[GRASS-SVN] r66471 - grass/trunk/lib/python/pygrass/vector/testsuite
Sun Oct 11 23:22:30 PDT 2015
Author: zarch
Date: 2015-10-11 23:22:30 -0700 (Sun, 11 Oct 2015)
New Revision: 66471
Added:
   grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry_attrs.py
pygrass: Add tests for geometry attrs (set/get item methods)
Added: grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry_attrs.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry_attrs.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry_attrs.py	2015-10-12 06:22:30 UTC (rev 66471)
@@ -0,0 +1,81 @@
+# -*- coding: utf-8 -*-
+Created on Thu Jun 19 14:13:53 2014
+ at author: pietro
+import sys
+import unittest
+import numpy as np
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+import grass.lib.vector as libvect
+from grass.script.core import run_command
+from grass.pygrass.vector import VectorTopo
+class GeometryAttrsTestCase(TestCase):
+    tmpname = "GeometryAttrsCase_map"
+    @classmethod
+    def setUpClass(cls):
+        from grass.pygrass import utils
+        utils.create_test_vector_map(cls.tmpname)
+        cls.vect = None
+        cls.vect = VectorTopo(cls.tmpname)
+        cls.vect.open('r')
+        cls.c_mapinfo = cls.vect.c_mapinfo
+        cls.attrs = cls.vect[1].attrs
+    @classmethod
+    def tearDownClass(cls):
+        cls.attrs = None
+        if cls.vect is not None:
+            cls.vect.close()
+            cls.c_mapinfo = None
+        """Remove the generated vector map, if exist"""
+        cls.runModule("g.remove", flags='f', type='vector',
+                      name=cls.tmpname)
+    def test_getitem(self):
+        """Test __getitem__ magic method"""
+        self.assertEqual(self.attrs['name'], u'point')
+        self.assertEqual(self.attrs['value'], 1.0)
+        self.assertTupleEqual(self.attrs['name', 'value'], (u'point', 1.0))
+        with self.assertRaises(ValueError) as cm:
+            self.attrs['not_existing_column_name']
+        self.assertEqual(cm.exception.message,
+                         u"The SQL is not correct:\n"
+                         u"'SELECT not_existing_column_name FROM "
+                         u"GeometryAttrsCase_map WHERE cat=1;',"
+                         u"\nvalues: None,\n"
+                         u"SQL error: no such column: "
+                         u"not_existing_column_name")
+    def test_setitem(self):
+        """Test __setitem__ magic method"""
+        newname = 'setitem_point_1'
+        newvalue = 100.0
+        newpairs = ('setitem_point_2', 1000.)
+        self.attrs.__setitem__('name', newname)
+        self.assertEqual(self.attrs['name'], newname)
+        self.attrs.__setitem__('value', newvalue)
+        self.assertEqual(self.attrs['value'], newvalue)
+        self.attrs.__setitem__(('name', 'value'), newpairs)
+        self.assertEqual(self.attrs['name', 'value'], newpairs)
+if __name__ == '__main__':
+    test()
Property changes on: grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry_attrs.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
