[GRASS-SVN] r66727 - grass/branches/releasebranch_7_0/gui/wxpython/xml
svn_grass at osgeo.org
Tue Nov 3 08:28:34 PST 2015
Author: neteler
Date: 2015-11-03 08:28:34 -0800 (Tue, 03 Nov 2015)
New Revision: 66727
grass/branches/releasebranch_7_0/gui/wxpython/xml/wxgui_items.xml
wxgui_items.xml: update of a few of several outdated module descriptions (avoid almost identical strings. Make them identical or significantly different for good reason (trunk, r66687)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/xml/wxgui_items.xml
--- grass/branches/releasebranch_7_0/gui/wxpython/xml/wxgui_items.xml 2015-11-03 12:53:15 UTC (rev 66726)
+++ grass/branches/releasebranch_7_0/gui/wxpython/xml/wxgui_items.xml 2015-11-03 16:28:34 UTC (rev 66727)
@@ -192,14 +192,14 @@
<label>Common formats import</label>
<handler>OnImportGdalLayers</handler>
<related-module>r.in.gdal</related-module>
- <description>Import raster data into a GRASS map layer using GDAL.</description>
+ <description>Imports raster data into a GRASS raster map using GDAL library.</description>
<keywords>raster,import</keywords>
</wxgui-item>
<wxgui-item name="CommonImportFormats">
<label>Common import formats</label>
<handler>OnImportOgrLayers</handler>
<related-module>v.in.ogr</related-module>
- <description>Converts vector layers into a GRASS vector map using OGR.</description>
+ <description>Imports vector data into a GRASS vector map using OGR library.</description>
<keywords>vector,import</keywords>
</wxgui-item>
<wxgui-item name="DXFImport">
