[GRASS-SVN] r66823 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Thu Nov 12 14:51:02 PST 2015
Author: wenzeslaus
Date: 2015-11-12 14:51:02 -0800 (Thu, 12 Nov 2015)
New Revision: 66823
grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: import points only in selected areas [news]
It uses a vector map with areas as a mask to specify
where to import the points (ignores points outside
the mask, does the opposite with -i flag).
Cashing the bboxes seems to be slightly faster
than just creating them all over again. Otherwise,
this implementation is the simplest (not fastest) way possible.
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2015-11-12 22:28:39 UTC (rev 66822)
+++ grass/trunk/vector/v.in.lidar/main.c 2015-11-12 22:51:02 UTC (rev 66823)
@@ -113,11 +113,13 @@
struct GModule *module;
struct Option *in_opt, *out_opt, *spat_opt, *filter_opt, *class_opt;
struct Option *id_layer_opt, *return_layer_opt, *class_layer_opt;
+ struct Option *vector_mask_opt, *vector_mask_field_opt;
struct Option *skip_opt, *preserve_opt, *offset_opt, *limit_opt;
struct Option *outloc_opt;
struct Flag *print_flag, *notab_flag, *region_flag, *notopo_flag;
struct Flag *nocats_flag;
struct Flag *over_flag, *extend_flag, *no_import_flag;
+ struct Flag *invert_mask_flag;
char buf[2000];
struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
struct Key_Value *proj_info, *proj_units;
@@ -155,12 +157,12 @@
unsigned long long n_features; /* what libLAS reports as point count */
unsigned long long points_imported; /* counter how much we have imported */
unsigned long long feature_count, n_outside,
- n_filtered, n_class_filtered, not_valid;
+ n_outside_mask, n_filtered, n_class_filtered, not_valid;
#else
unsigned long n_features;
unsigned long points_imported;
unsigned long feature_count, n_outside,
#endif
int overwrite;
@@ -227,6 +229,18 @@
"If not specified, all points are imported.");
class_opt->guisection = _("Selection");
+ vector_mask_opt = G_define_standard_option(G_OPT_V_INPUT);
+ vector_mask_opt->key = "mask";
+ vector_mask_opt->required = NO;
+ vector_mask_opt->label = _("Areas where to import points");
+ vector_mask_opt->description = _("Name of vector map with areas where the points should be imported");
+ vector_mask_opt->guisection = _("Selection");
+ vector_mask_field_opt = G_define_standard_option(G_OPT_V_FIELD);
+ vector_mask_field_opt->key = "mask_layer";
+ vector_mask_field_opt->label = _("Layer number or name for mask option");
+ vector_mask_field_opt->guisection = _("Selection");
skip_opt = G_define_option();
skip_opt->key = "skip";
skip_opt->type = TYPE_INTEGER;
@@ -283,6 +297,11 @@
region_flag->guisection = _("Selection");
region_flag->description = _("Limit import to the current region");
+ invert_mask_flag = G_define_flag();
+ invert_mask_flag->key = 'i';
+ invert_mask_flag->description = _("Invert mask when selecting points");
+ invert_mask_flag->guisection = _("Selection");
extend_flag = G_define_flag();
extend_flag->key = 'e';
extend_flag->description =
@@ -752,6 +771,23 @@
db_begin_transaction(driver);
+ struct Map_info vector_mask;
+ int naareas;
+ int aarea;
+ struct bound_box *mask_area_boxes;
+ int invert_mask = 0;
+ if (vector_mask_opt->answer) {
+ if (Vect_open_old2(&vector_mask, vector_mask_opt->answer, "", vector_mask_field_opt->answer) < 2)
+ G_fatal_error(_("Failed to open vector <%s>"), vector_mask_opt->answer);
+ naareas = Vect_get_num_areas(&vector_mask);
+ mask_area_boxes = G_malloc(naareas * sizeof(struct bound_box));
+ for (aarea = 1; aarea <= naareas; aarea++) {
+ Vect_get_area_box(&vector_mask, aarea, &mask_area_boxes[aarea - 1]);
+ if (invert_mask_flag->answer)
+ invert_mask = 1;
/* Import feature */
points_imported = 0;
cat = 1;
@@ -760,6 +796,7 @@
n_outside = 0;
n_filtered = 0;
n_class_filtered = 0;
+ n_outside_mask = 0;
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -817,6 +854,19 @@
continue;
+ skipme = TRUE;
+ if (Vect_point_in_area(x, y, &vector_mask, aarea, &mask_area_boxes[aarea - 1])) {
+ skipme = FALSE;
+ break;
+ if (invert_mask ^ skipme) {
+ n_outside_mask++;
+ continue;
if (return_filter != LAS_ALL) {
int return_no = LASPoint_GetReturnNumber(LAS_point);
int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
@@ -992,6 +1042,11 @@
db_close_database_shutdown_driver(driver);
+ Vect_close(&vector_mask);
+ G_free(mask_area_boxes);
LASSRS_Destroy(LAS_srs);
LASHeader_Destroy(LAS_header);
LASReader_Destroy(LAS_reader);
@@ -1004,7 +1059,7 @@
/* can be easily determined only when iterated over all points */
if (!limit_n && !cat_max_reached && points_imported != n_features
- not_valid - n_outside - n_filtered - n_class_filtered
- - offset_n_counter - n_count_filtered)
+ - n_outside_mask - offset_n_counter - n_count_filtered)
G_warning(_("The underlying libLAS library is at its limits."
" Previously reported counts might have been distorted."
" However, the import itself should be unaffected."));
@@ -1018,6 +1073,8 @@
G_message(_("%llu input points were not valid"), not_valid);
if (n_outside)
G_message(_("%llu input points were outside of the selected area"), n_outside);
+ if (n_outside_mask)
+ G_message(_("%llu input points were outside of the area specified by mask"), n_outside_mask);
if (n_filtered)
G_message(_("%llu input points were filtered out by return number"), n_filtered);
if (n_class_filtered)
@@ -1035,6 +1092,8 @@
G_message(_("%lu input points were not valid"), not_valid);
if (n_outside)
G_message(_("%lu input points were outside of the selected area"), n_outside);
+ G_message(_("%lu input points were outside of the area specified by mask"), n_outside_mask);
if (n_filtered)
G_message(_("%lu input points were filtered out by return number"), n_filtered);
