[GRASS-SVN] r66695 - grass-addons/grass7/raster/r.import
svn_grass at osgeo.org
Sun Nov 1 14:44:41 PST 2015
Author: neteler
Date: 2015-11-01 14:44:41 -0800 (Sun, 01 Nov 2015)
New Revision: 66695
grass-addons/grass7/raster/r.import/r.import.html
grass-addons/grass7/raster/r.import/r.import.py
r.import addon: sync to relbranch70 (for users of installations prior to 7.0.2)
Modified: grass-addons/grass7/raster/r.import/r.import.html
--- grass-addons/grass7/raster/r.import/r.import.html 2015-11-01 17:08:20 UTC (rev 66694)
+++ grass-addons/grass7/raster/r.import/r.import.html 2015-11-01 22:44:41 UTC (rev 66695)
@@ -1,13 +1,16 @@
<h2>DESCRIPTION</h2>
-<em>r.import</em> imports selected bands from a GDAL raster datasouce
-into the current location and mapset. If the projection of the input
-does not match the projection of the location, the input is reprojected
-into the current location. If the projection of the input does match
-the projection of the location, the input is imported directly with <a
-href="r.in.gdal.html">r.in.gdal</a>.
+<em>r.import</em> imports a map or selected bands from a GDAL raster datasource
+into the current location and mapset. If the projection of the input
+does not match the projection of the location, the input is reprojected
+into the current location. If the projection of the input does match
+the projection of the location, the input is imported directly with
+<a href="r.in.gdal.html">r.in.gdal</a>.
-<h4>Resolution</h4>
+<h2>NOTES</h2>
+<h3>Resolution</h3>
<em>r.import</em> reports the estimated target resolution for each
input band. The estimated resolution will usually be some floating
point number, e.g. 271.301. In case option <b>resolution</b> is set to
@@ -20,7 +23,15 @@
For latlong locations, the resolution might be set to arc seconds, e.g. 1, 3, 7.5,
15, and 30 arc seconds are commonly used resolutions.
-<h4>Resampling methods</h4>
+<h3>Resampling methods</h3>
+When reprojecting a map to a new spatial reference system, the projected
+data is resampled with one of four different methods: nearest neighbor,
+bilinear, bicubic iterpolation or lanczos.
+<p>
+In the following common use cases:
+<p>
<b>nearest</b> is the simplest method and the only possible method for
categorical data.
<p>
@@ -38,19 +49,57 @@
<b>nearest</b> or <b>bilinear</b>, linear features can become zigzag
features after reprojection.
+<p>
+For explanation of the <b>-l</b> flag, please refer to the
+<a href="r.in.gdal.html">r.in.gdal</a> manual.
+<p>
+When importing whole-world maps the user should disable map-trimming with
+the <b>-n</b> flag. For further explanations of <b>-n</b> flag, please refer
+the to <a href="r.proj.html">r.proj</a> manual.
+<h2>EXAMPLE</h2>
+Import of a subset from <a href="">Bioclim data set</a>, to be reprojected
+to current location projection (North Carolina sample dataset). While normally
+the full raster map is imported, we spatially subset using the <em>extent</em>
+parameter:
+<div class="code"><pre>
+# download selected Bioclim data
+wget http://biogeo.ucdavis.edu/data/climate/worldclim/1_4/grid/cur/bio_2-5m_bil.zip
+# extract BIO1 from package:
+unzip bio_2-5m_bil.zip bio1.bil bio1.hdr
+# set computational region to North Carolina, 4000 m target pixel resolution
+g.region -d res=4000 -ap
+# subset to current region and reproject on the fly to current location projection,
+# using -n since whole-world map is imported:
+r.import input=bio1.bil output=bioclim01 resample=bilinear \
+ extent=region resolution=region -n
+r.info bioclim01
+r.univar -e bioclim01
+</pre></div>
<h2>KNOWN ISSUES</h2>
-Option <b>extent</b>=<em>region</em> works only when dataset has different
-projection than current location (<a href="r.proj.html">r.proj</a> is then used).
