[GRASS-SVN] r66822 - grass/trunk/vector/v.patch
Thu Nov 12 14:28:39 PST 2015
Author: wenzeslaus
Date: 2015-11-12 14:28:39 -0800 (Thu, 12 Nov 2015)
New Revision: 66822
   grass/trunk/vector/v.patch/main.c
v.patch: flags to work without topology and with z [news]
Merge point clouds with -nzb flags to skip z check,
not require topology and use z even when it was not detected
(since the topology/index/meta was missing).
Modified: grass/trunk/vector/v.patch/main.c
--- grass/trunk/vector/v.patch/main.c	2015-11-12 16:04:33 UTC (rev 66821)
+++ grass/trunk/vector/v.patch/main.c	2015-11-12 22:28:39 UTC (rev 66822)
@@ -50,6 +50,7 @@
     struct GModule *module;
     struct Option *old, *new, *bbox;
     struct Flag *append, *table_flag, *no_topo;
+    struct Flag *no_input_topo_flag, *force_z_flag;
     struct Map_info InMap, OutMap, BBoxMap;
     int n_files;
     int do_table;
@@ -80,18 +81,31 @@
     bbox->description =
 	_("Name for output vector map where bounding boxes of input vector maps are written to");
-    append = G_define_flag();
-    append->key = 'a';
-    append->description = _("Append files to existing file "
-			    "(overwriting existing files must be activated)");
+    no_input_topo_flag = G_define_flag();
+    no_input_topo_flag->key = 'n';
+    no_input_topo_flag->label = _("Do not expect input with topology");
+    no_input_topo_flag->description =
+        _("Applicable when input is points without topology");
+    force_z_flag = G_define_flag();
+    force_z_flag->key = 'z';
+    force_z_flag->label = _("Expect z coordinate even when not using topology");
+    force_z_flag->description =
+        _("Applicable when input is points with z coordinate but without topology");
     table_flag = G_define_flag();
     table_flag->key = 'e';
     table_flag->label = _("Copy also attribute table");
     table_flag->description =
 	_("Only the table of layer 1 is currently supported");
+    append = G_define_flag();
+    append->key = 'a';
+    append->description = _("Append files to existing file "
+			    "(overwriting existing files must be activated)");
     no_topo = G_define_standard_flag(G_FLG_V_TOPO);
+    no_topo->description = _("Advantageous when handling a large number of points");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -109,7 +123,7 @@
 	in_name = old->answers[i++];
 	Vect_check_input_output_name(in_name, new->answer, G_FATAL_EXIT);
-	Vect_set_open_level(2);
+	Vect_set_open_level(no_input_topo_flag->answer ? 1 : 2);
 	if (Vect_open_old_head(&InMap, in_name, "") < 0)
 	    G_fatal_error(_("Unable to open vector map <%s>"), in_name);
@@ -118,6 +132,8 @@
 	Vect_close(&InMap);
+    if (force_z_flag->answer)
+        out_is_3d = WITH_Z;
     table_out = NULL;
     fi_in = NULL;
