[GRASS-SVN] r66506 - grass/branches/releasebranch_7_0/scripts/v.unpack
Thu Oct 15 09:20:06 PDT 2015
Author: annakrat
Date: 2015-10-15 09:20:05 -0700 (Thu, 15 Oct 2015)
New Revision: 66506
   grass/branches/releasebranch_7_0/scripts/v.unpack/v.unpack.py
v.unpack: synchronize gui with r.unpack (merge from trunk, r66505)
Modified: grass/branches/releasebranch_7_0/scripts/v.unpack/v.unpack.py
--- grass/branches/releasebranch_7_0/scripts/v.unpack/v.unpack.py	2015-10-15 16:18:07 UTC (rev 66505)
+++ grass/branches/releasebranch_7_0/scripts/v.unpack/v.unpack.py	2015-10-15 16:20:05 UTC (rev 66506)
@@ -20,17 +20,20 @@
 #% keyword: import
 #% keyword: copying
 #%end
-#%option G_OPT_F_INPUT
+#%option G_OPT_F_BIN_INPUT
 #% description: Name of input pack file
+#% key_desc: name.pack
 #%end
 #%option G_OPT_V_OUTPUT
 #% label: Name for output vector map
 #% description: Default: taken from input file internals
 #% required : no
+#% guisection: Output settings
 #%end
 #%flag
 #% key: o
 #% description: Override projection check (use current location's projection)
 #%end
 import os
