[GRASS-SVN] r66870 - in grass-addons/grass7/raster: . r.mregression.series r.series.decompose
Thu Nov 19 23:43:28 PST 2015
Author: DmitryKolesov
Date: 2015-11-19 23:43:28 -0800 (Thu, 19 Nov 2015)
New Revision: 66870
Added:
   grass-addons/grass7/raster/r.series.decompose/
   grass-addons/grass7/raster/r.series.decompose/Makefile
   grass-addons/grass7/raster/r.series.decompose/r.series.decompose.html
   grass-addons/grass7/raster/r.series.decompose/r.series.decompose.py
   grass-addons/grass7/raster/r.mregression.series/r.mregression.series.py
Add r.series.decompose (draft version, refactoring is required)
Modified: grass-addons/grass7/raster/r.mregression.series/r.mregression.series.py
--- grass-addons/grass7/raster/r.mregression.series/r.mregression.series.py	2015-11-20 06:01:25 UTC (rev 66869)
+++ grass-addons/grass7/raster/r.mregression.series/r.mregression.series.py	2015-11-20 07:43:28 UTC (rev 66870)
@@ -7,7 +7,7 @@
 # AUTHOR(S):    Dmitry Kolesov <kolesov.dm at gmail.com>
-# PURPOSE:      multiple regression between two time series
+# PURPOSE:      multiple regression between several time series
 # COPYRIGHT:    (C) 2015 by the GRASS Development Team
@@ -18,7 +18,7 @@
 #%Module
-#% description: Program calculates multiple regression between two series: Y = a1*X1 + ... + an*Xn
+#% description: Program calculates multiple regression between time series: Y = b1*X1 + ... + bn*Xn
 #% overwrite: yes
 #%End
 #%option
@@ -244,7 +244,6 @@
                         b.put(r, c, coefs[i])
         finally:
             self.close_rasters()
-        print 'ols'
 def main(options, flags):
Added: grass-addons/grass7/raster/r.series.decompose/Makefile
--- grass-addons/grass7/raster/r.series.decompose/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.series.decompose/Makefile	2015-11-20 07:43:28 UTC (rev 66870)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR =../..
+PGM = r.series.decompose
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.series.decompose/r.series.decompose.html
--- grass-addons/grass7/raster/r.series.decompose/r.series.decompose.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.series.decompose/r.series.decompose.html	2015-11-20 07:43:28 UTC (rev 66870)
@@ -0,0 +1,148 @@
+<h2>DESCRIPTION</h2>
+<em>r.series.decompose</em> is a module to calculate decomposintion of signal X.
+<div class="code"><pre>
+X(t) = B0 + B1*t + B2*sin(B1*t) + B3 * cos(B1*t) + ... + B{n-1}*sin(Bk*t) + Bn * cos(Bk*t) + e
+</pre></div>
+<p>
+where <em>X</em> is a raster time series, <em>t</em> is time (<em>t</em>
+in <em>[0, pi]</em>), <em>sin(Fi*t)</em> and <em>cos(Fi*t)</em> are time
+variables; <em>Fi</em> are user specifed frequencies; <em>e</em> is a error.
+<p>
+The module used r.mregression.series to find the regression coefficients
+<em>Bi</em>, then it produces the fitted rasters series <em>X(t)</em>
+using the coefficients.
+<p>
+So the module makes each output cell value a function of the values
+assigned to the corresponding cells in the time variable raster map series
+and the rasters of the coefficients.
+<p>
+<em>input</em>   Raster names of equally spaced time series <em>X</em>
+<p>
+<em>result_prefix</em> Prefix for raster names of filterd <em>X(t)</em>
+<p>
+<em>coef_prefix</em>   Prefix for names of result raster
+	(rasters of coefficients)
+<p>
+<em>timevar_prefix</em>   Prefix for names of result raster
+	(rasters of time variables)
+<p>
+<em>freq</em>   List of frequencies for sin and cos functions
+<p>
+<h2>NOTES</h2>
+<em>X</em> must be equally spaced time serie. If the serie isn't equally
+spaced, insert NULL raster maps into <em>X</em>.
