[GRASS-SVN] r66477 - in grass/trunk: . include/Make
svn_grass at osgeo.org
Mon Oct 12 04:10:48 PDT 2015
Author: glynn
Date: 2015-10-12 04:10:48 -0700 (Mon, 12 Oct 2015)
New Revision: 66477
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/include/Make/Platform.make.in
Remove wxWidgets support
Modified: grass/trunk/configure
--- grass/trunk/configure 2015-10-12 10:31:01 UTC (rev 66476)
+++ grass/trunk/configure 2015-10-12 11:10:48 UTC (rev 66477)
@@ -76,11 +76,6 @@
e.g. '--with-liblas=/usr/local/bin/liblas-config',
default: no)"
ac_help="$ac_help
- --with-wxwidgets[=path/wx-config]
- enable wxWidgets support (wx-config with path,
- e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
- default: no)"
-ac_help="$ac_help
--with-netcdf[=path/nc-config]
enable NetCDF support (nc-config with path,
e.g. '--with-nc=/usr/local/bin/nc-config',
@@ -743,7 +738,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:747: checking host system type" >&5
+echo "configure:742: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -766,7 +761,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:770: checking for $ac_word" >&5
+echo "configure:765: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -793,7 +788,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:797: checking for $ac_word" >&5
+echo "configure:792: checking for $ac_word" >&5
@@ -841,7 +836,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:845: checking for $ac_word" >&5
+echo "configure:840: checking for $ac_word" >&5
@@ -870,7 +865,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:874: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:869: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -881,12 +876,12 @@
cat > conftest.$ac_ext << EOF
-#line 885 "configure"
+#line 880 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -912,19 +907,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:916: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:911: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:921: checking whether we are using GNU C" >&5
+echo "configure:916: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:928: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:923: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -942,7 +937,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:946: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:941: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -971,10 +966,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:975: checking for Cygwin environment" >&5
+echo "configure:970: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 978 "configure"
+#line 973 "configure"
int main() {
@@ -985,7 +980,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:989: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:984: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -1001,17 +996,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1005: checking for mingw32 environment" >&5
+echo "configure:1000: checking for mingw32 environment" >&5
-#line 1008 "configure"
+#line 1003 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:1015: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1010: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1029,7 +1024,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1033: checking for executable suffix" >&5
+echo "configure:1028: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1048,23 +1043,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1052: checking for full floating-point support" >&5
+echo "configure:1047: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1057: checking whether "cc -mieee" works" >&5
+echo "configure:1052: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1061 "configure"
+#line 1056 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1068: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1063: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1080,7 +1075,7 @@
else
-#line 1084 "configure"
+#line 1079 "configure"
#include <float.h>
@@ -1094,7 +1089,7 @@
EOF
-if { (eval echo configure:1098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1107,14 +1102,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1111: checking for full floating-point support with -mieee" >&5
+echo "configure:1106: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1118 "configure"
+#line 1113 "configure"
#include <float.h>
@@ -1128,7 +1123,7 @@
EOF
-if { (eval echo configure:1132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1165,7 +1160,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1169: checking for $ac_word" >&5
+echo "configure:1164: checking for $ac_word" >&5
case "$pwd" in
@@ -1203,7 +1198,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1207: checking for source directory" >&5
+echo "configure:1202: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1214,7 +1209,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1218: checking for build directory" >&5
+echo "configure:1213: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1282,7 +1277,7 @@
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
-echo "configure:1286: checking for $ac_word" >&5
+echo "configure:1281: checking for $ac_word" >&5
case "$SVN_VERSION" in
@@ -1341,7 +1336,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1345: checking for MacOSX App" >&5
+echo "configure:1340: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1353,7 +1348,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1357: checking for MacOSX architectures" >&5
+echo "configure:1352: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1382,7 +1377,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1386: checking for MacOSX SDK" >&5
+echo "configure:1381: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1392,7 +1387,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1396: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1391: checking for $with_macosx_sdk/SDKSettings.plist" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1436,7 +1431,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1440: checking how to build libraries" >&5
+echo "configure:1435: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1889,15 +1884,6 @@
fi
-# Check whether --with-wxwidgets or --without-wxwidgets was given.
-if test "${with_wxwidgets+set}" = set; then
- withval="$with_wxwidgets"
-else
- with_wxwidgets="no"
-fi
# Check whether --with-netcdf or --without-netcdf was given.
if test "${with_netcdf+set}" = set; then
withval="$with_netcdf"
@@ -2306,7 +2292,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2310: checking for additional include dirs" >&5
+echo "configure:2296: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2329,7 +2315,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2333: checking for additional library dirs" >&5
+echo "configure:2319: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2363,7 +2349,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2367: checking for a BSD compatible install" >&5
+echo "configure:2353: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2416,7 +2402,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:2420: checking for $ac_word" >&5
+echo "configure:2406: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2447,13 +2433,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2451: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2437: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
-#line 2457 "configure"
+#line 2443 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2464,7 +2450,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2489,7 +2475,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2493: checking for $ac_word" >&5
+echo "configure:2479: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2529,7 +2515,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2533: checking for $ac_word" >&5
+echo "configure:2519: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2560,7 +2546,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2564: checking for $ac_word" >&5
+echo "configure:2550: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2598,7 +2584,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2602: checking for $ac_word" >&5
+echo "configure:2588: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2627,7 +2613,7 @@
-echo "configure:2631: checking for $ac_word" >&5
+echo "configure:2617: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2658,7 +2644,7 @@
-echo "configure:2662: checking for $ac_word" >&5
+echo "configure:2648: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2687,7 +2673,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2691: checking for $ac_word" >&5
+echo "configure:2677: checking for $ac_word" >&5
case "$PERL" in
@@ -2718,7 +2704,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2722: checking how to run the C preprocessor" >&5
+echo "configure:2708: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2731,13 +2717,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2735 "configure"
+#line 2721 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2741: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2727: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2748,13 +2734,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2752 "configure"
+#line 2738 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2758: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2744: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2765,13 +2751,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2769 "configure"
+#line 2755 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2775: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2761: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2795,10 +2781,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2799: checking for ANSI C header files" >&5
+echo "configure:2785: checking for ANSI C header files" >&5
-#line 2802 "configure"
+#line 2788 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2806,7 +2792,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2796: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2823,7 +2809,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2827 "configure"
+#line 2813 "configure"
#include <string.h>
EOF
@@ -2841,7 +2827,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2845 "configure"
+#line 2831 "configure"
#include <stdlib.h>
EOF
@@ -2862,7 +2848,7 @@
else
-#line 2866 "configure"
+#line 2852 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2873,7 +2859,7 @@
exit (0); }
EOF
-if { (eval echo configure:2877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2900,15 +2886,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2904: checking for $ac_hdr" >&5
+echo "configure:2890: checking for $ac_hdr" >&5
-#line 2907 "configure"
+#line 2893 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2912: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2898: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2937,15 +2923,15 @@
do
-echo "configure:2941: checking for $ac_hdr" >&5
+echo "configure:2927: checking for $ac_hdr" >&5
-#line 2944 "configure"
+#line 2930 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2949: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2974,15 +2960,15 @@
do
-echo "configure:2978: checking for $ac_hdr" >&5
+echo "configure:2964: checking for $ac_hdr" >&5
-#line 2981 "configure"
+#line 2967 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2986: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2972: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3011,15 +2997,15 @@
do
-echo "configure:3015: checking for $ac_hdr" >&5
+echo "configure:3001: checking for $ac_hdr" >&5
-#line 3018 "configure"
+#line 3004 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3023: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3009: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3048,15 +3034,15 @@
do
-echo "configure:3052: checking for $ac_hdr" >&5
+echo "configure:3038: checking for $ac_hdr" >&5
-#line 3055 "configure"
+#line 3041 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3082,10 +3068,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3086: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3072: checking whether time.h and sys/time.h may both be included" >&5
-#line 3089 "configure"
+#line 3075 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3094,7 +3080,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3098: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3084: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3114,10 +3100,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3118: checking for off_t" >&5
+echo "configure:3104: checking for off_t" >&5
-#line 3121 "configure"
+#line 3107 "configure"
#if STDC_HEADERS
@@ -3144,10 +3130,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3148: checking for uid_t in sys/types.h" >&5
+echo "configure:3134: checking for uid_t in sys/types.h" >&5
-#line 3151 "configure"
+#line 3137 "configure"
EOF
@@ -3175,10 +3161,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3179: checking return type of signal handlers" >&5
+echo "configure:3165: checking return type of signal handlers" >&5
-#line 3182 "configure"
+#line 3168 "configure"
#include <signal.h>
@@ -3195,7 +3181,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3199: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3185: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3213,10 +3199,10 @@
-echo "configure:3217: checking for Cygwin environment" >&5
+echo "configure:3203: checking for Cygwin environment" >&5
-#line 3220 "configure"
+#line 3206 "configure"
int main() {
@@ -3227,7 +3213,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3231: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3217: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3245,10 +3231,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3249: checking for $ac_func" >&5
+echo "configure:3235: checking for $ac_func" >&5
-#line 3252 "configure"
+#line 3238 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3271,7 +3257,7 @@
; return 0; }
EOF
-if { (eval echo configure:3275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3297,10 +3283,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3301: checking for $ac_func" >&5
+echo "configure:3287: checking for $ac_func" >&5
-#line 3304 "configure"
+#line 3290 "configure"
@@ -3323,7 +3309,7 @@
; return 0; }
EOF
-if { (eval echo configure:3327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3349,10 +3335,10 @@
for ac_func in drand48
do
-echo "configure:3353: checking for $ac_func" >&5
+echo "configure:3339: checking for $ac_func" >&5
-#line 3356 "configure"
+#line 3342 "configure"
@@ -3375,7 +3361,7 @@
; return 0; }
EOF
-if { (eval echo configure:3379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3401,10 +3387,10 @@
for ac_func in putenv setenv
do
-echo "configure:3405: checking for $ac_func" >&5
+echo "configure:3391: checking for $ac_func" >&5
-#line 3408 "configure"
+#line 3394 "configure"
@@ -3427,7 +3413,7 @@
; return 0; }
EOF
-if { (eval echo configure:3431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3453,10 +3439,10 @@
for ac_func in nanosleep
do
-echo "configure:3457: checking for $ac_func" >&5
+echo "configure:3443: checking for $ac_func" >&5
-#line 3460 "configure"
+#line 3446 "configure"
@@ -3479,7 +3465,7 @@
; return 0; }
EOF
-if { (eval echo configure:3483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3504,13 +3490,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3508: checking whether setpgrp takes no argument" >&5
+echo "configure:3494: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3514 "configure"
+#line 3500 "configure"
#ifdef HAVE_UNISTD_H
@@ -3530,7 +3516,7 @@
EOF
-if { (eval echo configure:3534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3558,16 +3544,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3562: checking for long long int" >&5
+echo "configure:3548: checking for long long int" >&5
-#line 3564 "configure"
+#line 3550 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3571: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3557: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -3587,7 +3573,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3591: checking for W11" >&5
+echo "configure:3577: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3615,7 +3601,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3619: checking for X" >&5
+echo "configure:3605: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3675,12 +3661,12 @@
# First, try using that file with no special directory specified.
-#line 3679 "configure"
+#line 3665 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3684: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3670: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3749,14 +3735,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3753 "configure"
+#line 3739 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3861,17 +3847,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3865: checking whether -R must be followed by a space" >&5
+echo "configure:3851: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3868 "configure"
+#line 3854 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3887,14 +3873,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3891 "configure"
+#line 3877 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3926,13 +3912,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3930: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3916: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3936 "configure"
+#line 3922 "configure"
@@ -3943,7 +3929,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3964,13 +3950,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3968: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3954: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3974 "configure"
+#line 3960 "configure"
@@ -3981,7 +3967,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4009,10 +3995,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4013: checking for gethostbyname" >&5
+echo "configure:3999: checking for gethostbyname" >&5
-#line 4016 "configure"
+#line 4002 "configure"
which can conflict with char gethostbyname(); below. */
@@ -4035,7 +4021,7 @@
; return 0; }
EOF
-if { (eval echo configure:4039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4055,13 +4041,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4059: checking for gethostbyname in -lnsl" >&5
+echo "configure:4045: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4065 "configure"
+#line 4051 "configure"
@@ -4072,7 +4058,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4101,10 +4087,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4105: checking for connect" >&5
+echo "configure:4091: checking for connect" >&5
-#line 4108 "configure"
+#line 4094 "configure"
which can conflict with char connect(); below. */
@@ -4127,7 +4113,7 @@
; return 0; }
EOF
-if { (eval echo configure:4131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4147,13 +4133,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4151: checking for connect in -lsocket" >&5
+echo "configure:4137: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4157 "configure"
+#line 4143 "configure"
@@ -4164,7 +4150,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4168: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4187,10 +4173,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4191: checking for remove" >&5
+echo "configure:4177: checking for remove" >&5
-#line 4194 "configure"
+#line 4180 "configure"
which can conflict with char remove(); below. */
@@ -4213,7 +4199,7 @@
; return 0; }
EOF
-if { (eval echo configure:4217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4233,13 +4219,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4237: checking for remove in -lposix" >&5
+echo "configure:4223: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4243 "configure"
+#line 4229 "configure"
@@ -4250,7 +4236,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4273,10 +4259,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4277: checking for shmat" >&5
+echo "configure:4263: checking for shmat" >&5
-#line 4280 "configure"
+#line 4266 "configure"
which can conflict with char shmat(); below. */
@@ -4299,7 +4285,7 @@
; return 0; }
EOF
-if { (eval echo configure:4303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4319,13 +4305,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4323: checking for shmat in -lipc" >&5
+echo "configure:4309: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4329 "configure"
+#line 4315 "configure"
@@ -4336,7 +4322,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4368,13 +4354,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4372: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4358: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4378 "configure"
+#line 4364 "configure"
@@ -4385,7 +4371,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4425,12 +4411,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4429: checking for library containing cuserid" >&5
+echo "configure:4415: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4434 "configure"
+#line 4420 "configure"
@@ -4441,7 +4427,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4452,7 +4438,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4456 "configure"
+#line 4442 "configure"
@@ -4463,7 +4449,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4489,10 +4475,10 @@
for ac_func in asprintf
do
-echo "configure:4493: checking for $ac_func" >&5
+echo "configure:4479: checking for $ac_func" >&5
-#line 4496 "configure"
+#line 4482 "configure"
@@ -4515,7 +4501,7 @@
; return 0; }
EOF
-if { (eval echo configure:4519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4542,10 +4528,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4546: checking for atan" >&5
+echo "configure:4532: checking for atan" >&5
-#line 4549 "configure"
+#line 4535 "configure"
which can conflict with char atan(); below. */
@@ -4568,7 +4554,7 @@
; return 0; }
EOF
-if { (eval echo configure:4572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4586,13 +4572,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4590: checking for atan in -lm" >&5
+echo "configure:4576: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4596 "configure"
+#line 4582 "configure"
@@ -4603,7 +4589,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4630,10 +4616,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4634: checking for dlsym" >&5
+echo "configure:4620: checking for dlsym" >&5
-#line 4637 "configure"
+#line 4623 "configure"
which can conflict with char dlsym(); below. */
@@ -4656,7 +4642,7 @@
; return 0; }
EOF
-if { (eval echo configure:4660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4674,13 +4660,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4678: checking for dlsym in -ldl" >&5
+echo "configure:4664: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4684 "configure"
+#line 4670 "configure"
@@ -4691,7 +4677,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4718,10 +4704,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4722: checking for iconv" >&5
+echo "configure:4708: checking for iconv" >&5
-#line 4725 "configure"
+#line 4711 "configure"
which can conflict with char iconv(); below. */
@@ -4744,7 +4730,7 @@
; return 0; }
EOF
-if { (eval echo configure:4748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4762,13 +4748,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4766: checking for iconv in -liconv" >&5
+echo "configure:4752: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4772 "configure"
+#line 4758 "configure"
@@ -4779,7 +4765,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4798,13 +4784,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4802: checking for iconv in -lgiconv" >&5
