[GRASS-SVN] r66469 - grass/trunk/lib/python/pygrass/vector
Sun Oct 11 23:18:14 PDT 2015
Author: zarch
Date: 2015-10-11 23:18:14 -0700 (Sun, 11 Oct 2015)
New Revision: 66469
   grass/trunk/lib/python/pygrass/vector/table.py
pygrass: Table.execute add values in the exception message
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py	2015-10-11 04:19:52 UTC (rev 66468)
+++ grass/trunk/lib/python/pygrass/vector/table.py	2015-10-12 06:18:14 UTC (rev 66469)
@@ -1074,9 +1074,10 @@
             if many and values:
                 return cur.executemany(sqlc, values)
             return cur.execute(sqlc)
-        except Exception, e:
-            #import ipdb; ipdb.set_trace()
-            raise ValueError("The SQL is not correct:\n%r, SQL error: %s" % (sqlc, str(e)))
+        except Exception as exc:
+            raise ValueError("The SQL is not correct:\n%r,\n"
+                             "values: %r,\n"
+                             "SQL error: %s" % (sqlc, values, str(exc)))
     def exist(self, cursor=None):
         """Return True if the table already exist in the DB, False otherwise
