[GRASS-SVN] r66432 - grass-addons/grass7/raster/r.stream.watersheds
svn_grass at osgeo.org
Wed Oct 7 14:20:16 PDT 2015
Author: martinl
Date: 2015-10-07 14:20:16 -0700 (Wed, 07 Oct 2015)
New Revision: 66432
Added:
grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds.html
grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds.py
Removed:
r.stream.watershed: python script must have .py extension + add empty html page
Deleted: grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds
--- grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds 2015-10-07 21:17:46 UTC (rev 66431)
+++ grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds 2015-10-07 21:20:16 UTC (rev 66432)
@@ -1,348 +0,0 @@
-#!/bin/bash
-# MODULE: r.stream.watersheds
-# AUTHOR(S): Giuseppe Amatulli & Sami Domisch
-# based on "Domisch, S., Amatulli, G., Jetz, W. (in review)
-# Near-global freshwater-specific environmental variables for
-# biodiversity analyses in 1km resolution. Scientific Data"
-# PURPOSE: Delineate the upstream contributing area ('sub-watershed') and
-# stream sections ('sub-stream') for each grid cell of a
-# stream network
-# COPYRIGHT: (C) 2001-2012 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: Sub-watershed and sub-stream delineation based on the drainage direction and a gridded stream network.
-#% keywords: drainage, stream, hydrology
-#%End
-#%option
-#% key: drainage
-#% type: string
-#% key_desc: name
-#% description: Name of the drainage direction raster (generated with r.watershed)
-#% required : yes
-#%end
-#%option
-#% key: stream
-#% type: string
-#% key_desc: name
-#% description: Name of the stream network raster
-#% required : yes
-#%end
-#%option
-#% key: folder
-#% type: string
-#% key_desc: name
-#% description: Provide the full folder path and name where the sub-watersheds and sub-streams should be stored
-#% required:no
-#% answer: GISDBASE/folder_structure
-#%end
-#%option
-#% key: cpu
-#% type: double
-#% description: Number of CPUs used for the parallel computation
-#% answer: 1
-#% required:no
-#%end
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
-fi
-#### check if we have awk
-if [ ! -x "`which awk`" ] ; then
- g.message -e "awk required, please install awk or gawk first"
- exit 1
-fi
-# setting environment, so that awk works properly in all languages
-unset LC_ALL
-LC_NUMERIC=C
-export LC_NUMERIC
-#test:
-if [ -z "$GIS_OPT_DRAINAGE" ] ; then
- g.message "Please provide the name of the drainage direction raster."
-exit 1
-fi
-if [ -z "$GIS_OPT_STREAM" ] ; then
- g.message "Please provide the name of the stream network raster."
-exit 1
-fi
-#check if drainage and stream file exists
-eval `g.findfile element=cell file="$GIS_OPT_STREAM"`
-if [ ! "$file" ] ; then
- g.message -e "<$GIS_OPT_STREAM> does not exist! Aborting."
- exit 1
-fi
-eval `g.findfile element=cell file="$GIS_OPT_DRAINAGE"`
- g.message -e "<$GIS_OPT_DRAINAGE> does not exist! Aborting."
- exit 1
-fi
-export GISDBASE=$(g.gisenv get=GISDBASE separator=space)
-export LOCATION_NAME=$(g.gisenv get=LOCATION_NAME separator=space)
-export GIS_OPT_STREAM
-export GIS_OPT_DRAINAGE
-export GIS_OPT_CPU
-if [ ${GIS_OPT_FOLDER} = "GISDBASE/folder_structure" ] ; then
- export GIS_OPT_FOLDER=$GISDBASE"/folder_structure"
-else
- export GIS_OPT_FOLDER=$GIS_OPT_FOLDER
-fi
-# what to do in case of user break:
-exitprocedure()
-echo ""
-g.message -e 'Process aborted by user. All intermediate files have been deleted!'
-# reset in the permanent mapset
-g.gisenv set="MAPSET=PERMANENT"
-g.gisenv set="LOCATION_NAME=$LOCATION_NAME"
-g.gisenv set="GISDBASE=$GISDBASE"
-# delete folder structure and sub-watershed mapset
-rm -fr $GIS_OPT_FOLDER $GISDBASE/$LOCATION_NAME/sub_watershedID*
-exit 1
-# shell check for user break (signal list: trap -l)
-trap "exitprocedure" 2 3 15
-echo ""
-echo "#######################################################################################################"
-echo "Sub-watershed and sub-stream delineation based on the drainage direction and a gridded stream network."