+<p>
+The list of inputs for each cell (including NULLs) is passed to the
+regression function. The functin compute the parameters over the
+non-NULL values, producing a NULL result only if there aren't enough
+non-NULL values for computing.
+The regression coefficients <em>Bi</em> are stored in raster maps.
+They can be used for construct more detail time series via the equation:
+</pre></div>
+<p>
+To do that the user have to create time variables (<em>t</em>,
+<em>sin(Fi*t)</em> and <em>cos(Fi*t)</em>) at desired time <em>T0</em>
+and then use r.mapcalc to produce the <em>X(T0)</em>.
+<p>
+The maximum number of raster maps to be processed is limited by the
+operating system. For example, both the hard and soft limits are
+typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n
+1500</tt> (UNIX-based operating systems) but not higher than the hard
+limit. If it is too low, you can as superuser add an entry in
+/etc/security/limits.conf
+# <domain>      <type>  <item>         <value>
+your_username  hard    nofile          1500
+</pre></div>
+This would raise the hard limit to 1500 file. Be warned that more
+files open need more RAM.
+<h2>EXAMPLES</h2>
+Suppose we have time series of MODIS NDVI data (from 01 jan to 27 dec):
+<pre>
+> g.mlist rast pattern="mod*", separator=','
+mod2003_01_01,mod2003_01_09,...,mod2003_12_27
+</pre>
+<p>
+We use one year data, so we suppose the there is a half of sinusoid signal
+in the data (NDVI values icrease, then decrease usualy). So 01 jan is t0==0,
+27 dec is tn==2*pi, there is a frequence 0.5 in the data (and there are more
+frequencies, for example 1.0 and 1.5).
+<p>
+Decompose the signal:
+<pre>
+> maps = $(g.list rast pattern="mod*", separator=',')
+> r.series.decompose input=$maps coef_prefix="coef." \
+	timevar_prefix="dec." result_pref="res." \
+	freq=0.5,1.0,1.5
+</pre>
+<p>
+The command creates rasters of the coefficiens <em>coef.*</em>:
+<pre>
+coef.const
+coef.time
+coef.sin_fr0.5
+coef.cos_fr0.5
+coef.sin_fr1.0
+coef.cos_fr1.0
+coef.cos_fr1.5
+coef.sin_fr1.5
+</pre>
+and rasters of fitted NDVI <em>res.*</em>:
+<pre>
+res.mod2003_01_01
+res.mod2003_01_09
+</pre>
+<p>
+To compute NDVI for 03 jan we need: (1) find time <em>T</em> for 03 jan
+(2) create time variables for 02 jan.
+<p>
+The length (in days) of the NDVI time series is 362, 03 jan
+is the third day of the series, so <em>T</em> = <em>3 * (2*pi/362)</em>
+radians. But r.mapcalc uses degrees for <em>sin()</em> and <em>cos()</em>
+functions. So <em>T</em> = <em>3 * 360/362</em> degrees.