+echo "configure:4788: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4808 "configure"
+#line 4794 "configure"
@@ -4815,7 +4801,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4834,10 +4820,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4838: checking for libiconv" >&5
+echo "configure:4824: checking for libiconv" >&5
-#line 4841 "configure"
+#line 4827 "configure"
which can conflict with char libiconv(); below. */
@@ -4860,7 +4846,7 @@
; return 0; }
EOF
-if { (eval echo configure:4864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -4878,13 +4864,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4882: checking for libiconv in -liconv" >&5
+echo "configure:4868: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4888 "configure"
+#line 4874 "configure"
@@ -4895,7 +4881,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4914,13 +4900,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4918: checking for libiconv in -lgiconv" >&5
+echo "configure:4904: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4924 "configure"
+#line 4910 "configure"
@@ -4931,7 +4917,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4968,10 +4954,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4972: checking for socket" >&5
+echo "configure:4958: checking for socket" >&5
-#line 4975 "configure"
+#line 4961 "configure"
which can conflict with char socket(); below. */
@@ -4994,7 +4980,7 @@
; return 0; }
EOF
-if { (eval echo configure:4998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5012,13 +4998,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5016: checking for socket in -lsocket" >&5
+echo "configure:5002: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5022 "configure"
+#line 5008 "configure"
@@ -5029,7 +5015,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5077,7 +5063,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5081: checking for location of zlib includes" >&5
+echo "configure:5067: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5103,15 +5089,15 @@
do
-echo "configure:5107: checking for $ac_hdr" >&5
+echo "configure:5093: checking for $ac_hdr" >&5
-#line 5110 "configure"
+#line 5096 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5115: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5145,7 +5131,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5149: checking for location of zlib library" >&5
+echo "configure:5135: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5170,13 +5156,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5174: checking for deflate in -lz" >&5
+echo "configure:5160: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5180 "configure"
+#line 5166 "configure"
@@ -5187,7 +5173,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5235,7 +5221,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5239: checking for location of External PROJ.4 includes" >&5
+echo "configure:5225: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5261,15 +5247,15 @@
do
-echo "configure:5265: checking for $ac_hdr" >&5
+echo "configure:5251: checking for $ac_hdr" >&5
-#line 5268 "configure"
+#line 5254 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5273: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5259: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5306,7 +5292,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5310: checking External PROJ.4 version" >&5
+echo "configure:5296: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5314,7 +5300,7 @@
else
-#line 5318 "configure"
+#line 5304 "configure"
#include <stdio.h>
@@ -5326,7 +5312,7 @@
EOF
-if { (eval echo configure:5330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5351,7 +5337,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5355: checking for location of External PROJ.4 library" >&5
+echo "configure:5341: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5376,13 +5362,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5380: checking for pj_get_def in -lproj" >&5
+echo "configure:5366: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5386 "configure"
+#line 5372 "configure"
@@ -5393,7 +5379,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5427,7 +5413,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5431: checking for location of External PROJ.4 data files" >&5
+echo "configure:5417: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5451,14 +5437,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5455: checking for epsg" >&5
+echo "configure:5441: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5462: checking for $PROJSHARE/epsg" >&5
+echo "configure:5448: checking for $PROJSHARE/epsg" >&5
@@ -5490,7 +5476,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5494: checking for $ac_word" >&5
+echo "configure:5480: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5530,7 +5516,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5534: checking whether to use regex" >&5
+echo "configure:5520: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5550,7 +5536,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5554: checking for location of regex includes" >&5
+echo "configure:5540: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5576,15 +5562,15 @@
do
-echo "configure:5580: checking for $ac_hdr" >&5
+echo "configure:5566: checking for $ac_hdr" >&5
-#line 5583 "configure"
+#line 5569 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5588: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5574: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5618,7 +5604,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5622: checking for location of regex library" >&5
+echo "configure:5608: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5643,10 +5629,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5647: checking for regcomp" >&5
+echo "configure:5633: checking for regcomp" >&5
-#line 5650 "configure"
+#line 5636 "configure"
which can conflict with char regcomp(); below. */
@@ -5669,7 +5655,7 @@
; return 0; }
EOF
-if { (eval echo configure:5673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5696,13 +5682,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5700: checking for regcomp in -lregex" >&5
+echo "configure:5686: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5706 "configure"
+#line 5692 "configure"
@@ -5713,7 +5699,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5763,7 +5749,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5767: checking whether to use Readline" >&5
+echo "configure:5753: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5784,7 +5770,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5788: checking for location of Readline includes" >&5
+echo "configure:5774: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5810,15 +5796,15 @@
do
-echo "configure:5814: checking for $ac_hdr" >&5
+echo "configure:5800: checking for $ac_hdr" >&5
-#line 5817 "configure"
+#line 5803 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5822: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5854,15 +5840,15 @@
do
-echo "configure:5858: checking for $ac_hdr" >&5
+echo "configure:5844: checking for $ac_hdr" >&5
-#line 5861 "configure"
+#line 5847 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5866: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5852: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5896,7 +5882,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5900: checking for location of Readline library" >&5
+echo "configure:5886: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5921,13 +5907,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5925: checking for readline in -lreadline" >&5
+echo "configure:5911: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 5931 "configure"
+#line 5917 "configure"
@@ -5938,7 +5924,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:5942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5973,13 +5959,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:5977: checking for add_history in -lhistory" >&5
+echo "configure:5963: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 5983 "configure"
+#line 5969 "configure"
@@ -5990,7 +5976,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:5994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6032,7 +6018,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6036: checking whether to use GDAL" >&5
+echo "configure:6022: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6050,7 +6036,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6054: checking for $ac_word" >&5
+echo "configure:6040: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6105,14 +6091,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6109 "configure"
+#line 6095 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6121,14 +6107,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6125 "configure"
+#line 6111 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6160,7 +6146,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6164: checking whether to use libLAS" >&5
+echo "configure:6150: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6177,7 +6163,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6181: checking for $ac_word" >&5
+echo "configure:6167: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6227,14 +6213,14 @@
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
CPPFLAGS="$CPPFLAGS $LIBLAS_INC"
-#line 6231 "configure"
+#line 6217 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6242,14 +6228,14 @@
rm -rf conftest*
-#line 6246 "configure"
+#line 6232 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6282,7 +6268,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6286: checking whether to use NetCDF" >&5
+echo "configure:6272: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6299,7 +6285,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6303: checking for $ac_word" >&5
+echo "configure:6289: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6346,14 +6332,14 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6350 "configure"
+#line 6336 "configure"
#include <netcdf.h>
int main() {
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6361,14 +6347,14 @@
rm -rf conftest*
-#line 6365 "configure"
+#line 6351 "configure"
#include <netcdf.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6399,7 +6385,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6403: checking whether to use GEOS" >&5
+echo "configure:6389: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6417,7 +6403,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6421: checking for $ac_word" >&5
+echo "configure:6407: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6465,15 +6451,15 @@
do
-echo "configure:6469: checking for $ac_hdr" >&5
+echo "configure:6455: checking for $ac_hdr" >&5
-#line 6472 "configure"
+#line 6458 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6477: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6463: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6512,13 +6498,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6516: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6502: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6522 "configure"
+#line 6508 "configure"
@@ -6529,7 +6515,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6573,7 +6559,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6577: checking whether to use TIFF" >&5
+echo "configure:6563: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6593,7 +6579,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6597: checking for location of TIFF includes" >&5
+echo "configure:6583: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6619,15 +6605,15 @@
do
-echo "configure:6623: checking for $ac_hdr" >&5
+echo "configure:6609: checking for $ac_hdr" >&5
-#line 6626 "configure"
