[GRASS-SVN] r65335 - grass-addons/grass7/gui/wxpython/wx.mwprecip
svn_grass at osgeo.org
Tue May 26 16:48:20 PDT 2015
Author: krejcmat
Date: 2015-05-26 16:48:20 -0700 (Tue, 26 May 2015)
New Revision: 65335
grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py
fix path,aw value,export geometry,empty schema
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-05-26 18:02:01 UTC (rev 65334)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-05-26 23:48:20 UTC (rev 65335)
@@ -10,8 +10,8 @@
from core.gcmd import GMessage, GError
from gui_core import gselect
-import wx.lib.scrolledpanel as scrolled
+import time
class DBconn(wx.ScrolledWindow):
def __init__(self, parent, settings={}):
@@ -47,12 +47,13 @@
self.SetSizerAndFit(panelSizer)
def getSettVal(self,key):
- if self.settings[key] is not None:
- return self.settings[key]
- if self.settings[key] is not 'None':
- if self.settings[key] is not'':
+ if self.settings[key] is None:
+ return ''
+ elif self.settings[key] is 'None':
+ return ''
+ elif self.settings[key] is '':
+ return ''
+ return self.settings[key]
def loadSettings(self, sett=None):
if sett:
@@ -147,20 +148,20 @@
self.round = BaseInput(self, 'Round data to "n" of decimal places') # TODO MODE disable
self.quantile = BaseInput(self, 'Set quantile in %') # TODO quantile disable
self.aw = BaseInput(self, 'Antena wetting value')
+ self.aw.SetValue('0')
self.dryInterval = TextInput(self, 'Set interval(s) of dry period')
self.fromFileVal = TextInput(self, 'Set baseline values in csv format')
- #self.okBtt = wx.Button(self, wx.ID_OK, label='ok and close')
self.onChangeMethod()
self.onChangeStatistic()
self.fromFile.Bind(wx.EVT_RADIOBUTTON, self.onChangeMethod)
self.dryWin.Bind(wx.EVT_RADIOBUTTON, self.onChangeMethod)
self.noDryWin.Bind(wx.EVT_RADIOBUTTON, self.onChangeMethod)
- #self.okBtt.Bind(wx.EVT_BUTTON, self.saveSettings)
if len(settings) > 0:
self.loadSettings(None)
self._layout()
def onChangeStatistic(self,evt=None):
if self.baselType.GetValue() == 'avg':
self.round.Disable()
@@ -330,21 +331,29 @@
if self.vectorMap.GetValue():
self.links.Hide()
self.mapLabel.Show()
self.map.Show()
else:
self.links.Show()
self.mapLabel.Hide()
self.map.Hide()
self.Fit()
self.Parent.Fit()
def saveSettings(self, evt=None, sett=None):
if sett:
self.settings = sett
+ if self.vectorMap.GetValue():
+ self.settings['linksMap'] = self.map.GetValue()
+ else:
+ self.settings['linksMap'] = None
self.settings['linksOnly'] = self.linksOnly.GetValue()
self.settings['linksIngnore'] = self.linksIngnore.GetValue()
- self.settings['linksMap'] = self.map.GetValue()
self.settings['links'] = self.links.GetValue()
self.settings['start'] = self.start.GetValue()
self.settings['end'] = self.end.GetValue()
@@ -527,30 +536,28 @@
class MWMainFrame(wx.Frame):
def __init__(self, parent, id, title):
wx.Frame.__init__(self, parent, id, title,style=wx.DEFAULT_FRAME_STYLE )
- #self.workPath = tempfile.gettempdir()
self.workPath = os.path.join(pathToMapset(), "temp")
self.initWorkingFoldrs()
self.settings = {}
- self.settings['workPath']=self.workPath
self.settingsLst = []
self.mainSizer = wx.BoxSizer(wx.VERTICAL)
self.panelSizer = wx.BoxSizer(wx.VERTICAL)
self.mainPanel = wx.Panel(self,id=wx.ID_ANY)
+ self.worker = None
menubar = wx.MenuBar()
settMenu = wx.Menu()
databaseItem = settMenu.Append(wx.ID_ANY, 'Database', 'Set database')
- #baselineItem = settMenu.Append(wx.ID_ANY, 'Baseline', 'Set baseline methods')
geometry = settMenu.Append(wx.ID_ANY, 'Geometry', 'Create vector geometry')
- woringPath = settMenu.Append(wx.ID_ANY, 'Working Dir', 'Set working directory')
+ workingPath = settMenu.Append(wx.ID_ANY, 'Working Dir', 'Set working directory')
quitItem = settMenu.Append(wx.ID_EXIT, 'Quit', 'Quit application')
menubar.Append(settMenu, '&Menu')
self.SetMenuBar(menubar)
self.Bind(wx.EVT_MENU, self.onQuit, quitItem)
self.Bind(wx.EVT_MENU, self.onSetDatabase, databaseItem)
- self.Bind(wx.EVT_MENU, self.onSetWorkPath, woringPath)
