[GRASS-SVN] r66852 - grass-addons/grass7/vector/v.class.mlR
Mon Nov 16 08:52:06 PST 2015
Author: mlennert
Date: 2015-11-16 08:52:06 -0800 (Mon, 16 Nov 2015)
New Revision: 66852
   grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html
   grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py
check if R directory exists in $HOME, if not create one and use it for install of package
Modified: grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html
--- grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html	2015-11-16 14:46:56 UTC (rev 66851)
+++ grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html	2015-11-16 16:52:06 UTC (rev 66852)
@@ -49,7 +49,9 @@
 latter solution is quite useful in a computer lab where rpy2 is not installed).
 <p>
-Other classifiers should be included.
+Other classifiers should be included. One option would be to use the 'caret'
+R package but this would mean handling the different dependency packages for
+the different methods.
 <h2>EXAMPLE</h2>
Modified: grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py
--- grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py	2015-11-16 14:46:56 UTC (rev 66851)
+++ grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py	2015-11-16 16:52:06 UTC (rev 66852)
@@ -148,10 +148,18 @@
     r_file = open(r_commands, 'w')
+    create_dir = 'homeR = paste(Sys.getenv("HOME"), "/R/personal", sep="")\n'
+    create_dir += "if(!file.exists(homeR)) {dir.create(homeR, recursive=TRUE)}\n"
+    create_dir += ".libPaths(homeR)"
+    r_file.write(create_dir)
+    r_file.write("\n")
     install = "if(!is.element('e1071', installed.packages()[,1])) "
-    install += "{cat('\n\nInstalling e1071 package from CRAN\n\n')\n"
+    install += "{cat('\n\nInstalling e1071 package from CRAN into\n')\n"
+    install += "cat(homeR)\n"
+    install += "cat('\n')\n"
     install += "install.packages('e1071', "
-    install += "repos='https://mirror.ibcp.fr/pub/CRAN/')}"
+    install += "repos='https://mirror.ibcp.fr/pub/CRAN/', "
+    install += "lib = homeR)}"
     r_file.write(install)
     r_file.write("\n")
     r_file.write('library(e1071)')
@@ -236,8 +244,14 @@
     r_file.write(model_string)
     r_file.write("\n")
-    r_file.write("cat('\nTuning (or model) summary: ')")
+    r_file.write("cat('\nTuning (or model) summary: \n\n')")
     r_file.write("\n")
+    r_file.write("cat('Kernel used: ')")
+    r_file.write("cat('%s\n')" % kernel)
+    install += "cat('\n')"
     r_file.write("summary(model)")
     r_file.write("\n")
     if tune:
