[GRASS-SVN] r66975 - grass-addons/grass7/vector/v.in.natura2000
Sat Nov 28 13:54:09 PST 2015
Author: hellik
Date: 2015-11-28 13:54:09 -0800 (Sat, 28 Nov 2015)
New Revision: 66975
Added:
   grass-addons/grass7/vector/v.in.natura2000/Makefile
   grass-addons/grass7/vector/v.in.natura2000/v.in.natura2000.html
   grass-addons/grass7/vector/v.in.natura2000/v.in.natura2000.py
v.in.natura2000: new addon - step 2: adding script, html, Makefile
Added: grass-addons/grass7/vector/v.in.natura2000/Makefile
--- grass-addons/grass7/vector/v.in.natura2000/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.in.natura2000/Makefile	2015-11-28 21:54:09 UTC (rev 66975)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.in.natura2000
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/vector/v.in.natura2000/v.in.natura2000.html
--- grass-addons/grass7/vector/v.in.natura2000/v.in.natura2000.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.in.natura2000/v.in.natura2000.html	2015-11-28 21:54:09 UTC (rev 66975)
@@ -0,0 +1,86 @@
+<h2>DESCRIPTION</h2>
+<em>v.in.natura2000</em> imports  <a href="http://www.eea.europa.eu/data-and-maps/data/ds_resolveuid/52E54BF3-ACDB-4959-9165-F3E4469BE610">Natura 2000 protected areas</a>.
+The tool is implemented for the sqlite/spatialite version of this data
+(size > 1 GB). Listing und import operations of <em>v.in.natura2000</em>
+may be slow due to the huge data file size. Listing (already availabe
+layers, biogeographic regions, EU member states codes, habitat codes,
+species codes, protected area site types) and importing (all data,
+protected areas of a defined habitat/species/member states/biogeographic
+region) is limited to some small selection of  wide range of possible
+cases.
+<h3>Important notes</h3>
+<p>
+Topological correctness of the input data is not guaranteed, overlapping
+of (many) polygones may occur. According to GRASS GIS topological model,
+imported data may have more layers in case of overlapping polygones .
+The sqlite/spatialite data is shipped in EPSG:3035 projection.
+</p>
+<h2>EXAMPLE</h2>
+<div class="code">
+ <pre>
+# list spatial layer(s) already availabe in the sqlite/spatialite database
+v.in.natura2000 -l input=C:\data\Natura2000_end2014_Spatialite\Natura2000_end2014.sqlite
+# import already available spatial layer
+v.in.natura2000 input=C:\data\Natura2000_end2014_Spatialite\Natura2000_end2014.sqlite /
+existing_layer=sv1800
+# list biogeographic regions
+v.in.natura2000 -b input=C:\data\Natura2000_end2014_Spatialite\Natura2000_end2014.sqlite
+# list EU member states codes
+v.in.natura2000 -m input=C:\data\Natura2000_end2014_Spatialite\Natura2000_end2014.sqlite
+# list habitats of community interest
+v.in.natura2000 -h input=C:\data\Natura2000_end2014_Spatialite\Natura2000_end2014.sqlite
+# list species of community interest
+v.in.natura2000 -s input=C:\data\Natura2000_end2014_Spatialite\Natura2000_end2014.sqlite
+# list protected area site types
+v.in.natura2000 -t input=C:\data\Natura2000_end2014_Spatialite\Natura2000_end2014.sqlite
+# import protected areas of type A
+output=pa_typeA sitetype=A
+# import protected areas with habitat 3230
+output=pa_habitat3230 habitat_code=3230
+# import protected areas with species 1800
+output=pa_species1800 species_code=1800
+# import protected areas within the Alpine biogeographical region
+output=pa_alpineregion biogeographic_region=Alpine
+# import protected areas of member state Austria
+output=pa_austria member_state=AT