+<p>
+Create time variables:
+<pre>
+r.mapcalc "T = 3.0 * 360.0/362.0"
+r.mapcalc "sin0.5 = sin(0.5*3.0*360.0/362.0)"
+r.mapcalc "cos0.5 = cos(0.5*3.0*360.0/362.0)"
+r.mapcalc "sin1 = sin(3.0*360.0/362.0)"
+r.mapcalc "cos1 = cos(3.0*360.0/362.0)"
+r.mapcalc "sin1.5 = sin(1.5*3.0*360.0/362.0)"
+r.mapcalc "cos1.5 = cos(1.5*3.0*360.0/362.0)"
+</pre>
+<p>
+Create NDVI for 03 jan:
+<pre>
+r.mapcals "ndvi03jan = coef.const + coef.time*T +\
+	coef.sin_fr0.5*sin0.4 + coef.cos_fr0.5*cos0.5 +\
+	coef.sin_fr1.0*sin1 + coef.cos_fr1.0*cos1 +\
+	coef.sin_fr1.5*sin1.5 + coef.cos_fr1.5*cos1.5"
+</pre>
+<h2>SEE ALSO</h2>
+<em><a href="addons/r.mregression.series.html">r.regression.series</a></em>,
+<em><a href="r.series.html">r.series</a></em>,
+<em><a href="r.regression.line.html">r.regression.line</a></em>,
+<em><a href="g.list.html">g.list</a></em>,
+<h2>AUTHOR</h2>
+Dmitry Kolesov
+<p><i>Last changed: $Date: 2014-10-29 02:11:08 +0300 (Ср., 29 окт. 2014) $</i>
Added: grass-addons/grass7/raster/r.series.decompose/r.series.decompose.py
--- grass-addons/grass7/raster/r.series.decompose/r.series.decompose.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.series.decompose/r.series.decompose.py	2015-11-20 07:43:28 UTC (rev 66870)
@@ -0,0 +1,238 @@
+#!/usr/bin/env python
+# -*- coding: utf-8  -*-
+# MODULE:       r.series.decompose
+# AUTHOR(S):    Dmitry Kolesov <kolesov.dm at gmail.com>
+# PURPOSE:      Perform decomposition of time series X :
+#               X(t) = b0 + b1 *t + sin(2*pi*t/N) + cos(2*pi*t/N) + ... + sin(2*pi*t/k*N) + cos(2*pi*t/k*N)
+# COPYRIGHT:    (C) 2015 by the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#% description: Program calculates decomposition of time series X
+#% overwrite: yes
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: list of raster names
+#% description: Raster names of equally spaced time series.
+#% required : yes
+#% multiple: yes
+#%end
+#%option
+#% key: result_prefix
+#% type: string
+#% gisprompt: prefix of result raster names
+#% description: Prefix for raster names of filterd X(t)
+#% required : yes
+#% multiple: no
+#%end
+#%option
+#% key: coef_prefix
+#% type: string
+#% gisprompt: prefix for raster names of decomposition coefficients
+#% description: Prefix for names of result raster (rasters of coefficients)
+#% required : yes
+#% multiple: no
+#%end
+#%option
+#% key:  timevar_prefix
+#% type: string
+#% gisprompt: prefix for raster names of time variables
+#% description: Prefix for names of result raster (rasters of time variables)
+#% required : yes
+#% multiple: no
+#%end
+#%option
+#% key: freq
+#% type: double
+#% gisprompt: list of used frequiences
+#% description:  List of frequencies for sin and cos functions
+#% required : yes
+#% multiple: yes
+#%end
+import os
+import sys
+import csv
+import uuid
+from math import pi, degrees
+if "GISBASE" not in os.environ:
+    sys.stderr.write("You must be in GRASS GIS to run this program.\n")
+    sys.exit(1)
+import grass.script as grass
+def get_time(N, t, deg=True):
+    """Returns point number t from linspace [0, 2*pi]
+    if deg == True, return degrees
+    step = 2 * pi / N
+    x = step * t
+    if deg:
+        x = degrees(x)
+    return x
+def _freq_to_name(freq):
+    return "_fr%s" % (freq)
+def _time_to_name(time):
+    return "_t%04d" % (time, )
+def _generate_time(N, prefix):
+    """Generate (constant) rasters of time line
+        t0, t1, t2, ..., t_{N-1})
+        where t0 = 0, t_{N-1} = 2*pi
+    N -- count of result rasters
+    prefix -- prefix for the raster names
+    return list of names for the result rasters
+    assert N > 1
+    names = dict()
+    for i in range(N):
+        output = prefix + _time_to_name(i)
+        t = get_time(N, i, deg=True)
