[GRASS-SVN] r66470 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Sun Oct 11 23:19:58 PDT 2015
Author: zarch
Date: 2015-10-11 23:19:58 -0700 (Sun, 11 Oct 2015)
New Revision: 66470
grass/trunk/lib/python/pygrass/vector/geometry.py
pygrass: Attrs support multiple columns get/set
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2015-10-12 06:18:14 UTC (rev 66469)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2015-10-12 06:19:58 UTC (rev 66470)
@@ -154,7 +154,7 @@
cat = property(fget=_get_cat, fset=_set_cat,
doc="Set and obtain cat value")
- def __getitem__(self, key):
+ def __getitem__(self, keys):
"""Return the value stored in the attribute table.
>>> from grass.pygrass.vector import VectorTopo
@@ -163,21 +163,21 @@
>>> v1 = test_vect[1]
>>> v1.attrs['name']
u'point'
+ >>> v1.attrs['name', 'value']
+ (u'point', 1.0)
>>> test_vect.close()
- #SELECT {cols} FROM {tname} WHERE {condition};
- try:
- cur = self.table.execute(sql.SELECT_WHERE.format(cols=key,
- tname=self.table.name,
- condition=self.cond))
- except:
- import ipdb; ipdb.set_trace()
+ sqlcode = sql.SELECT_WHERE.format(cols=(keys if np.isscalar(keys)
+ else ', '.join(keys)),
+ tname=self.table.name,
+ condition=self.cond)
+ cur = self.table.execute(sqlcode)
results = cur.fetchone()
if results is not None:
return results[0] if len(results) == 1 else results
- def __setitem__(self, key, value):
+ def __setitem__(self, keys, values):
"""Set value of a given column of a table attribute.
@@ -187,22 +187,28 @@
>>> v1.attrs['name']
u'point'
- #>>> v1.attrs['name'] = "new_point"
- #u'new_point'
- #>>> v1.attrs['name'] = "point"
- #u'point'
- #>>> v.table.conn.commit()
+ >>> v1.attrs['name'] = "new_point_1"
+ u'new_point_1'
+ >>> v1.attrs['name', 'value'] = "new_point_2", 100.
+ (u'new_point_2', 100.0)
+ >>> v1.attrs['name', 'value'] = "point", 1.
+ >>> v1.attrs.table.conn.commit()
>>> test_vect.close()
if self.writeable:
- #UPDATE {tname} SET {new_col} = {old_col} WHERE {condition}
- values = '%s=%r' % (key, value)
- self.table.execute(sql.UPDATE_WHERE.format(tname=self.table.name,
- values=values,
+ if np.isscalar(keys):
+ keys, values = (keys, ), (values, )
+ vals = ','.join(['%s=%r' % (k, v) for k, v in zip(keys, values)])
+ # "UPDATE {tname} SET {values} WHERE {condition};"
+ sqlcode = sql.UPDATE_WHERE.format(tname=self.table.name,
+ values=vals,
+ self.table.execute(sqlcode)
#self.table.conn.commit()
else:
str_err = "You can only read the attributes if the map is in another mapset"
@@ -262,29 +268,29 @@
table=None, writeable=False, is2D=True, free_points=False,
free_cats=False):
"""Constructor of a geometry object
:param v_id: The vector feature id
:param c_mapinfo: A pointer to the vector mapinfo structure
:param c_points: A pointer to a libvect.line_pnts structure, this
- is optional, if not set an internal structure will
+ is optional, if not set an internal structure will
be allocated and free'd at object destruction
:param c_cats: A pointer to a libvect.line_cats structure, this
:param table: The attribute table to select attributes for
this feature
:param writeable: Not sure what this is for?
:param is2D: If True this feature has two dimensions, False if
this feature has three dimensions
- :param free_points: Set this True if the provided c_points structure
+ :param free_points: Set this True if the provided c_points structure
should be free'd at object destruction, be aware
that no other object should free them, otherwise
you can expect a double free corruption segfault
- :param free_cats: Set this True if the provided c_cats structure
+ :param free_cats: Set this True if the provided c_cats structure
self.id = v_id # vector id
self.c_mapinfo = c_mapinfo
@@ -295,7 +301,7 @@
# to free the cats and points structures on destruction
self._free_points = False
self._free_cats = False
read = False
# set c_points
if c_points is None:
@@ -319,10 +325,10 @@
self.read()
# set the attributes as last thing to do
- self.attrs = None
+ self.attrs = None
if table is not None and self.cat is not None:
self.attrs = Attrs(self.cat, table, writeable)
def __del__(self):
"""Take care of the allocated line_pnts and line_cats allocation
@@ -410,8 +416,8 @@
>>> c_cats = ctypes.pointer(libvect.line_cats())
>>> p = Point(c_points = c_points, c_cats=c_cats)
>>> del p
>>> c_points = ctypes.pointer(libvect.line_pnts())
>>> p = Point(c_points=c_points, c_cats=c_cats, free_points=True,
@@ -1794,16 +1800,16 @@
def read_next_line(c_mapinfo, table=None, writeable=False,
c_points=None, c_cats=None, is2D=True):
"""Return the next geometry feature of a vector map."""
# Take care of good memory management
free_points = False
if c_points == None:
free_points = True
free_cats = False
if c_cats == None:
free_cats = True
c_points = c_points if c_points else ctypes.pointer(libvect.line_pnts())
c_cats = c_cats if c_cats else ctypes.pointer(libvect.line_cats())
ftype, v_id, c_points, c_cats = c_read_next_line(c_mapinfo, c_points,
@@ -1835,7 +1841,7 @@
free_points = False
free_points = True
free_cats = False
if c_cats == None:
free_cats = True
@@ -1848,7 +1854,7 @@
return GV_TYPE[ftype]['obj'](v_id=feature_id, c_mapinfo=c_mapinfo,
table=table, writeable=writeable, is2D=is2D,
- free_points=free_points,
+ free_points=free_points,
free_cats=free_cats)
if __name__ == "__main__":
