[GRASS-SVN] r66489 - in grass/trunk/gui/wxpython: core datacatalog gui_core
svn_grass at osgeo.org
Tue Oct 13 20:34:34 PDT 2015
Author: annakrat
Date: 2015-10-13 20:34:34 -0700 (Tue, 13 Oct 2015)
New Revision: 66489
grass/trunk/gui/wxpython/core/treemodel.py
grass/trunk/gui/wxpython/datacatalog/catalog.py
grass/trunk/gui/wxpython/datacatalog/frame.py
grass/trunk/gui/wxpython/datacatalog/tree.py
grass/trunk/gui/wxpython/gui_core/treeview.py
wxGUI/catalog: major refactoring
Modified: grass/trunk/gui/wxpython/core/treemodel.py
--- grass/trunk/gui/wxpython/core/treemodel.py 2015-10-13 10:04:04 UTC (rev 66488)
+++ grass/trunk/gui/wxpython/core/treemodel.py 2015-10-14 03:34:34 UTC (rev 66489)
@@ -78,10 +78,11 @@
node.parent = parent
return node
- def SearchNodes(self, **kwargs):
+ def SearchNodes(self, parent=None, **kwargs):
"""Search nodes according to specified attributes."""
nodes = []
- self._searchNodes(node=self.root, foundNodes=nodes, **kwargs)
+ parent = parent if parent else self.root
+ self._searchNodes(node=parent, foundNodes=nodes, **kwargs)
return nodes
def _searchNodes(self, node, foundNodes, **kwargs):
@@ -132,6 +133,11 @@
if node.parent:
node.parent.children.remove(node)
+ def SortChildren(self, node):
+ """Sorts children alphabetically based on label."""
+ if node.children:
+ node.children.sort(key=lambda node: node.label)
def __str__(self):
"""Print tree."""
text = []
Modified: grass/trunk/gui/wxpython/datacatalog/catalog.py
--- grass/trunk/gui/wxpython/datacatalog/catalog.py 2015-10-13 10:04:04 UTC (rev 66488)
+++ grass/trunk/gui/wxpython/datacatalog/catalog.py 2015-10-14 03:34:34 UTC (rev 66489)
@@ -44,7 +44,7 @@
# some layout
self._layout()
def _layout(self):
"""Do layout"""
sizer = wx.BoxSizer(wx.VERTICAL)
Modified: grass/trunk/gui/wxpython/datacatalog/frame.py
--- grass/trunk/gui/wxpython/datacatalog/frame.py 2015-10-13 10:04:04 UTC (rev 66488)
+++ grass/trunk/gui/wxpython/datacatalog/frame.py 2015-10-14 03:34:34 UTC (rev 66489)
@@ -4,7 +4,6 @@
@brief Data catalog frame class
Classes:
- - datacatalog::DataCatalogTree
- datacatalog::DataCatalogFrame
(C) 2014-2015 by Tereza Fiedlerova, and the GRASS Development Team
@@ -18,11 +17,10 @@
import wx
-from grass.script import core as gcore
from core.utils import _
from datacatalog.tree import DataCatalogTree
class DataCatalogFrame(wx.Frame):
"""Frame for testing purposes only."""