+ self.Bind(wx.EVT_MENU, self.onSetWorkPath, workingPath)
#self.Bind(wx.EVT_MENU, self.onSetBaseline, baselineItem)
self.Bind(wx.EVT_MENU, self.onSetGeometry, geometry)
@@ -576,7 +583,7 @@
#def initProfileSett(self):
self.loadScheme = wx.StaticText(self.mainPanel, label='Load settings', id=wx.ID_ANY)
- self.profilSelection = wx.ComboBox(self.mainPanel)
+ self.profilSelection = wx.ComboBox(self.mainPanel,style=wx.CB_READONLY)
self.schema = BaseInput(self.mainPanel, 'Name of new working profile')
self.schema.text.Bind(wx.EVT_TEXT, self.OnSchemeTxtChange)
self.newScheme = wx.Button(self.mainPanel, label='Save new profile')
@@ -586,6 +593,7 @@
#def initRunBtt(self):
self.computeBtt = wx.Button(self.mainPanel, label='Compute')
+ self.computeBtt.Disable()
self.exportDataBtt = wx.Button(self.mainPanel, label='Export data')
self.computeBtt.Bind(wx.EVT_BUTTON, self.runCompute)
self.exportDataBtt.Bind(wx.EVT_BUTTON, self.exportData)
@@ -595,34 +603,39 @@
def getMinTime(self, evt=None):
self.OnSaveSettings(toFile=False)
- interface = Gui2Model(self, self.settings) # TODO optimalize init
- if interface.connStatus:
+ interface = Gui2Model(self, self.settings,self.workPath) # TODO optimalize init
+ if interface.checkConn():
+ interface.initConnection()
self.dataMgrMW.start.SetValue(interface.dbConn.minTimestamp())
def getMaxTime(self, evt=None):
self.dataMgrMW.end.SetValue(interface.dbConn.maxTimestamp())
def GetConnection(self):
return interface.dbConn
def OnSchemeTxtChange(self, evt=None):
if self.schema.GetValue() is not None:
self.newScheme.Enable()
+ self.computeBtt.Enable()
else:
self.newScheme.Disable()
def OnLoadSettings(self, evt=None):
- print 'combobox'
currSelId = self.profilSelection.GetSelection()
- print(currSelId)
+ self.schema.SetValue(self.profilSelection.GetValue())
print self.settingsLst[currSelId]
self.settings = self.settingsLst[currSelId]
try:
self.dataMgrMW.loadSettings(self.settings)
except:
@@ -644,19 +657,11 @@
except:
pass
def OnSaveSettings(self, evt=None, toFile=True):
try:
self.settings = self.dataMgrMW.saveSettings(sett=self.settings)
except:
pass
- # try:
- # self.settings=self.dataMgrRG.saveSettings(sett=self.settings)
- # except:
- # pass
try:
self.settings = self.databasePnl.saveSettings(sett=self.settings)
except:
@@ -671,8 +676,6 @@
pass
self.settings['workSchema'] = self.profilSelection.GetValue()
- #self.settings['workPath'] = self.workPath
self.settings['workSchema'] = self.schema.GetValue()
print self.settings
@@ -698,10 +701,11 @@
GMessage('Cannot find "save" folder')
return
filePathList = getFilesInFoldr(projectDir, True)
+ print filePathList
# print 'filePathList',filePathList
if filePathList != 0:
self.profilSelection.Clear()
- for n, path in enumerate(filePathList):
+ for path in filePathList:
tmpDict = readDict(path)
self.settingsLst.append(tmpDict)
self.profilSelection.Append(str(tmpDict['workSchema']))
@@ -751,7 +755,6 @@
pass
def onSetWorkPath(self,evt):
#f = tempfile.TemporaryFile()
dlg = wx.DirDialog(self,
message="Select working directory",
@@ -796,8 +799,10 @@
self.dbDialog.Destroy()
def createGeometry(self, type, name):
- interface.initVectorGrass(type=type, name=name)
+ interface.initVectorGrass(type=type, name=name)
def exportData(self, evt):
self.exportDialog = wx.Dialog(self, id=wx.ID_ANY,
@@ -886,11 +891,11 @@
else:
self.settings['IDtype'] = 'linkid'
interface.initVectorGrass()
interface.initTimeWinMW()
interface.initBaseline()
- interface.doCompute()
+ interface.Run()
conn= interface.dbConn
@@ -915,23 +920,26 @@
exportData = {'getData': False, 'dataOnly': False}
self.settings['dataExport'] = exportData
- # if rain gauges
if self.dataMgrMW.inpRainGauge.GetPath() is not None:
self.settings['IDtype'] = 'gaugeid'
else:
- interface.initVectorGrass()
- #if interpolate points along lines
- #if self.pointInter.interpolState.GetValue():
- # interface.initPInterpolation()
+ self.worker = Gui2Model(self, self.settings,self.workPath)