-echo ""
-echo "Citation: Domisch, S., Amatulli, G., Jetz, W. (in review)"
-echo "Near-global freshwater-specific environmental variables for"
-echo "biodiversity analyses in 1km resolution. Scientific Data"
-echo ""
-echo Exporting stream grid cell coordinates and saving in $GIS_OPT_FOLDER/stream_coord_lines.txt
-rm -fr $GIS_OPT_FOLDER 2> /dev/null
-mkdir $GIS_OPT_FOLDER 2> /dev/null
-r.out.xyz --o input=$GIS_OPT_STREAM separator=space output=$GIS_OPT_FOLDER/stream_coord.txt --q
-awk 'BEGIN {print "X","Y","ID"} { print $1, $2 , NR }' $GIS_OPT_FOLDER/stream_coord.txt > $GIS_OPT_FOLDER/stream_coord_lines.txt
-echo Create the raster ID file
-v.in.ascii --overwrite input=$GIS_OPT_FOLDER/stream_coord_lines.txt output=vector_ID x=1 y=2 separator=' ' skip=1 --q 2> /dev/null
-echo Rasterize the stream network point coordinates
-v.to.rast --overwrite input=vector_ID output=grid_ID layer=vector_ID use=attr attrcolumn=cat type=point --q
-echo Create the folder structure in $GIS_OPT_FOLDER/ to save results
-# build up folder structure for all the digit bigger than 9999.
-# from 0 to 9999 goes in the /0digit4/0digit3/0digit2/0digit1/
-# from 10000 to 19999 goes in the /0digit4/0digit3/0digit2/1digit1/
-max_line=$(wc -l $GIS_OPT_FOLDER/stream_coord.txt | awk '{ print $1 }' )
-max_seq1d=${max_line: -5:1} ; if [ -z $max_seq1d ] ; then max_seq1d=0 ; fi
-max_seq2d=${max_line: -6:1} ; if [ -z $max_seq2d ] ; then max_seq2d=0 ; else max_seq1d=9 ; fi
-max_seq3d=${max_line: -7:1} ; if [ -z $max_seq3d ] ; then max_seq3d=0 ; else max_seq2d=9 ; max_seq1d=9 ; fi
-max_seq4d=${max_line: -8:1} ; if [ -z $max_seq4d ] ; then max_seq4d=0 ; else max_seq3d=9 ; max_seq2d=9 ; max_seq1d=9 ; fi
-for dir4d in $(seq 0 $max_seq4d) ; do
- for dir3d in $(seq 0 $max_seq3d) ; do
- for dir2d in $(seq 0 $max_seq2d) ; do
- for dir1d in $(seq 0 $max_seq1d) ; do
- mkdir -p $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1
- done
- done
- done
-done
-mkdir $GIS_OPT_FOLDER/blockfile
-echo "Split the stream grid cell coordinate file with $( wc -l $GIS_OPT_FOLDER/stream_coord.txt | awk '{ print $1 }' ) grid cells into blocks of 10000 cells"
-awk -v PATH=$GIS_OPT_FOLDER 'NR%10000==1{x=PATH"/blockfile/blockfile"(++i*10000-10000)}{print > x}' $GIS_OPT_FOLDER/stream_coord_lines.txt
-awk '{ if(NR>1) print }' $GIS_OPT_FOLDER/blockfile/blockfile0 > $GIS_OPT_FOLDER/blockfile/blockfile0_tmp
-mv $GIS_OPT_FOLDER/blockfile/blockfile0_tmp $GIS_OPT_FOLDER/blockfile/blockfile0
-echo Create $( ls $GIS_OPT_FOLDER/blockfile/blockfile* | wc -l ) subsets: $GIS_OPT_FOLDER/blockfile/blockfile*.tif
-rm -fr $GISDBASE/$LOCATION_NAME/sub_watershedID*
-export GISRC_def=$GISRC
-for file in $GIS_OPT_FOLDER/blockfile/blockfile* ; do
- filename=$(basename $file )
- export BLKID=$(echo $filename | awk '{ gsub("0000", "") ; gsub("blockfile","") ; print }')
- export dir4d=${BLKID: -4:1} ; if [ -z $dir4d ] ; then dir4d=0 ; fi
- export dir3d=${BLKID: -3:1} ; if [ -z $dir3d ] ; then dir3d=0 ; fi
- export dir2d=${BLKID: -2:1} ; if [ -z $dir2d ] ; then dir2d=0 ; fi
- export dir1d=${BLKID: -1:1} ; if [ -z $dir1d ] ; then dir1d=0 ; fi
- export file=$file
-rm -f $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/*.tif
