[GRASS-SVN] r66478 - grass/branches/releasebranch_7_0/raster/r.in.gdal
Mon Oct 12 06:06:19 PDT 2015
Author: neteler
Date: 2015-10-12 06:06:19 -0700 (Mon, 12 Oct 2015)
New Revision: 66478
   grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
r.in.gdal: add -j flag to perform projection check only (used by r.import) (r65911, fixes r66466)
Modified: grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
--- grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c	2015-10-12 11:10:48 UTC (rev 66477)
+++ grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c	2015-10-12 13:06:19 UTC (rev 66478)
@@ -75,7 +75,8 @@
 	struct Option *input, *output, *target, *title, *outloc, *band,
 	              *memory, *offset, *rat;
     } parm;
-    struct Flag *flag_o, *flag_e, *flag_k, *flag_f, *flag_l, *flag_c, *flag_p;
+    struct Flag *flag_o, *flag_e, *flag_k, *flag_f, *flag_l, *flag_c, *flag_p,
+        *flag_j;
     /*      Initialize.                                                     */
@@ -157,6 +158,13 @@
     flag_o->description =
 	_("Override projection (use location's projection)");
+    flag_j = G_define_flag();
+    flag_j->key = 'j';
+    flag_j->description =
+	_("Perform projection check only and exit");
+    flag_j->suppress_required = YES;
+    G_option_requires(flag_j, parm.input, NULL);
     flag_e = G_define_flag();
     flag_e->key = 'e';
     flag_e->label = _("Extend region extents based on new dataset");
@@ -189,7 +197,6 @@
     flag_p->key = 'p';
     flag_p->description = _("Print number of bands and exit");
     flag_p->suppress_required = YES;
     G_option_requires(flag_p, parm.input, NULL);
     /* The parser checks if the map already exists in current mapset, this is
@@ -297,7 +304,7 @@
         exit(EXIT_SUCCESS);
-    if (!parm.outloc->answer &&
+    if (output && !parm.outloc->answer &&
         GDALGetRasterCount(hDS) == 1) {	/* Check if the map exists */
 	if (G_find_raster2(output, G_mapset())) {
 	    if (overwrite)
@@ -409,6 +416,8 @@
 	    G_warning(_("Unable to convert input raster map projection information to "
 		       "GRASS format for checking"));
 	else {
+            void (*msg_fn)(const char *, ...);
 	    /*      Does the projection of the current location match the           */
 	    /*      dataset?                                                        */
@@ -508,11 +517,24 @@
 		strcat(error_msg,
 		       _("Consider generating a new location from the input dataset using "
 			"the 'location' parameter.\n"));
-		G_fatal_error(error_msg);
+                if (flag_j->answer)
+                    msg_fn = G_message;
+                else
+                    msg_fn = G_fatal_error;
+                msg_fn(error_msg);
+                    exit(EXIT_FAILURE);
 	    else {
-		G_verbose_message(_("Projection of input dataset and current location "
-                                    "appear to match"));
+                else
+                    msg_fn = G_verbose_message;
+                msg_fn(_("Projection of input dataset and current location "
+                            "appear to match"));
+                    exit(EXIT_SUCCESS);
@@ -817,8 +839,6 @@
 	G_message(_("Region for the current mapset updated"));
-    G_done_msg(" ");
     exit(EXIT_SUCCESS);