+#line 6612 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6631: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6617: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6661,7 +6647,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6665: checking for location of TIFF library" >&5
+echo "configure:6651: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6692,13 +6678,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6696: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6682: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6702 "configure"
+#line 6688 "configure"
#include "confdefs.h"
@@ -6709,7 +6695,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6728,13 +6714,13 @@
-echo "configure:6732: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6718: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6738 "configure"
+#line 6724 "configure"
@@ -6745,7 +6731,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6764,13 +6750,13 @@
-echo "configure:6768: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6754: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6774 "configure"
+#line 6760 "configure"
@@ -6781,7 +6767,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6800,13 +6786,13 @@
-echo "configure:6804: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6790: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 6810 "configure"
+#line 6796 "configure"
@@ -6817,7 +6803,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6836,13 +6822,13 @@
-echo "configure:6840: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6826: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 6846 "configure"
+#line 6832 "configure"
@@ -6853,7 +6839,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6872,13 +6858,13 @@
-echo "configure:6876: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6862: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6882 "configure"
+#line 6868 "configure"
@@ -6889,7 +6875,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6908,13 +6894,13 @@
-echo "configure:6912: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6898: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6918 "configure"
+#line 6904 "configure"
@@ -6925,7 +6911,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6944,13 +6930,13 @@
-echo "configure:6948: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6934: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6954 "configure"
+#line 6940 "configure"
@@ -6961,7 +6947,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7059,7 +7045,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7063: checking whether to use PNG" >&5
+echo "configure:7049: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7078,7 +7064,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7082: checking for location of PNG includes" >&5
+echo "configure:7068: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7104,15 +7090,15 @@
do
-echo "configure:7108: checking for $ac_hdr" >&5
+echo "configure:7094: checking for $ac_hdr" >&5
-#line 7111 "configure"
+#line 7097 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7116: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7102: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7146,7 +7132,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7150: checking for location of PNG library" >&5
+echo "configure:7136: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7171,13 +7157,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7175: checking for png_read_image in -lpng" >&5
+echo "configure:7161: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7181 "configure"
+#line 7167 "configure"
@@ -7188,7 +7174,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7230,7 +7216,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7234: checking whether to use PostgreSQL" >&5
+echo "configure:7220: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7257,7 +7243,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7261: checking for location of PostgreSQL includes" >&5
+echo "configure:7247: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7283,15 +7269,15 @@
do
-echo "configure:7287: checking for $ac_hdr" >&5
+echo "configure:7273: checking for $ac_hdr" >&5
-#line 7290 "configure"
+#line 7276 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7329,7 +7315,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7333: checking for location of PostgreSQL library" >&5
+echo "configure:7319: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7358,13 +7344,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7362: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7348: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7368 "configure"
+#line 7354 "configure"
@@ -7375,7 +7361,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7394,13 +7380,13 @@
-echo "configure:7398: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7384: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7404 "configure"
+#line 7390 "configure"
@@ -7411,7 +7397,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7430,13 +7416,13 @@
-echo "configure:7434: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7420: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7440 "configure"
+#line 7426 "configure"
@@ -7447,7 +7433,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7466,13 +7452,13 @@
-echo "configure:7470: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7456: checking for PQsetdbLogin in -lpq" >&5
ac_save_LIBS="$LIBS"
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7476 "configure"
+#line 7462 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7483,7 +7469,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7540,13 +7526,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7544: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7530: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7550 "configure"
+#line 7536 "configure"
@@ -7557,7 +7543,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7561: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7579,13 +7565,13 @@
-echo "configure:7583: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7569: checking for PQcmdTuples in -lpq" >&5
-#line 7589 "configure"
+#line 7575 "configure"
@@ -7596,7 +7582,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7639,7 +7625,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7643: checking whether to use MySQL" >&5
+echo "configure:7629: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7659,7 +7645,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7663: checking for location of MySQL includes" >&5
+echo "configure:7649: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7685,15 +7671,15 @@
do
-echo "configure:7689: checking for $ac_hdr" >&5
+echo "configure:7675: checking for $ac_hdr" >&5
-#line 7692 "configure"
+#line 7678 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7683: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7730,7 +7716,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7734: checking for location of MySQL library" >&5
+echo "configure:7720: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7761,13 +7747,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7765: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7751: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7771 "configure"
+#line 7757 "configure"
@@ -7778,7 +7764,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7797,13 +7783,13 @@
-echo "configure:7801: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7787: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7807 "configure"
+#line 7793 "configure"
@@ -7814,7 +7800,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7833,13 +7819,13 @@
-echo "configure:7837: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7823: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7843 "configure"
+#line 7829 "configure"
@@ -7850,7 +7836,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7869,13 +7855,13 @@
-echo "configure:7873: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7859: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7879 "configure"
+#line 7865 "configure"
@@ -7886,7 +7872,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7905,13 +7891,13 @@
-echo "configure:7909: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7895: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7915 "configure"
+#line 7901 "configure"
@@ -7922,7 +7908,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7941,13 +7927,13 @@
-echo "configure:7945: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7931: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7951 "configure"
+#line 7937 "configure"
@@ -7958,7 +7944,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7977,13 +7963,13 @@
-echo "configure:7981: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7967: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 7987 "configure"
+#line 7973 "configure"
@@ -7994,7 +7980,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8013,13 +7999,13 @@
-echo "configure:8017: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8003: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8023 "configure"
+#line 8009 "configure"
@@ -8030,7 +8016,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8120,7 +8106,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8124: checking for $ac_word" >&5
+echo "configure:8110: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8169,10 +8155,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8173: checking for mysql_server_init" >&5
+echo "configure:8159: checking for mysql_server_init" >&5
-#line 8176 "configure"
+#line 8162 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8198,7 +8184,7 @@
; return 0; }
EOF
-if { (eval echo configure:8202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8250,7 +8236,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8254: checking whether to use SQLite" >&5
+echo "configure:8240: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8270,7 +8256,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8274: checking for location of SQLite includes" >&5
+echo "configure:8260: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8296,15 +8282,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8300: checking for $ac_hdr" >&5
+echo "configure:8286: checking for $ac_hdr" >&5
-#line 8303 "configure"
+#line 8289 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8308: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8294: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8347,7 +8333,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8351: checking for location of SQLite library" >&5
+echo "configure:8337: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8376,13 +8362,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8380: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8366: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8386 "configure"
+#line 8372 "configure"
@@ -8393,7 +8379,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8412,13 +8398,13 @@
-echo "configure:8416: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8402: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8422 "configure"
+#line 8408 "configure"
@@ -8429,7 +8415,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8448,13 +8434,13 @@
-echo "configure:8452: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8438: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8458 "configure"
+#line 8444 "configure"
@@ -8465,7 +8451,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8484,13 +8470,13 @@
-echo "configure:8488: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8474: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8494 "configure"
+#line 8480 "configure"
@@ -8501,7 +8487,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8576,7 +8562,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:8580: checking whether to use OpenGL" >&5