def __init__(self, parent, giface=None):
@@ -35,38 +33,39 @@
# tree
self.tree = DataCatalogTree(parent=self.panel, giface=self._giface)
self.tree.InitTreeItems()
+ self.tree.ExpandCurrentLocation()
# buttons
self.btnClose = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
self.btnClose.SetToolTipString(_("Close GRASS GIS Data Catalog"))
self.btnClose.SetDefault()
# events
self.btnClose.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
self._layout()
def _layout(self):
sizer.Add(self.tree, proportion=1, flag=wx.EXPAND)
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+ btnSizer.AddStretchSpacer()
btnSizer.Add(self.btnClose)
- sizer.Add(item = btnSizer, proportion = 0,
- flag = wx.ALL | wx.ALIGN_RIGHT,
- border = 5)
- self.panel.SetSizerAndFit(sizer)
- sizer.SetSizeHints(self.panel)
+ sizer.Add(item=btnSizer, proportion=0,
+ flag=wx.ALL | wx.ALIGN_RIGHT | wx.EXPAND,
+ border=5)
+ self.panel.SetSizer(sizer)
+ sizer.Fit(self.panel)
self.SetMinSize((400, 500))
def OnCloseWindow(self, event):
"""Cancel button pressed"""
if not isinstance(event, wx.CloseEvent):
self.Destroy()
event.Skip()
Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
--- grass/trunk/gui/wxpython/datacatalog/tree.py 2015-10-13 10:04:04 UTC (rev 66488)
+++ grass/trunk/gui/wxpython/datacatalog/tree.py 2015-10-14 03:34:34 UTC (rev 66489)
@@ -7,101 +7,186 @@
- datacatalog::LocationMapTree
- at todo:
- - use gui_core/treeview.py
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@author Tereza Fiedlerova
+ at author Anna Petrasova (kratochanna gmail com)
+import os
+from multiprocessing import Process, Queue, cpu_count
import wx
-from core.gcmd import RunCommand, GError, GMessage
-from core.utils import GetListOfLocations, ListOfMapsets
+from core.gcmd import RunCommand, GError, GMessage, GWarning
+from core.utils import GetListOfLocations
from core.debug import Debug
from gui_core.dialogs import TextEntryDialog
from core.giface import StandaloneGrassInterface
+from core.treemodel import TreeModel, DictNode
+from gui_core.treeview import TreeView
from grass.pydispatch.signal import Signal
-import grass.script as grass
+import grass.script as gscript
+from grass.exceptions import CalledModuleError
-class LocationMapTree(wx.TreeCtrl):
- def __init__(self, parent, style=wx.TR_HIDE_ROOT | wx.TR_EDIT_LABELS | wx.TR_LINES_AT_ROOT |
+def getEnvironment(gisdbase, location, mapset):
+ """Creates environment to be passed in run_command for example.
+ Returns tuple with temporary file path and the environment. The user
+ of this function is responsile for deleting the file."""
+ tmp_gisrc_file = gscript.tempfile()
+ with open(tmp_gisrc_file, 'w') as f:
+ f.write('MAPSET: {mapset}\n'.format(mapset=mapset))
+ f.write('GISDBASE: {g}\n'.format(g=gisdbase))
+ f.write('LOCATION_NAME: {l}\n'.format(l=location))
+ f.write('GUI: text\n')
+ env = os.environ.copy()
+ env['GISRC'] = tmp_gisrc_file
+ return tmp_gisrc_file, env
+def getLocationTree(gisdbase, location, queue):
+ """Creates dictionary with mapsets, elements, layers for given location.
+ Returns tuple with the dictionary and error (or None)"""
+ tmp_gisrc_file, env = getEnvironment(gisdbase, location, 'PERMANENT')
+ env['GRASS_SKIP_MAPSET_OWNER_CHECK'] = '1'
+ maps_dict = {}
+ elements = ['raster', 'raster_3d', 'vector']
+ try:
+ mapsets = gscript.read_command('g.mapsets', flags='l', quiet=True, env=env).strip()
+ except CalledModuleError:
+ queue.put((maps_dict, _("Failed to read mapsets from location {l}.").format(l=location)))
+ gscript.try_remove(tmp_gisrc_file)
+ return
+ else:
+ listOfMapsets = mapsets.split()
+ for each in listOfMapsets:
+ maps_dict[each] = {}
+ for elem in elements:
+ maps_dict[each][elem] = []
+ try:
+ maplist = gscript.read_command('g.list', flags='mt', type=elements,
+ mapset=','.join(listOfMapsets), quiet=True, env=env).strip()
+ queue.put((maps_dict, _("Failed to read maps from location {l}.").format(l=location)))
+ return
+ else:
+ # fill dictionary
+ for each in maplist.splitlines():
+ ltype, wholename = each.split('/')
+ name, mapset = wholename.split('@')
+ maps_dict[mapset][ltype].append(name)
+ queue.put((maps_dict, None))
+class DataCatalogNode(DictNode):
+ """Node representing item in datacatalog."""
+ def __init__(self, label, data=None):
+ super(DataCatalogNode, self).__init__(label=label, data=data)
+ def match(self, **kwargs):
+ """Method used for searching according to given parameters.
