[GRASS-SVN] r66728 - grass/trunk
    svn_grass at osgeo.org
    Tue Nov  3 08:34:22 PST 2015
Author: neteler
Date: 2015-11-03 08:34:21 -0800 (Tue, 03 Nov 2015)
New Revision: 66728
   grass/trunk/aclocal.m4
   grass/trunk/configure
Makefile system: add soname on linux (trac #68)
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4	2015-11-03 16:28:34 UTC (rev 66727)
+++ grass/trunk/aclocal.m4	2015-11-03 16:34:21 UTC (rev 66728)
@@ -488,7 +488,7 @@
     case $host in
         *-linux-* | *-gnu* | *-kfreebsd*-gnu)
 	    SHLIB_CFLAGS="-fPIC"
-            SHLIB_LD_FLAGS=""
+            SHLIB_LD_FLAGS="-Wl,-soname,\$(notdir \$[@])"
 	    SHLIB_SUFFIX=".so"
 	    SHLIB_LD="${CC} -shared"
             LDFLAGS="-Wl,--export-dynamic"
Modified: grass/trunk/configure
--- grass/trunk/configure	2015-11-03 16:28:34 UTC (rev 66727)
+++ grass/trunk/configure	2015-11-03 16:34:21 UTC (rev 66728)
@@ -1481,7 +1481,7 @@
     case $host in
-            SHLIB_LD_FLAGS=""
+            SHLIB_LD_FLAGS="-Wl,-soname,\$(notdir \$@)"
 	    SHLIB_SUFFIX=".so"
@@ -11805,7 +11805,58 @@
   fi
 fi
+for ac_declaration in \
+   '#include <stdlib.h>' \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+  cat > conftest.$ac_ext <<EOF
+#line 11819 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:11827: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  continue
+fi
+rm -f conftest*
+#line 11837 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:11844: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
 	CXX=
 	CXXFLAGS=
@@ -11818,7 +11869,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:11822: checking whether to use openDWG" >&5
+echo "configure:11873: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -11838,7 +11889,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:11842: checking for location of openDGW includes" >&5
+echo "configure:11893: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -11864,15 +11915,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11868: checking for $ac_hdr" >&5
+echo "configure:11919: checking for $ac_hdr" >&5
-#line 11871 "configure"
+#line 11922 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11927: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -11906,7 +11957,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:11910: checking for location of openDWG library" >&5
+echo "configure:11961: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -11947,7 +11998,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:11951: checking whether to use POSIX threads" >&5
+echo "configure:12002: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -11967,7 +12018,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:11971: checking for location of POSIX threads includes" >&5
+echo "configure:12022: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -11993,15 +12044,15 @@
 do
-echo "configure:11997: checking for $ac_hdr" >&5
+echo "configure:12048: checking for $ac_hdr" >&5
-#line 12000 "configure"
+#line 12051 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12056: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12035,7 +12086,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12039: checking for location of POSIX threads library" >&5
+echo "configure:12090: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12060,10 +12111,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12064: checking for pthread_create" >&5
+echo "configure:12115: checking for pthread_create" >&5
-#line 12067 "configure"
+#line 12118 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -12086,7 +12137,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12113,13 +12164,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12117: checking for pthread_create in -lpthread" >&5
+echo "configure:12168: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpthread  $LIBS"
-#line 12123 "configure"
+#line 12174 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12130,7 +12181,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12180,7 +12231,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12184: checking whether to use OpenMP" >&5
+echo "configure:12235: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12201,7 +12252,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12205: checking for location of OpenMP includes" >&5
+echo "configure:12256: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12227,15 +12278,15 @@
 do
-echo "configure:12231: checking for $ac_hdr" >&5
+echo "configure:12282: checking for $ac_hdr" >&5
-#line 12234 "configure"
+#line 12285 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12239: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12273,7 +12324,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12277: checking for location of OpenMP library" >&5
+echo "configure:12328: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12298,10 +12349,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12302: checking for GOMP_parallel_start" >&5
+echo "configure:12353: checking for GOMP_parallel_start" >&5
-#line 12305 "configure"
+#line 12356 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12324,7 +12375,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12351,13 +12402,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12355: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12406: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12361 "configure"
+#line 12412 "configure"
@@ -12368,7 +12419,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12441,7 +12492,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12445: checking whether to use OpenCL" >&5
+echo "configure:12496: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -12461,7 +12512,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12465: checking for location of OpenCL includes" >&5
+echo "configure:12516: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12488,15 +12539,15 @@
 do
-echo "configure:12492: checking for $ac_hdr" >&5
+echo "configure:12543: checking for $ac_hdr" >&5
-#line 12495 "configure"
+#line 12546 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12500: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12551: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12536,10 +12587,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:12540: checking for clGetPlatformInfo" >&5
+echo "configure:12591: checking for clGetPlatformInfo" >&5
-#line 12543 "configure"
+#line 12594 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -12562,7 +12613,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -12601,15 +12652,15 @@
 do
-echo "configure:12605: checking for $ac_hdr" >&5
+echo "configure:12656: checking for $ac_hdr" >&5
-#line 12608 "configure"
+#line 12659 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12613: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12664: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12642,7 +12693,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:12646: checking for location of OpenCL library" >&5
+echo "configure:12697: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -12666,13 +12717,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:12670: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:12721: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 12676 "configure"
+#line 12727 "configure"
@@ -12683,7 +12734,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:12687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12743,7 +12794,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:12747: checking for special C compiler options needed for large files" >&5
+echo "configure:12798: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -12751,7 +12802,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 12755 "configure"
+#line 12806 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -12767,7 +12818,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12771: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12822: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -12776,7 +12827,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 12780 "configure"
+#line 12831 "configure"
@@ -12792,7 +12843,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12796: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12847: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -12819,11 +12870,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:12823: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:12874: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 12827 "configure"
+#line 12878 "configure"
@@ -12839,14 +12890,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12843: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12894: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 12850 "configure"
+#line 12901 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -12864,7 +12915,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12868: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12919: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -12890,11 +12941,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:12894: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:12945: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 12898 "configure"
+#line 12949 "configure"
@@ -12910,14 +12961,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12914: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12965: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 12921 "configure"
+#line 12972 "configure"
 #define _LARGE_FILES 1
@@ -12935,7 +12986,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12939: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12990: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -12961,25 +13012,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:12965: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13016: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 12969 "configure"
+#line 13020 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:12976: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13027: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 12983 "configure"
+#line 13034 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -12988,7 +13039,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:12992: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13043: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13020,25 +13071,25 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13024: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13075: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13028 "configure"
+#line 13079 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13035: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13086: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13042 "configure"
+#line 13093 "configure"
 #include <stdio.h>
@@ -13047,7 +13098,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13051: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13102: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13077,18 +13128,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13081: checking for fseeko" >&5
+echo "configure:13132: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13085 "configure"
+#line 13136 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13105,10 +13156,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13109: checking if system supports Large Files at all" >&5
+echo "configure:13160: checking if system supports Large Files at all" >&5
-#line 13112 "configure"
+#line 13163 "configure"
 #include <stdio.h>
@@ -13140,7 +13191,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13144: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13195: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