+echo "configure:8566: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -8610,7 +8596,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:8614: checking for location of OpenGL includes" >&5
+echo "configure:8600: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -8636,15 +8622,15 @@
do
-echo "configure:8640: checking for $ac_hdr" >&5
+echo "configure:8626: checking for $ac_hdr" >&5
-#line 8643 "configure"
+#line 8629 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8648: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8634: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8678,7 +8664,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:8682: checking for location of OpenGL library" >&5
+echo "configure:8668: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -8707,13 +8693,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:8711: checking for glBegin in -lGL" >&5
+echo "configure:8697: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 8717 "configure"
+#line 8703 "configure"
@@ -8724,7 +8710,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:8728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8743,13 +8729,13 @@
-echo "configure:8747: checking for glBegin in -lGL" >&5
+echo "configure:8733: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 8753 "configure"
+#line 8739 "configure"
@@ -8760,7 +8746,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:8764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8779,13 +8765,13 @@
-echo "configure:8783: checking for glBegin in -lGL" >&5
+echo "configure:8769: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 8789 "configure"
+#line 8775 "configure"
@@ -8796,7 +8782,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:8800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8815,13 +8801,13 @@
-echo "configure:8819: checking for glBegin in -lGL" >&5
+echo "configure:8805: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 8825 "configure"
+#line 8811 "configure"
@@ -8832,7 +8818,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:8836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8894,13 +8880,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:8898: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:8884: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 8904 "configure"
+#line 8890 "configure"
@@ -8911,7 +8897,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:8915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8930,13 +8916,13 @@
-echo "configure:8934: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:8920: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 8940 "configure"
+#line 8926 "configure"
@@ -8947,7 +8933,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:8951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8994,10 +8980,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:8998: checking for glXCreatePbuffer" >&5
+echo "configure:8984: checking for glXCreatePbuffer" >&5
-#line 9001 "configure"
+#line 8987 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -9020,7 +9006,7 @@
; return 0; }
EOF
-if { (eval echo configure:9024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9057,10 +9043,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9061: checking for glXCreateGLXPixmap" >&5
+echo "configure:9047: checking for glXCreateGLXPixmap" >&5
-#line 9064 "configure"
+#line 9050 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9083,7 +9069,7 @@
; return 0; }
EOF
-if { (eval echo configure:9087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9126,7 +9112,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9130: checking for location of OpenGL framework" >&5
+echo "configure:9116: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9150,15 +9136,15 @@
do
-echo "configure:9154: checking for $ac_hdr" >&5
+echo "configure:9140: checking for $ac_hdr" >&5
-#line 9157 "configure"
+#line 9143 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9162: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9148: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9194,10 +9180,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9198: checking for glBegin" >&5
+echo "configure:9184: checking for glBegin" >&5
-#line 9201 "configure"
+#line 9187 "configure"
which can conflict with char glBegin(); below. */
@@ -9220,7 +9206,7 @@
; return 0; }
EOF
-if { (eval echo configure:9224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9257,10 +9243,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9261: checking for gluBeginCurve" >&5
+echo "configure:9247: checking for gluBeginCurve" >&5
-#line 9264 "configure"
+#line 9250 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9283,7 +9269,7 @@
; return 0; }
EOF
-if { (eval echo configure:9287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9331,7 +9317,7 @@
-echo "configure:9335: checking for location of OpenGL includes" >&5
+echo "configure:9321: checking for location of OpenGL includes" >&5
@@ -9357,15 +9343,15 @@
do
-echo "configure:9361: checking for $ac_hdr" >&5
+echo "configure:9347: checking for $ac_hdr" >&5
-#line 9364 "configure"
+#line 9350 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9399,7 +9385,7 @@
-echo "configure:9403: checking for location of OpenGL library" >&5
+echo "configure:9389: checking for location of OpenGL library" >&5
@@ -9424,18 +9410,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9428: checking for OpenGL library" >&5
+echo "configure:9414: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9432 "configure"
+#line 9418 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9459,18 +9445,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9463: checking for GLU library" >&5
+echo "configure:9449: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 9467 "configure"
+#line 9453 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:9474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -9519,7 +9505,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:9523: checking whether to use ODBC" >&5
+echo "configure:9509: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -9538,7 +9524,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:9542: checking for location of ODBC includes" >&5
+echo "configure:9528: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -9564,15 +9550,15 @@
do
-echo "configure:9568: checking for $ac_hdr" >&5
+echo "configure:9554: checking for $ac_hdr" >&5
-#line 9571 "configure"
+#line 9557 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9576: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9562: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9606,7 +9592,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:9610: checking for location of ODBC library" >&5
+echo "configure:9596: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -9631,13 +9617,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:9635: checking for SQLConnect in -lodbc" >&5
+echo "configure:9621: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 9641 "configure"
+#line 9627 "configure"
@@ -9648,7 +9634,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:9652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9673,13 +9659,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:9677: checking for SQLConnect in -liodbc" >&5
+echo "configure:9663: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 9683 "configure"
+#line 9669 "configure"
@@ -9690,7 +9676,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:9694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9715,11 +9701,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:9719: checking for ODBC library" >&5
+echo "configure:9705: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 9723 "configure"
+#line 9709 "configure"
#include <windows.h>
#include <sql.h>
@@ -9727,7 +9713,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:9731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -9776,7 +9762,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:9780: checking whether to use FFTW" >&5
+echo "configure:9766: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -9795,7 +9781,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:9799: checking for location of FFTW includes" >&5
+echo "configure:9785: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -9821,15 +9807,15 @@
do
-echo "configure:9825: checking for $ac_hdr" >&5
+echo "configure:9811: checking for $ac_hdr" >&5
-#line 9828 "configure"
+#line 9814 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9833: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9857,15 +9843,15 @@
do
-echo "configure:9861: checking for $ac_hdr" >&5
+echo "configure:9847: checking for $ac_hdr" >&5
-#line 9864 "configure"
+#line 9850 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9869: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9893,15 +9879,15 @@
do
-echo "configure:9897: checking for $ac_hdr" >&5
+echo "configure:9883: checking for $ac_hdr" >&5
-#line 9900 "configure"
+#line 9886 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9905: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9947,7 +9933,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:9951: checking for location of FFTW library" >&5
+echo "configure:9937: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -9972,13 +9958,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:9976: checking for fftw_execute in -lfftw3" >&5
+echo "configure:9962: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 9982 "configure"
+#line 9968 "configure"
@@ -9989,7 +9975,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:9993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10014,13 +10000,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10018: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10004: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10024 "configure"
+#line 10010 "configure"
@@ -10031,7 +10017,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10056,13 +10042,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10060: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10046: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10066 "configure"
+#line 10052 "configure"
@@ -10073,7 +10059,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10130,7 +10116,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10134: checking whether to use BLAS" >&5
+echo "configure:10120: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10151,7 +10137,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10155: checking for location of BLAS includes" >&5
+echo "configure:10141: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10171,7 +10157,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10175: checking for location of BLAS library" >&5
+echo "configure:10161: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10197,15 +10183,15 @@
do
-echo "configure:10201: checking for $ac_hdr" >&5
+echo "configure:10187: checking for $ac_hdr" >&5
-#line 10204 "configure"
+#line 10190 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10195: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10240,13 +10226,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10244: checking for dnrm2_ in -lblas" >&5
+echo "configure:10230: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10250 "configure"
+#line 10236 "configure"
@@ -10257,7 +10243,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10276,13 +10262,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10280: checking for dnrm2_ in -lblas" >&5
+echo "configure:10266: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10286 "configure"
+#line 10272 "configure"
@@ -10293,7 +10279,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10337,13 +10323,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10341: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10327: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10347 "configure"