+ :param value: dictionary value to be matched
+ :param key: data dictionary key
+ if not kwargs:
+ return False
+ for key in kwargs:
+ if not (key in self.data and self.data[key] == kwargs[key]):
+ return False
+ return True
+class LocationMapTree(TreeView):
+ def __init__(self, parent, model=None, style=wx.TR_HIDE_ROOT | wx.TR_EDIT_LABELS | wx.TR_LINES_AT_ROOT |
wx.TR_HAS_BUTTONS | wx.TR_FULL_ROW_HIGHLIGHT | wx.TR_SINGLE):
"""Location Map Tree constructor."""
- super(LocationMapTree, self).__init__(parent, id=wx.ID_ANY, style=style)
+ self._model = TreeModel(DataCatalogNode)
+ super(LocationMapTree, self).__init__(parent=parent, model=self._model, id=wx.ID_ANY, style=style)
self.showNotification = Signal('Tree.showNotification')
self.parent = parent
- self.root = self.AddRoot('Catalog') # will not be displayed when we use TR_HIDE_ROOT flag
+ self.contextMenu.connect(self.OnRightClick)
self._initVariables()
- self.MakeBackup()
- wx.EVT_TREE_ITEM_RIGHT_CLICK(self, wx.ID_ANY, self.OnRightClick)
- self.Bind(wx.EVT_LEFT_DCLICK, self.OnDoubleClick)
- self.Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
- self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
- def _initTreeItems(self, locations = [], mapsets = []):
- """Add locations, mapsets and layers to the tree."""
+ def _initTreeItems(self, locations=None, mapsets=None):
+ """Add locations, mapsets and layers to the tree.
+ Runs in multiple processes. Saves resulting data and error."""
+ # mapsets param currently unused
if not locations:
locations = GetListOfLocations(self.gisdbase)
- if not mapsets:
- mapsets = ['*']
- first = True
- for loc in locations:
- location = loc
- if first:
- self.ChangeEnvironment(location, 'PERMANENT')
- first = False
- else:
- self.ChangeEnvironment(location)
- varloc = self.AppendItem(self.root, loc)
- # add all mapsets
- mapsets = ListOfMapsets()
- if mapsets:
- for mapset in mapsets:
- self.AppendItem(varloc, mapset)
- else:
- self.AppendItem(varloc, _("No mapsets readable"))
- continue
- # get list of all maps in location
- maplist = RunCommand('g.list', flags='mt', type='raster,raster_3d,vector', mapset=','.join(mapsets),
- quiet=True, read=True)
- maplist = maplist.splitlines()
- for ml in maplist:
- # parse
- parts1 = ml.split('/')
- parts2 = parts1[1].split('@')
- mapset = parts2[1]
- mlayer = parts2[0]
- ltype = parts1[0]
+ loc_count = proc_count = 0
+ queue_list = []
+ proc_list = []
+ loc_list = []
+ nprocs = 4
+ try:
+ nprocs = cpu_count()
+ except NotImplementedError:
+ nprocs = 4
+ results = dict()
+ errors = []
+ location_nodes = []
+ for location in locations:
+ results[location] = dict()
+ varloc = self._model.AppendNode(parent=self._model.root, label=location,
+ data=dict(type='location', name=location))
+ location_nodes.append(varloc)
+ loc_count += 1
- # add mapset
- if self.itemExists(mapset, varloc) == False:
- varmapset = self.AppendItem(varloc, mapset)
- else:
- varmapset = self.getItemByName(mapset, varloc)
+ q = Queue()
+ p = Process(target=getLocationTree,
+ args=(self.gisdbase, location, q))
+ p.start()
- # add type node if not exists
- if self.itemExists(ltype, varmapset) == False:
- vartype = self.AppendItem(varmapset, ltype)
- self.AppendItem(vartype, mlayer)
- self.RestoreBackup()
- Debug.msg(1, "Tree filled")
+ queue_list.append(q)
+ proc_list.append(p)
+ loc_list.append(location)
+ proc_count += 1
+ # Wait for all running processes
+ if proc_count == nprocs or loc_count == len(locations):
+ for i in range(len(loc_list)):
+ proc_list[i].join()
+ maps, error = queue_list[i].get()
+ if error:
+ errors.append(error)
+ for key in sorted(maps.keys()):
+ mapset_node = self._model.AppendNode(parent=location_nodes[i], label=key,
+ data=dict(type='mapset', name=key))
+ for elem in maps[key]:
+ if maps[key][elem]:
+ element_node = self._model.AppendNode(parent=mapset_node, label=elem,
+ data=dict(type='element', name=elem))
+ for layer in maps[key][elem]:
+ self._model.AppendNode(parent=element_node, label=layer,
+ data=dict(type=elem, name=layer))
+ proc_count = 0
+ proc_list = []
+ queue_list = []
+ loc_list = []
+ if errors:
+ GWarning('\n'.join(errors))
+ Debug.msg(1, "Tree filled")
+ self.RefreshItems()
def InitTreeItems(self):
"""Create popup menu for layers"""
raise NotImplementedError()
@@ -120,136 +205,87 @@
self.selected_type = None
self.selected_mapset = None
self.selected_location = None
- self.gisdbase = grass.gisenv()['GISDBASE']
- self.ctrldown = False
+ gisenv = gscript.gisenv()
+ self.gisdbase = gisenv['GISDBASE']
+ self.glocation = gisenv['LOCATION_NAME']
+ self.gmapset = gisenv['MAPSET']
def GetControl(self):
"""Returns control itself."""
