[GRASS-SVN] r66449 - in grass/trunk/raster/r.patch: . testsuite
svn_grass at osgeo.org
Fri Oct 9 09:45:29 PDT 2015
Author: wenzeslaus
Date: 2015-10-09 09:45:29 -0700 (Fri, 09 Oct 2015)
New Revision: 66449
Added:
grass/trunk/raster/r.patch/testsuite/
grass/trunk/raster/r.patch/testsuite/test_rpatch_artificial.py
grass/trunk/raster/r.patch/main.c
grass/trunk/raster/r.patch/r.patch.html
r.patch: test and doc improvements
Modified: grass/trunk/raster/r.patch/main.c
--- grass/trunk/raster/r.patch/main.c 2015-10-09 15:49:08 UTC (rev 66448)
+++ grass/trunk/raster/r.patch/main.c 2015-10-09 16:45:29 UTC (rev 66449)
@@ -58,6 +58,8 @@
G_add_keyword(_("raster"));
G_add_keyword(_("geometry"));
G_add_keyword(_("mosaicking"));
+ G_add_keyword(_("merge"));
+ G_add_keyword(_("patching"));
module->description =
_("Creates a composite raster map layer by using "
"known category values from one (or more) map layer(s) "
Modified: grass/trunk/raster/r.patch/r.patch.html
--- grass/trunk/raster/r.patch/r.patch.html 2015-10-09 15:49:08 UTC (rev 66448)
+++ grass/trunk/raster/r.patch/r.patch.html 2015-10-09 16:45:29 UTC (rev 66449)
@@ -21,12 +21,15 @@
maps will be used, in order, to supply data values for for the remaining
"no data" cells.
-<h2>EXAMPLE</h2>
+<h3>Example of filling areas</h3>
-Below, the raster map layer on the far left is <b>patched</b>
-with the middle (<em>patching</em>) raster map layer,
-to produce the <em>composite</em> raster map layer on the right.
+<!-- this example is also used in the tests -->
+Below, the raster map layer on the far left is <b>patched</b>
+with the middle (<em>patching</em>) raster map layer,
+to produce the <em>composite</em> raster map layer on the right.
+The example assumes zero values to be treated as NULLs (<b>-z</b> flag).
<div class="code"><pre>
1 1 1 0 2 2 0 0 0 0 1 1 0 0 0 0 1 1 1 1 2 2 0 0
1 1 0 2 2 2 0 0 0 0 1 1 0 0 0 0 1 1 1 2 2 2 0 0
@@ -48,6 +51,7 @@
4 4 4 4 4 4 4 4 0 0 0 0 0 0 0 0 4 4 4 4 4 4 4 4
</pre></div>
<h2>NOTES</h2>
Frequently, this program is used to patch together adjacent map layers which
Added: grass/trunk/raster/r.patch/testsuite/test_rpatch_artificial.py
--- grass/trunk/raster/r.patch/testsuite/test_rpatch_artificial.py (rev 0)
+++ grass/trunk/raster/r.patch/testsuite/test_rpatch_artificial.py 2015-10-09 16:45:29 UTC (rev 66449)
@@ -0,0 +1,223 @@
+TEST: r.patch
+AUTHOR(S): Vaclav Petras
+PURPOSE: Test r.patch using artificial and small data
+COPYRIGHT: (C) 2015 Vaclav Petras, and by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+cell_1 = """\
+north: 20
+south: 10
+east: 25
+west: 15
+rows: 4
+cols: 4
+505 501 500 520
+506 501 550 520
+504 401 400 520
+502 520 540 520
+cell_2 = """\
+north: 30
+south: 20
+east: 25
+west: 15
+rows: 4
+cols: 4
+505 505 500 520
+406 409 550 520
+304 405 400 560
+302 520 540 520
+cell_patched_ref = """\
+north: 30
+south: 10
+east: 25
+west: 15
+rows: 8
+cols: 4
+505 505 500 520
+406 409 550 520
+304 405 400 560
+302 520 540 520
+505 501 500 520
+506 501 550 520
+504 401 400 520
+502 520 540 520
+# the following comes from the manual
+cell_overlap_a = """\
+north: 35
+south: 20
+east: 25
+west: 15
+rows: 6
+cols: 8
+1 1 1 0 2 2 0 0
+1 1 0 2 2 2 0 0
+3 3 3 3 2 2 0 0
+3 3 3 3 0 0 0 0
+3 3 3 0 0 0 0 0
+0 0 0 0 0 0 0 0
+cell_overlap_b = """\
+north: 35
+south: 20
+east: 25
+west: 15
+rows: 6
+cols: 8
+0 0 1 1 0 0 0 0
+0 0 1 1 0 0 0 0
+0 0 0 0 0 0 0 0
+4 4 4 4 4 4 4 4
+4 4 4 4 4 4 4 4
+4 4 4 4 4 4 4 4
+cell_overlap_ab = """\
+north: 35
+south: 20
+east: 25
+west: 15
+rows: 6