+ </pre>
+</div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.import.html">v.import</a>
+<a href="v.in.ogr.html">v.in.ogr</a>
+<a href="v.proj.html">v.proj</a>
+</em>
+<h2>AUTHOR</h2>
+Helmut Kudrnovsky
+<p>
+<i>Last changed: $Date: 2015-08-28 18:13:57 +0200 (Fr, 28 Aug 2015) $</i>
+</p>
\ No newline at end of file
Added: grass-addons/grass7/vector/v.in.natura2000/v.in.natura2000.py
--- grass-addons/grass7/vector/v.in.natura2000/v.in.natura2000.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.in.natura2000/v.in.natura2000.py	2015-11-28 21:54:09 UTC (rev 66975)
@@ -0,0 +1,368 @@
+#!/usr/bin/env python
+MODULE:    v.in.natura2000
+AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
+PURPOSE:   Imports Natura 2000 spatial data of protected areas
+COPYRIGHT: (C) 2015 by the GRASS Development Team
+           This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+#%module
+#% description: importing of Natura 2000 spatial data of protected areas
+#% keyword: vector
+#% keyword: geometry
+#%end
+#%option G_OPT_F_BIN_INPUT
+#% key: input
+#% required: yes
+#%end
+#%option G_OPT_V_OUTPUT
+#% key: output
+#% description: name of imported spatial data set
+#% required : no
+#% guisection: output
+#%end
+#%option sitetype
+#% key: sitetype
+#% description: Select site type of input (A, B or C)
+#% required : no
+#% guisection: selection
+#%end
+#%option habitat_code
+#% key: habitat_code
+#% description: Select habitat code of input
+#% required : no
+#%end
+#%option species_code
+#% key: species_code
+#% description: Select species of input
+#% required : no
+#%end
+#%option biogeographic_region
+#% key: biogeographic_region
+#% description: Select biogeographic region of input
+#% required : no
+#%end
+#%option member_state
+#% key: member_state
+#% description: Select member state of input
+#% required : no
+#%end
+#%option existing_layer
+#% key: existing_layer
+#% description: Import of existing layer
+#% required : no
+#% guisection: layer
+#%end
+#%flag
+#% key: l
+#% description: Print available layer
+#%end
+#%flag
+#% key: b
+#% description: Print list of biogeographic regions
+#% guisection: print
+#%end
+#%flag
+#% key: m
+#% description: Print list of EU member states codes
+#%end
+#%flag
+#% key: h
+#% description: Print list of habitats of community interest
+#%end
+#%flag
+#% key: s
+#% description: Print list of species of community interest
+#%end
+#%flag
+#% key: t
+#% description: Print list of protected area site types
+#%end
+import sys
+import os
+import csv
+import math
+import shutil
+import tempfile
+import pyspatialite.dbapi2 as db
+import grass.script as grass
+if not os.environ.has_key("GISBASE"):
+    grass.message( "You must be in GRASS GIS to run this program." )
+    sys.exit(1)
+def main():
+    n2k_input = options['input']
+    n2k_output = options['output']
+    pa_sitetype_input = options['sitetype']
+    habitat_code_input = options['habitat_code']
+    species_code_input = options['species_code']
+    biogeoreg_long = options['biogeographic_region']
+    biogeoreg_long2 = biogeoreg_long.replace(" ", "_")
+    biogeoreg_long_quoted = '"'+biogeoreg_long+'"'
+    habitat_view = 'v'+habitat_code_input
+    habitat_spatial_view = 'sv'+habitat_code_input
+    species_view = 'v'+species_code_input
+    species_spatial_view = 'sv'+species_code_input
+    biogeoreg_view = 'v'+biogeoreg_long2
+    biogeoreg_spatial_view = 'sv'+biogeoreg_long2