-g.region -d rast=$GIS_OPT_DRAINAGE at PERMANENT
-echo "Start the sub-watershed delineation for subset $file"
-awk '{ print NR , $1 , $2 ,$3 }' $file | xargs -n 4 -P $GIS_OPT_CPU bash -c $'
-NR=$1
-X_coord=$2
-Y_coord=$3
-ID=$4
-if [ $( expr $( expr $NR + 1 ) / 100) -eq $( expr $NR / 100 + 1 ) ] ; then
-echo -en "\r$(expr $NR / 100 + 1 )% done"
-fi
-# replicate the start-GISRC in a unique GISRC
-cp $GISRC_def $HOME/.grass7/rc$ID
-export GISRC=$HOME/.grass7/rc$ID
-g.mapset -c mapset=sub_watershedID$ID location=$LOCATION_NAME dbase=$GISDBASE --quiet
-rm -f $GISDBASE/$LOCATION_NAME/sub_watershedID$ID/.gislock
-export GISBASE=$( grep gisbase $(which grass70) | awk \'{ if(NR==2) { gsub ("\\"","" ) ; print $3 } }\' )
-export PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
-export LD_LIBRARY_PATH="$GISBASE/lib"
-export GRASS_LD_LIBRARY_PATH="$LD_LIBRARY_PATH"
-export PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
-export MANPATH=$MANPATH:$GISBASE/man
-r.water.outlet --o --q input=$GIS_OPT_DRAINAGE at PERMANENT output=sub_watershedID$ID coordinates=$X_coord,$Y_coord
-g.region rast=sub_watershedID${ID}@sub_watershedID${ID} zoom=sub_watershedID${ID}@sub_watershedID${ID}
-r.out.gdal -c type=Byte --o --q nodata=255 createopt="COMPRESS=LZW,ZLEVEL=9" input=sub_watershedID$ID at sub_watershedID${ID} output=$GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_watershedID$ID.tif
-### Crop this basin template --> for temperature only for the stream cells in this basin
-r.mapcalc "sub_streamID${ID} = if ( sub_watershedID${ID}@sub_watershedID${ID} == 1 & ${GIS_OPT_STREAM}@PERMANENT >= 1 , 1 , null() )" --o --q
-r.null map=sub_streamID${ID} setnull=0 --q
-r.out.gdal -c type=Byte --o --q nodata=255 createopt="COMPRESS=LZW,ZLEVEL=9" input=sub_streamID${ID}@sub_watershedID${ID} output=$GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif
-if [ ! -f $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif ] ; then the file $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif dose not exist ; fi
-rm -r $HOME/.grass7/rc$ID $GISDBASE/$LOCATION_NAME/sub_watershedID$ID
-' _
-echo -en "\r100% done"
-echo ""
-echo $(ls -l $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_watershedID*.tif | wc -l ) sub-watersheds have been processed
-# reset mapset to PERMANENT
-echo Check for missing files due to RAM overload
-cat $file | xargs -n 3 -P 1 bash -c $'
-X_coord=$1
-Y_coord=$2
-ID=$3
-if [ ! -f $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_watershedID$ID.tif ] ; then
-echo Fix missing file $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_watershedID$ID.tif using only 1 CPU
-fi
-' _
-echo "Compress the sub-watersheds and sub-streams to reduce the number of inodes filling up the hard disk"
-cd $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/
-tar -zcPf ${filename}_sub_watershed.tar.gz sub_watershedID*.tif
-tar -zcPf ${filename}_sub_stream.tar.gz sub_streamID*.tif
-cd $GIS_OPT_FOLDER
-rm -fr $GISDBASE/$LOCATION_NAME/sub_watershedID* $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/*.tif
-done
-echo "The full sub-watershed delineation process has been done!"
-echo "To list the compressed files: ls $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/*.tar.gz"
-echo "Now you can use r.stream.variables to compute stream-specific environmental variables."
Added: grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds.html
--- grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds.html (rev 0)
+++ grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds.html 2015-10-07 21:20:16 UTC (rev 66432)
@@ -0,0 +1,6 @@
+<h2>DESCRIPTION</h2>
+<h2>AUTHORS</h2>
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Copied: grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds.py (from rev 66429, grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds)
--- grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds.py (rev 0)
+++ grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds.py 2015-10-07 21:20:16 UTC (rev 66432)
@@ -0,0 +1,348 @@
+#!/bin/bash
+# MODULE: r.stream.watersheds
+# AUTHOR(S): Giuseppe Amatulli & Sami Domisch
+# based on "Domisch, S., Amatulli, G., Jetz, W. (in review)
+# Near-global freshwater-specific environmental variables for
+# biodiversity analyses in 1km resolution. Scientific Data"
+# PURPOSE: Delineate the upstream contributing area ('sub-watershed') and
+# stream sections ('sub-stream') for each grid cell of a
+# stream network
+# COPYRIGHT: (C) 2001-2012 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Sub-watershed and sub-stream delineation based on the drainage direction and a gridded stream network.
+#% keywords: drainage, stream, hydrology
+#%End
+#%option
+#% key: drainage
+#% type: string
+#% key_desc: name
+#% description: Name of the drainage direction raster (generated with r.watershed)
+#% required : yes
+#%end
+#%option
+#% key: stream
+#% type: string
+#% key_desc: name
+#% description: Name of the stream network raster
+#% required : yes
+#%end
+#%option
+#% key: folder
+#% type: string
+#% key_desc: name
+#% description: Provide the full folder path and name where the sub-watersheds and sub-streams should be stored
+#% required:no
+#% answer: GISDBASE/folder_structure
+#%end
+#%option
+#% key: cpu
+#% type: double
+#% description: Number of CPUs used for the parallel computation
+#% answer: 1
+#% required:no
+#%end
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+#### check if we have awk
+if [ ! -x "`which awk`" ] ; then
+ g.message -e "awk required, please install awk or gawk first"
+ exit 1
+fi
+# setting environment, so that awk works properly in all languages
+unset LC_ALL
+LC_NUMERIC=C
+export LC_NUMERIC
+#test:
+if [ -z "$GIS_OPT_DRAINAGE" ] ; then
+ g.message "Please provide the name of the drainage direction raster."
+exit 1
+fi
+if [ -z "$GIS_OPT_STREAM" ] ; then
+ g.message "Please provide the name of the stream network raster."
+exit 1
+fi
+#check if drainage and stream file exists
+eval `g.findfile element=cell file="$GIS_OPT_STREAM"`
+if [ ! "$file" ] ; then
+ g.message -e "<$GIS_OPT_STREAM> does not exist! Aborting."
+ exit 1
+fi
+eval `g.findfile element=cell file="$GIS_OPT_DRAINAGE"`
+ g.message -e "<$GIS_OPT_DRAINAGE> does not exist! Aborting."
+ exit 1
+fi
+export GISDBASE=$(g.gisenv get=GISDBASE separator=space)
+export LOCATION_NAME=$(g.gisenv get=LOCATION_NAME separator=space)
+export GIS_OPT_STREAM
+export GIS_OPT_DRAINAGE
+export GIS_OPT_CPU
+if [ ${GIS_OPT_FOLDER} = "GISDBASE/folder_structure" ] ; then
+ export GIS_OPT_FOLDER=$GISDBASE"/folder_structure"
+else
+ export GIS_OPT_FOLDER=$GIS_OPT_FOLDER
+fi
+# what to do in case of user break:
+exitprocedure()
+echo ""
+g.message -e 'Process aborted by user. All intermediate files have been deleted!'
+# reset in the permanent mapset
+g.gisenv set="MAPSET=PERMANENT"
+g.gisenv set="LOCATION_NAME=$LOCATION_NAME"
+g.gisenv set="GISDBASE=$GISDBASE"
+# delete folder structure and sub-watershed mapset
+rm -fr $GIS_OPT_FOLDER $GISDBASE/$LOCATION_NAME/sub_watershedID*
+exit 1
+# shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+echo ""
+echo "#######################################################################################################"
+echo "Sub-watershed and sub-stream delineation based on the drainage direction and a gridded stream network."
+echo ""
+echo "Citation: Domisch, S., Amatulli, G., Jetz, W. (in review)"
+echo "Near-global freshwater-specific environmental variables for"
+echo "biodiversity analyses in 1km resolution. Scientific Data"
+echo ""
+echo Exporting stream grid cell coordinates and saving in $GIS_OPT_FOLDER/stream_coord_lines.txt
+rm -fr $GIS_OPT_FOLDER 2> /dev/null
+mkdir $GIS_OPT_FOLDER 2> /dev/null
+r.out.xyz --o input=$GIS_OPT_STREAM separator=space output=$GIS_OPT_FOLDER/stream_coord.txt --q
+awk 'BEGIN {print "X","Y","ID"} { print $1, $2 , NR }' $GIS_OPT_FOLDER/stream_coord.txt > $GIS_OPT_FOLDER/stream_coord_lines.txt
+echo Create the raster ID file
+v.in.ascii --overwrite input=$GIS_OPT_FOLDER/stream_coord_lines.txt output=vector_ID x=1 y=2 separator=' ' skip=1 --q 2> /dev/null
+echo Rasterize the stream network point coordinates
+v.to.rast --overwrite input=vector_ID output=grid_ID layer=vector_ID use=attr attrcolumn=cat type=point --q
+echo Create the folder structure in $GIS_OPT_FOLDER/ to save results
+# build up folder structure for all the digit bigger than 9999.
+# from 0 to 9999 goes in the /0digit4/0digit3/0digit2/0digit1/
+# from 10000 to 19999 goes in the /0digit4/0digit3/0digit2/1digit1/
+max_line=$(wc -l $GIS_OPT_FOLDER/stream_coord.txt | awk '{ print $1 }' )
+max_seq1d=${max_line: -5:1} ; if [ -z $max_seq1d ] ; then max_seq1d=0 ; fi
+max_seq2d=${max_line: -6:1} ; if [ -z $max_seq2d ] ; then max_seq2d=0 ; else max_seq1d=9 ; fi
+max_seq3d=${max_line: -7:1} ; if [ -z $max_seq3d ] ; then max_seq3d=0 ; else max_seq2d=9 ; max_seq1d=9 ; fi
+max_seq4d=${max_line: -8:1} ; if [ -z $max_seq4d ] ; then max_seq4d=0 ; else max_seq3d=9 ; max_seq2d=9 ; max_seq1d=9 ; fi
+for dir4d in $(seq 0 $max_seq4d) ; do
+ for dir3d in $(seq 0 $max_seq3d) ; do
+ for dir2d in $(seq 0 $max_seq2d) ; do
+ for dir1d in $(seq 0 $max_seq1d) ; do
+ mkdir -p $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1
+ done
+ done
+ done
+done
+mkdir $GIS_OPT_FOLDER/blockfile
+echo "Split the stream grid cell coordinate file with $( wc -l $GIS_OPT_FOLDER/stream_coord.txt | awk '{ print $1 }' ) grid cells into blocks of 10000 cells"
+awk -v PATH=$GIS_OPT_FOLDER 'NR%10000==1{x=PATH"/blockfile/blockfile"(++i*10000-10000)}{print > x}' $GIS_OPT_FOLDER/stream_coord_lines.txt
+awk '{ if(NR>1) print }' $GIS_OPT_FOLDER/blockfile/blockfile0 > $GIS_OPT_FOLDER/blockfile/blockfile0_tmp
+mv $GIS_OPT_FOLDER/blockfile/blockfile0_tmp $GIS_OPT_FOLDER/blockfile/blockfile0
+echo Create $( ls $GIS_OPT_FOLDER/blockfile/blockfile* | wc -l ) subsets: $GIS_OPT_FOLDER/blockfile/blockfile*.tif
+rm -fr $GISDBASE/$LOCATION_NAME/sub_watershedID*
+export GISRC_def=$GISRC
+for file in $GIS_OPT_FOLDER/blockfile/blockfile* ; do
+ filename=$(basename $file )
+ export BLKID=$(echo $filename | awk '{ gsub("0000", "") ; gsub("blockfile","") ; print }')
+ export dir4d=${BLKID: -4:1} ; if [ -z $dir4d ] ; then dir4d=0 ; fi
+ export dir3d=${BLKID: -3:1} ; if [ -z $dir3d ] ; then dir3d=0 ; fi
+ export dir2d=${BLKID: -2:1} ; if [ -z $dir2d ] ; then dir2d=0 ; fi
+ export dir1d=${BLKID: -1:1} ; if [ -z $dir1d ] ; then dir1d=0 ; fi
+ export file=$file
+rm -f $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/*.tif
+g.region -d rast=$GIS_OPT_DRAINAGE at PERMANENT
