[GRASS-SVN] r66525 - in grass/trunk/lib/python/temporal: . testsuite
    svn_grass at osgeo.org
    Sun Oct 18 18:03:34 PDT 2015
Author: huhabla
Date: 2015-10-18 18:03:34 -0700 (Sun, 18 Oct 2015)
New Revision: 66525
   grass/trunk/lib/python/temporal/register.py
   grass/trunk/lib/python/temporal/testsuite/test_register_function.py
temporal framework: Better error handling in register function
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py	2015-10-18 14:05:26 UTC (rev 66524)
+++ grass/trunk/lib/python/temporal/register.py	2015-10-19 01:03:34 UTC (rev 66525)
@@ -79,6 +79,16 @@
         msgr.fatal(_("%s= and %s= are mutually exclusive") % ("end",
                                                               "increment"))
+    if end and interval:
+        msgr.fatal(_("%s= and the %s flag are mutually exclusive") % ("end",
+        "interval"))
+    if increment and not start:
+        msgr.fatal(_("The increment option requires the start option"))
+    if interval and not start:
+        msgr.fatal(_("The interval flag requires the start option"))
     if end and not start:
         msgr.fatal(_("Please specify %s= and %s=") % ("start_time",
                                                       "end_time"))
@@ -154,6 +164,14 @@
             maplist.append(row)
+        if start_time_in_file is True and increment:
+            increment = None
+            msgr.warning(_("The increment option will be ignored because of time stamps in input file"))
+        if start_time_in_file is True and interval:
+            increment = None
+            msgr.warning(_("The interval flag will be ignored because of time stamps in input file"))
     num_maps = len(maplist)
     map_object_list = []
     statement = ""
Modified: grass/trunk/lib/python/temporal/testsuite/test_register_function.py
--- grass/trunk/lib/python/temporal/testsuite/test_register_function.py	2015-10-18 14:05:26 UTC (rev 66524)
+++ grass/trunk/lib/python/temporal/testsuite/test_register_function.py	2015-10-19 01:03:34 UTC (rev 66525)
@@ -301,5 +301,39 @@
         self.assertEqual(end, 2000000)
         self.assertEqual(unit, "seconds")
+class TestRegisterFails(TestCase):
+    def test_error_handling_1(self):
+        # start option is missing
+        self.assertModuleFail("t.register", input="test", end='2001-01-01', maps=("a", "b"))
+    def test_error_handling_2(self):
+        # No input definition
+        self.assertModuleFail("t.register", input="test", start='2001-01-01')
+    def test_error_handling_3(self):
+        # File and maps are mutually exclusive
+        self.assertModuleFail("t.register", input="test", start='2001-01-01', maps=("a", "b"), file="maps.txt")
+    def test_error_handling_4(self):
+        # Increment needs start
+        self.assertModuleFail("t.register", input="test", increment="1 day", maps=("a", "b"))
+    def test_error_handling_5(self):
+        # Interval needs start
+        self.assertModuleFail("t.register", flags="i", input="test", maps=("a", "b"))
+    def test_error_handling_6(self):
+        # Increment and end are mutually exclusive
+        self.assertModuleFail("t.register", input="test", start='2001-01-01', end='2001-01-01',
+                              increment="1 day", maps=("a", "b"))
+    def test_error_handling_7(self):
+        # Interval and end are mutually exclusive
+        self.assertModuleFail("t.register", flags="i", input="test", start='2001-01-01', end='2001-01-01',
+                              maps=("a", "b"))
 if __name__ == '__main__':
     test()