+    ms_input = options['member_state']
+    layer_exist = options['existing_layer']
+    list_n2k_layer = flags['l']
+    list_bg_reg = flags['b']
+    list_ms =  flags['m']
+    list_habitats = flags['h']
+    list_species = flags['s']
+    list_site_type = flags['t']
+    global tmp
+    if list_n2k_layer :
+        grass.message( "Available data layer(s):" )
+        grass.message( "may take some time ..." )
+        grass.message( "..." )
+        grass.run_command("v.in.ogr", input = n2k_input,
+                                     flags = 'l')
+    if list_bg_reg :
+        grass.message( "Biogeographic regions:" )
+        conn = db.connect("%s" % n2k_input)
+        c = conn.cursor()
+        for row in c.execute('SELECT BIOGEFRAPHICREG FROM BIOREGION GROUP BY BIOGEFRAPHICREG'):
+                grass.message( row )
+        conn.close()
+    if list_ms :
+        grass.message( "EU member states:" )
+        c = conn.cursor()
+        for row in c.execute('SELECT MS FROM Natura2000polygon GROUP BY MS'):
+        conn.close()
+    if list_habitats :
+        grass.message( "habitat codes of EU community interest:" )
+        c = conn.cursor()
+        for row in c.execute('SELECT HABITATCODE, DESCRIPTION FROM HABITATS GROUP BY HABITATCODE'):
+        conn.close()
+    if list_species :
+        grass.message( "species codes of EU community interest:" )
+        c = conn.cursor()
+        for row in c.execute('SELECT SPECIESCODE, SPECIESNAME FROM SPECIES GROUP BY SPECIESCODE'):
+        conn.close()
+    if list_site_type :
+        grass.message( "site types:" )
+        c = conn.cursor()
+        for row in c.execute('SELECT SITETYPE FROM NATURA2000SITES GROUP BY SITETYPE'):
+        conn.close()
+    if pa_sitetype_input :
+        grass.message( "importing protected areas of site type: %s" % pa_sitetype_input )
+        grass.run_command( "v.in.ogr", input = "%s" % (n2k_input),
+								layer = "natura2000polygon",
+								output = n2k_output,
+								where = "SITETYPE = '%s'" % (pa_sitetype_input),
+								quiet = False)
+    if ms_input :
+        grass.message( "importing protected areas of member state: %s" % ms_input )
+								where = "MS = '%s'" % (ms_input),
+								quiet = False)
+    if habitat_code_input :
+       grass.message( "importing protected areas with habitat (code): %s" % habitat_code_input )
+       grass.message( "preparing (spatial) views in the sqlite/spatialite database:" )
+       c = conn.cursor()
+       # create view of defined habitat
+       grass.message( "view: %s" % habitat_view )
+       sqlhabitat = 'CREATE VIEW "%s" AS ' % (habitat_view)
+       sqlhabitat += 'SELECT * FROM HABITATS '
+       sqlhabitat += 'WHERE HABITATCODE = "%s" ' % (habitat_code_input)
+       sqlhabitat += 'ORDER BY "SITECODE"'
+       grass.message ( sqlhabitat )
+       c.execute( sqlhabitat )
+       # create spatial view of defined habitat - part 1
+       grass.message( "spatial view: %s" % habitat_spatial_view )
+       sqlhabitatspatial1 = 'CREATE VIEW "%s" AS ' % (habitat_spatial_view)
+       sqlhabitatspatial1 += 'SELECT "a"."ROWID" AS "ROWID", "a"."PK_UID" AS "PK_UID", '
+       sqlhabitatspatial1 += '"a"."SITECODE" AS "SITECODE", "a"."SITENAME" AS "SITENAME", '
+       sqlhabitatspatial1 += '"a"."RELEASE_DA" AS "RELEASE_DA", "a"."MS" AS "MS", '
+       sqlhabitatspatial1 += '"a"."SITETYPE" AS "SITETYPE", "a"."Geometry" AS "Geometry", '
