[GRASS-SVN] r66871 - in grass/trunk: lib/gis lib/python/temporal lib/vector/Vlib raster/r.in.xyz scripts/g.extension
svn_grass at osgeo.org
Fri Nov 20 03:33:21 PST 2015
Author: neteler
Date: 2015-11-20 03:33:21 -0800 (Fri, 20 Nov 2015)
New Revision: 66871
grass/trunk/lib/gis/strings.c
grass/trunk/lib/python/temporal/temporal_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
grass/trunk/lib/vector/Vlib/cindex.c
grass/trunk/raster/r.in.xyz/r.in.xyz.html
grass/trunk/scripts/g.extension/g.extension.html
various typo fixed (trac #2803)
Modified: grass/trunk/lib/gis/strings.c
--- grass/trunk/lib/gis/strings.c 2015-11-20 07:43:28 UTC (rev 66870)
+++ grass/trunk/lib/gis/strings.c 2015-11-20 11:33:21 UTC (rev 66871)
@@ -206,7 +206,7 @@
return G_store(buffer);
if (strlen(new_str) > strlen(old_str)) {
- /* Count occurences of old_str */
+ /* Count occurrences of old_str */
count = 0;
len = strlen(old_str);
B = buffer;
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py 2015-11-20 07:43:28 UTC (rev 66870)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py 2015-11-20 11:33:21 UTC (rev 66871)
@@ -1102,7 +1102,7 @@
stds = dataset_factory(stds_type, id_input)
else:
stds = dataset_factory(self.stdstype, id_input)
- # Check for occurence of space time dataset.
+ # Check for occurrence of space time dataset.
if stds.is_in_db(dbif=self.dbif) == False:
raise FatalError(_("Space time %s dataset <%s> not found") %
(stds.get_new_map_instance(None).get_type(), id_input))
@@ -2208,7 +2208,7 @@
id_input = input + "@" + self.mapset
# Create empty map dataset.
map_i = dataset_factory(self.maptype, id_input)
if map_i.map_exists() == False:
raise FatalError(_("%s map <%s> not found in GRASS spatial database") %
(map_i.get_type(), id_input))
Modified: grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2015-11-20 07:43:28 UTC (rev 66870)
+++ grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2015-11-20 11:33:21 UTC (rev 66871)
@@ -650,7 +650,7 @@
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c 2015-11-20 07:43:28 UTC (rev 66870)
+++ grass/trunk/lib/vector/Vlib/cindex.c 2015-11-20 11:33:21 UTC (rev 66871)
@@ -38,7 +38,7 @@
G_fatal_error(_("Layer index out of range"));
-/* search for first occurence of cat in cat index, starting at first */
+/* search for first occurrence of cat in cat index, starting at first */
static int ci_search_cat(struct Cat_index *ci, int first, int cat)
int lo, hi, mid;
Modified: grass/trunk/raster/r.in.xyz/r.in.xyz.html
--- grass/trunk/raster/r.in.xyz/r.in.xyz.html 2015-11-20 07:43:28 UTC (rev 66870)
+++ grass/trunk/raster/r.in.xyz/r.in.xyz.html 2015-11-20 11:33:21 UTC (rev 66871)
@@ -197,7 +197,7 @@
<h3>Import of x,y,string data</h3>
<em>r.in.xyz</em> is expecting numeric values as z column. In order to
-perform a occurence count operation even on x,y data with non-numeric
+perform a occurrence count operation even on x,y data with non-numeric
attribute(s), the data can be imported using either the x or y
coordinate as a fake z column for <b>method</b>=<tt>n</tt> (count
number of points per grid cell), the z values are ignored anyway.
Modified: grass/trunk/scripts/g.extension/g.extension.html
--- grass/trunk/scripts/g.extension/g.extension.html 2015-11-20 07:43:28 UTC (rev 66870)
+++ grass/trunk/scripts/g.extension/g.extension.html 2015-11-20 11:33:21 UTC (rev 66871)
@@ -14,7 +14,7 @@
<li>Source code (mostly written in C programming language; may also be written
in C++, Fortran or other languages): while on MS-Windows systems the requested
GRASS GIS extension is downloaded pre-compiled from the GRASS GIS site, on Unix
- based systems the installation is preceeded by the automated download of the
+ based systems the installation is preceded by the automated download of the
extension's source code along with subsequent compilation and installation.
This requires a compiler environment to be present on the user's computer.</li>
</ul>
