[GRASS-SVN] r66696 - in grass-addons/grass7/raster/r.green/r.green.hydro: r.green.hydro.discharge r.green.hydro.financial r.green.hydro.optimal r.green.hydro.recommended r.green.hydro.structure r.green.hydro.technical r.green.hydro.theoretical
Sun Nov 1 22:18:49 PST 2015
Author: zarch
Date: 2015-11-01 22:18:49 -0800 (Sun, 01 Nov 2015)
New Revision: 66696
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
r.green: Fix undefine warning function introduced in r66681
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py	2015-11-01 22:44:41 UTC (rev 66695)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py	2015-11-02 06:18:49 UTC (rev 66696)
@@ -182,7 +182,7 @@
     from libgreen.utils import cleanup
     from libhydro.basin import dtm_corr
 except ImportError:
-    warning('libgreen and libhydro not in the python path!')
+    gcore.warning('libgreen and libhydro not in the python path!')
 if "GISBASE" not in os.environ:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py	2015-11-01 22:44:41 UTC (rev 66695)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py	2015-11-02 06:18:49 UTC (rev 66696)
@@ -513,8 +513,9 @@
 try:
     import numexpr as ne
 except ImportError:
+    ne = None
     warning('You should install numexpr to use this module: '
-                  'pip install numexpr')
+            'pip install numexpr')
 try:
     # set python path to the shared r.green libraries
@@ -595,8 +596,9 @@
 def get_cnames(expr,
-               _names_cache=ne.utils.CacheDict(256),
-               _numexpr_cache=ne.utils.CacheDict(256), **kwargs):
+               _names_cache=ne.utils.CacheDict(256) if ne else ne,
+               _numexpr_cache=ne.utils.CacheDict(256) if ne else ne,
+               **kwargs):
     if not isinstance(expr, (str, unicode)):
         raise ValueError("must specify expression as a string")
     # Get the names for this expression
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py	2015-11-01 22:44:41 UTC (rev 66695)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py	2015-11-02 06:18:49 UTC (rev 66696)
@@ -118,7 +118,7 @@
     from libhydro.optimal import write_plants
     from libhydro.optimal import write_points
 except ImportError:
 # optimization problem
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py	2015-11-01 22:44:41 UTC (rev 66695)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py	2015-11-02 06:18:49 UTC (rev 66696)
@@ -205,7 +205,7 @@
     # finally import the module in the library
 except ImportError:
     print("You must be in GRASS GIS to run this program.")
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py	2015-11-01 22:44:41 UTC (rev 66695)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py	2015-11-02 06:18:49 UTC (rev 66696)
@@ -133,7 +133,7 @@
 import atexit
 from grass.exceptions import ParameterError
-from grass.script.core import parser, overwrite
+from grass.script.core import parser, overwrite, warning
 from grass.pygrass.utils import set_path
 from grass.pygrass.raster import RasterRow
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py	2015-11-01 22:44:41 UTC (rev 66695)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py	2015-11-02 06:18:49 UTC (rev 66696)
@@ -234,7 +234,7 @@
     from libhydro.optimal import conv_segpoints
 except ImportError:
 DEBUG = False
 TMPRAST = []
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py	2015-11-01 22:44:41 UTC (rev 66695)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py	2015-11-02 06:18:49 UTC (rev 66696)
@@ -114,7 +114,7 @@
     from libgreen.utils import raster2numpy
     from libgreen.utils import remove_pixel_from_raster
 except ImportError:
