[GRASS-SVN] r66448 - grass/trunk/scripts/r.import
svn_grass at osgeo.org
Fri Oct 9 08:49:08 PDT 2015
Author: annakrat
Date: 2015-10-09 08:49:08 -0700 (Fri, 09 Oct 2015)
New Revision: 66448
grass/trunk/scripts/r.import/r.import.py
r.import: fix temporary vector handling (need to remove it for multi bands import, cleanup), improve messages about resolution, with e flag report for all bands
Modified: grass/trunk/scripts/r.import/r.import.py
--- grass/trunk/scripts/r.import/r.import.py 2015-10-09 14:32:32 UTC (rev 66447)
+++ grass/trunk/scripts/r.import/r.import.py 2015-10-09 15:49:08 UTC (rev 66448)
@@ -117,6 +117,7 @@
TMPLOC = None
SRCGISRC = None
GISDBASE = None
+TMP_REG_NAME = None
def cleanup():
@@ -125,9 +126,13 @@
grass.try_rmdir(os.path.join(GISDBASE, TMPLOC))
if SRCGISRC:
grass.try_remove(SRCGISRC)
+ if TMP_REG_NAME:
+ grass.run_command('g.remove', type='vector', name=TMP_REG_NAME,
+ flags='f', quiet=True)
def main():
- global TMPLOC, SRCGISRC, GISDBASE
+ global TMPLOC, SRCGISRC, GISDBASE, TMP_REG_NAME
GDALdatasource = options['input']
output = options['output']
@@ -274,7 +279,7 @@
grass.run_command('g.region', n=n, s=s, e=e, w=w)
# v.in.region in tgt
- vreg = 'vreg_' + str(os.getpid())
+ vreg = TMP_REG_NAME = 'vreg_tmp_' + str(os.getpid())
grass.run_command('v.in.region', output=vreg, quiet=True)
grass.del_temp_region()
@@ -297,14 +302,17 @@
cells = grass.region()['cells']
estres = math.sqrt((n - s) * (e - w) / cells)
+ # remove from source location for multi bands import
+ grass.run_command('g.remove', type='vector', name=vreg,
os.environ['GISRC'] = str(tgtgisrc)
- grass.message(_("Estimated target resolution for input band <%s>: %g") % (outfile, estres))
+ grass.message(_("Estimated target resolution for input band <{out}>: {res}").format(out=outfile, res=estres))
if flags['e']:
- return 0
+ continue
if options['extent'] == 'input':
grass.use_temp_region()
@@ -315,6 +323,12 @@
res = estres
elif tgtres == 'value':
res = tgtres_value
+ grass.message(_("Using given resolution for input band <{out}>: {res}").format(out=outfile, res=res))
+ else:
+ curr_reg = grass.region()
+ grass.message(_("Using current region resolution for input band "
+ "<{out}>: nsres={ns}, ewres={ew}").format(out=outfile, ns=curr_reg['nsres'],
+ ew=curr_reg['ewres']))
# r.proj
grass.message(_("Reprojecting <%s>...") % outfile)
@@ -332,6 +346,9 @@
+ if flags['e']:
+ return 0
if group:
grass.run_command('i.group', group=output, input=','.join(outfiles))
