[GRASS-SVN] r65217 - in grass/branches/releasebranch_7_0:	raster/r.carve raster/r.drain raster/r.in.lidar	raster/r.in.mat raster/r.in.xyz raster/r.mapcalc	raster/r.out.mpeg raster/r.random raster/r.texture	raster/r.timestamp raster/r.to.vect raster3d/r3.timestamp	scripts/r.tileset scripts/r3.in.xyz vector/v.net.visibility	vector/v.parallel vector/v.qcount vector/v.reclass	vector/v.segment vector/v.surf.bspline vector/v.timestamp	vector/v.vol.rst
    svn_grass at osgeo.org
    Sun May 10 17:16:13 PDT 2015
Author: annakrat
Date: 2015-05-10 17:16:13 -0700 (Sun, 10 May 2015)
New Revision: 65217
   grass/branches/releasebranch_7_0/raster/r.carve/r.carve.html
   grass/branches/releasebranch_7_0/raster/r.drain/r.drain.html
   grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html
   grass/branches/releasebranch_7_0/raster/r.in.mat/r.in.mat.html
   grass/branches/releasebranch_7_0/raster/r.in.xyz/r.in.xyz.html
   grass/branches/releasebranch_7_0/raster/r.mapcalc/r3.mapcalc.html
   grass/branches/releasebranch_7_0/raster/r.out.mpeg/r.out.mpeg.html
   grass/branches/releasebranch_7_0/raster/r.random/r.random.html
   grass/branches/releasebranch_7_0/raster/r.texture/r.texture.html
   grass/branches/releasebranch_7_0/raster/r.timestamp/r.timestamp.html
   grass/branches/releasebranch_7_0/raster/r.to.vect/r.to.vect.html
   grass/branches/releasebranch_7_0/raster3d/r3.timestamp/r3.timestamp.html
   grass/branches/releasebranch_7_0/scripts/r.tileset/r.tileset.html
   grass/branches/releasebranch_7_0/scripts/r3.in.xyz/r3.in.xyz.html
   grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html
   grass/branches/releasebranch_7_0/vector/v.parallel/v.parallel.html
   grass/branches/releasebranch_7_0/vector/v.qcount/v.qcount.html
   grass/branches/releasebranch_7_0/vector/v.reclass/v.reclass.html
   grass/branches/releasebranch_7_0/vector/v.segment/v.segment.html
   grass/branches/releasebranch_7_0/vector/v.surf.bspline/v.surf.bspline.html
   grass/branches/releasebranch_7_0/vector/v.timestamp/v.timestamp.html
   grass/branches/releasebranch_7_0/vector/v.vol.rst/v.vol.rst.html
rename section BUGS to KNOWN ISSUES in manuals (merge from trunk, r65216)
Modified: grass/branches/releasebranch_7_0/raster/r.carve/r.carve.html
--- grass/branches/releasebranch_7_0/raster/r.carve/r.carve.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.carve/r.carve.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -25,7 +25,7 @@
 r.carve rast=elevation vect=streams out=carve_dem width=20 depth=5
 </pre></div>
-<h2>BUGS</h2>
+<h2>KNOWN ISSUES</h2>
 <!-- Is this still the case as of Jan 11, 2008? - EP -->
 The module does not operate yet in latitude-longitude locations.  It
 has not been thoroughly tested, so not all options may work properly -
Modified: grass/branches/releasebranch_7_0/raster/r.drain/r.drain.html
--- grass/branches/releasebranch_7_0/raster/r.drain/r.drain.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.drain/r.drain.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -183,7 +183,7 @@
 </pre></div>
 <p>
-<h2>BUGS</h2>
 <p>Sometimes, when the differences among integer cell category values in the
 <em><a href="r.cost.html">r.cost</a></em> cumulative cost surface output are
Modified: grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html
--- grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -257,7 +257,7 @@
      <!-- Bob Covill has supplied patches for MBIO interface already -->
 </ul>
-<h2>BUGS</h2>
 <ul>
 <li> <em>n</em> map <tt>percent=100</tt> and <tt>percent=xx</tt> maps
Modified: grass/branches/releasebranch_7_0/raster/r.in.mat/r.in.mat.html
--- grass/branches/releasebranch_7_0/raster/r.in.mat/r.in.mat.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.in.mat/r.in.mat.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -108,7 +108,7 @@
 Option to import a version 5 MAT-File, with map and support information
 stored in a single structured array.
