[GRASS-SVN] r66851 - grass-addons/grass7/vector/v.import
svn_grass at osgeo.org
Mon Nov 16 06:46:56 PST 2015
Author: neteler
Date: 2015-11-16 06:46:56 -0800 (Mon, 16 Nov 2015)
New Revision: 66851
grass-addons/grass7/vector/v.import/v.import.html
grass-addons/grass7/vector/v.import/v.import.py
v.import Addon: sync to relbranch70
Modified: grass-addons/grass7/vector/v.import/v.import.html
--- grass-addons/grass7/vector/v.import/v.import.html 2015-11-16 13:10:41 UTC (rev 66850)
+++ grass-addons/grass7/vector/v.import/v.import.html 2015-11-16 14:46:56 UTC (rev 66851)
@@ -7,23 +7,23 @@
the projection of the location, the input is imported directly with
<a href="v.in.ogr.html">v.in.ogr</a>.
-<h4>Topology cleaning</h4>
+<h2>NOTES</h2>
+<h3>Topology cleaning</h3>
When importing polygons, non-topological polygons are converted to
-topological areas. If the original polygons contain errors (unexpected
+topological areas. By default, a very small snapping threshold is applied
+(1e-13 map units) to avoid topological errors caused by numerical inaccuracy
+of the input data format. If the original polygons contain errors (unexpected
overlapping areas or small gaps between polygons), the import might
-need to be repeated using the <em>snap</em> option for
-<a href="v.in.ogr.html">v.in.ogr</a>. In this case, automated import and
-reprojection does not work, and the data need to be manually imported
-first with appropriate settings and optionally cleaned afterwards with
-<a href="v.clean.html">v.clean</a>. The cleaned import can then be
-manually reprojected to the target location.
+need to be repeated using a larger <em>snap</em> value.
<h2>EXAMPLE</h2>
<div class="code"><pre>
# import SHAPE file at full extent and reproject to current location projection
-v.import input=research_area.shp output=research_area extents=input
+v.import input=research_area.shp output=research_area extent=input
</pre></div>
<h2>SEE ALSO</h2>
@@ -33,9 +33,10 @@
<a href="v.proj.html">v.proj</a>
</em>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
-Markus Metz
+Markus Metz<br>
+Improvements: Martin Landa, Anna Petrasova
<p>
<i>Last changed: $Date: 2015-01-20 20:52:27 +0100 (Tue, 20 Jan 2015) $</i>
Modified: grass-addons/grass7/vector/v.import/v.import.py
--- grass-addons/grass7/vector/v.import/v.import.py 2015-11-16 13:10:41 UTC (rev 66850)
+++ grass-addons/grass7/vector/v.import/v.import.py 2015-11-16 14:46:56 UTC (rev 66851)
@@ -17,17 +17,16 @@
#%module
-#% description: Imports vector data into a GRASS vector map using OGR library and reproject on the fly.
+#% description: Imports vector data into a GRASS vector map using OGR library and reprojects on the fly.
#% keyword: vector
#% keyword: import
#% keyword: projection
#%end
-#%option
+#%option G_OPT_F_BIN_INPUT
#% key: input
-#% type: string
#% required: yes
#% description: Name of OGR datasource to be imported
-#% gisprompt: old,datasource,datasource
+#% guisection: Input
#%end
#%option
#% key: layer
@@ -35,7 +34,6 @@
#% multiple: yes
#% description: OGR layer name. If not given, all available layers are imported
-#% gisprompt: old,datasource_layer,datasource_layer
#%end
#%option G_OPT_V_OUTPUT
#% description: Name for output vector map (default: input)
@@ -43,12 +41,12 @@
#% guisection: Output
#%end
#%option
-#% key: extents
+#% key: extent
#% type: string
#% options: input,region
#% answer: input
-#% description: Ouput vector map extents
-#% descriptions: input;extents of input map;region;extents of current region
+#% description: Output vector map extent
+#% descriptions: input;extent of input map;region;extent of current region
#%end
#%option
@@ -58,6 +56,14 @@
#% descriptions: Overrides encoding interpretation, useful when importing ESRI Shapefile
#%end
+#%option
+#% key: snap
+#% type: double
+#% label: Snapping threshold for boundaries (map units)
+#% description: '-1' for no snap
+#% answer: 1e-13
+#% guisection: Output
+#%end
#%flag
#% key: f
#% description: List supported OGR formats and exit
@@ -71,28 +77,28 @@
import sys
import os
-import shutil
import atexit
-import math
import grass.script as grass
+from grass.exceptions import CalledModuleError
+# initialize global vars
+TMPLOC = None
+SRCGISRC = None
+GISDBASE = None
def cleanup():
# remove temp location
- if tmploc:
- grass.try_rmdir(os.path.join(gisdbase, tmploc))
- if srcgisrc:
- grass.try_remove(srcgisrc)
+ if TMPLOC:
+ grass.try_rmdir(os.path.join(GISDBASE, TMPLOC))
+ if SRCGISRC:
+ grass.try_remove(SRCGISRC)
def main():
- global tmploc, srcgisrc, gisdbase
+ global TMPLOC, SRCGISRC, GISDBASE
- # initialize global vars
- tmploc = None
- srcgisrc = None
- gisdbase = None
# list formats and exit
if flags['f']:
grass.run_command('v.in.ogr', flags='f')
@@ -102,53 +108,54 @@
if flags['l']:
grass.run_command('v.in.ogr', flags='l', input=options['input'])