return self
- def DefineItems(self, item0):
+ def DefineItems(self, item):
"""Set selected items."""
self.selected_layer = None
- items = []
- item = item0
- while (self.GetItemParent(item)):
- items.insert(0,item)
- item = self.GetItemParent(item)
- self.selected_location = items[0]
- length = len(items)
- if (length > 1):
- self.selected_mapset = items[1]
- if (length > 2):
- self.selected_type = items[2]
- if (length > 3):
- self.selected_layer = items[3]
- def getItemByName(self, match, root):
- """Return match item from the root."""
- item, cookie = self.GetFirstChild(root)
- while item.IsOk():
- if self.GetItemText(item) == match:
- return item
- item, cookie = self.GetNextChild(root, cookie)
- return None
- def itemExists(self, match, root):
- """Return true if match item exists in the root item."""
- return True
- return False
- def UpdateTree(self):
- """Update whole tree."""
- self.DeleteAllItems()
- self.root = self.AddRoot('Tree')
- self.AddTreeItems()
- label = "Tree updated."
- self.showNotification.emit(message=label)
+ type = item.data['type']
+ if type in ('raster', 'raster_3d', 'vector'):
+ self.selected_layer = item
+ type = 'element'
+ item = item.parent
+ if type == 'element':
+ self.selected_type = item
+ type = 'mapset'
+ if type == 'mapset':
+ self.selected_mapset = item
+ type = 'location'
+ if type == 'location':
+ self.selected_location = item
def OnSelChanged(self, event):
- def OnRightClick(self, event):
+ def OnRightClick(self, node):
"""Display popup menu."""
- self.DefineItems(event.GetItem())
- if(self.selected_layer):
+ self.DefineItems(node)
+ if self.selected_layer:
self._popupMenuLayer()
- elif(self.selected_mapset and self.selected_type==None):
- self._popupMenuMapset()
- def OnDoubleClick(self, event):
- """Double click"""
- Debug.msg(1, "Double CLICK")
- def OnKeyDown(self, event):
- """Set key event and check if control key is down"""
- keycode = event.GetKeyCode()
- if keycode == wx.WXK_CONTROL:
- self.ctrldown = True
- Debug.msg(1,"CONTROL ON")
+ elif self.selected_mapset and not self.selected_type:
+ self._popupMenuMapset()
- def OnKeyUp(self, event):
- """Check if control key is up"""
- Debug.msg(1,"CONTROL OFF")
- def MakeBackup(self):
- """Make backup for case of change"""
- gisenv = grass.gisenv()
- self.glocation = gisenv['LOCATION_NAME']
- self.gmapset = gisenv['MAPSET']
- def RestoreBackup(self):
- """Restore backup"""
- stringl = 'LOCATION_NAME='+self.glocation
- RunCommand('g.gisenv', set=stringl)
- stringm = 'MAPSET='+self.gmapset
- RunCommand('g.gisenv', set=stringm)
- def ChangeEnvironment(self, location, mapset=None):
- """Change gisenv variables -> location, mapset"""
- stringl = 'LOCATION_NAME='+location
- if mapset:
- stringm = 'MAPSET='+mapset
def ExpandCurrentLocation(self):
"""Expand current location"""
- location = grass.gisenv()['LOCATION_NAME']
- item = self.getItemByName(location, self.root)
- if item is not None:
- self.SelectItem(item)
- self.ExpandAllChildren(item)
- self.EnsureVisible(item)
+ location = gscript.gisenv()['LOCATION_NAME']
+ item = self._model.SearchNodes(name=location, type='location')
+ if item:
+ self.Select(item[0], select=True)
+ self.ExpandNode(item[0], recursive=True)
else:
Debug.msg(1, "Location <%s> not found" % location)
class DataCatalogTree(LocationMapTree):
"""Data Catalog Tree constructor."""