-<h2>BUGS</h2>
 If you encounter any problems, please contact the GRASS Development Team.
Modified: grass/branches/releasebranch_7_0/raster/r.in.xyz/r.in.xyz.html
--- grass/branches/releasebranch_7_0/raster/r.in.xyz/r.in.xyz.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.in.xyz/r.in.xyz.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -257,7 +257,7 @@
 </ul>
-<h2>BUGS</h2>
 <ul>
 <li> <em>n</em> map sum can be ever-so-slightly more than `<tt>wc -l</tt>`
Modified: grass/branches/releasebranch_7_0/raster/r.mapcalc/r3.mapcalc.html
--- grass/branches/releasebranch_7_0/raster/r.mapcalc/r3.mapcalc.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.mapcalc/r3.mapcalc.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -540,7 +540,7 @@
 </pre></div>
-<h2>BUGS</h2>
 Continuation lines must end with a \ and have NO trailing white space
 (blanks or tabs).  If the user does leave white space at the end of
 continuation lines, the error messages produced by <em>r3.mapcalc</em> will
Modified: grass/branches/releasebranch_7_0/raster/r.out.mpeg/r.out.mpeg.html
--- grass/branches/releasebranch_7_0/raster/r.out.mpeg/r.out.mpeg.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.out.mpeg/r.out.mpeg.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -57,7 +57,7 @@
 the <b>CURRENTLY DEFINED GRASS REGION for the output size</b>. So be
 careful to set region to a reasonable size prior to encoding.
-<h2>BUGS</h2>
 MPEG images must be 16-pixel aligned for successful compression, so if
 the rows & columns of the calculated image size (scaled, with
Modified: grass/branches/releasebranch_7_0/raster/r.random/r.random.html
--- grass/branches/releasebranch_7_0/raster/r.random/r.random.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.random/r.random.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -95,7 +95,7 @@
 </pre></div>
-<h2>BUGS</h2>
 It's not possible to use the <b>-i</b> flag and not also specify the <b>n</b>
 parameter.
Modified: grass/branches/releasebranch_7_0/raster/r.texture/r.texture.html
--- grass/branches/releasebranch_7_0/raster/r.texture/r.texture.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.texture/r.texture.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -118,7 +118,7 @@
 This calculates four maps (requested texture at four orientations):
 ortho_texture_ASM_0, ortho_texture_ASM_45, ortho_texture_ASM_90, ortho_texture_ASM_135.
-<h2>BUGS</h2>
 The program can run incredibly slow for large raster maps.
 <h2>REFERENCES</h2>
Modified: grass/branches/releasebranch_7_0/raster/r.timestamp/r.timestamp.html
--- grass/branches/releasebranch_7_0/raster/r.timestamp/r.timestamp.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.timestamp/r.timestamp.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -118,7 +118,7 @@
     r.timestamp map=soils date=none
 </pre></div>
-<h2>BUGS</h2>
 Spaces in the timestamp value are required.
 <h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/r.to.vect.html
--- grass/branches/releasebranch_7_0/raster/r.to.vect/r.to.vect.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/r.to.vect.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -102,7 +102,7 @@
 v.colors my_landclass96 color=random
 </pre></div>
-<h2>BUGS</h2>
 For type=line the input raster map MUST be thinned by
 <em><a href="r.thin.html">r.thin</a></em>;
Modified: grass/branches/releasebranch_7_0/raster3d/r3.timestamp/r3.timestamp.html
--- grass/branches/releasebranch_7_0/raster3d/r3.timestamp/r3.timestamp.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/raster3d/r3.timestamp/r3.timestamp.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -82,7 +82,7 @@
 	     3 years 10 days
 </tt>
-<h2>BUGS</h2>
 <h2>AUTHOR</h2>
Modified: grass/branches/releasebranch_7_0/scripts/r.tileset/r.tileset.html
--- grass/branches/releasebranch_7_0/scripts/r.tileset/r.tileset.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/scripts/r.tileset/r.tileset.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -87,7 +87,7 @@
 r.tileset sourceproj="`g.proj -j location=IrishGrid`" maxrows=400 maxcols=300 overlap=3 -g
 </pre></div>
-<h2>BUGS</h2>
 <ul>
 <li><em>r.tileset</em> does not know about meridians that
Modified: grass/branches/releasebranch_7_0/scripts/r3.in.xyz/r3.in.xyz.html
--- grass/branches/releasebranch_7_0/scripts/r3.in.xyz/r3.in.xyz.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/scripts/r3.in.xyz/r3.in.xyz.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -66,7 +66,7 @@
 </pre></div>
-<h2>BUGS</h2>
 <em>r.to.rast3</em> always creates a <tt>double</tt> output map
 regardless of input.
