[GRASS-SVN] r66490 - grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata
svn_grass at osgeo.org
Tue Oct 13 20:38:15 PDT 2015
Author: annakrat
Date: 2015-10-13 20:38:15 -0700 (Tue, 13 Oct 2015)
New Revision: 66490
grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py
wx.metadata: temporarily copy LocationMapTree which changed in trunk, needs to be rewritten using new LocationMapTree in trunk
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py 2015-10-14 03:34:34 UTC (rev 66489)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py 2015-10-14 03:38:15 UTC (rev 66490)
@@ -28,7 +28,10 @@
from grass.pydispatch import dispatcher
from core.gcmd import RunCommand, GError, GMessage
import grass.temporal as tgis
-from datacatalog.tree import LocationMapTree
+#from datacatalog.tree import LocationMapTree
+from grass.pydispatch.signal import Signal
+from core.utils import GetListOfLocations, ListOfMapsets
+from core.debug import Debug
set_path(modulename='wx.metadata', dirname='mdlib')
@@ -53,9 +56,212 @@
MAINFRAME = None
+class LocationMapTree(wx.TreeCtrl):
+ def __init__(self, parent, style=wx.TR_HIDE_ROOT | wx.TR_EDIT_LABELS | wx.TR_LINES_AT_ROOT |
+ wx.TR_HAS_BUTTONS | wx.TR_FULL_ROW_HIGHLIGHT | wx.TR_SINGLE):
+ """Location Map Tree constructor."""
+ super(LocationMapTree, self).__init__(parent, id=wx.ID_ANY, style=style)
+ self.showNotification = Signal('Tree.showNotification')
+ self.parent = parent
+ self.root = self.AddRoot('Catalog') # will not be displayed when we use TR_HIDE_ROOT flag
+ self._initVariables()
+ self.MakeBackup()
+ wx.EVT_TREE_ITEM_RIGHT_CLICK(self, wx.ID_ANY, self.OnRightClick)
+ self.Bind(wx.EVT_LEFT_DCLICK, self.OnDoubleClick)
+ self.Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
+ self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
+ def _initTreeItems(self, locations = [], mapsets = []):
+ """Add locations, mapsets and layers to the tree."""
+ if not locations:
+ locations = GetListOfLocations(self.gisdbase)
+ if not mapsets:
+ mapsets = ['*']
+ first = True
+ for loc in locations:
+ location = loc
+ if first:
+ self.ChangeEnvironment(location, 'PERMANENT')
+ first = False
+ else:
+ self.ChangeEnvironment(location)
+ varloc = self.AppendItem(self.root, loc)
+ # add all mapsets
+ mapsets = ListOfMapsets()
+ if mapsets:
+ for mapset in mapsets:
+ self.AppendItem(varloc, mapset)
+ else:
+ self.AppendItem(varloc, _("No mapsets readable"))
+ continue
+ # get list of all maps in location
+ maplist = RunCommand('g.list', flags='mt', type='raster,raster_3d,vector', mapset=','.join(mapsets),
+ quiet=True, read=True)
+ maplist = maplist.splitlines()
+ for ml in maplist:
+ # parse
+ parts1 = ml.split('/')
+ parts2 = parts1[1].split('@')
+ mapset = parts2[1]
+ mlayer = parts2[0]
+ ltype = parts1[0]
+ # add mapset
+ if self.itemExists(mapset, varloc) == False:
+ varmapset = self.AppendItem(varloc, mapset)
+ else:
+ varmapset = self.getItemByName(mapset, varloc)
+ # add type node if not exists
+ if self.itemExists(ltype, varmapset) == False:
+ vartype = self.AppendItem(varmapset, ltype)
+ self.AppendItem(vartype, mlayer)
+ self.RestoreBackup()
+ Debug.msg(1, "Tree filled")
+ def InitTreeItems(self):
+ """Create popup menu for layers"""
+ raise NotImplementedError()
+ def _popupMenuLayer(self):
+ def _popupMenuMapset(self):
+ """Create popup menu for mapsets"""
+ def _initVariables(self):
+ """Init variables."""
+ self.selected_layer = None
+ self.selected_type = None
+ self.selected_mapset = None
+ self.selected_location = None
+ self.gisdbase = grass.gisenv()['GISDBASE']
+ self.ctrldown = False
+ def GetControl(self):
+ """Returns control itself."""
+ return self
+ def DefineItems(self, item0):
+ """Set selected items."""
+ items = []
+ item = item0
+ while (self.GetItemParent(item)):
+ items.insert(0,item)
+ item = self.GetItemParent(item)
+ self.selected_location = items[0]
+ length = len(items)
+ if (length > 1):
+ self.selected_mapset = items[1]
+ if (length > 2):
+ self.selected_type = items[2]
+ if (length > 3):
+ self.selected_layer = items[3]
+ def getItemByName(self, match, root):
+ """Return match item from the root."""
+ item, cookie = self.GetFirstChild(root)
+ while item.IsOk():
+ if self.GetItemText(item) == match:
+ return item
+ item, cookie = self.GetNextChild(root, cookie)
+ return None
+ def itemExists(self, match, root):
+ """Return true if match item exists in the root item."""
+ return True
+ return False
+ def UpdateTree(self):
+ """Update whole tree."""
+ self.DeleteAllItems()
+ self.root = self.AddRoot('Tree')
+ self.AddTreeItems()
+ label = "Tree updated."
+ self.showNotification.emit(message=label)
+ def OnSelChanged(self, event):
+ def OnRightClick(self, event):
+ """Display popup menu."""
+ self.DefineItems(event.GetItem())
+ if(self.selected_layer):
+ self._popupMenuLayer()
+ elif(self.selected_mapset and self.selected_type==None):
+ self._popupMenuMapset()
+ def OnDoubleClick(self, event):
+ """Double click"""
+ Debug.msg(1, "Double CLICK")
+ def OnKeyDown(self, event):
+ """Set key event and check if control key is down"""
+ keycode = event.GetKeyCode()
+ if keycode == wx.WXK_CONTROL:
+ self.ctrldown = True
+ Debug.msg(1,"CONTROL ON")
+ def OnKeyUp(self, event):
+ """Check if control key is up"""
+ Debug.msg(1,"CONTROL OFF")
+ def MakeBackup(self):
+ """Make backup for case of change"""
+ gisenv = grass.gisenv()
+ self.glocation = gisenv['LOCATION_NAME']
+ self.gmapset = gisenv['MAPSET']
+ def RestoreBackup(self):
+ """Restore backup"""
+ stringl = 'LOCATION_NAME='+self.glocation
+ RunCommand('g.gisenv', set=stringl)
+ stringm = 'MAPSET='+self.gmapset
+ RunCommand('g.gisenv', set=stringm)
+ def ChangeEnvironment(self, location, mapset=None):
+ """Change gisenv variables -> location, mapset"""
+ stringl = 'LOCATION_NAME='+location
+ if mapset:
+ stringm = 'MAPSET='+mapset
+ def ExpandCurrentLocation(self):
+ """Expand current location"""
+ location = grass.gisenv()['LOCATION_NAME']
+ item = self.getItemByName(location, self.root)
+ if item is not None:
+ self.SelectItem(item)
+ self.ExpandAllChildren(item)
+ self.EnsureVisible(item)
+ else:
+ Debug.msg(1, "Location <%s> not found" % location)
class MdMainFrame(wx.Frame):
'''Main frame of metadata editor