super(DataCatalogTree, self).__init__(parent)
self._giface = giface
self._initVariablesCatalog()
+ self.beginDrag = Signal('DataCatalogTree.beginDrag')
+ self.endDrag = Signal('DataCatalogTree.endDrag')
+ self.startEdit = Signal('DataCatalogTree.startEdit')
+ self.endEdit = Signal('DataCatalogTree.endEdit')
- wx.EVT_TREE_BEGIN_DRAG(self, wx.ID_ANY, self.OnBeginDrag)
- wx.EVT_TREE_END_DRAG(self, wx.ID_ANY, self.OnEndDrag)
- wx.EVT_TREE_END_LABEL_EDIT(self, wx.ID_ANY, self.OnEditLabel)
- wx.EVT_TREE_BEGIN_LABEL_EDIT(self, wx.ID_ANY, self.OnStartEditLabel)
+ self.Bind(wx.EVT_TREE_BEGIN_DRAG, lambda evt:
+ self._emitSignal(evt.GetItem(), self.beginDrag, event=evt))
+ self.Bind(wx.EVT_TREE_END_DRAG, lambda evt:
+ self._emitSignal(evt.GetItem(), self.endDrag, event=evt))
+ self.beginDrag.connect(self.OnBeginDrag)
+ self.endDrag.connect(self.OnEndDrag)
+ self.Bind(wx.EVT_TREE_BEGIN_LABEL_EDIT, lambda evt:
+ self._emitSignal(evt.GetItem(), self.startEdit, event=evt))
+ self.Bind(wx.EVT_TREE_END_LABEL_EDIT, lambda evt:
+ self._emitSignal(evt.GetItem(), self.endEdit, event=evt))
+ self.startEdit.connect(self.OnStartEditLabel)
+ self.endEdit.connect(self.OnEditLabel)
def _initVariablesCatalog(self):
"""Init variables."""
self.copy_layer = None
@@ -260,195 +296,194 @@
self._initTreeItems()
- def OnCopy(self, event):
+ def OnCopy(self, event):
"""Copy layer or mapset (just save it temporarily, copying is done by paste)"""
self.copy_layer = self.selected_layer
self.copy_type = self.selected_type
self.copy_mapset = self.selected_mapset
- self.copy_location = self.selected_location
- label = "Layer "+self.GetItemText(self.copy_layer)+" copied to clipboard. You can paste it to selected mapset."
+ self.copy_location = self.selected_location
+ label = _("Layer {layer} copied to clipboard."
+ "You can paste it to selected mapset.".format(layer=self.copy_layer.label))
- def OnRename(self, event):
+ def OnRename(self, event):
"""Rename levent with dialog"""
- if (self.selected_layer):
- self.old_name = self.GetItemText(self.selected_layer)
+ self.old_name = self.selected_layer.label
self.new_name = self._getUserEntry(_('New name'), _('Rename map'), self.old_name)
- self.rename()
- def OnStartEditLabel(self, event):
+ self.Rename()
+ def OnStartEditLabel(self, node, event):
"""Start label editing"""
- item = event.GetItem()
- self.DefineItems(item)
- Debug.msg(1, "Start label edit "+self.GetItemText(item))
- label = _("Editing") + " " + self.GetItemText(item)
+ Debug.msg(1, "Start label edit {name}".format(name=node.label))
+ label = _("Editing {name}").format(name=node.label)
- if (self.selected_layer == None):
+ if not self.selected_layer:
event.Veto()
- def OnEditLabel(self, event):
+ def OnEditLabel(self, node, event):
"""End label editing"""
- self.old_name = self.GetItemText(item)
- Debug.msg(1, "End label edit "+self.old_name)
- wx.CallAfter(self.afterEdit, self, item)
- def afterEdit(pro, self, item):
- self.new_name = self.GetItemText(item)
- self.rename()
- def rename(self):
+ if self.selected_layer and not event.IsEditCancelled():
+ self.old_name = node.label
+ Debug.msg(1, "End label edit {name}".format(name=self.old_name))
+ self.new_name = event.GetLabel()
+ self.Rename()
+ def Rename(self):
"""Rename layer"""
if self.selected_layer and self.new_name:
- string = self.old_name+','+self.new_name
- self.ChangeEnvironment(self.GetItemText(self.selected_location), self.GetItemText(self.selected_mapset))
+ string = self.old_name + ',' + self.new_name
+ gisrc, env = getEnvironment(self.gisdbase, self.selected_location.label, self.selected_mapset.label)
renamed = 0
- label = _("Renaming") + " " + string + " ..."