+ if self.worker.checkConn():
+ if not self.worker.initConnection():
+ return
+ self.worker.initVectorGrass()
- interface.initTimeWinMW()
- interface.initBaseline()
+ #if interpolate points along lines
+ #if self.pointInter.interpolState.GetValue():
+ # interface.initPInterpolation()
+ self.worker.initTimeWinMW()
+ self.worker.initBaseline()
+ self.worker.Run()
def layout(self):
self.panelSizer.Add(self.loadScheme, flag=wx.EXPAND)
@@ -956,22 +964,26 @@
class Gui2Model():
- def __init__(self, wxParent, settings):
- parent = wxParent
+ def __init__(self, wxParent, settings,path):
self.settings = settings
self.dbConn = None
self.connStatus = False
- self.initConnection()
+ self.conninfo=None
+ self.workPath=path
- def initConnection(self, info=False):
- conninfo = None
+ def checkConn(self):
try:
- conninfo = {'name': self.settings['database']}
+ self.conninfo = {'name': self.settings['database']}
+ return True
except:
GMessage('name of database is missing')
- return
+ self.connStatus = False
+ return False
+ def initConnection(self, info=False):
+ conninfo = self.conninfo
if 'workSchema' in self.settings:
conninfo['workSchema'] = self.settings['workSchema']
if 'schema' in self.settings:
@@ -984,28 +996,27 @@
conninfo['port'] = self.settings['port']
if 'passwd' in self.settings:
conninfo['password'] = self.settings['passwd']
- conninfo['workPath']=self.settings['workPath']
- if conninfo is None:
- self.connStatus = False
- GMessage('Database connection failed')
- return
+ conninfo['workPath'] = self.workPath
if not info: # prepare for computing
self.dbConn = Database(**conninfo)
self.connStatus = True
self.dbConn.firstPreparation()
self.dbConn.prepareDB()
self.dbConn.prepareDir()
return self.dbConn
else: # just get info about curr database state
return self.dbConn
def initVectorGrass(self, type=None, name=None):
convertor = VectorLoader(self.dbConn)
- if name:
+ if name is not None:
self.dbConn.nodeVecMapName = name
self.dbConn.linkVecMapName = name
@@ -1035,7 +1046,6 @@
baselInit = {}
if 'baselType' in self.settings:
baselInit['statFce'] = self.settings['baselType']
if 'quantile' in self.settings:
baselInit['quantile'] = self.settings['quantile']
if 'round' in self.settings:
@@ -1073,16 +1083,16 @@
if not methodSel:
self.errMsg('Baseline method is not selected')
- print baselInit
self.baseline = Baseline(**baselInit)
def initTimeWinMW(self):
- winInit = {}
+ winInit =\
if 'linksOnly' in self.settings:
winInit['linksOnly'] = self.settings['linksOnly']
if 'linksMap' in self.settings:
- winInit['linksOnly'] = self.settings['linksMap']
+ winInit['linksMap'] = self.settings['linksMap']
if 'linksIngnore' in self.settings:
winInit['linksIgnored'] = self.settings['linksIngnore']
if 'links' in self.settings:
@@ -1100,8 +1110,7 @@
self.twin = TimeWindows(**winInit)
- def doCompute(self):
+ def Run(self):
# GMessage('OK')
comp = Computor(self.baseline, self.twin, self.dbConn, self.settings['dataExport'])
state, msg = comp.GetStatus()
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-05-26 18:02:01 UTC (rev 65334)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-05-26 23:48:20 UTC (rev 65335)
@@ -311,30 +311,28 @@
class Baseline():
- def __init__(self, type='noDryWin', pathToFile=None, statFce='mode', quantile=97, roundMode=3, aw=0):
+ def __init__(self, type='noDryWin', pathToFile=None, statFce='quantile', quantile=97, roundMode=3, aw=0):
+ if quantile is None:
+ quantile=97
+ grass.message('Quantile is not defined. Default is 97')
self.quantile = quantile
+ if roundMode is None:
+ roundMode=3
+ grass.message('Round is not defined. Default is 3 decimal places')
self.roundMode = roundMode
+ if aw is None:
+ aw=0
+ grass.message('Antena wetting value is not defined. Default is 0')
self.aw = aw
self.pathToFile = pathToFile
self.type = type
self.statFce = statFce
- if statFce == 'mode':
- if self.roundMode is None:
- grass.warning('Value "round" is missing.')
