[GRASS-SVN] r65334 - grass/trunk/lib/db/dbmi_client
Tue May 26 11:02:01 PDT 2015
Author: martinl
Date: 2015-05-26 11:02:01 -0700 (Tue, 26 May 2015)
New Revision: 65334
   grass/trunk/lib/db/dbmi_client/copy_tab.c
fix db_copy_table() for pg driver (db_list_tables() return names including schema name)
Modified: grass/trunk/lib/db/dbmi_client/copy_tab.c
--- grass/trunk/lib/db/dbmi_client/copy_tab.c	2015-05-26 18:00:25 UTC (rev 65333)
+++ grass/trunk/lib/db/dbmi_client/copy_tab.c	2015-05-26 18:02:01 UTC (rev 65334)
@@ -158,11 +158,33 @@
     for (i = 0; i < count; i++) {
-	const char *tblname = db_get_string(&tblnames[i]);
 	int ret;
+        char *tblname_i;
+        tblname_i = NULL;
+        if (strcmp(to_drvname, "pg") == 0) {
+            char *p, *tbl;
+            dbConnection connection;
+            tbl = db_get_string(&tblnames[i]);
+            db_get_connection(&connection);
+            p = strstr(tbl, ".");
+            if (p) {
+                char buf[GNAME_MAX];
+                sprintf(buf, "%s.%s", connection.schemaName ? connection.schemaName : "public",
+                        to_tblname);
+                if (strcmp(buf, tbl) == 0)
+                    tblname_i = G_store(p + 1); /* skip dot */
+        if (!tblname_i) {
+            tblname_i = G_store(db_get_string(&tblnames[i]));
 	ret = DB_FAILED;
-	if (strcmp(to_tblname, tblname) == 0) {
+	if (strcmp(to_tblname, tblname_i) == 0) {
 	    if (G_get_overwrite()) {
 		G_warning(_("Table <%s> already exists in database and will be overwritten"),
 			  to_tblname);
@@ -181,6 +203,8 @@
 		return DB_FAILED;
+        G_free(tblname_i);
     /* Create new table */