+ label = _("Renaming {name}...").format(name=string)
- if (self.GetItemText(self.selected_type)=='vector'):
- renamed = RunCommand('g.rename', vector=string)
- elif (self.GetItemText(self.selected_type)=='raster'):
- renamed = RunCommand('g.rename', raster=string)
+ if self.selected_type.label == 'vector':
+ renamed = RunCommand('g.rename', vector=string, env=env)
+ elif self.selected_type.label == 'raster':
+ renamed = RunCommand('g.rename', raster=string, env=env)
else:
- renamed = RunCommand('g.rename', raster3d=string)
- if (renamed==0):
- self.SetItemText(self.selected_layer,self.new_name)
- label = "g.rename "+self.GetItemText(self.selected_type)+"="+string+" -- completed"
+ renamed = RunCommand('g.rename', raster3d=string, env=env)
+ if renamed == 0:
+ self.selected_layer.label = self.new_name
+ self.selected_layer.data['name'] = self.new_name
+ self.RefreshNode(self.selected_layer)
+ label = "g.rename " + self.selected_type.label + "=" + string + " -- completed"
- Debug.msg(1,"LAYER RENAMED TO: "+self.new_name)
+ Debug.msg(1, "LAYER RENAMED TO: " + self.new_name)
+ gscript.try_remove(gisrc)
def OnPaste(self, event):
- """Paste layer or mapset"""
+ """Paste layer or mapset"""
# copying between mapsets of one location
- if (self.copy_layer == None):
- return
- if (self.selected_location == self.copy_location and self.selected_mapset):
- if (self.selected_type != None):
- if (self.GetItemText(self.copy_type) != self.GetItemText(self.selected_type)): # copy raster to vector or vice versa
- GError(_("Failed to copy layer: invalid type."), parent = self)
+ if not self.copy_layer:
+ return
+ if self.selected_location == self.copy_location and self.selected_mapset:
+ if self.selected_type:
+ if self.copy_type.label != self.selected_type.label: # copy raster to vector or vice versa
+ GError(_("Failed to copy layer: invalid type."), parent=self)
return
self.new_name = self._getUserEntry(_('New name'), _('Copy map'),
- self.GetItemText(self.copy_layer) + '_copy')
+ self.copy_layer.label + '_copy')
if not self.new_name:
return
- if (self.GetItemText(self.copy_layer) == self.new_name):
- GMessage(_("Layer was not copied: new layer has the same name"), parent=self)
+ if self.copy_layer.label == self.new_name:
+ GMessage(_("Layer was not copied: new layer has the same name"), parent=self)
return
- string = self.GetItemText(self.copy_layer)+'@'+self.GetItemText(self.copy_mapset)+','+self.new_name
+ string = self.copy_layer.label + '@' + self.copy_mapset.label + ',' + self.new_name
pasted = 0
- type = None
- label = _("Copying") + " " + string + " ..."
+ label = _("Copying {name}...").format(name=string)
- if (self.GetItemText(self.copy_type)=='vector'):
- pasted = RunCommand('g.copy', vector=string)
- node = 'vector'
- elif (self.GetItemText(self.copy_type)=='raster'):
- pasted = RunCommand('g.copy', raster=string)
+ if self.copy_type.label == 'vector':
+ pasted = RunCommand('g.copy', vector=string, env=env)
+ node = 'vector'
+ elif self.copy_type.label == 'raster':
+ pasted = RunCommand('g.copy', raster=string, env=env)
node = 'raster'
else:
- pasted = RunCommand('g.copy', raster_3d=string)
+ pasted = RunCommand('g.copy', raster_3d=string, env=env)
node = 'raster_3d'
if pasted == 0:
- if self.selected_type == None:
- self.selected_type = self.getItemByName(node, self.selected_mapset)
+ if not self.selected_type:
+ found = self._model.SearchNodes(parent=self.selected_mapset, type=node)
+ self.selected_type = found[0] if found else None
- self.selected_type = self.AppendItem(self.selected_mapset, node)
- self.AppendItem(self.selected_type,self.new_name)
- self.SortChildren(self.selected_type)
- Debug.msg(1,"COPIED TO: "+self.new_name)
- label = "g.copy "+self.GetItemText(self.copy_type)+"="+string+" -- completed" # generate this message (command) automatically?
