[GRASS-SVN] r66450 - grass/branches/releasebranch_7_0/raster/r.patch
svn_grass at osgeo.org
Fri Oct 9 09:55:34 PDT 2015
Author: wenzeslaus
Date: 2015-10-09 09:55:34 -0700 (Fri, 09 Oct 2015)
New Revision: 66450
grass/branches/releasebranch_7_0/raster/r.patch/do_patch.c
grass/branches/releasebranch_7_0/raster/r.patch/local_proto.h
grass/branches/releasebranch_7_0/raster/r.patch/main.c
grass/branches/releasebranch_7_0/raster/r.patch/r.patch.html
r.patch: call Rast_cell_size just once, not for every cell (backport r64877 and part of 66449)
Modified: grass/branches/releasebranch_7_0/raster/r.patch/do_patch.c
--- grass/branches/releasebranch_7_0/raster/r.patch/do_patch.c 2015-10-09 16:45:29 UTC (rev 66449)
+++ grass/branches/releasebranch_7_0/raster/r.patch/do_patch.c 2015-10-09 16:55:34 UTC (rev 66450)
@@ -21,7 +21,7 @@
int do_patch(void *result, void *patch,
struct Cell_stats *statf, int ncols,
- RASTER_MAP_TYPE out_type, int use_zero)
+ RASTER_MAP_TYPE out_type, size_t out_cell_size, int use_zero)
int more;
@@ -56,8 +56,8 @@
} /* NULL support */
- result = G_incr_void_ptr(result, Rast_cell_size(out_type));
- patch = G_incr_void_ptr(patch, Rast_cell_size(out_type));
+ result = G_incr_void_ptr(result, out_cell_size);
+ patch = G_incr_void_ptr(patch, out_cell_size);
return more;
Modified: grass/branches/releasebranch_7_0/raster/r.patch/local_proto.h
--- grass/branches/releasebranch_7_0/raster/r.patch/local_proto.h 2015-10-09 16:45:29 UTC (rev 66449)
+++ grass/branches/releasebranch_7_0/raster/r.patch/local_proto.h 2015-10-09 16:55:34 UTC (rev 66450)
@@ -1,6 +1,6 @@
/* do_patch.c */
int do_patch(void *result, void *, struct Cell_stats *, int, RASTER_MAP_TYPE,
- int);
+ size_t, int);
/* support.c */
int support(char **, struct Cell_stats *, int, struct Categories *,
int *, struct Colors *, int *, RASTER_MAP_TYPE);
Modified: grass/branches/releasebranch_7_0/raster/r.patch/main.c
--- grass/branches/releasebranch_7_0/raster/r.patch/main.c 2015-10-09 16:45:29 UTC (rev 66449)
+++ grass/branches/releasebranch_7_0/raster/r.patch/main.c 2015-10-09 16:55:34 UTC (rev 66450)
@@ -31,6 +31,7 @@
int colr_ok;
int outfd;
RASTER_MAP_TYPE out_type, map_type;
+ size_t out_cell_size;
struct History history;
void *presult, *patch;
int nfiles;
@@ -54,6 +55,8 @@
G_add_keyword(_("raster"));
G_add_keyword(_("geometry"));
G_add_keyword(_("mosaicking"));
+ G_add_keyword(_("merge"));
+ G_add_keyword(_("patching"));
module->description =
_("Creates a composite raster map layer by using "
"known category values from one (or more) map layer(s) "
@@ -111,6 +114,8 @@
Rast_get_cellhd(name, "", &cellhd[i]);
+ out_cell_size = Rast_cell_size(out_type);
rname = opt2->answer;
outfd = Rast_open_new(new_name = rname, out_type);
@@ -143,7 +148,8 @@
Rast_get_row(infd[i], patch, row, out_type);
if (!do_patch
- (presult, patch, &statf[i], ncols, out_type, use_zero))
+ (presult, patch, &statf[i], ncols, out_type, out_cell_size,
+ use_zero))
break;
Rast_put_row(outfd, presult, out_type);
Modified: grass/branches/releasebranch_7_0/raster/r.patch/r.patch.html
--- grass/branches/releasebranch_7_0/raster/r.patch/r.patch.html 2015-10-09 16:45:29 UTC (rev 66449)
+++ grass/branches/releasebranch_7_0/raster/r.patch/r.patch.html 2015-10-09 16:55:34 UTC (rev 66450)
@@ -21,12 +21,15 @@
maps will be used, in order, to supply data values for for the remaining
"no data" cells.
-<h2>EXAMPLE</h2>
+<h3>Example of filling areas</h3>
-Below, the raster map layer on the far left is <b>patched</b>
-with the middle (<em>patching</em>) raster map layer,
-to produce the <em>composite</em> raster map layer on the right.
+<!-- this example is also used in the tests -->
+Below, the raster map layer on the far left is <b>patched</b>
+with the middle (<em>patching</em>) raster map layer,
+to produce the <em>composite</em> raster map layer on the right.
+The example assumes zero values to be treated as NULLs (<b>-z</b> flag).
<div class="code"><pre>
1 1 1 0 2 2 0 0 0 0 1 1 0 0 0 0 1 1 1 1 2 2 0 0
1 1 0 2 2 2 0 0 0 0 1 1 0 0 0 0 1 1 1 2 2 2 0 0
@@ -48,6 +51,7 @@
4 4 4 4 4 4 4 4 0 0 0 0 0 0 0 0 4 4 4 4 4 4 4 4
</pre></div>
<h2>NOTES</h2>
Frequently, this program is used to patch together adjacent map layers which