+#line 10333 "configure"
@@ -10354,7 +10340,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10369,13 +10355,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10373: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10359: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10379 "configure"
+#line 10365 "configure"
@@ -10386,7 +10372,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10401,13 +10387,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10405: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10391: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10411 "configure"
+#line 10397 "configure"
@@ -10418,7 +10404,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10464,16 +10450,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10468: checking for sgemm in $vlib_flags" >&5
+echo "configure:10454: checking for sgemm in $vlib_flags" >&5
-#line 10470 "configure"
+#line 10456 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:10477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -10491,13 +10477,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10495: checking for sgemm_ in -lblas" >&5
+echo "configure:10481: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 10501 "configure"
+#line 10487 "configure"
@@ -10508,7 +10494,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10523,13 +10509,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:10527: checking for dgemm_ in -ldgemm" >&5
+echo "configure:10513: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 10533 "configure"
+#line 10519 "configure"
@@ -10540,7 +10526,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:10544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10555,13 +10541,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:10559: checking for sgemm_ in -lsgemm" >&5
+echo "configure:10545: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 10565 "configure"
+#line 10551 "configure"
@@ -10572,7 +10558,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10606,13 +10592,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:10610: checking for acosp in -lsunmath" >&5
+echo "configure:10596: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 10616 "configure"
+#line 10602 "configure"
@@ -10623,7 +10609,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:10627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10638,13 +10624,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:10642: checking for sgemm_ in -lsunperf" >&5
+echo "configure:10628: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 10648 "configure"
+#line 10634 "configure"
@@ -10655,7 +10641,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10685,13 +10671,13 @@
# Generic BLAS library
-echo "configure:10689: checking for sgemm_ in -lblas" >&5
+echo "configure:10675: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 10695 "configure"
+#line 10681 "configure"
@@ -10702,7 +10688,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10741,7 +10727,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:10745: checking whether to use LAPACK" >&5
+echo "configure:10731: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -10766,7 +10752,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:10770: checking for location of LAPACK includes" >&5
+echo "configure:10756: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -10786,7 +10772,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:10790: checking for location of LAPACK library" >&5
+echo "configure:10776: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -10812,15 +10798,15 @@
do
-echo "configure:10816: checking for $ac_hdr" >&5
+echo "configure:10802: checking for $ac_hdr" >&5
-#line 10819 "configure"
+#line 10805 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10852,10 +10838,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:10856: checking for dsegv_" >&5
+echo "configure:10842: checking for dsegv_" >&5
-#line 10859 "configure"
+#line 10845 "configure"
which can conflict with char dsegv_(); below. */
@@ -10878,7 +10864,7 @@
; return 0; }
EOF
-if { (eval echo configure:10882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -10905,13 +10891,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:10909: checking for desgv_ in -llapack" >&5
+echo "configure:10895: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 10915 "configure"
+#line 10901 "configure"
@@ -10922,7 +10908,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:10926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10954,13 +10940,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:10958: checking for dgesv_ in -llapack" >&5
+echo "configure:10944: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 10964 "configure"
+#line 10950 "configure"
@@ -10971,7 +10957,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:10975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10990,13 +10976,13 @@
-echo "configure:10994: checking for dgesv_ in -llapack" >&5
+echo "configure:10980: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11000 "configure"
+#line 10986 "configure"
@@ -11007,7 +10993,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11063,7 +11049,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11067: checking whether to use Cairo" >&5
+echo "configure:11053: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11095,7 +11081,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11099: checking for location of cairo includes" >&5
+echo "configure:11085: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11121,15 +11107,15 @@
do
-echo "configure:11125: checking for $ac_hdr" >&5
+echo "configure:11111: checking for $ac_hdr" >&5
-#line 11128 "configure"
+#line 11114 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11133: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11119: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11165,7 +11151,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11169: checking for location of cairo library" >&5
+echo "configure:11155: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11185,7 +11171,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11189: checking for cairo linking flags" >&5
+echo "configure:11175: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11201,10 +11187,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11205: checking for cairo_create" >&5
+echo "configure:11191: checking for cairo_create" >&5
-#line 11208 "configure"
+#line 11194 "configure"
which can conflict with char cairo_create(); below. */
@@ -11227,7 +11213,7 @@
; return 0; }
EOF
-if { (eval echo configure:11231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11261,10 +11247,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11265: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11251: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11268 "configure"
+#line 11254 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11287,7 +11273,7 @@
; return 0; }
EOF
-if { (eval echo configure:11291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11320,10 +11306,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11324: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11310: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11327 "configure"
+#line 11313 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11346,7 +11332,7 @@
; return 0; }
EOF
-if { (eval echo configure:11350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11388,7 +11374,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11392: checking whether to use FreeType" >&5
+echo "configure:11378: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11407,7 +11393,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11411: checking for location of FreeType includes" >&5
+echo "configure:11397: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11433,15 +11419,15 @@
do
-echo "configure:11437: checking for $ac_hdr" >&5
+echo "configure:11423: checking for $ac_hdr" >&5
-#line 11440 "configure"
+#line 11426 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11445: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11431: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11475,7 +11461,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11479: checking for location of FreeType library" >&5
+echo "configure:11465: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11500,13 +11486,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:11504: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11490: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 11510 "configure"
+#line 11496 "configure"
@@ -11517,7 +11503,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:11521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11558,7 +11544,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:11562: checking whether to use NLS" >&5
+echo "configure:11548: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -11578,10 +11564,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:11582: checking for gettext" >&5
+echo "configure:11568: checking for gettext" >&5
-#line 11585 "configure"
+#line 11571 "configure"
which can conflict with char gettext(); below. */
@@ -11604,7 +11590,7 @@
; return 0; }
EOF
-if { (eval echo configure:11608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -11622,13 +11608,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:11626: checking for gettext in -lintl" >&5
+echo "configure:11612: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 11632 "configure"
+#line 11618 "configure"
@@ -11639,7 +11625,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:11643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11674,7 +11660,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:11678: checking whether to use C++" >&5
+echo "configure:11664: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -11690,7 +11676,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:11694: checking for $ac_word" >&5
+echo "configure:11680: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -11719,7 +11705,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:11723: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:11709: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -11730,12 +11716,12 @@
cat > conftest.$ac_ext << EOF
-#line 11734 "configure"
+#line 11720 "configure"
#include "confdefs.h"
int main(){return(0);}
EOF
-if { (eval echo configure:11739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -11761,19 +11747,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:11765: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:11751: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:11770: checking whether we are using GNU C++" >&5
+echo "configure:11756: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:11777: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:11763: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -11791,7 +11777,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:11795: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:11781: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -11819,58 +11805,7 @@
fi
fi
-for ac_declaration in \
- '#include <stdlib.h>' \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
- cat > conftest.$ac_ext <<EOF
-#line 11833 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:11841: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- continue
-fi
-rm -f conftest*
-#line 11851 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:11858: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
CXX=
CXXFLAGS=
@@ -11883,7 +11818,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:11887: checking whether to use openDWG" >&5
+echo "configure:11822: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -11903,7 +11838,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:11907: checking for location of openDGW includes" >&5
+echo "configure:11842: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -11929,15 +11864,15 @@