+The option <b>extent</b>=<em>region</em> only works when the dataset has a
+different projection than the current location (i.e., internally
+<a href="r.proj.html">r.proj</a> is invoked).
<h2>SEE ALSO</h2>
<em>
-<a href="r.in.gdal.html">r.in.gdal</a>,<br>
+<a href="r.in.gdal.html">r.in.gdal</a>,
</em>
<h2>AUTHORS</h2>
Markus Metz<br>
+Improvements: Martin Landa, Anna Petrasova
-<p><i>Last changed: $Date: 2015-01-20 20:52:27 +0100 (Tue, 20 Jan 2015) $</i>
+<p>
+<i>Last changed: $Date: 2015-01-20 20:52:27 +0100 (Tue, 20 Jan 2015) $</i>
Modified: grass-addons/grass7/raster/r.import/r.import.py
--- grass-addons/grass7/raster/r.import/r.import.py 2015-11-01 17:08:20 UTC (rev 66694)
+++ grass-addons/grass7/raster/r.import/r.import.py 2015-11-01 22:44:41 UTC (rev 66695)
@@ -17,15 +17,12 @@
#%module
-#% description: Imports raster data into a GRASS raster map using GDAL library and reproject on the fly.
+#% description: Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly.
#% keyword: raster
#% keyword: import
#% keyword: projection
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
+#%option G_OPT_F_BIN_INPUT
#% description: Name of GDAL dataset to be imported
#% guisection: Input
#%end
@@ -54,11 +51,12 @@
#%option
#% key: resample
#% type: string
-#% required: yes
+#% required: no
#% multiple: no
#% options: nearest,bilinear,bicubic,lanczos,bilinear_f,bicubic_f,lanczos_f
#% description: Resampling method to use for reprojection
#% descriptions: nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback
+#% answer: nearest
#% guisection: Output
#%end
#%option
@@ -101,6 +99,10 @@
#% description: Do not perform region cropping optimization
#% guisection: Optional
#%end
+#%flag
+#% key: l
+#% description: Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)
+#%end
import sys
@@ -116,6 +118,7 @@
TMPLOC = None
SRCGISRC = None
GISDBASE = None
+TMP_REG_NAME = None
def cleanup():
@@ -124,9 +127,13 @@
grass.try_rmdir(os.path.join(GISDBASE, TMPLOC))
if SRCGISRC:
grass.try_remove(SRCGISRC)
+ if TMP_REG_NAME:
+ grass.run_command('g.remove', type='vector', name=TMP_REG_NAME,
+ flags='f', quiet=True)
def main():
- global TMPLOC, SRCGISRC, GISDBASE
+ global TMPLOC, SRCGISRC, GISDBASE, TMP_REG_NAME
GDALdatasource = options['input']
output = options['output']
@@ -162,7 +169,7 @@
tgtsrs = grass.read_command('g.proj', flags='j', quiet=True)
# create temp location from input without import
- grass.message(_("Creating temporary location for <%s>...") % GDALdatasource)
+ grass.verbose(_("Creating temporary location for <%s>...") % GDALdatasource)
parameters = dict(input=GDALdatasource, output=output,
memory=memory, flags='c',
location=TMPLOC, quiet=True)
@@ -176,26 +183,24 @@
# switch to temp location
os.environ['GISRC'] = str(SRCGISRC)
- # compare source and target srs
- insrs = grass.read_command('g.proj', flags='j', quiet=True)
# switch to target location
os.environ['GISRC'] = str(tgtgisrc)
- if insrs == tgtsrs:
- # try r.in.gdal directly
+ # try r.in.gdal directly first
+ additional_flags = 'l' if flags['l'] else ''
+ if grass.run_command('r.in.gdal', input=GDALdatasource, flags='j',
+ errors='status', quiet=True) == 0:
- memory=memory, flags='k')
+ memory=memory, flags='k' + additional_flags)
if bands:
parameters['band'] = bands
- grass.message(_("Importing <%s>...") % GDALdatasource)
try:
grass.run_command('r.in.gdal', **parameters)
- except CalledModuleError:
+ grass.verbose(_("Input <%s> successfully imported without reprojection") % GDALdatasource)
+ return 0
+ except CalledModuleError as e:
grass.fatal(_("Unable to import GDAL dataset <%s>") % GDALdatasource)
- grass.message(_("Input <%s> successfully imported without reprojection") % GDALdatasource)
- return 0
# make sure target is not xy
if grass.parse_command('g.proj', flags='g')['name'] == 'xy_location_unprojected':
grass.fatal(_("Coordinate reference system not available for current location <%s>") % tgtloc)
@@ -208,9 +213,9 @@
grass.fatal(_("Coordinate reference system not available for input <%s>") % GDALdatasource)
# import into temp location
- grass.message(_("Importing <%s> to temporary location...") % GDALdatasource)
+ grass.verbose(_("Importing <%s> to temporary location...") % GDALdatasource)
if bands:
try:
@@ -256,17 +261,27 @@
memory=memory, quiet=True)
grass.fatal(_("Unable to get reprojected map extent"))
+ try:
+ srcregion = grass.parse_key_val(tgtextents, val_type=float, vsep=' ')
+ n = srcregion['n']
+ s = srcregion['s']
+ e = srcregion['e']
+ w = srcregion['w']
+ except ValueError: # import into latlong, expect 53:39:06.894826N
+ srcregion = grass.parse_key_val(tgtextents, vsep=' ')
+ n = grass.float_or_dms(srcregion['n'][:-1]) * \
+ (-1 if srcregion['n'][-1] == 'S' else 1)
+ s = grass.float_or_dms(srcregion['s'][:-1]) * \
+ (-1 if srcregion['s'][-1] == 'S' else 1)
+ e = grass.float_or_dms(srcregion['e'][:-1]) * \
+ (-1 if srcregion['e'][-1] == 'W' else 1)
+ w = grass.float_or_dms(srcregion['w'][:-1]) * \
+ (-1 if srcregion['w'][-1] == 'W' else 1)
- srcregion = grass.parse_key_val(tgtextents, val_type=float, vsep=' ')
- n = srcregion['n']
- s = srcregion['s']
- e = srcregion['e']
- w = srcregion['w']
grass.run_command('g.region', n=n, s=s, e=e, w=w)
# v.in.region in tgt
- vreg = 'vreg_' + str(os.getpid())
+ vreg = TMP_REG_NAME = 'vreg_tmp_' + str(os.getpid())
grass.run_command('v.in.region', output=vreg, quiet=True)
grass.del_temp_region()
@@ -283,20 +298,23 @@
# set region from region vector
grass.run_command('g.region', raster=outfile)
grass.run_command('g.region', vector=vreg)
- # align to fist band
+ # align to first band
grass.run_command('g.region', align=outfile)
# get number of cells
cells = grass.region()['cells']
estres = math.sqrt((n - s) * (e - w) / cells)
+ # remove from source location for multi bands import
+ grass.run_command('g.remove', type='vector', name=vreg,
- grass.message(_("Estimated target resolution for input band <%s>: %g") % (outfile, estres))
+ grass.message(_("Estimated target resolution for input band <{out}>: {res}").format(out=outfile, res=estres))
if flags['e']:
- return 0
+ continue
if options['extent'] == 'input':
grass.use_temp_region()
@@ -307,6 +325,14 @@
res = estres
elif tgtres == 'value':
res = tgtres_value
+ grass.message(_("Using given resolution for input band <{out}>: {res}").format(out=outfile, res=res))
+ # align to requested resolution
+ grass.run_command('g.region', res=res, flags='a')
+ else:
+ curr_reg = grass.region()
+ grass.message(_("Using current region resolution for input band "
+ "<{out}>: nsres={ns}, ewres={ew}").format(out=outfile, ns=curr_reg['nsres'],
+ ew=curr_reg['ewres']))
# r.proj
grass.message(_("Reprojecting <%s>...") % outfile)
@@ -324,9 +350,14 @@
+ if flags['e']:
+ return 0
if group:
grass.run_command('i.group', group=output, input=','.join(outfiles))
+ # TODO: write metadata with r.support
return 0
if __name__ == "__main__":