+ self.selected_type = self._model.AppendNode(parent=self.selected_mapset, label=node,
+ data=dict(type='element', name=node))
+ self._model.AppendNode(parent=self.selected_type, label=self.new_name,
+ data=dict(type=node, name=self.new_name))
+ self._model.SortChildren(self.selected_type)
+ self.RefreshNode(self.selected_type, recursive=True)
+ Debug.msg(1, "COPIED TO: " + self.new_name)
+ label = "g.copy " + self.copy_type.label + "=" + string + " -- completed" # generate this message (command) automatically?
else:
GError(_("Failed to copy layer: action is allowed only within the same location."),
parent=self)
# expand selected mapset
- self.ExpandAllChildren(self.selected_mapset)
- self.EnsureVisible(self.selected_mapset)
+ self.ExpandNode(self.selected_mapset, recursive=True)
def OnDelete(self, event):
"""Delete layer or mapset"""
- string = self.GetItemText(self.selected_layer)
+ string = self.selected_layer.label
removed = 0
# TODO: rewrite this that it will tell map type in the dialog
- if (self._confirmDialog(question=_('Do you really want to delete map <{m}>?').format(m=string),
- title=_('Delete map')) == wx.ID_YES):
- label = _("Deleting") + " " + string + " ..."
+ if self._confirmDialog(question=_('Do you really want to delete map <{m}>?').format(m=string),
+ title=_('Delete map')) == wx.ID_YES:
+ label = _("Deleting {name}...").format(name=string)
removed = RunCommand('g.remove', flags='f', type='vector',
- name=string)
+ name=string, env=env)
removed = RunCommand('g.remove', flags='f', type='raster',
- name=string)
else:
removed = RunCommand('g.remove', flags='f', type='raster_3d',
- name=string)
- if (removed==0):
- self.Delete(self.selected_layer)
- Debug.msg(1,"LAYER "+string+" DELETED")
- label = "g.remove -f type="+self.GetItemText(self.selected_type)+" name="+string+" -- completed" # generate this message (command) automatically?
+ if removed == 0:
+ self._model.RemoveNode(self.selected_layer)
+ Debug.msg(1, "LAYER " + string + " DELETED")
+ label = "g.remove -f type=" + self.selected_type.label + " name=" + string + " -- completed" # generate this message (command) automatically?
def OnDisplayLayer(self, event):
"""Display layer in current graphics view"""
layerName = []
- if (self.GetItemText(self.selected_location) == self.glocation and self.selected_mapset):
- string = self.GetItemText(self.selected_layer)+'@'+self.GetItemText(self.selected_mapset)
+ if self.selected_location.label == self.glocation and self.selected_mapset:
+ string = self.selected_layer.label + '@' + self.selected_mapset.label
layerName.append(string)
- label = _("Displaying") + " " + string + " ..."
+ label = _("Displaying {name}...").format(name=string)
- label = "d."+self.GetItemText(self.selected_type)+" --q map="+string+" -- completed. Go to Map layers for further operations."
+ label = "d." + self.selected_type.label + " --q map=" + string + \
+ " -- completed. Go to Map layers for further operations."
self._giface.lmgr.AddMaps(layerName, 'vector', True)
- self._giface.lmgr.AddMaps(layerName, 'raster', True)
+ self._giface.lmgr.AddMaps(layerName, 'raster', True)
else:
self._giface.lmgr.AddMaps(layerName, 'raster_3d', True)
- label = "d.rast --q map="+string+" -- completed. Go to 'Map layers' for further operations." # generate this message (command) automatically?
+ label = "d.rast --q map=" + string + " -- completed. Go to 'Map layers' for further operations." # generate this message (command) automatically?