+       sqlhabitatspatial1 += '"b"."SITECODE" AS "SITECODE_1", "b"."HABITATCODE" AS "HABITATCODE", "b"."DESCRIPTION" AS "DESCRIPTION", '
+       sqlhabitatspatial1 += '"b"."COVER_HA" AS "COVER_HA", "b"."CAVES" AS "CAVES", "b"."REPRESENTATIVITY" AS "REPRESENTATIVITY", '
+       sqlhabitatspatial1 += '"b"."RELSURFACE" AS "RELSURFACE", "b"."CONSERVATION" AS "CONSERVATION", '
+       sqlhabitatspatial1 += '"b"."GLOBAL_ASSESMENT" AS "GLOBAL_ASSESMENT", "b"."DATAQUALITY" AS "DATAQUALITY", '
+       sqlhabitatspatial1 += '"b"."PERCENTAGE_COVER" AS "PERCENTAGE_COVER" '
+       sqlhabitatspatial1 += 'FROM "Natura2000polygon" AS "a" '
+       sqlhabitatspatial1 += 'JOIN %s AS "b" USING ("SITECODE") ' % (habitat_view)
+       sqlhabitatspatial1 += 'ORDER BY "a"."SITECODE";'
+       grass.message ( sqlhabitatspatial1 )
+       c.execute( sqlhabitatspatial1 )
+       # create spatial view of defined habitat - part 2
+       sqlhabitatspatial2 = 'INSERT INTO views_geometry_columns '
+       sqlhabitatspatial2 += '(view_name, view_geometry, view_rowid, f_table_name, f_geometry_column, read_only) '
+       sqlhabitatspatial2 += 'VALUES ("%s", "geometry", "rowid", "natura2000polygon", "geometry", 1);' % (habitat_spatial_view.lower())
+       grass.message ( sqlhabitatspatial2 )
+       # execute spatial vieww
+       c.execute( sqlhabitatspatial2 )
+       conn.commit()
+       conn.close()
+       # import spatial view
+       grass.message ( "importing data..." )
+       grass.message ( "may take some time..." )
+                                   layer = "%s" % (habitat_spatial_view),
+                                   quiet = False)
+    if species_code_input :
+       grass.message( "importing protected areas with species (code): %s" % species_code_input )
+       c = conn.cursor()
+       # create view of defined species
+       grass.message( "view: %s" % species_view )
+       sqlspecies = 'CREATE VIEW "%s" AS ' % (species_view)
+       sqlspecies += 'SELECT * FROM SPECIES '
+       sqlspecies += 'WHERE SPECIESCODE = "%s" ' % (species_code_input)
+       sqlspecies += 'ORDER BY "SITECODE"'
+       grass.message ( sqlspecies )
+       c.execute( sqlspecies )
+       # create spatial view of defined species - part 1
+       grass.message( "spatial view: %s" % species_spatial_view )
+       sqlspeciesspatial1 = 'CREATE VIEW "%s" AS ' % (species_spatial_view)
+       sqlspeciesspatial1 += 'SELECT "a"."ROWID" AS "ROWID", "a"."PK_UID" AS "PK_UID", '
+       sqlspeciesspatial1 += '"a"."SITECODE" AS "SITECODE", "a"."SITENAME" AS "SITENAME", '
+       sqlspeciesspatial1 += '"a"."RELEASE_DA" AS "RELEASE_DA", "a"."MS" AS "MS", '
+       sqlspeciesspatial1 += '"a"."SITETYPE" AS "SITETYPE", "a"."Geometry" AS "Geometry", '
+       sqlspeciesspatial1 += '"b"."COUNTRY_CODE" AS "COUNTRY_CODE", "b"."SITECODE" AS "SITECODE_1", '
+       sqlspeciesspatial1 += '"b"."SPECIESNAME" AS "SPECIESNAME", "b"."SPECIESCODE" AS "SPECIESCODE", '
+       sqlspeciesspatial1 += '"b"."REF_SPGROUP" AS "REF_SPGROUP", "b"."SPGROUP" AS "SPGROUP", '
+       sqlspeciesspatial1 += '"b"."SENSITIVE" AS "SENSITIVE", "b"."NONPRESENCEINSITE" AS "NONPRESENCEINSITE", '
+       sqlspeciesspatial1 += '"b"."POPULATION_TYPE" AS "POPULATION_TYPE", "b"."LOWERBOUND" AS "LOWERBOUND", '
+       sqlspeciesspatial1 += '"b"."UPPERBOUND" AS "UPPERBOUND", "b"."COUNTING_UNIT" AS "COUNTING_UNIT", '
+       sqlspeciesspatial1 += '"b"."ABUNDANCE_CATEGORY" AS "ABUNDANCE_CATEGORY", '
