[GRASS-SVN] r66960 - grass/trunk/gui/wxpython/core
Sat Nov 28 03:27:44 PST 2015
Author: martinl
Date: 2015-11-28 03:27:44 -0800 (Sat, 28 Nov 2015)
New Revision: 66960
   grass/trunk/gui/wxpython/core/ws.py
wxGUI/wms: replace CmdThread by gThread
Modified: grass/trunk/gui/wxpython/core/ws.py
--- grass/trunk/gui/wxpython/core/ws.py	2015-11-28 09:50:52 UTC (rev 66959)
+++ grass/trunk/gui/wxpython/core/ws.py	2015-11-28 11:27:44 UTC (rev 66960)
@@ -9,7 +9,7 @@
  - ws::RenderWMSMgr
  - ws::GDALRasterMerger
-(C) 2012 by the GRASS Development Team
+(C) 2012-2015 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -18,18 +18,18 @@
 import sys
 import copy
+import time
 import wx
 from wx.lib.newevent import NewEvent
 from grass.script.utils import try_remove
-from grass.script.task import cmdtuple_to_list
 from grass.script import core as grass
+from grass.exceptions import CalledModuleError
 from core          import utils
 from core.debug    import Debug
-from core.gconsole import CmdThread, GStderr, EVT_CMD_DONE, EVT_CMD_OUTPUT
+from core.gthread import  gThread
 from core.utils import _
 try:
@@ -45,7 +45,7 @@
 class RenderWMSMgr(wx.EvtHandler):
     """Fetch and prepare WMS data for rendering.
-    def __init__(self, layer, env={}):
+    def __init__(self, layer, env):
         if not haveGdal:
             sys.stderr.write(_("Unable to load GDAL Python bindings.\n"\
                                "WMS layers can not be displayed without the bindings.\n"))
@@ -55,21 +55,17 @@
         wx.EvtHandler.__init__(self)
         # thread for d.wms commands
-        self.thread = CmdThread(self)
-        self.Bind(EVT_CMD_DONE, self.OnDataFetched)
+        self.thread = gThread()
+        self._startTime = None
         self.downloading = False
         self.renderedRegion = None
         self.updateMap = True
         self.fetched_data_cmd = None
-        self.cmdStdErr = GStderr(self)
         self.tempMap = grass.tempfile()
         self.dstSize = {}
-        self.Bind(EVT_CMD_OUTPUT, self.OnCmdOutput)
         self.dataFetched = Signal('RenderWMSMgr.dataFetched')
         self.updateProgress = Signal('RenderWMSMgr.updateProgress')
@@ -124,31 +120,29 @@
             try_remove(self.tempMap)
             self.currentPid = self.thread.GetId()
-            self.thread.abort()
+            ### self.thread.Terminate()
             self.downloading = True
             self.fetching_cmd = cmd
-            cmdList = cmdtuple_to_list(cmd)
-            if Debug.GetLevel() < 3:
-                cmdList.append('--quiet')
             env["GRASS_RENDER_FILE"] = self.tempMap
             env["GRASS_REGION"] = self._createRegionStr(region)
-            self.thread.RunCmd(cmdList, env=env, stderr=self.cmdStdErr)
-            self.updateProgress.emit(layer=self.layer)
-    def OnCmdOutput(self, event):
-        """Print cmd output according to debug level.
-        if Debug.GetLevel() == 0:
-            if event.type == 'error':
-                sys.stderr.write(event.text)
-                sys.stderr.flush()
-        else:
-            Debug.msg(1, event.text)
+            cmd_render = copy.deepcopy(cmd)
+            cmd_render[1]['quiet'] = True # be quiet
+            self._startTime = time.time()
+            self.thread.Run(callable=self._render, cmd=cmd_render, env=env,
+                            ondone=self.OnDataFetched)
+            self.layer.forceRender = False
+    def _render(self, cmd, env):
+        try:
+            return grass.run_command(cmd[0], env=env, **cmd[1])
+        except CalledModuleError as e:
+            grass.error(e)
+            return 1
     def OnDataFetched(self, event):
         """Fetch data
@@ -175,6 +169,9 @@
         self.fetched_data_cmd = self.fetching_cmd
+        Debug.msg(1, "RenderWMSMgr.OnDataFetched(%s): ret=%d time=%f" % \
+                      (self.layer, event.ret, time.time() - self._startTime))
         self.dataFetched.emit(layer=self.layer)
     def _getRegionDict(self, env):
@@ -236,11 +233,15 @@
             region['n-s resol'] = region['e-w resol']
     def Abort(self):
-        """Abort process"""
+        """Abort rendering process"""
+        Debug.msg(1, "RenderWMSMgr({}).Abort()".format(self.layer))
+        self.thread.Terminate()
+        # force rendering layer next time
+        self.layer.forceRender = True
         self.updateMap = False
-        self.thread.abort(abortall = True)
+        self.thread.Terminate(False)
 class GDALRasterMerger:
     """Merge rasters.