- Debug.msg(1,"LAYER "+self.GetItemText(self.selected_layer)+" DISPLAYED")
+ Debug.msg(1, "LAYER " + self.selected_layer.label + " DISPLAYED")
else:
GError(_("Failed to display layer: not in current mapset or invalid layer"),
- parent = self)
+ parent=self)
- def OnBeginDrag(self, event):
+ def OnBeginDrag(self, node, event):
"""Just copy necessary data"""
- if (self.ctrldown):
+ if wx.GetMouseState().ControlDown():
#cursor = wx.StockCursor(wx.CURSOR_HAND)
#self.SetCursor(cursor)
event.Allow()
self.OnCopy(event)
- Debug.msg(1,"DRAG")
+ Debug.msg(1, "DRAG")
else:
event.Veto()
- Debug.msg(1,"DRAGGING without ctrl key does nothing")
- def OnEndDrag(self, event):
+ Debug.msg(1, "DRAGGING without ctrl key does nothing")
+ def OnEndDrag(self, node, event):
"""Copy layer into target"""
#cursor = wx.StockCursor(wx.CURSOR_ARROW)
- if (event.GetItem()):
+ if node:
event.Allow()
self.OnPaste(event)
#cursor = wx.StockCursor(wx.CURSOR_DEFAULT)
#self.SetCursor(cursor) # TODO: change cursor while dragging and then back, this is not working
- Debug.msg(1,"DROP DONE")
+ Debug.msg(1, "DROP DONE")
else:
event.Veto()
@@ -474,7 +509,7 @@
def _popupMenuLayer(self):
menu = wx.Menu()
item = wx.MenuItem(menu, wx.NewId(), _("&Copy"))
menu.AppendItem(item)
self.Bind(wx.EVT_MENU, self.OnCopy, item)
@@ -482,11 +517,11 @@
item = wx.MenuItem(menu, wx.NewId(), _("&Paste"))
self.Bind(wx.EVT_MENU, self.OnPaste, item)
item = wx.MenuItem(menu, wx.NewId(), _("&Delete"))
self.Bind(wx.EVT_MENU, self.OnDelete, item)
item = wx.MenuItem(menu, wx.NewId(), _("&Rename"))
self.Bind(wx.EVT_MENU, self.OnRename, item)
@@ -495,10 +530,10 @@
item = wx.MenuItem(menu, wx.NewId(), _("&Display layer"))
self.Bind(wx.EVT_MENU, self.OnDisplayLayer, item)
self.PopupMenu(menu)
menu.Destroy()
def _popupMenuMapset(self):
"""Create popup menu for mapsets"""
menu = wx.Menu()
@@ -506,6 +541,6 @@
menu.Destroy()
Modified: grass/trunk/gui/wxpython/gui_core/treeview.py
--- grass/trunk/gui/wxpython/gui_core/treeview.py 2015-10-13 10:04:04 UTC (rev 66488)
+++ grass/trunk/gui/wxpython/gui_core/treeview.py 2015-10-14 03:34:34 UTC (rev 66489)
@@ -107,7 +107,41 @@
item = self.GetItemByIndex(index)
self.SelectItem(item, select)
- def _emitSignal(self, item, signal):
+ def ExpandNode(self, node, recursive=True):
+ """Expand items.
+ :param node: node representing item
+ :param recursive: True/False to expand all children
+ index = self._model.GetIndexOfNode(node)
+ item = self.GetItemByIndex(index)
+ if recursive:
+ self.ExpandAllChildren(item)
+ else:
+ self.Expand(item)
+ self.EnsureVisible(item)
+ def CollapseNode(self, node, recursive=True):
+ """Collapse items.
+ :param recursive: True/False to collapse all children
+ if recursive:
+ self.CollapseAllChildren(item)
+ else:
+ self.Collapse(item)
+ def RefreshNode(self, node, recursive=False):
+ """Refreshes node."""
+ self.RefreshItem(index)
+ if recursive:
+ self.RefreshChildrenRecursively(self.GetItemByIndex(index))
+ def _emitSignal(self, item, signal, **kwargs):
"""Helper method for emitting signals.
:param item: tree item
@@ -117,7 +151,7 @@
return
index = self.GetIndexOfItem(item)
node = self._model.GetNodeByIndex(index)
- signal.emit(node = node)
+ signal.emit(node=node, **kwargs)
class TreeView(AbstractTreeViewMixin, wx.TreeCtrl):
