrite=ow,expression='soil_map=99999')
soilp2_map='soil_map'
- if flgs['x'] == False:
- import_map(opts, flgs, vector_forest)
- yield_pix_process(opts,flgs,vector_forest,yield_,yield_surface,rivers,lakes,forest_roads,management,treatment,roughness)
+ yield_pix_process(opts,flgs,forest,yield_,yield_surface,rivers,lakes,forest_roads,management,treatment,roughness)
- revenues(opts, flgs,yield_surface,management,treatment)
+ revenues(opts, flgs,yield_surface,management,treatment,forest,yield_)
costs(opts, flgs)
