[GRASS-SVN] r65255 - grass/trunk/gui/wxpython/core
    svn_grass at osgeo.org
    Sat May 16 09:20:14 PDT 2015
Author: martinl
Date: 2015-05-16 09:20:13 -0700 (Sat, 16 May 2015)
New Revision: 65255
   grass/trunk/gui/wxpython/core/render.py
wxGUI/render: fix multithread rendering to work in mapswipe
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2015-05-16 14:49:39 UTC (rev 65254)
+++ grass/trunk/gui/wxpython/core/render.py	2015-05-16 16:20:13 UTC (rev 65255)
@@ -145,10 +145,9 @@
             raise GException(_("<%(name)s>: layer type <%(type)s> is not supported") % \
                                  {'type' : self.type, 'name' : self.name})
-        if env:
-            env.update(self.render_env)
-        else:
-            env = self.render_env.copy()
+        if not env:
+            env = os.environ.copy()
+        env.update(self.render_env)
         # render layers
         try:
@@ -464,6 +463,22 @@
                                                            len(self.layers)))
         return nlayers
+    def GetRenderEnv(self, windres=False):
+        env.update(self._render_env)
+        # use external gisrc if defined
+        if self.Map.gisrc:
+            env['GISRC'] = self.Map.gisrc
+        env['GRASS_REGION'] = self.Map.SetRegion(windres)
+        env['GRASS_RENDER_WIDTH'] = str(self.Map.width)
+        env['GRASS_RENDER_HEIGHT'] = str(self.Map.height)
+        if UserSettings.Get(group = 'display', key = 'driver', subkey = 'type') == 'png':
+            env['GRASS_RENDER_IMMEDIATE'] = 'png'
+        else:
+            env['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+        return env
     def Render(self, force = False, windres = False):
         """Render map composition
@@ -478,20 +493,7 @@
         wx.BeginBusyCursor()
         self._rendering = True
-        env = os.environ.copy()
-        env.update(self._render_env)
-        # use external gisrc if defined
-        if self.Map.gisrc:
-            env['GISRC'] = self.Map.gisrc
-        env['GRASS_REGION'] = self.Map.SetRegion(windres)
-        env['GRASS_RENDER_WIDTH'] = str(self.Map.width)
-        env['GRASS_RENDER_HEIGHT'] = str(self.Map.height)
-        driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
-        if driver == 'png':
-            env['GRASS_RENDER_IMMEDIATE'] = 'png'
-        else:
-            env['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+        env = self.GetRenderEnv(windres)
         self._init(env)
         if self._renderLayers(env, force, windres) == 0:
             self.renderDone.emit()
@@ -1087,7 +1089,7 @@
         self.renderMgr.Render(force, windres)
-    def _addLayer(self, layer, render=False, pos=-1):
+    def _addLayer(self, layer, pos=-1):
         if layer.type == 'overlay':
             llist = self.overlays
         else:
@@ -1100,8 +1102,6 @@
             llist.append(layer)
         Debug.msg (3, "Map._addLayer(): layer=%s type=%s" % (layer.name, layer.type))
-        if render and not layer.Render():
-            raise GException(_("Unable to render map layer <%s>.") % name)
         return layer
@@ -1130,7 +1130,7 @@
         layer = MapLayer(ltype = ltype, name = name, cmd = command, Map = self,
                          active = active, hidden = hidden, opacity = opacity)
-        self._addLayer(layer, render, pos)
+        self._addLayer(layer, pos)
         renderMgr = layer.GetRenderMgr()
         Debug.msg(1, "Map.AddLayer(): ltype={}, command={}".format(ltype, ' '.join(command)))
@@ -1138,6 +1138,7 @@
             if layer.type == 'wms':
                 renderMgr.dataFetched.connect(self.renderMgr.ReportProgress)
             renderMgr.updateProgress.connect(self.renderMgr.ReportProgress)
+        layer.forceRender = render
         self.layerAdded.emit(layer=layer)
@@ -1219,12 +1220,9 @@
         if 'opacity' in kargs:
             layer.SetOpacity(kargs['opacity'])
-                             layer.GetName())
+        self.forceRender = render
         # not needed since there is self.forceRender
         ### self.layerChanged(layer=layer)
@@ -1374,11 +1372,9 @@
             overlay.SetOpacity(kargs['opacity'])
-        if render and overlay.GetCmd() != [] and not overlay.Render():
-            raise GException(_("Unable to render overlay <%s>.") %
-                             overlay.GetType())
+        overlay.forceRender = render
         return overlay
     def GetOverlay(self, id, list=False):