- if statFce == 'quantile':
- if self.quantile is None:
- grass.warning('Value "quentile" is missing.')
- if self.type == 'fromDryWin':
- if self.pathToFile is None:
- grass.warning('Dry interval is not defined.')
- if self.type == 'values':
- grass.warning('Baseline values are not defined.')
- print self.pathToFile
class TimeWindows():
def __init__(self, database, IDtype, sumStep, startTime=None,
endTime=None, linksIgnored=False, linksOnly=False, links=None, linksMap=None):
@@ -371,14 +369,15 @@
def createWin(self):
self.sumValues()
# self.setTimestamp()
- if not self.linksMap:
- if self.linksIgnored:
- self.removeLinksIgnore()
- if self.linksOnly:
- self.removeLinksOthers()
- else:
+ if self.linksMap is not None:
self.database.linkVecMapName = self.linksMap
+ elif self.linksIgnored:
+ self.removeLinksIgnore()
+ elif self.linksOnly:
+ self.removeLinksOthers()
self.crateTimeWin()
def sumValues(self):
@@ -884,7 +883,6 @@
quantileRes=np.percentile(data, (100-float(baseline.quantile))/100)
tmp.append(str(linkid) + ',' + str(quantileRes)+ '\n')
- #print tmp
io0 = open(os.path.join(database.pathworkSchemaDir, "baseline"), 'w+')
io0.writelines(tmp)
io0.close()
@@ -929,8 +927,10 @@
return True
return False
+ if self.baseline.aw is None:
+ self.baseline.aw=0
Aw = float(self.baseline.aw)
link_num = self.database.connection.count("link")
compPrecTab = "%s.%s" % (self.database.schema, self.database.computedPrecip)
# self.timeWin.sumValues()
@@ -1022,6 +1022,7 @@
'Missing values "linkid,baseline," in text file. Data are not available in dry interval(baseline) .')
temp = []
+ errLinkList=[]
grass.message("Computing precipitation")
skippedList = []
for record in resu:
@@ -1043,8 +1044,10 @@
if checkValidity(curLinkData[2], curLinkData[1]):
coef_a_k = self.computeAlphaK(curLinkData[2], curLinkData[1])
else:
- self.logMsg('Data of link <%s> are not valid'%record[0])
- continue
+ if record[0] not in errLinkList:
+ errLinkList.append(record[0])
+ self.logMsg('Data of link <%s> are not valid'%record[0])
+ continue
#read value from dictionary
baseline_decibel = (self.baselineDict[record[0]])
@@ -1165,17 +1168,15 @@
self.rules = rules
self.database = database
map = self.connectDBaLayers()
if color is not None or rules is not None:
self.makeRGB(map)
def makeRGB(self, map):
grass.message('Creating RGB column in database')
- # print map
- # print self.database.linkVecMapName
- # print self.database.precipColName
- # print self.color
if self.color is not None:
for lay in range(1, self.getNumLayer(self.database.linkVecMapName), 1):
Module('v.colors',
map=map,
@@ -1233,8 +1234,11 @@
def connectDBaLayers(self):
grass.message('Connecting tables to maps')
inputMap = self.database.linkVecMapName
+ if '@' in self.database.linkVecMapName:
+ self.database.linkVecMapName=self.database.linkVecMapName.split('@')[0]
self.database.linkVecMapName += '_%s' % self.database.schema
try:
f = open(os.path.join(self.database.pathworkSchemaDir, "l_timewindow"), 'r')
except:
@@ -1308,13 +1312,8 @@
if datasetTdescription is not None:
self.datasetTdescription = datasetTdescription
- # print '--'*10
- # #print self.datasetName
- # print self.datasetTitle
- # print self.datasetTdescription
- # print temporalType
- # print semanticType
RunCommand('t.create',
type='stvds',
output=self.datasetName,
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py 2015-05-26 18:02:01 UTC (rev 65334)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py 2015-05-26 23:48:20 UTC (rev 65335)
@@ -404,12 +404,11 @@
else:
tmp.append(path)
- if len(tmp) > 0:
- return tmp
- else:
- return 0
+ return tmp
def isAttributExist(connection, schema, table, columns):
sql = "SELECT EXISTS( SELECT * FROM information_schema.columns WHERE \
table_schema = '%s' AND \