+cols: 8
+1 1 1 1 2 2 0 0
+1 1 1 2 2 2 0 0
+3 3 3 3 2 2 0 0
+3 3 3 3 4 4 4 4
+3 3 3 4 4 4 4 4
+4 4 4 4 4 4 4 4
+cell_overlap_ba = """\
+north: 35
+south: 20
+east: 25
+west: 15
+rows: 6
+cols: 8
+1 1 1 1 2 2 0 0
+1 1 1 1 2 2 0 0
+3 3 3 3 2 2 0 0
+4 4 4 4 4 4 4 4
+4 4 4 4 4 4 4 4
+4 4 4 4 4 4 4 4
+class TestSmallDataNoOverlap(TestCase):
+ # TODO: replace by unified handing of maps
+ to_remove = []
+ cell_1 = 'rpatch_small_test_cell_1'
+ cell_2 = 'rpatch_small_test_cell_2'
+ cell_patched = 'rpatch_small_test_cell_patched'
+ cell_patched_ref = 'rpatch_small_test_cell_patched_ref'
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
+ # 10 / 4 == 2.5 (size of raster / number of cells)
+ cls.runModule('g.region', n=30, s=10, e=25, w=15, res=2.5)
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ if cls.to_remove:
+ cls.runModule('g.remove', flags='f', type='raster',
+ name=','.join(cls.to_remove), verbose=True)
+ def test_patching_cell(self):
+ """Test patching two neighboring CELL raster maps"""
+ self.runModule('r.in.ascii', input='-', stdin=cell_1,
+ output=self.cell_1)
+ self.to_remove.append(self.cell_1)
+ self.runModule('r.in.ascii', input='-', stdin=cell_2,
+ output=self.cell_2)
+ self.to_remove.append(self.cell_2)
+ self.assertModule('r.patch', input=(self.cell_1, self.cell_2),
+ output=self.cell_patched)
+ self.to_remove.append(self.cell_patched)
+ self.runModule('r.in.ascii', input='-', stdin=cell_patched_ref,
+ output=self.cell_patched_ref)
+ self.to_remove.append(self.cell_patched_ref)
+ self.assertRastersNoDifference(self.cell_patched,
+ self.cell_patched_ref, precision=0)
+class TestSmallDataOverlap(TestCase):
+ to_remove = []
+ cell_a = 'rpatch_small_test_cell_a'
+ cell_b = 'rpatch_small_test_cell_b'
+ cell_ab = 'rpatch_small_test_cell_ab_reference'
+ cell_ba = 'rpatch_small_test_cell_ba_reference'
+ cell_ab_result = 'rpatch_small_test_cell_ab_result'
+ cell_ba_result = 'rpatch_small_test_cell_ba_result'
+ @classmethod
+ # 15 / 6 == 2.5 ((n-s) / number of cells)
+ # 10 / 8 == 1.25 ((e-w) / number of cells)
+ cls.runModule('g.region', n=35, s=20, e=25, w=15,
+ nsres=2.5, ewres=1.25)
+ cls.runModule('r.in.ascii', input='-', stdin=cell_overlap_a,
+ output=cls.cell_a)
+ cls.to_remove.append(cls.cell_a)
+ cls.runModule('r.in.ascii', input='-', stdin=cell_overlap_b,
+ output=cls.cell_b)
+ cls.to_remove.append(cls.cell_b)
+ cls.runModule('r.in.ascii', input='-', stdin=cell_overlap_ab,
+ output=cls.cell_ab)
+ cls.to_remove.append(cls.cell_ab)
+ cls.runModule('r.in.ascii', input='-', stdin=cell_overlap_ba,
+ output=cls.cell_ba)
+ cls.to_remove.append(cls.cell_ba)
+ @classmethod
+ if cls.to_remove:
+ def test_patch_oder_ab_cell(self):
+ """Test patching two overlapping CELL raster maps (watching order)"""
+ self.assertModule('r.patch', input=(self.cell_a, self.cell_b),
+ output=self.cell_ab_result, flags='z')
+ self.assertRasterExists(self.cell_ab_result)
+ self.to_remove.append(self.cell_ab_result)
+ self.assertRastersNoDifference(self.cell_ab_result,
+ self.cell_ab, precision=0)
+ def test_patch_oder_ba_cell(self):
+ self.assertModule('r.patch', input=(self.cell_b, self.cell_a),
+ output=self.cell_ba_result, flags='z')
+ self.assertRasterExists(self.cell_ba_result)
+ self.to_remove.append(self.cell_ba_result)
+ self.assertRastersNoDifference(self.cell_ba_result,
+ self.cell_ba, precision=0)
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/raster/r.patch/testsuite/test_rpatch_artificial.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