+       sqlspeciesspatial1 += '"b"."DATAQUALITY" AS "DATAQUALITY", "b"."POPULATION" AS "POPULATION", '
+       sqlspeciesspatial1 += '"b"."CONSERVATION" AS "CONSERVATION", "b"."ISOLATION" AS "ISOLATION", '
+       sqlspeciesspatial1 += '"b"."GLOBAL" AS "GLOBAL" '
+       sqlspeciesspatial1 += 'FROM "Natura2000polygon" AS "a" '
+       sqlspeciesspatial1 += 'JOIN %s AS "b" USING ("SITECODE") ' % (species_view)
+       sqlspeciesspatial1 += 'ORDER BY "a"."SITECODE";'
+       grass.message ( sqlspeciesspatial1 )
+       c.execute( sqlspeciesspatial1 )
+       sqlspeciesspatial2 = 'INSERT INTO views_geometry_columns '
+       sqlspeciesspatial2 += '(view_name, view_geometry, view_rowid, f_table_name, f_geometry_column, read_only) '
+       sqlspeciesspatial2 += 'VALUES ("%s", "geometry", "rowid", "natura2000polygon", "geometry", 1);' % (species_spatial_view.lower())
+       grass.message ( sqlspeciesspatial2 )
+       c.execute( sqlspeciesspatial2 )
+       conn.commit()
+       conn.close()
+                        layer = "%s" % (species_spatial_view),
+                        quiet = False)
+    if biogeoreg_long :
+       grass.message( "importing protected areas of biogeographic region: %s" % biogeoreg_long )
+       c = conn.cursor()
+       # create view of defined biogeographic region
+       grass.message( "view: %s" % biogeoreg_view )
+       sqlbioreg = 'CREATE VIEW "%s" AS ' % (biogeoreg_view)
+       sqlbioreg += 'SELECT * FROM BIOREGION '
+       sqlbioreg += 'WHERE BIOGEFRAPHICREG = "%s" ' % (biogeoreg_long)
+       sqlbioreg += 'ORDER BY "SITECODE"'
+       grass.message ( sqlbioreg )
+       c.execute( sqlbioreg )
+       # create spatial view of defined biogeographical region - part 1
+       grass.message( "spatial view: %s" % biogeoreg_spatial_view )
+       sqlbioregspatial1 = 'CREATE VIEW "%s" AS ' % (biogeoreg_spatial_view)
+       sqlbioregspatial1 += 'SELECT "a"."ROWID" AS "ROWID", "a"."PK_UID" AS "PK_UID", '
+       sqlbioregspatial1 += '"a"."RELEASE_DA" AS "RELEASE_DA", "a"."MS" AS "MS", '
+       sqlbioregspatial1 += '"a"."SITETYPE" AS "SITETYPE", "a"."Geometry" AS "Geometry", '
+       sqlbioregspatial1 += '"b"."SITECODE" AS "SITECODE_1", "b"."BIOGEFRAPHICREG" AS "BIOGEFRAPHICREG", '
+       sqlbioregspatial1 += '"b"."PERCENTAGE" AS "PERCENTAGE" '
+       sqlbioregspatial1 += 'FROM "Natura2000polygon" AS "a" '
+       sqlbioregspatial1 += 'JOIN %s AS "b" USING ("SITECODE") ' % (biogeoreg_view)
+       sqlbioregspatial1 += 'ORDER BY "a"."SITECODE";'
+       grass.message ( sqlbioregspatial1 )
+       c.execute( sqlbioregspatial1)
+       # create spatial view of defined biogeographical region - part 2
+       sqlbioregspatial2 = 'INSERT INTO views_geometry_columns '
+       sqlbioregspatial2 += '(view_name, view_geometry, view_rowid, f_table_name, f_geometry_column, read_only) '
+       sqlbioregspatial2 += 'VALUES ("%s", "geometry", "rowid", "natura2000polygon", "geometry", 1);' % (biogeoreg_spatial_view.lower())
+       grass.message ( sqlbioregspatial2 )
+       c.execute( sqlbioregspatial2 )
+       conn.commit()
+       conn.close()
+                        layer = "%s" % (biogeoreg_spatial_view),
+                        quiet = False)
+    if layer_exist :
+       grass.message( "importing existing spatial layer %s of the dataset" % layer_exist )
+                        layer = "%s" % (layer_exist),
+                        quiet = False)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