do
-echo "configure:11933: checking for $ac_hdr" >&5
+echo "configure:11868: checking for $ac_hdr" >&5
-#line 11936 "configure"
+#line 11871 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11941: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11971,7 +11906,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:11975: checking for location of openDWG library" >&5
+echo "configure:11910: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12012,7 +11947,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12016: checking whether to use POSIX threads" >&5
+echo "configure:11951: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12032,7 +11967,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12036: checking for location of POSIX threads includes" >&5
+echo "configure:11971: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12058,15 +11993,15 @@
do
-echo "configure:12062: checking for $ac_hdr" >&5
+echo "configure:11997: checking for $ac_hdr" >&5
-#line 12065 "configure"
+#line 12000 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12070: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12100,7 +12035,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12104: checking for location of POSIX threads library" >&5
+echo "configure:12039: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12125,10 +12060,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12129: checking for pthread_create" >&5
+echo "configure:12064: checking for pthread_create" >&5
-#line 12132 "configure"
+#line 12067 "configure"
which can conflict with char pthread_create(); below. */
@@ -12151,7 +12086,7 @@
; return 0; }
EOF
-if { (eval echo configure:12155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12178,13 +12113,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12182: checking for pthread_create in -lpthread" >&5
+echo "configure:12117: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 12188 "configure"
+#line 12123 "configure"
@@ -12195,7 +12130,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12245,7 +12180,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12249: checking whether to use OpenMP" >&5
+echo "configure:12184: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12266,7 +12201,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12270: checking for location of OpenMP includes" >&5
+echo "configure:12205: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12292,15 +12227,15 @@
do
-echo "configure:12296: checking for $ac_hdr" >&5
+echo "configure:12231: checking for $ac_hdr" >&5
-#line 12299 "configure"
+#line 12234 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12304: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12239: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12338,7 +12273,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12342: checking for location of OpenMP library" >&5
+echo "configure:12277: checking for location of OpenMP library" >&5
case "$with_openmp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12363,10 +12298,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12367: checking for GOMP_parallel_start" >&5
+echo "configure:12302: checking for GOMP_parallel_start" >&5
-#line 12370 "configure"
+#line 12305 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12389,7 +12324,7 @@
; return 0; }
EOF
-if { (eval echo configure:12393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12416,13 +12351,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12420: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12355: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lgomp $LIBS"
-#line 12426 "configure"
+#line 12361 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12433,7 +12368,7 @@
; return 0; }
EOF
-if { (eval echo configure:12437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12506,7 +12441,7 @@
echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12510: checking whether to use OpenCL" >&5
+echo "configure:12445: checking whether to use OpenCL" >&5
echo "$ac_t"""$with_opencl"" 1>&6
case "$with_opencl" in
"no") USE_OPENCL= ;;
@@ -12526,7 +12461,7 @@
echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12530: checking for location of OpenCL includes" >&5
+echo "configure:12465: checking for location of OpenCL includes" >&5
case "$with_opencl_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12553,15 +12488,15 @@
do
-echo "configure:12557: checking for $ac_hdr" >&5
+echo "configure:12492: checking for $ac_hdr" >&5
-#line 12560 "configure"
+#line 12495 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12565: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12500: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12601,10 +12536,10 @@
LIBS="-framework OpenCL $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:12605: checking for clGetPlatformInfo" >&5
+echo "configure:12540: checking for clGetPlatformInfo" >&5
-#line 12608 "configure"
+#line 12543 "configure"
which can conflict with char clGetPlatformInfo(); below. */
@@ -12627,7 +12562,7 @@
; return 0; }
EOF
-if { (eval echo configure:12631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_clGetPlatformInfo=yes"
else
@@ -12666,15 +12601,15 @@
do
-echo "configure:12670: checking for $ac_hdr" >&5
+echo "configure:12605: checking for $ac_hdr" >&5
-#line 12673 "configure"
+#line 12608 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12613: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12707,7 +12642,7 @@
# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:12711: checking for location of OpenCL library" >&5
+echo "configure:12646: checking for location of OpenCL library" >&5
case "$with_opencl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -12731,13 +12666,13 @@
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:12735: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:12670: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
LIBS="-lOpenCL $LIBS"
-#line 12741 "configure"
+#line 12676 "configure"
@@ -12748,7 +12683,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:12752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12808,7 +12743,7 @@
fi
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:12812: checking for special C compiler options needed for large files" >&5
+echo "configure:12747: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -12816,7 +12751,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 12820 "configure"
+#line 12755 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -12832,7 +12767,7 @@
; return 0; }
EOF
-if { (eval echo configure:12836: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12771: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -12841,7 +12776,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 12845 "configure"
+#line 12780 "configure"
@@ -12857,7 +12792,7 @@
; return 0; }
EOF
-if { (eval echo configure:12861: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12796: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -12884,11 +12819,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:12888: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:12823: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 12892 "configure"
+#line 12827 "configure"
@@ -12904,14 +12839,14 @@
; return 0; }
EOF
-if { (eval echo configure:12908: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12843: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 12915 "configure"
+#line 12850 "configure"
#define _FILE_OFFSET_BITS 64
@@ -12929,7 +12864,7 @@
; return 0; }
EOF
-if { (eval echo configure:12933: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12868: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -12955,11 +12890,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:12959: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:12894: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 12963 "configure"
+#line 12898 "configure"
@@ -12975,14 +12910,14 @@
; return 0; }
EOF
-if { (eval echo configure:12979: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12914: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 12986 "configure"
+#line 12921 "configure"
#define _LARGE_FILES 1
@@ -13000,7 +12935,7 @@
; return 0; }
EOF
-if { (eval echo configure:13004: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12939: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13026,25 +12961,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13030: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:12965: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13034 "configure"
+#line 12969 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13041: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12976: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13048 "configure"
+#line 12983 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13053,7 +12988,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13057: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12992: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13085,25 +13020,25 @@
ac_save_cflags=${CFLAGS}
CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13089: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13024: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13093 "configure"
+#line 13028 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13100: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13035: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13107 "configure"
+#line 13042 "configure"
#include <stdio.h>
@@ -13112,7 +13047,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13116: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13051: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13142,18 +13077,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13146: checking for fseeko" >&5
+echo "configure:13081: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13150 "configure"
+#line 13085 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13170,10 +13105,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13174: checking if system supports Large Files at all" >&5
+echo "configure:13109: checking if system supports Large Files at all" >&5
-#line 13177 "configure"
+#line 13112 "configure"
#include <stdio.h>
@@ -13205,7 +13140,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13209: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13144: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13233,177 +13168,6 @@
CFLAGS=${ac_save_cflags}
# Done large file support
-# Enable wxWidgets support (for wxGUI)
-echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13240: checking whether to use wxWidgets" >&5
-WXVERSION=
-WXWIDGETSCXXFLAGS=
-WXWIDGETSCPPFLAGS=
-WXWIDGETSLIB=
-USE_WXWIDGETS=
-MACOSX_ARCHS_WXPYTHON=
-if test "$with_wxwidgets" = "no" ; then
- echo "$ac_t""no" 1>&6
-else
- echo "$ac_t""yes" 1>&6
- USE_WXWIDGETS="1"
- if test "$with_wxwidgets" != "yes" ; then
- WX_CONFIG="$with_wxwidgets"
- fi
- # Extract the first word of "wx-config", so it can be a program name with args.
-set dummy wx-config; ac_word=$2
-echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13261: checking for $ac_word" >&5
-case "$WX_CONFIG" in
- ac_cv_path_WX_CONFIG="$WX_CONFIG" # Let the user override the test with a path.
- ac_cv_path_WX_CONFIG="$WX_CONFIG" # Let the user override the test with a dos path.
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
- ac_dummy="$PATH"
- for ac_dir in $ac_dummy; do
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/$ac_word; then
- ac_cv_path_WX_CONFIG="$ac_dir/$ac_word"
- break
- fi
- done
- IFS="$ac_save_ifs"
- test -z "$ac_cv_path_WX_CONFIG" && ac_cv_path_WX_CONFIG="no"
-esac
-WX_CONFIG="$ac_cv_path_WX_CONFIG"
-if test -n "$WX_CONFIG"; then
- echo "$ac_t""$WX_CONFIG" 1>&6
-else
-fi
- if test "$WX_CONFIG" = "no" ; then
- { echo "configure: error: *** couldn't find wx-config
- wxWidgets must be installed on your system.