+echo "Start the sub-watershed delineation for subset $file"
+awk '{ print NR , $1 , $2 ,$3 }' $file | xargs -n 4 -P $GIS_OPT_CPU bash -c $'
+NR=$1
+X_coord=$2
+Y_coord=$3
+ID=$4
+if [ $( expr $( expr $NR + 1 ) / 100) -eq $( expr $NR / 100 + 1 ) ] ; then
+echo -en "\r$(expr $NR / 100 + 1 )% done"
+fi
+# replicate the start-GISRC in a unique GISRC
+cp $GISRC_def $HOME/.grass7/rc$ID
+export GISRC=$HOME/.grass7/rc$ID
+g.mapset -c mapset=sub_watershedID$ID location=$LOCATION_NAME dbase=$GISDBASE --quiet
+rm -f $GISDBASE/$LOCATION_NAME/sub_watershedID$ID/.gislock
+export GISBASE=$( grep gisbase $(which grass70) | awk \'{ if(NR==2) { gsub ("\\"","" ) ; print $3 } }\' )
+export PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
+export LD_LIBRARY_PATH="$GISBASE/lib"
+export GRASS_LD_LIBRARY_PATH="$LD_LIBRARY_PATH"
+export PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
+export MANPATH=$MANPATH:$GISBASE/man
+r.water.outlet --o --q input=$GIS_OPT_DRAINAGE at PERMANENT output=sub_watershedID$ID coordinates=$X_coord,$Y_coord
+g.region rast=sub_watershedID${ID}@sub_watershedID${ID} zoom=sub_watershedID${ID}@sub_watershedID${ID}
+r.out.gdal -c type=Byte --o --q nodata=255 createopt="COMPRESS=LZW,ZLEVEL=9" input=sub_watershedID$ID at sub_watershedID${ID} output=$GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_watershedID$ID.tif
+### Crop this basin template --> for temperature only for the stream cells in this basin
+r.mapcalc "sub_streamID${ID} = if ( sub_watershedID${ID}@sub_watershedID${ID} == 1 & ${GIS_OPT_STREAM}@PERMANENT >= 1 , 1 , null() )" --o --q
+r.null map=sub_streamID${ID} setnull=0 --q
+r.out.gdal -c type=Byte --o --q nodata=255 createopt="COMPRESS=LZW,ZLEVEL=9" input=sub_streamID${ID}@sub_watershedID${ID} output=$GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif
+if [ ! -f $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif ] ; then the file $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif dose not exist ; fi
+rm -r $HOME/.grass7/rc$ID $GISDBASE/$LOCATION_NAME/sub_watershedID$ID
+' _
+echo -en "\r100% done"
+echo ""
+echo $(ls -l $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_watershedID*.tif | wc -l ) sub-watersheds have been processed
+# reset mapset to PERMANENT
+echo Check for missing files due to RAM overload
+cat $file | xargs -n 3 -P 1 bash -c $'
+X_coord=$1
+Y_coord=$2
+ID=$3
+if [ ! -f $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_watershedID$ID.tif ] ; then
+echo Fix missing file $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_watershedID$ID.tif using only 1 CPU
+fi
+' _
+echo "Compress the sub-watersheds and sub-streams to reduce the number of inodes filling up the hard disk"
+cd $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/
+tar -zcPf ${filename}_sub_watershed.tar.gz sub_watershedID*.tif
+tar -zcPf ${filename}_sub_stream.tar.gz sub_streamID*.tif
+cd $GIS_OPT_FOLDER
+rm -fr $GISDBASE/$LOCATION_NAME/sub_watershedID* $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/*.tif
+done
+echo "The full sub-watershed delineation process has been done!"
+echo "To list the compressed files: ls $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/*.tar.gz"
+echo "Now you can use r.stream.variables to compute stream-specific environmental variables."