+        grass.mapcalc("${out} = ${t}", out=output, t=t,
+                      quiet=True, overwrite=grass.overwrite())
+        names[i] = output
+    return names
+def _generate_harmonics(time_names, freq, prefix):
+    """Generate (constant) rasters of harmonics
+    freq -- frequencies for sin() and cos() rasters
+    names = dict()
+    for i in time_names:
+        harm = dict()
+        t = get_time(len(time_names), i)
+        for f in freq:
+            sin_output = prefix + 'sin' + _time_to_name(i) + _freq_to_name(f)
+            grass.mapcalc("${out} = sin(${f} * ${t})", out=sin_output, t=t, f=f,
+            cos_output = prefix + 'cos' + _time_to_name(i) + _freq_to_name(f)
+            grass.mapcalc("${out} = cos(${f} * ${t})", out=cos_output, t=t, f=f,
+            harm[f] = dict(sin=sin_output, cos=cos_output)
+        names[i] = harm
+    return names
+def _generate_const(prefix):
+    output = prefix + 'const'
+    grass.mapcalc("${out} = 1.0", out=output,
+    return output
+def generate_vars(time_count, freq, prefix):
+    """Generate time_count sets of variables.
+    const_name = _generate_const(prefix)
+    time_names = _generate_time(time_count, prefix)
+    harm_names = _generate_harmonics(time_names, freq, prefix)
+    return const_name, time_names, harm_names
+def _generate_sample_descr(fileobj, freq, xnames, const_name, time_names, harm_names):
+    """Generate settings file for r.mregression.series
+    freq_names = []
+    for f in freq:
+        freq_names.append('sin' + _freq_to_name(f))
+        freq_names.append('cos' + _freq_to_name(f))
+    header = ['x', 'const', 'time'] + freq_names
+    writer = csv.writer(fileobj, delimiter=',')
+    writer.writerow(header)
+    size = len(xnames)
+    for i in range(size):
+        row = [xnames[i], const_name, time_names[i]]
+        f_name = harm_names[i]
+        for f in freq:
+            sin_name = f_name[f]['sin']
+            cos_name = f_name[f]['cos']
+            row.append(sin_name)
+            row.append(cos_name)
+        writer.writerow(row)
+def regression(settings_name, coef_prefix):
+    grass.run_command('r.mregression.series',
+                      samples=settings_name, result_prefix=coef_prefix,
+                      overwrite=grass.overwrite())
+def inverse_transform(settings_name, coef_prefix, result_prefix='res.'):
+    reader = csv.reader(open(settings_name), delimiter=',')
+    header = reader.next()
+    data_names = [coef_prefix + name for name in header[1:]]
+    for row in reader:
+        s = "%s%s = " % (result_prefix, row[0])
+        sums = []
+        for i in range(len(data_names)):
+            sums.append("%s*%s" % (data_names[i], row[i+1]))
+        s += ' + '.join(sums)
+        grass.mapcalc(s, overwrite=grass.overwrite(), quite=True)
+def main(options, flags):
+    xnames = options['input']
+    coef_pref = options['coef_prefix']
+    timevar_pref = options['timevar_prefix']
+    result_pref = options['result_prefix']
+    freq = options['freq']
+    freq = [float(f) for f in freq.split(',')]
+    xnames = xnames.split(',')
+    N = len(xnames)
+    if len(freq) >= (N-1)/2:
+        grass.error("Count of used harmonics is to large. Reduce the paramether.")
+        sys.exit(1)
+    const_name, time_names, harm_names = generate_vars(N, freq, timevar_pref)
+    settings_name = uuid.uuid4().hex
+    settings = open(settings_name, 'w')
+    _generate_sample_descr(settings, freq, xnames, const_name, time_names, harm_names)
+    settings.close()
+    regression(settings_name, coef_pref)
+    inverse_transform(settings_name, coef_pref, result_pref)
+    os.unlink(settings_name)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main(options, flags)