- Please check that wx-config is in path, the directory
- where wxWidgets libraries are installed (returned by
- 'wx-config --libs' or 'wx-config --static --libs' command)
- is in LD_LIBRARY_PATH or equivalent variable and
- wxWidgets version is 2.8.1 or above." 1>&2; exit 1; }
- fi
- # Check wxWidgets version
- REQWX="2.8.1"
- echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13309: checking wxWidgets version" >&5
- if WXVERSION=`"$WX_CONFIG" --version`; then
- echo "$ac_t""$WXVERSION" 1>&6
- else
- echo "$ac_t""not found" 1>&6
- { echo "configure: error: wxWidgets is required." 1>&2; exit 1; }
- fi
- if test `expr "$WXVERSION" \< "$REQWX"` = 1 ; then
- { echo "configure: error: *** wxWidgets "$REQWX" or later is required." 1>&2; exit 1; }
- fi
- # With wxWidgets includes directory
- WXWIDGETSCXXFLAGS=`"$WX_CONFIG" --cxxflags`
- WXWIDGETSCPPFLAGS=`"$WX_CONFIG" --cppflags`
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$WXWIDGETSCPPFLAGS $CPPFLAGS"
-for ac_hdr in wx/wxprec.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13332: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 13335 "configure"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=yes"
-else
- echo "$ac_err" >&5
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
- ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
- cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
-{ echo "configure: error: *** Unable to locate wxWidgets includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
- # With wxWidgets library directory
- WXWIDGETSLIB=`"$WX_CONFIG" --libs`
- # shouldn't have arch flags in C/LD flags on OSX
- for a in i386 ppc x86_64 ppc64
- do
- WXWIDGETSCXXFLAGS=`echo "$WXWIDGETSCXXFLAGS" | sed "s/-arch *$a//g"`
- WXWIDGETSCPPFLAGS=`echo "$WXWIDGETSCPPFLAGS" | sed "s/-arch *$a//g"`
- WXWIDGETSLIB=`echo "$WXWIDGETSLIB" | sed "s/-arch *$a//g"`
- done
- # check for available OSX archs in wxPython
- if test -n "$MACOSX_ARCHS" ; then
- wxver=`"$WX_CONFIG" --version`
- wxlib=`"$WX_CONFIG" --prefix`/lib/lib`"$WX_CONFIG" --basename`-`echo "$wxver" | cut -d . -f1,2`.dylib
- wxlibinfo=`file "$wxlib"`
- do
- # add only if in MACOSX_ARCHS
- if test -n "`echo \"$wxlibinfo\" | grep \"library $a\"`" ; then
- if test -n "`echo \"$MACOSX_ARCHS\" | grep $a`" ; then
- MACOSX_ARCHS_WXPYTHON="$MACOSX_ARCHS_WXPYTHON -arch $a"
- fi
- fi
- done
- fi
-fi # $USE_WXWIDGETS
-# Done checking wxWidgets
USE_TERMIO=
@@ -13665,13 +13429,6 @@
s%@USE_OPENCL@%$USE_OPENCL%g
s%@USE_LARGEFILES@%$USE_LARGEFILES%g
s%@LFS_CFLAGS@%$LFS_CFLAGS%g
-s%@WX_CONFIG@%$WX_CONFIG%g
-s%@WXVERSION@%$WXVERSION%g
-s%@WXWIDGETSCXXFLAGS@%$WXWIDGETSCXXFLAGS%g
-s%@WXWIDGETSCPPFLAGS@%$WXWIDGETSCPPFLAGS%g
-s%@WXWIDGETSLIB@%$WXWIDGETSLIB%g
-s%@USE_WXWIDGETS@%$USE_WXWIDGETS%g
-s%@MACOSX_ARCHS_WXPYTHON@%$MACOSX_ARCHS_WXPYTHON%g
s%@USE_TERMIO@%$USE_TERMIO%g
s%@STRIPFLAG@%$STRIPFLAG%g
s%@GRASS_HOME@%$GRASS_HOME%g
@@ -14002,8 +13759,6 @@
echo " TIFF support: `if test -n "${USE_TIFF}" ; then echo yes ; else echo no ; fi`"
-echo " wxWidgets support: `if test -n "${USE_WXWIDGETS}" ; then echo yes ; else echo no ; fi`"
echo " X11 support: `if test -n "${USE_X11}" ; then echo yes ; else echo no ; fi`"
echo ""
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2015-10-12 10:31:01 UTC (rev 66476)
+++ grass/trunk/configure.in 2015-10-12 11:10:48 UTC (rev 66477)
@@ -277,12 +277,6 @@
e.g. '--with-liblas=/usr/local/bin/liblas-config',
default: no)],, with_liblas="no")
-AC_ARG_WITH(wxwidgets,
-[ --with-wxwidgets[=path/wx-config]
- enable wxWidgets support (wx-config with path,
- e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
- default: no)],, with_wxwidgets="no")
AC_ARG_WITH(netcdf,
[ --with-netcdf[=path/nc-config]
enable NetCDF support (nc-config with path,
@@ -1768,100 +1762,6 @@
-AC_MSG_CHECKING(whether to use wxWidgets)
-WXVERSION=
-WXWIDGETSCXXFLAGS=
-WXWIDGETSCPPFLAGS=
-WXWIDGETSLIB=
-USE_WXWIDGETS=
- AC_MSG_RESULT(no)
-else
- AC_MSG_RESULT(yes)
- USE_WXWIDGETS="1"
- fi
- AC_PATH_PROG(WX_CONFIG, wx-config, no)
- AC_MSG_ERROR([*** couldn't find wx-config
- wxWidgets version is 2.8.1 or above.])
- fi
- REQWX="2.8.1"
- AC_MSG_CHECKING([wxWidgets version])
- AC_MSG_RESULT([$WXVERSION])
- else
- AC_MSG_RESULT([not found])
- AC_MSG_ERROR([wxWidgets is required.])
- fi
- AC_MSG_ERROR([*** wxWidgets "$REQWX" or later is required.])
- fi
- LOC_CHECK_INCLUDES(wx/wxprec.h,wxWidgets,$WXWIDGETSCPPFLAGS)
- do
- done
- do
- fi
- fi
- done
- fi
-AC_SUBST(WXVERSION)
-AC_SUBST(WXWIDGETSCXXFLAGS)
-AC_SUBST(WXWIDGETSCPPFLAGS)
-AC_SUBST(WXWIDGETSLIB)
-AC_SUBST(USE_WXWIDGETS)
-AC_SUBST(MACOSX_ARCHS_WXPYTHON)
USE_TERMIO=
AC_SUBST(USE_TERMIO)
@@ -1920,6 +1820,5 @@
LOC_MSG_USE(Regex support,USE_REGEX)
LOC_MSG_USE(SQLite support,USE_SQLITE)
LOC_MSG_USE(TIFF support,USE_TIFF)
-LOC_MSG_USE(wxWidgets support,USE_WXWIDGETS)
LOC_MSG_USE(X11 support,USE_X11)
LOC_MSG()
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2015-10-12 10:31:01 UTC (rev 66476)
+++ grass/trunk/include/Make/Platform.make.in 2015-10-12 11:10:48 UTC (rev 66477)
@@ -199,14 +199,6 @@
#Python
PYTHON = python
-#wxWidgets
-WXVERSION = @WXVERSION@
-WXWIDGETSCXXFLAGS = @WXWIDGETSCXXFLAGS@
-WXWIDGETSCPPFLAGS = @WXWIDGETSCPPFLAGS@
-WXWIDGETSLIB = @WXWIDGETSLIB@
-USE_WXWIDGETS = @USE_WXWIDGETS@
-MACOSX_ARCHS_WXPYTHON = @MACOSX_ARCHS_WXPYTHON@
#regex
REGEXINCPATH = @REGEXINCPATH@
REGEXLIBPATH = @REGEXLIBPATH@