Modified: grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html
--- grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/vector/v.net.visibility/v.net.visibility.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -122,7 +122,7 @@
 d.vect archsites col=red
 </pre></div>
-<h2>KNOWN BUGS</h2>
 In some cases when 3 points or nodes are collinear, some wrong edges
 are added. This happens only really rarly and shouldn't be a big
 problem. When two points have the exact same x coordinate and are
Modified: grass/branches/releasebranch_7_0/vector/v.parallel/v.parallel.html
--- grass/branches/releasebranch_7_0/vector/v.parallel/v.parallel.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/vector/v.parallel/v.parallel.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -6,7 +6,7 @@
 <h2>NOTES</h2>
 Usage of <b>-b</b> flag will overrule the <b>side</b> parameter.
-<h2>BUGS</h2>
 There is a problem with side-offset parallel line generation for inside corners.
 To avoid this problem, the <b>-b</b> flag might be used.
 <!-- in Vect_line_parallel(), v.segment is also affected -->
Modified: grass/branches/releasebranch_7_0/vector/v.qcount/v.qcount.html
--- grass/branches/releasebranch_7_0/vector/v.qcount/v.qcount.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/vector/v.qcount/v.qcount.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -61,7 +61,7 @@
 Biology</em>, 2:215-235, 1959.</li>
 </ul>
-<h2>BUGS</h2>
 Timestamp not working for header part of counts output. (2000-10-28)
Modified: grass/branches/releasebranch_7_0/vector/v.reclass/v.reclass.html
--- grass/branches/releasebranch_7_0/vector/v.reclass/v.reclass.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/vector/v.reclass/v.reclass.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -76,7 +76,7 @@
 </pre></div>
-<h2>BUGS</h2>
 No table is created for reclassed layer if <b>rules</b> option is used.
Modified: grass/branches/releasebranch_7_0/vector/v.segment/v.segment.html
--- grass/branches/releasebranch_7_0/vector/v.segment/v.segment.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/vector/v.segment/v.segment.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -158,7 +158,7 @@
 tracks from the end of the line up to the middle point, offset 500m to the right
 </center>
-<h2>BUGS</h2>
 <!-- in Vect_line_parallel(), v.parallel is also affected -->
Modified: grass/branches/releasebranch_7_0/vector/v.surf.bspline/v.surf.bspline.html
--- grass/branches/releasebranch_7_0/vector/v.surf.bspline/v.surf.bspline.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/vector/v.surf.bspline/v.surf.bspline.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -143,7 +143,7 @@
 </pre></div>
-<h2>BUGS</h2>
 Known issues:
Modified: grass/branches/releasebranch_7_0/vector/v.timestamp/v.timestamp.html
--- grass/branches/releasebranch_7_0/vector/v.timestamp/v.timestamp.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/vector/v.timestamp/v.timestamp.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -118,7 +118,7 @@
     v.timestamp map=lidar date=none
 </pre></div>
-<h2>BUGS</h2>
 <h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_7_0/vector/v.vol.rst/v.vol.rst.html
--- grass/branches/releasebranch_7_0/vector/v.vol.rst/v.vol.rst.html	2015-05-11 00:11:34 UTC (rev 65216)
+++ grass/branches/releasebranch_7_0/vector/v.vol.rst/v.vol.rst.html	2015-05-11 00:16:13 UTC (rev 65217)
@@ -222,7 +222,7 @@
 paraview --data=volume.vtk
 </pre></div>
-<h2>BUGS</h2>
 <b>deviations</b> file is written as 2D and deviations are not written as attributes.
 <h2>REFERENCES</h2>