return 0
OGRdatasource = options['input']
output = options['output']
layers = options['layer']
vflags = None
- if options['extents'] == 'region':
+ if options['extent'] == 'region':
vflags = 'r'
vopts = {}
if options['encoding']:
vopts['encoding'] = options['encoding']
grassenv = grass.gisenv()
tgtloc = grassenv['LOCATION_NAME']
tgtmapset = grassenv['MAPSET']
- gisdbase = grassenv['GISDBASE']
+ GISDBASE = grassenv['GISDBASE']
tgtgisrc = os.environ['GISRC']
- srcgisrc = grass.tempfile()
- tmploc = 'temp_import_location_' + str(os.getpid())
+ SRCGISRC = grass.tempfile()
- f = open(srcgisrc, 'w')
+ TMPLOC = 'temp_import_location_' + str(os.getpid())
+ f = open(SRCGISRC, 'w')
f.write('MAPSET: PERMANENT\n')
- f.write('GISDBASE: %s\n' % gisdbase)
- f.write('LOCATION_NAME: %s\n' % tmploc);
+ f.write('GISDBASE: %s\n' % GISDBASE)
+ f.write('LOCATION_NAME: %s\n' % TMPLOC)
f.write('GUI: text\n')
f.close()
- tgtsrs = grass.read_command('g.proj', flags = 'j', quiet = True)
+ tgtsrs = grass.read_command('g.proj', flags='j', quiet=True)
# create temp location from input without import
- grass.message(_("Creating temporary location for <%s>...") % OGRdatasource)
+ grass.verbose(_("Creating temporary location for <%s>...") % OGRdatasource)
if layers:
vopts['layer'] = layers
if output:
vopts['output'] = output
- returncode = grass.run_command('v.in.ogr', input = OGRdatasource,
- location = tmploc, flags = 'i', quiet = True, **vopts)
- # if it fails, return
- if returncode != 0:
+ vopts['snap'] = options['snap']
+ try:
+ grass.run_command('v.in.ogr', input=OGRdatasource,
+ location=TMPLOC, flags='i', quiet=True, **vopts)
+ except CalledModuleError:
grass.fatal(_("Unable to create location from OGR datasource <%s>") % OGRdatasource)
# switch to temp location
- os.environ['GISRC'] = str(srcgisrc)
+ os.environ['GISRC'] = str(SRCGISRC)
# compare source and target srs
- insrs = grass.read_command('g.proj', flags = 'j', quiet = True)
+ insrs = grass.read_command('g.proj', flags='j', quiet=True)
# switch to target location
os.environ['GISRC'] = str(tgtgisrc)
@@ -156,61 +163,58 @@
if insrs == tgtsrs:
# try v.in.ogr directly
grass.message(_("Importing <%s>...") % OGRdatasource)
- flags = vflags, **vopts)
- # if it succeeds, return
- if returncode == 0:
- grass.message(_("Input <%s> successfully imported without reprojection") % OGRdatasource)
+ try:
+ flags=vflags, **vopts)
+ grass.message(_("Input <%s> successfully imported without reprojection") % OGRdatasource)
return 0
- else:
grass.fatal(_("Unable to import <%s>") % OGRdatasource)
# make sure target is not xy
- if grass.parse_command('g.proj', flags = 'g')['name'] == 'xy_location_unprojected':
+ if grass.parse_command('g.proj', flags='g')['name'] == 'xy_location_unprojected':
grass.fatal(_("Coordinate reference system not available for current location <%s>") % tgtloc)
# make sure input is not xy
- grass.fatal(_("Coordinate reference system not available for input <%s>") % GDALdatasource)
+ grass.fatal(_("Coordinate reference system not available for input <%s>") % OGRdatasource)
# v.in.region in tgt
vreg = 'vreg_' + str(os.getpid())
- grass.run_command('v.in.region', output = vreg, quiet = True)
+ grass.run_command('v.in.region', output=vreg, quiet=True)
# reproject to src
- returncode = grass.run_command('v.proj', input = vreg, output = vreg,
- location = tgtloc, mapset = tgtmapset, quiet = True)
+ try:
+ grass.run_command('v.proj', input=vreg, output=vreg,
+ location=tgtloc, mapset=tgtmapset, quiet=True)
grass.fatal(_("Unable to reproject to source location"))
# set region from region vector
- grass.run_command('g.region', res = '1')
- grass.run_command('g.region', vector = vreg)
+ grass.run_command('g.region', res='1')
+ grass.run_command('g.region', vector=vreg)
# import into temp location
grass.message(_("Importing <%s> ...") % OGRdatasource)
+ try:
grass.fatal(_("Unable to import OGR datasource <%s>") % OGRdatasource)
# if output is not define check source mapset
if not output:
output = grass.list_grouped('vector')['PERMANENT'][0]
@@ -218,19 +222,20 @@
if not grass.overwrite() and \
grass.find_file(output, element='vector', mapset='.')['mapset']:
grass.fatal(_("option <%s>: <%s> exists.") % ('output', output))
- grass.run_command('g.remove', type = 'vector', name = vreg,
- flags = 'f', quiet = True)
+ grass.run_command('g.remove', type='vector', name=vreg,
+ flags='f', quiet=True)
# v.proj
grass.message(_("Reprojecting <%s>...") % output)
- returncode = grass.run_command('v.proj', location = tmploc,
- mapset = 'PERMANENT', input = output,
- quiet = True)
+ try:
+ grass.run_command('v.proj', location=TMPLOC,
+ mapset='PERMANENT', input=output,
+ quiet=True)
grass.fatal(_("Unable to to reproject vector <%s>") % output)
return 0
if __name__ == "__main__":
