[GRASS-SVN] r66505 - grass/trunk/scripts/v.unpack
svn_grass at osgeo.org
Thu Oct 15 09:18:07 PDT 2015
Author: annakrat
Date: 2015-10-15 09:18:07 -0700 (Thu, 15 Oct 2015)
New Revision: 66505
grass/trunk/scripts/v.unpack/v.unpack.py
v.unpack: synchronize gui with r.unpack
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py 2015-10-15 14:05:52 UTC (rev 66504)
+++ grass/trunk/scripts/v.unpack/v.unpack.py 2015-10-15 16:18:07 UTC (rev 66505)
@@ -20,18 +20,21 @@
#% keyword: import
#% keyword: copying
#%end
-#%option G_OPT_F_INPUT
+#%option G_OPT_F_BIN_INPUT
#% description: Name of input pack file
+#% key_desc: name.pack
#%end
#%option G_OPT_V_OUTPUT
#% label: Name for output vector map
#% description: Default: taken from input file internals
#% required : no
+#% guisection: Output settings
#%end
#%flag
#% key: o
#% label: Override projection check (use current location's projection)
#% description: Assume that the dataset has same projection as the current location
#%end
import os
