[GRASS-SVN] r66959 - grass/branches/releasebranch_7_0/general/g.remove
Sat Nov 28 01:50:52 PST 2015
Author: martinl
Date: 2015-11-28 01:50:52 -0800 (Sat, 28 Nov 2015)
New Revision: 66959
   grass/branches/releasebranch_7_0/general/g.remove/main.c
g.remove: print warning when no files found
          turn important message to warning
          (merge r66958 from trunk)
Modified: grass/branches/releasebranch_7_0/general/g.remove/main.c
--- grass/branches/releasebranch_7_0/general/g.remove/main.c	2015-11-28 09:47:18 UTC (rev 66958)
+++ grass/branches/releasebranch_7_0/general/g.remove/main.c	2015-11-28 09:50:52 UTC (rev 66959)
@@ -58,7 +58,7 @@
     char *pattern, *exclude;
     const char *mapset;
     int result;
-    int i, all, num_types, nlist;
+    int i, all, num_types, nlist, num_removed;
     void *filter, *exclude_filter;
     G_gisinit(argv[0]);
@@ -222,6 +222,7 @@
 	num_types = i;
+    num_removed = 0;
     for (i = 0; i < num_types; i++) {
 	int n, rast, num_files, j;
 	const struct list *elem;
@@ -241,6 +242,7 @@
 	for (j = 0; j < num_files; j++) {
 	    if (!flag.force->answer) {
 		fprintf(stdout, "%s/%s@%s\n", elem->alias, files[j], mapset);
+                num_removed++;
 		continue;
@@ -249,17 +251,21 @@
 	    if (M_do_remove(n, (char *)files[j]) == 1)
 		result = EXIT_FAILURE;
+            num_removed++;
+    if (num_removed < 1)
+        G_warning(_("No data base element files found"));
     G_free_ls_filter(filter);
     if (exclude_filter)
 	G_free_ls_filter(exclude_filter);
-    if (!flag.force->answer)
-	G_important_message(_("You must use the force flag (-%c) to actually "
-			      "remove them. Exiting."), flag.force->key);
+    if (!flag.force->answer && num_removed > 0)
+	G_warning(_("Nothing removed. You must use the force flag (-%c) to actually "
+                    "remove them. Exiting."), flag.force->key);
     exit(result);
