[GRASS-SVN] r65254 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Sat May 16 07:49:39 PDT 2015
Author: martinl
Date: 2015-05-16 07:49:39 -0700 (Sat, 16 May 2015)
New Revision: 65254
grass/trunk/gui/wxpython/core/render.py
wxGUI/render: layer.Render() env optional (attempt to fix mapswipe)
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py 2015-05-15 21:56:58 UTC (rev 65253)
+++ grass/trunk/gui/wxpython/core/render.py 2015-05-16 14:49:39 UTC (rev 65254)
@@ -122,7 +122,7 @@
def __repr__(self):
return self.__str__()
- def Render(self, env):
+ def Render(self, env=None):
"""Render layer to image
:return: rendered image filename
@@ -144,9 +144,13 @@
if self.type not in layertypes:
raise GException(_("<%(name)s>: layer type <%(type)s> is not supported") % \
{'type' : self.type, 'name' : self.name})
+ if env:
+ env.update(self.render_env)
+ else:
+ env = self.render_env.copy()
# render layers
- env.update(self.render_env)
try:
if self.type == 'command':
first = True
